Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
Thread: TvrHD functional cu CCCam+ Oscam
    Ai si fisierul oscam.dvbapi?
    # dvbapi configuration
    # types:
    # P - Priority
    # format:
    # P: <caid>:[<provider>]:[<srvid>]:[<ecmpid>]
    # I - Ignore
    # format:
    # I: <caid>:[<provider>]:[<srvid>]:[<ecmpid>]
    # M - Map
    # format:
    # M: <caid>:[<provider>]:[<srvid>]:[<ecmpid>] <target caid>:[<target provider>]
    # D - Delay
    # format:
    # D: <caid>:[<provider>]:[<srvid>]:[<ecmpid>] <delay (ms)>
    P:0500:030b00
    P: :025900
    I: :022F00
    I: :024F00
    P:1880:000000
    P:1802:000000
    P:1802:002111
    P:0100:004106
    P:0100:000000
    P:0100:003311
    P:0d02:00008C
    18 Jul 2010
    nu am, de fapt nici un fisier nu aveam, toate le-am cules de pe net.
    EDITAT:
    dupa ce am creat oscam.dvbapi deja mi-a pornit, in cateva secunde am strans 31 ecmuri.
    Este drept ca pana acuma nu am pus pe tvr ci doar m-am uitat in lista de servere.
    card reader /dev/sci0
    handled 31(31) ecms and 0(0) emms
    Viaccess card
    Caid 500
    Cardserial xxxx
    ident fff720 - bf645e
    ident 25900 - bf645e
    ident 25910 - bf645e
    valid from 24-2-2011 untill 28-9-2011
    valid from 21-2-2011 untill 22-3-2011
    valid from 8-2-2011 untill 28-9-2011
    | Username       | Host          | Connected  | Idle time  | ECM   | EMM | Version| Last used share                             |
    |test1           |192.168.1.66   |00d 00:07:54|00d 00:00:09|44 (44)|0 (0)|2.0.11  |0500:025900:0002 (ok)                        |
    | Username       | Shareinfo                             |
    |           test1|local 0500:025900 44(44)               |
    La servere nu-mi apare, de ce nu-mi apare in lista de servere?
    | Host                             | Connected  | Type    | Version| NodeID         | Cards | CAID/Idents                   |
    |127.0.0.1:25900                   |            |newcamd  |        |                |     0 |                               |
    la partajare imi apare:
    |/dev/sci0                |sci      | 500|viaccess   |fff720,25900,25910 |0   11 |           |
    24 Jun 2009
    Hamburg
    cccamu nu deschide din share cardul dolce chiar daca il primesti, trebuie sa folosesti mgcam ca sa iti mearga din share
    18 Jul 2010
    Lasa naibii cccam , vezi daca ai imagine pe tv. Si vezi ce zice in webif la oscam la reader
    XXXXXB0 r 1 tvrhd ONTVRHD OFF 127.0.0.1 0 internal 24.06.11 19:44:45 03d 20:20:50 0000:0000 NO DATA 02d 00:53:23 CARDOK
    Si nu vede cardul din linie in cccam ca ai pus
    allowed = 192.168.1.60-255.255.255.0,192.168.1.255-255.255.255.0
    adauga si 127.0.0.1, sau daca vrei sa mai dai si la altii pune
    allowed = 0.0.0.0-255.255.255.0
    24 Jun 2009
    Hamburg
    da greseala mea , vroiam sa spun TVR HD
    18 Jul 2010
    @lao
    3001F8B0 s 0 root 127.0.0.1 0 server 02.07.11 11:27:05 00:43:05 0000:0000 00:00:00 OK
    3182C4F0 h 1 root 127.0.0.1 0 http 02.07.11 11:27:05 00:51:06 0000:0000    00:22:24 OK
    c 1 tvr    ON ON 127.0.0.1 1103 newcamd (CCcam)    02.07.11 12:31:31 00:00:28 0000:0000 00:00:28 OK
    2011/07/02 12:30:48 3001F8B0 s >> OSCam << cardserver started, version 1.00-unstable_svn, build #5509 (powerpc-tuxbox-linux)
    2011/07/02 12:30:48 3001F8B0 s version=1.00-unstable_svn, build #5509, system=powerpc-tuxbox-linux, nice=-1
    2011/07/02 12:30:48 3001F8B0 s client max. idle=120 sec, debug level=0
    2011/07/02 12:30:48 3001F8B0 s max. logsize=10000 Kb, loghistorysize=4096 bytes
    2011/07/02 12:30:48 3001F8B0 s client timeout=5000 ms, fallback timeout=2500 ms, cache delay=0 ms
    2011/07/02 12:30:48 3001F8B0 s services reloaded: 0 services freed, 1 services loaded, rejected 0
    2011/07/02 12:30:48 3001F8B0 s userdb reloaded: 1 accounts loaded, 0 expired, 0 disabled
    2011/07/02 12:30:48 3001F8B0 s signal handling initialized (type=sysv)
    2011/07/02 12:30:48 3001F8B0 s can't open file "/var/tuxbox/config/oscam.srvid" (err=2 No such file or directory), no service-id's loaded
    2011/07/02 12:30:48 3001F8B0 s can't open file "/var/tuxbox/config/oscam.tiers" (err=2 No such file or directory), no tier-id's loaded
    2011/07/02 12:30:48 3001F8B0 s can't open file "/var/tuxbox/config/oscam.provid" (err=2 No such file or directory), no provids's loaded
    2011/07/02 12:30:48 3001F8B0 s can't open file "/var/tuxbox/config/oscam.ird" (errno=2 No such file or directory) irdeto guessing not loaded
    2011/07/02 12:30:48 3001F8B0 s monitor: initialized (fd=9, port=988)
    2011/07/02 12:30:48 3001F8B0 s camd33: disabled
    2011/07/02 12:30:48 3001F8B0 s camd35: disabled
    2011/07/02 12:30:48 3001F8B0 s cs378x: disabled
    2011/07/02 12:30:48 3001F8B0 s newcamd: initialized (fd=10, port=34000, crypted)
    2011/07/02 12:30:48 3001F8B0 s CAID: 0500
    2011/07/02 12:30:48 3001F8B0 s provid #0: 1F1F1F
    2011/07/02 12:30:48 3001F8B0 s provid #1: 025910
    2011/07/02 12:30:48 3001F8B0 s radegast: disabled
    2011/07/02 12:30:48 3001F8B0 s http thread started
    2011/07/02 12:30:48 3001F8B0 s loadbalancer: can't read from file /tmp/.oscam/stat
    2011/07/02 12:30:48 3001F8B0 s waiting for local card init
    2011/07/02 12:30:48 3182C4F0 h HTTP Server listening on port 16002
    2011/07/02 12:30:48 3001F8B0 s init for all local cards done
    2011/07/02 12:30:48 3001F8B0 s anti cascading disabled
    2011/07/02 12:31:31 3282D4F0 c client connected to 34000 port
    2011/07/02 12:31:31 3282D4F0 c encrypted newcamd:34000-client 127.0.0.1 granted (tvr, au=on (1 reader))
    2011/07/02 12:31:31 3282D4F0 c user tvr authenticated successfully (CCcam)
    2011/07/02 12:31:31 3282D4F0 c AU disabled for user tvr
    Am reinstalat imaginea Gemini 4.70 si un nou Cccam 2.2.1 + Oscam 1.0(ambele manual ca pe Gemini server nu mai gasesc nimic).
    Testele le fac pe Skystar2 cu pluginsul Hadu 0.1.2.6.
    @franta deci pe cccam nu am sa deschid tvrul? dar vad ca o poate da mai departe.
    11 Apr 2008
    Fost mebru
    @ombre, tu citeşti ce scrie lumea pe aici ?
    Mai reciteşte odata postul #15
    Eu nu vad readerul tau nicaieri. Ai bagat o linie N de tvr in oscam?
    Cam asa trebuie sa se vada in webif:
    12 Nov 2007
    Va salut, mai merge combinatia CCCam+Oscam pentru TVR, deoarece nu reusesc sa-i dau de cap, am incercat setarile de aici dar nu merge.Setarile mele sunt urmatoarele:
    oscam conf:
    [global]
    pidfile = /tmp/oscam.pid
    usrfile = /var/log/oscamusr.log
    logfile = /var/log/oscam.log
    disablelog = 0
    disableuserfile = 0
    usrfileflag = 0
    clienttimeout = 5000
    fallbacktimeout = 2500
    clientmaxidle = 120
    bindwait = 120
    netprio = 0
    clientdyndns = 1
    resolvedelay = 30
    unlockparental = 0
    nice = -1
    serialreadertimeout = 1500
    maxlogsize = 10000
    waitforcards = 1
    preferlocalcards = 1
    saveinithistory = 1
    readerrestartseconds = 5
    readerautoloadbalance = 0
    readerautoloadbalance_save = 0
    [monitor]
    port = 988
    nocrypt =
    aulow = 1
    hideclient_to = 0
    monlevel = 0
    appendchaninfo = 0
    [newcamd]
    port = 34000@0500:000000
    allowed =
    keepalive = 1
    mgclient = 0
    [webif]
    httpport = 8080
    httpuser = root
    httppwd = xxx
    httprefresh = 10
    httpallowed = 0.0.0.0-255.255.255.0
    httphideidleclients = 0
    httpreadonly = 0
    oscam server:
    [reader]
    label=TVRHD
    protocol=internal
    detect=CD
    device=/dev/sci0
    group=1
    emmcache=1,3,2
    mhz=357
    cardmhz= 357
    CAID=500:000000
    IDENT= 025900, 025910
    ReconnectTimeout= 20
    DisableServerFilter= 1
    oscam user:
    [account]
    user =
    pwd =
    group = 1
    au = TVRHD
    caid = 500:000000
    ident= 025900, 025910
    cccamcfg:
    N: 127.0.0.1 34000 user pass 01 02 03 04 05 06 07 08 09 10 11 12 13 14 256 1
    Receptorul este dm800se clona.Multumesc pentru ajutor, orice sugestie este binevenita.
    Care setari de aici?
    In postul 14 sunt setarile, ale tale sunt gresite
    09 Feb 2007
    Bucharest
    Am un DM800 si card TVR. Am urmat setarile din postul 13. Am avut lumina, insa de ceva vreme nu imi mai decodeaza de pe card, imi decodeaza decat din linie de la CCCAM.
    Am vazut in status ca nu se initializeaza SCI0, si am remarcat ca are legatura cu ora sistemului, insa ora este aiurea, iar anul 1970...daca modific manual data si ora, se initializeaza SCI0, insa tot nu citeste de pe card, imi apare ERROR (no entitlements), desi in combinatia NEWCS+Mgcamd am lumina si am subscriptie pana pe 23.10.2013.
    Prima oara cand mi-a functionat era Oscam 1.20-r8241, acum folosesc 1.20 - r8972, dar tot degeaba.
    Da-ti-mi vre-o idee, ce sa mai caut, ce sa mai modific...
    Pune frecventele pe auto la card, s-a mai scris despre asta zilele astea pe forum.
    http://sateliti.eu/showthread.php/27...l=1#post230445
    Citeste mai mult, in principiu gasesti orice pe forum
