Results 1 to 12 of 12
Thread: SIF Team 1.94C - 500MV 2010 - Oct - 09
    14 Feb 2007
    Default SIF Team 1.94C - 500MV 2010 - Oct - 09
    O noua imagine SIF pentru posesorii de DM 500
    DB500:
    Usable to flash
    * Enigma of: 19.01.2010
    * Linux version 2.6.9
    * GCC 3.4.4 Original CVS
    * Web Interface: 6.0.2-Expert
    * Busybox 1.01
    * Tuxtxt v. 1.99
    Index of / E1
    IPBOX200S:
    Usable to flash
    * Enigma of: 19.01.2010 (patched for native version)
    * Linux version 2.6.17 (patched from sandali)
    * Busybox 1.01
    * U-BOOT 1.2.0 (patched from sandali)
    * New driver from sandali
    * MMC Drivers included with script for load
    * Have to SET mID 20
    IPBOX200S 64mb:
    * For ipbox-200@64mb you have:
      1) Install normal image (32mb)
      2) Install "serial_uboot_64.img"
    * Thanks to Sandali for serial_uboot_64.img
    IPBOX250S:
    Usable to HDD (CF) or flash
    * Busybox 1.01
    * Tuxtxt v. 1.99
    * Have to SET mID 25
    IPBOX350S:
    Usable to HDD, USB or flash
    * Busybox 1.01
    * Tuxtxt v. 1.99
    * Have to SET mID 26
    IPBOX400S:
    Usable to HDD or flash
    * Busybox 1.01
    * Tuxtxt v. 1.99
    * Have to SET mID 40
    DB5620:
    Usable to flash
    * Busybox 1.01
    * Tuxtxt v. 1.99
    DB7000:
    Usable to HDD, USB, CF or flash
    * GCC 3.4.4 Original CVS 1.1.0
    * Busybox 1.01
    * Tuxtxt v. 1.99
    DB7020:
    * Usable to HDD, USB, CF or flash
    * OE Build Configuration:
    BB_VERSION = "1.6.2"
    OE_REVISION = "format_version "1"
    new_manifest [0000000000000000000000000000000000000004]
    old_revision [8384ee468ef9c285a8c9b35ef333e53be78b6445]"
    TARGET_ARCH    = "powerpc"
    TARGET_OS      = "linux"
    MACHINE        = "dm7020"
    DISTRO         = "opendreambox"
    DISTRO_VERSION = "1.4.0"
    TARGET_FPU     = "soft"
    DB600PVR:
    * Usable to HDD or flash
    TARGET_OS      = "linux"
    MACHINE        = "dm600pvr"
    TARGET_FPU     = "soft"
    DB500PLUS:
    * Usable to flash
    TARGET_OS      = "linux"
    MACHINE        = "dm500plus"
    TARGET_FPU     = "soft"
    Qbox-one:
    Usable to flash
    * Busybox 1.01
    ALL DECODER ( same options not present to Qbox-one - IPBOX200s - DM500 - DM500+ - DM5620 ):
    Buttons:
    * 1 x BLUE        = Emu Panel
    * 1 x Yellow      = Plugins
    * 1 x Green       = Addons Panel
    * 1 x Red         = EPG ( settable from Control Pannel )
    * BLUE   > 1 sec  = Control Panel    ( new version "visual" )
    * Yellow > 1 sec. = Personal Plugin  ( settable from Control Pannel )
    * Green  > 1 sec. = Personal Plugin  ( settable from Control Pannel )
    Features:
    * Advanced MINICROND system configuration, with more script added (restart cam, restart openvpn ecc..)
    * Advanced FIREWALL with graphics start/stop/configuration
    * Advanced HDD with graphics configuration
    * Advanced SWAP with graphics start/stop/configuration
    * Advanced OPENVPN with graphics start/stop/configuration (have to install online package)
    * Advanced DROPBEARSSH with graphics start/stop/configuration (have to install online package)
    * Advanced INADYN-DNS with graphics start/stop/configuration
    * Advanced NFS with graphics start/stop/configuration (have to install online package)
    * Settable PICON directory
    * Automount HDD USB CF
    * Advanced SCRIPT options for personal set ( name to button is modifiable from Control Panel)
    * Formatting USB ( into 500 and 200 not have USB option, have manage remote control and free memory)
    * Advanced EPG options (is possible set personal EPG from Control Panel or use standard EPG)
    * Advanced Manage of Button Yellow and Green, is possible add one plugin to this buttons
    * Simple BACKUP with graphics start/stop/configuration (for save one dir. to extern support)
    * Advanced SAMBA with graphics start/stop/configuration (7020 - 600pvr - 500plus have samba installed from default)
    * Color set to RGB from default ( for lcd TV)
    * Inserted DM7020 Network Fix
    * Reiserfs and VFAT supported
    * Synchronize date from Internet
    * WebIf information (ecm.info with reload option)
    * New Button for second url (for download personel addons)
    * Autostandby if decoder turn off in bad mode (crash power ecc..)
    * Lock EMU panel from Parental Control option
    * Save downloaded packages (settable from expert menu)
    * See info package before install from online (settable from expert menu)
    * See last package present online from "news" button
    * Compatible with Upnp (Server/Client)
    Display Function:
    * Set zap without OSD (if press OK return OSD)
    * Set OSD always on when OK is pressed (required from nokia9k8)
    * Display Snr, Agc, Ber
    * Display video information
    * Display frequency, polarization, symbol rate
    * Display emu in use
    * Display service providers name
    * Display CaID, ProvID, PID (you can hide from options)
    * Display Decoding Source (you can hide from options)
    * Picon, already inserted to enigma code  (thanks to jlmota)
    * SkinPreview  (thanks to jlmota)
    * Skin Lite/Full, when Lite ..if no OSD present, and press OK see Full (thanks to tension for help)
    * Emu Panel now have image with icon report of decode
    * Fulltime
    * Analogic Clock
    * Move OSD (thanks to tension9000)
    * Always 16:9 settable in all decoder
    * Time visible in screen
    * Name channel visible in screen
    EMU:
    * Set Default CAM
    * Set channel CAM
    * Set provider CAM
    * Stop active CAM
    Addons:
    * Internet addons download
    * Manual addons install
    * Remove installed addons
    Misc:
    * Italian, English language
    * Many language in download
    * Picon for -skyit+italian channel- is already installed
    * Several Plugins/Games/Addons installed
    * IPBOX200S have UHF in/out
    * IPBOX200S ...for free memory (if is necessary):
     1) Go to free channel
     2) Click to "Free Memory"
     ...now is possible to start/stop install/remove visualize script ecc..
    * For use your personal Addons server, create file:
      /var/etc/SifTeam/tmp/url2 (that it contains your link)
      after, into server have write your cpanel-dream.xml (for dream decoder)
      or cpanel-ipbox.xml (for ipbox decoder), that contains your packages
      (for simple system, download cpanel*.xml from sifteam URL)
    THANKS TO:
    See Yellow from Control Panel for other help into this work.
    All IPBOX > ..special thanks to sandali for its branch of development.
    FOR ALL   > See About in Control Panel (blue > 1 sec.)
    Thanks to all and good fun :)
    VARIOUS:
    This image is based, beyond that my "much" code and hard work, to Dream-cvs, parts of old Hydra
    source (EMU/ADDONS ...emubroker is this) ...and other?
    ATTENZIONE:
    QUESTO FIRMWARE NON CONTIENE CHIAVI, NE' EMULATORI, NE'
    INDIRIZZI PER SCARICARE MATERIALE ILLEGALE DI NESSUN TIPO.
    L'AUTORE NON E' RESPONSABILE IN NESSUN MODO DELL'USO CHE
    GLI UTENTI NE FARANNO, DI LORO SPONTANEA VOLONTA'.
    THIS FIRMWARE DOES NOT INCLUDE KEYS, NOR EMULATORS, NOR
    URLS FOR DOWNLOADING ILLEGAL STUFFS OF ANY TYPE.
    AUTHOR IS NOT RESPONSIBLE IN ANY WAY FOR WHAT
    THE USERS WILL DO WITH THIS FIRMWARE.
    NOTE:
    Per la versione ipbox-200@64mb si deve:
    1) Installare l'immagine del 200 normale
    2) Installare il file "serial_uboot_64.img"
    ..entrambi con Flashtools o Flasher
    Programmi:
    Per avviare programmi personali, valido per tutte le immagini SifTeam:
    Aggiungere il comando voluto in /var/etc/rcS.d/S99user_start.sh in fondo
    al file (ci sono gia' presenti diversi esempi pronti all'uso, basta
    decommentarli rimuovendo il simbolo #)
    Tips:
    Per entrare nel Pannello di Controllo se ci si trova nel Pannello Emu basta
    premere il bottone giallo, funzione aggiunta per l'uso nella WebIf.
    Per aprire il menu' Script mentre ci si trova nel Pannello di Controllo basta
    premere lo 0 (zero).
    DOWNLOAD SifTeam-1.9.4C-500MV.img.zip size: 4.8 MB 2010-Oct-09
    16 Oct 2010
    merge perfect imaginea cu cccam 2.1.4
    08 Sep 2010
    ìn IAD
    Smile SifTeam 1.9.4c
    Salut, se misca bine imaginea pe receptor? sau e inca in probe? Am un IpBox 200s, si inainte sa o urc, cei care o folosesc rog sa posteze cum funccioneaza, chiar daca au dm500. Multumesc
    Probat pe optibox500, ok.
    01 Apr 2007
    Vagauna Romania
    Eu am avut probleme cu telnet-ul dupa instalarea imaginii, asa ca am revenit la Gemini 4.70...
    08 Sep 2010
    ìn IAD
    Smile Sif TeaM 1.9.4c
    Eu folosesc Evoluion 2.5 si nu am porbleme nici cu ethernetul nici cu cccam. Doar ca se bloqueaza aparatul si trebuie scos din priza, si cum am vazut asta mai noua ma gandesc sa o schimb.
    O zi frumoasa! Snow's Avatar
    Eu am 1.9.4. si nici un blocaj. Merge de mai bine de jumatate de an.
    08 Sep 2010
    ìn IAD
    Question SifTeam 1.9.4c
    Totusi, am gasit mai multe versiuni de 1.9.4c, cu data de publicatie diferita..
    SifTeam 1.9.4c - 09.10.2010
    IPBOX200S:
    Usable to flash
    * Enigma of: 04.06.2010 (patched for native version)
    * Busybox 1.01
    Changelog - 09\10\2010
    1) Updated to cvs Enigma 09-10-2010
    - Use bouqup/bouqdown buttons to display EPG of prev/next service when in EPG overview.
    - show marker in EPG overview when an EPG entry is overlapping with existing timer.
    Asta fiind ultima, si mi se pare putin diferit fata de cea postata aici.
    17 Jan 2008
    Default server
    am incercat si eu in treacat imaginea asta, dar direct pe server nu am gasit sa pun cccam. este pe undeva sau nu am gasit eu ?
    14 Feb 2007
    Descarca de ==> aici. Adresa o poti trece in fisierul url2 care se afla in var/etc/Sifteam/tmp.
    De ce nu va puneti voi manual emu de care aveti nevoie?Pe sifteam e cel mai simplu.Pentru cccam trebuie bin-ul si cccam.cfg la locurile lor apoi editati scriptul
    scriptul pt Sifteam se pune in var/etc fara atribut special , si are denumirea '' smartcam.config ''
    asa:
    osd-name 1 = Common Interface
    emulator 1 = Common Interface
    camd 1 =
    daemon 1 =
    kill 1 =
    sleep 1 =
    zap-sleep 1 =
    osd-name 2= CCcam
    emulator 2= CCcam
    camd 2=
    daemon 2= CCcam
    kill 2=
    sleep 2= 4
    zap-sleep 2= 1
    osd-name 3= CCcam+oscam
    emulator 3= CCcam+oscam
    camd 3=
    daemon 3= CCcam;oscam
    kill 3=
    sleep 3= 8
    zap-sleep 3= 1
    Unde denumirea bin-ului cccam este exact "CCcam" si a celui de la oscam bineinteles "oscam",acestea fiind in var/bin.Puteti adauga mai departe pe aceeasi idee cate combinati vreti si cate emulatoare vreti.Nu uitati ca in panel aveti combinatii pe care poate voi nu le vreti sau tot trebuie sa mai faceti artificii ca sa folositi versiunea dorita de cccam sau oscam,newcs,etc.
    Sper ca nu am gresit ceva,scriu din amintiri,nu am timp sa mai trag un ochi peste receptor.
    14 Feb 2007
    SIF Team URL2
    E1 ==> se transfera fisierul url2 din arhiva URL2_SIF_E1.zip in var/etc/SifTeam/tmp
    E2 ==> se transfera fisierul url2 din arhiva URL2_SIF_E2.zip in etc/ipkg
