Results 1 to 15 of 21
Thread: Azbox hd e2 images
    Golden Member qwess's Avatar
    26 Oct 2009
    Walachia / Paname
    Default Azbox hd e2 images
    RTi core RC4 Enigma 2
    Change Log :
    - New Kernel from 26.01.2011 ( Linux AZBox 2.6.22.19-19-the_ripper #216 PREEMPT Wed Jan 26 19:22:07 CET 2011 mips GNU/Linux )
    - New Drivers
    - Added support for .TS file Playback ( Now You are able to play recorded material directly from AzBox )
    - Added support for Timeshift
    - Several fixes on .py files for better stability
    In progress : We will move soon to the new structure / skeleton, and we will introduce support for DVB-T, DVB-C and second DVB-S2 tuner ( just for Premium+ model ). Result of this changes will be better stability and functionality of Enigma 2 in AzBox HD Receivers.
    Also, RTi team wants to express big THANK YOU to SIF Team, which also announced support for AzBox HD Devices.
    Download:
    RTi core 1.1.4 RC4 Enigma 2
    VIP
    23 Sep 2008
    din ce in ce mai bune imagini!
    15 Feb 2009
    Drivere noi, kernel nou......se cunoaste o inbunatatire la calitatea imaginii video?
    A probat cineva?
    VIP
    23 Sep 2008
    da,am probat eu.
    merge perfect,cu mici incoveniente!
    26 Oct 2009
    Walachia / Paname
    Default RTi core RC5 Enigma 2
    New_kernel:
    Linux AZBox 2.6.29.4-13-the_ripper #13 PREEMPT Wed Feb 23 14:42:05 CET 2011 mips GNU/Linux
    RC5 is RC4 + new kernel which enables install Official FW on USB (with AZUp) and boot automaticly if USB stick with Official FW is in AZBox during booting.
    by The_Ripper:
    Yes with kernel 2.6.29 I have activated KEXEC support for Sigma 8634 and now it is possible to boot official FW from USB, anyway telesat should unswer that if AzUP can be point on what USB port to install, but booting from USB1/USB2 can be done for official FW.
    You can install first on USB1 port and then to attach to USB2 port , heheheheh. this way it will work for shure
    New ver. RC5
    Changes in kernel - necessarily to write kernel (check 'copy kernel' in azup),
    ofcourse it is necessary only one time
    What is new :
    - NEW Kernel - allowed to use/install E2 on DOM and Official FW (dofferent kernel-old kernel) to USB stick
    - NEW structure/file format - now E2 files/kernel use .e2 extension
    NEW AZUp v.2.x.x - use only new .e2 extension
    - allow to prepare and install official FW on USB stick
    - allow to make Backup ch.list, settings and camd setings/scripts/cfgs from installed Enigma2 and Restore to new fresh E2 installation.
    -Added additional control before install : check cpu speed and if overclocked - reset to default value
    - Checking free ram (min) needed for some operation
    - Checking existing/correct mount for storage device - where you want to install E2.
    - Auto switch to rescue mode if AZBox is in E2 mode
    - Alsoo now you can see info about loaded E2 File
    pls read Readme file for more info about AZUp 2
    Direct Download RTI:
    AZUp 2
    Files need for install Official FW on USB
    E2 RTi Core RC5
    Dual boot:
    by MickeySA:
    In my Elite, I was running Official Firmware, then I put on my usb pendriver first RC4 patch.bin . I followed normal USB Update from screen, then I got rescue mode, and I remove my USB pen driver. I started AzUP 2.0.0. , I pressed flash E2 ( copy kernel and format extended partition is checked !!! ) , I browse for patch.e2 and all was successfully flashed.
    After I booted first time in E2, I press Go ! for Official Firmware Install process, then box rebooted in Rescue mode, I put there USB pendrive, and pressed again Go! below Official Firmware, and pointed to vmlinux and second file used from FW4USB folder. So when it was installed, no problem, AzBox booted in Official firmware, then I turned off STB, removed USB and my STB booted in RC5, again i turned of STB, then I placed in usb port USB pendrive on which i installed Official Firmware, I powered STB and it booted directly in Official firmware.
    15 May 2010
    Post RTi core RC6 Enigma 2
    RTi core RC6 Enigma 2 Image :
    Based on completly new Drivers and new Kernel.
    This Enigma 2 Image is for DOM Install !!!
    USE AzUP 2.1 to Install this Image in Your device
    ( Download AzUP 2.1 here : http://www.azbox-enigma.eu/upload/AZUp_v.2.0.1.rar )
    What is new :
    - All drivers are rewriten and placed in Kernel space !!!
    - Completly new kernel ( from 2.6.22-19 upgraded to 2.6.29 )
    - New DVB-S2 Tuner driver for Elite - Premium - Premium+ and Ultra
    - DVB-T and DVB-C for all models comming very soon.
    - Twin tuner support for Premium+ comming very soon.
    - Completly new Gstreamer build by sattomy ( Support for seeking added and Improved stability and playback )
    - New and enhanced Videomode ( A/V Settings ) by telesat ( Added settings for DTS and AC3 )
    - Deinterlace ( 1, 2, 3 - 1 and 2 give so far best result on our tests )
    - Digital Audio settings ( Inside of A/V Settings )
    - MediaCenter Plugin by sattomy
    - Fixed problem for HD channels on 23.5 , 13 E, 0.8 and 30 w
    - Improved Video quality
    - Better STC compensation ( Switching to / from AC3 or DTS fixed )
    Small Info :
    - Now You are also able to play WMA files , only thing what You have to do is to rename WMA extension to WAV , as Enigma 2 doesnt recognise WMA extension ( However, we will patch soon Enigma 2 to be able to recognise .wma extension ).
    Still You can expect some bugs which will be improved after implementation of DVB-T, DVB-C, ISDB-T and Twin Tuner support ( Premium+ )
    We would like to ask all of You to make Feedback as much as possible
    Download :
    New drivers
    Added Volume Up/Down + Mute/Unmute
    Pls replace old KO modules with new ones, /lib/modules/linux-2.6.29....../extra/
    DOWNLOAD NEW DRIVERS : http://azupd.ath.cx/fw/files/E2/10.03.2011.zip
    Link: http://www.multiupload.com/PMZQPNX1QC
    21 Jan 2011
    Default RTi core RC7 Enigma 2
    **** THIS VERSION IS JUST FOR ELITE & PREMIUM ****
    RC7 core Enigma 2 Image
    What is new :
    - New Kernel and Drivers
    - Support for DVB-T and DVB-C Tuners
    - Faster zapping time
    - New fixes for Media Center Plugin ( Especially on Audio part )
    - Improved stability
    - New Bootlogo
    - Extras is accessible by Blue button
    http://www.multiupload.com/3J35H68FO4
    26 Oct 2009
    Walachia / Paname
    Default RTi core RC8 Enigma 2
    RC8 - version ok for all models
    - EXPERIMENTAL - TWIN SUPPORT - ofcourse only on P+
    - Ultra model now work fine
    - STC Prebuffering - only for test , added in A/V Settings
    - Scart/RCA - Composite out fixed
    - Aspect Ratio and Scalling added in A/V Settings
    MultiMedia imrove and fixs :
    - fixing packed avi support for gstreamer (finally solved most sync issues)
    - been playing 1080p dts through mediacenter from nfs
    NOTE : STC Prebuffering is only for test, pls play with this and report on forum what is your experiances , and what is best combination and compromise between fast zap and stable zap
    RTi_Core_1.1.8.RC8.rar (46.33 MB)
    Golden Member istvan's Avatar
    14 Feb 2007
    Baia Mare
    Default RTi core RC9 Enigma 2
    RC9 - version ok for all models
    - Fixed recording
    - Added TS playback
    - Added timeshift
    - Added audio AC3+ PID detection inside Enigma2 (experimental, need to be tested)
    http://www.multiupload.com/KGJWNF3560
    RSP-TEAM
    26 Oct 2009
    Walachia / Paname
    O buna avansare cu ultimile 2, DVB-T functional SD/HD, unele pierderi de semnal audio pe HD(DVBT) dar revine cu zap +/-, calitatea video foarte buna pe HD.
    DVB S- AC3 =ok
    subtitrarea pe History HD 08W, afisata cate o fractiune de secunda!
    redarea .ts functionala cu RC9, inregistrarea OK, testat cu 3 in acelasi timp pe acelasi TP, atat sat cat si terestru.
    CCcam, newcs, oscam functioneaza bine, readerul intern inca nefunctional, smargo=OK.
    pe partea media incepe sa lucreze, mkv 1080P+DTS merge foarte bine, m2ts inca nu..., nu am testat mts(avchd).
    skinurile ruleaza bine, picons ok, EPG = ok.
    Plugins:
    Camd Manager=ok
    CCcamInfo=ok
    YouTube =netestat
    WebInterface=ok
    Weather=ok
    Insa la mine o problema: la revenirea din sleep in weekup prin hdmi...."no signal" necesita restart GUI.
    14 Feb 2007
    Baia Mare
    RTi core RC10 Enigma 2
    What is new in RC10 ?
    - New Enigma 2 from 29.03.2011
    - New Drivers from 29.03.2011
    - New Bootlogo
    Change log :
    - Fixed subtitles
    - Fixed Radio mode ( Radio channels should work now )
    - Fixed sync on Media player part ( for MKV and other formats )
    - Added support for subtitles in VOB files
    - Improoved support for AC3+ audio on DVB part
    - Added Online Update option ( We will push new updates trough this plugin, follow this thread to know when to update! )
    - Added Beyonce 9 skin by Matrix10
    RSP-TEAM
    14 Feb 2007
    Baia Mare
    RTi core RC11 Enigma 2
    What is new ?
    - Fix Reboot ( working now from menu in E2 )
    - Fix T/C tuner selection if no DVBS tuner on slotA
    - Fix AC3 PID detection on some channels in NA
    - Reactivated grab (video/osd) in driver
    - New grab app
    - Added modified Beyonce 9 skin modified by Matrix10 ( Skin should be faster )
    - Added Fan Control ( Menu -> Setup -> Fan Control , Turn On or Off for Premium+ and Ultra )
    RTi core RC11 Enigma 2 Image :http://www.multiupload.com/LRJCKMQTSF
    RTi core RC11 Enigma 2 Image - Mirror #1 :http://www.multiupload.com/NUQJ21TUJ7
    RSP-TEAM
    14 Feb 2007
    Baia Mare
    RTi core RC12 Enigma 2 Image, for download :
    New kernel - enable EXT4 - but necessarily to use latest ver. of AZUp
    Reboot - Solved
    Rescue mode via AZUp and Setup Menu - Solved
    Standby mode - Solved
    Changes in AV settings - AV Prebuffering (now step is 50ms)
    Repeated 2 x times Online Update in Extension menu and missing in plugin menu - Solved
    Improvement in CAMD Manager
    OverClock menu is removed now
    Problem with RGB Scart and encrypted ch. - Solved
    Changes in FSTAB file - usb drive now automounted on /media/hdd or/and /media/usb
    http://www.azbox-enigma.eu/RTi/forum...-RC12-Enigma-2
    RSP-TEAM
    26 Oct 2009
    Walachia / Paname
    Default RTi Core v1.0 Enigma 2
    What is new ?
    - Card Reader OK
    - New MediaCenter OK ( Menu -> Media Center, choose My Videos and wait 10-15 seconds to re-initialize HDMI!!!, for subtitles *.SRT press red button or SUB-T on RCU, they need to be named same as movie )
    - Audio BUG Fixed
    - A lot of other bugs fixed and so on.
    - Time for zap - reduced
    - VOL +/- Fixed
    - MUTE(when change ch.) - Fixed
    - Lost data when power off/on - Fixed
    - Problem with relaod ch.list - Fixed
    - Problem with external messages - Fixed
    - New/rewritten WebIf
    - NEW driver for RemoteControl - work like a charm
    - New way for go to rescue mode - press and hold VOL+ button (from front panel or RemoteControl) during AZBox booting
    - Removed DOM to be listed as HDD in Enigma2 Info, and now DOM is excluded from standby so COGs will show less.
    In Media Center we know that Seeking is not working and VOL UP and DOWN, so please do not report this as BUG, it will be fixed in next release!
    Attached Files ( azbox-enigma.eu )
    26 Oct 2009
    Walachia / Paname
    Default New Gemini3 Image for Azbox
    Most coplete image ever
    It has include lot of plugins
    VTI Panel is for managing emus
    CCcam INSIDE
    JUST PUT card
    and HAVE PHUN !
    Based on RTi1.0
    ChangeLog:
    # Gemini3 BluePanel v0.29r2- addons, softcam manager
    # Gigant Panel
    # VTI Panel v2.6 - addons, softcam manager
    # DMNapi 1.3.27
    # Ultime Notizie
    # RSS Reader Gp3
    # Dreamnetcast Gp3
    # Jukebox Gp3
    # Weather Gp3
    # Kamery internetowe Gp3
    # Setup spinner Gp3
    # Setup Bootlogo Gp3
    # Screenshot Gp3
    # Aspect Ratio Switch
    # CCcam Info + CCPrioMaker
    # Multi Quickbutton Gp3
    # PlanerFS v3.04
    # Multi Mediathek v2.9
    # Cool TV Guide V3.0.0
    # Easy Media Gp3
    # Saundetek Drviers
    # VTi Panel
    # Addons Manager
    # CCPrioManager
    # CCcam Info v1.3c
    # DMNapi
    # Dream Expoler
    # Webinterface
    # MyTube
    # DVD Player
    # Live Score
    # Cross EPG !!!
    Download:
    azbox image full 08.06.2011.rar (81.65 MB)
    mirror #1
