Likes Likes:  1
Page 1 of 3 123 LastLast
Results 1 to 15 of 41
Thread: RSP e2 RSPv3.149 G1192
    Default RSP e2 RSPv3.149 G1192
    UFS-910 e2 RSPv3.149 G1192
    Enigma2 OpenSource Project GIT Duckbox SH4-1192
    We take this opportunity to thank TDT and all active "sh4 _duckbox_project" contributors for all their hard work and dedication.
    RSP new improvements:
    + New menu option „User Options” useful variable settings for better tweaking your image
    + DTS downmix ON (user option available, better performance on MKV files playback)
    + backup & restore settings (now it really works and you can keep safe your preferred channel list)
    + Discardlateframe and Noaudiosync (important functional variables)
    + NTP time sync (optional network time synchronization on start-up and stand-by)
    + former EMUwatch and SWAP are now moved to the new „User Options” menu entry
    + Optimized SWAP scripts
    + Update of CrossEPG system plug-in
    + Cyfra+ 27500 SR issue solved
    + CAM added to User Options
    + Final panel separation of automat EMU and images addresses
    .... and lots of little changes.
    Noutati la RSP:
    + Meniu nou cu User Options
    + DTS downmix ON (optional din meniu, recomandat pentru MKV)
    + backup si restore la actualizare lista de canale (acum chiar merge )
    + Discardlateframe si Noaudiosync (parametrii de functionare )
    + NTP time sincro (optional - se sincronizeaza ceasul la start si iesirea din standby)
    + Mutat la User Options emuwatch si swap
    + Simplificat scripturi de SWAP
    + Update la Crossepg
    + Rezolvat sr27500 pe Cyfra+
    + Adaugat CAM la Options
    + Definitivat in panel separarea automata de adrese emu si imagini
    Multe alte mici modificari.
    09 Jan 2010
    Cross EPG not working properly on 28e.
    Menu > Setup > CrossEPG
    09 Jan 2010
    Hi Zildan
    I downloaded EPG data but not showing in EPG.
    Am descarcat EPG de date, dar nu arată in EPG.
    Last edited by zildan; 21-09-10 at 15:23. Reason: consecutive post quote is forbbiden
    RSP - TEAM
    03 May 2007
    @EDW try to change in Menu>Setup>CrossEPG "Preffered lamedb" to epgmedium and set yes only to "Enable provider skyuk_astra2_28.2". The other Enable provider ...." keep them as no
    I test it this way and I could get EPG info in Graphical Multi EPG, Astra 2/Eurobird 1 (28.2E), Sky digital bouquet.
    After loading the EPG, you will get an error as receiver is not able to get back to the channel you watched before. You will have to zap on channel, by remote control.
    Thank you for telling us about the issues, we will try to fix it ASAP.
    09 Jan 2010
    some channels not loading data such as ITV London
    http://tinypic.com/view.php?pic=23r1rib&s=7
    30 Dec 2008
    France
    Default dts
    thanks a lot for the DTS
    Flash : AAF2.e
    USB Stick with BA : RSP ( pkt ou AAF) with OSCAM
    5?W_13?E_19?E_28?E
    Se pare ca de la :
    1190 [evremote] extented to support long keypress detection
    de pe GIT, adica de la introducerea functiilor de apasare lunga, s-a pierdut semnificativ din viteza.
    Solutia e simpla, inlocuiti in /bin evremote2 cu cel din arhiva atasata acestui post.
    Verificati sa aiba 755 la drepturi si dati restart la sistem dupa inlocuire.
    (Replace the current evremote2 located in /bin with the one in the attached archive)
    Attached Files Attached Files
    18 Jun 2009
    Thanks to everyone for this image and for still supporting Kathrein ufs910, I have selected just the 28.2 East EPG and the "epglarge" and it seems to work, showing a week of programs, just the same as a dreambox does.
    I have given up with incubus and am using oscam, just as a client for now and it seems to be very stable.
    11 Apr 2009
    hello
    can i download skin for this image that worked?
    the url on ipkg is aaf and wrong for download
    22 Dec 2008
    Default Incubus 1.16
    Dear Zildan
    How do I make the incubusCamd 1.16 to work. I made the same ammendments as to the conf file of 0.97 but no success. When I use IncubusCamd 0.97, then it works but not in 1.16.
    Best regards
    Afzal
    15 Nov 2007
    In order to have a working incubus 0.98 to 1.16 on your Kathrein receiver, you have to change your MAC address as one between 00:13:18:00:00:00 to 00:13:18:FF:FF:FF
    For RSP e2 image edit: /hdd/ba/ba/<image name> /bootp.conf
    replace : hwaddr:$ethaddr
    with : hwaddr:00:13:18:00:01:02 or other 00:13:18:XX:XX:XX address
    http://www.sateliti.info/showthread.php?t=20067
    22 Dec 2008
    Dear mesteru
    Thanks a lot for your reply. However, I do not understand the instructions. Can you please be a little more elaborate.
    1. I change the MAC address of what, where and how?
    2. Where do I edit edit: /hdd/ba/ba/<image name> /bootp.conf
    Sorry for being absolutely ****.
    Best regards,
    Afzal
    If your image is installed with KCC:
    edit:
    /hdd/ba/ba/e2_RSPv3.149_G1192/bootp.conf file
    or,
    /tmp/sda1/ba/ba/e2_RSPv3.149_G1192/bootp.conf file
    in e2 image.
    In this file you must replace:
    hwaddr:$ethaddr
    with
    If image is installed from RSP Panel, you already have other ip in file (like hwaddr:00:50:fd:ff:78:ce)
    In this case replace existing mac with : hwaddr:00:13:18:ff:78:ce
    30 Dec 2008
    France
    Default automatic mount
    how may i have this ?
    /dev/sdb1 on /tmp/sdb1 type ext3 (rw,data=ordered)
    /dev/sdb5 on /tmp/sdb5 type ext2 (rw)
    /dev/sdb6 on /hdd/movie type ext3 (rw,data=ordered)
    Kathy_RSP:~# umount /tmp/sdb1
    Kathy_RSP:~# mount /dev/sdb1 /media/mkv
    Kathy_RSP:~# mount
    /dev/sdb1 on /media/mkv type ext3 (rw,data=ordered)
    with telnet , no problem, but i don't find where i modified the file to have this in automatic.
    thanks for your help
    Flash : AAF2.e
    5?W_13?E_19?E_28?E
