Results 1 to 15 of 20
Thread: Enigma2 NightlyBuild 1.1.1 for all versions
    27 Apr 2007
    Bayern, DE
    Default Enigma2 NightlyBuild 1.1.1 for all versions
    ENIGMA 2 for all Cuberevo-digital (old DGStation named) products:
    - cuberevo-100hd
    - cuberevo-mini-fta (cuberevo-200hd)
    - cuberevo-250hd (ipbox-91hd)
    - cuberevo-mini (ipbox-900hd)
    - cuberevo-mini2 (ipbox-910hd, cuberevo-3000hd, madtek-3000hd)
    - cuberevo-2000hd
    - cuberevo-9500hd (cuberevo-7000hd)
    - cuberevo (ipbox-9000hd rel1 and rel2)
    Coder: Tideglo
    First boot take a little bit much more than a normal boot, so wait until you can see the bandeau bar (the one with infos on current channel) on the tv screen.
    HISTORY:
    release 1.1.1
    - fixed the bug that causes crashing on enigma2 during pixellation/freeze (call it as you like)
    - fixed network setup crashes with standard skin
    - fixed green button-aspect ration function
    - updated to 02/01/2011 enigma2 cvs
    - fixed no audio on channel switch on few cases (i can't fully test this, so report if it happens again)
    - fixed audio crop on some televisions (when you hear crop-crop-crop on channel switching)
    - added support for AVS file codec
    - many other fixes for better code and stability and to prevent crashes
    I made a full reset of the buglist (because of the new structure), so start thinking like the needs to report also old bugs if you find them again
    Enjoy it! Tideglo
    Download
    19 Post(s)
    Am testat imaginea FLASH pentru IpBOX 910 ! concluziile sint :
    - imaginea se misca bine ...deocamdata fara ecrane verzi sau zapada !!! se pare ca insfarsit s-a incalzit vremea ...
    - miscarea prin meniuri rapida ... in nota deja uzuala
    - zappingul cu Oscam activ parca ceva mai lent
    - deocamdata nu am remarcat ciudatenii
    Iata statistica de consum resurse :
    Mem: 93396K used, 10468K free, 0K shrd, 11932K buff, 34560K cached
    CPU: 1% usr 8% sys 0% nic 90% idle 0% io 0% irq 0% sirq
    Load average: 11.79 9.03 8.96 2/77 1820
    Se vede limpede ca procesorul 710x este aproape de doua ori mai lent
    decat 7111 de la Alien !
    P.S. dupa 12 ore de mers ... nimic de reprosat ! merge uns .. doar zappingul ...
    04 Jan 2010
    Am testat si eu tot pe 910hd .
    Am uptime de 4 zile fara blocari ,etc ,l-am innebunit dar nu a cedat nimic .deci in sfarsit avem un produs stabil !
    Din acest moment avem un receptor comparabil ca si software cu dm500..800 ,zic eu ca imaginea pe 910hd este
    mai buna decat pe dm800 iar pretul e clar in favoarea ipbox .
    Am testat cu oscam ca si server de card 30 linii c + cardreader pt local .
    De aici cred ca slefuirile de la pkt sau act vor multumi pe toata lumea .
    Acum instalez si vidbrowser ce include playerul de youtube si alte siteuri de gen .
    Mai revin cu informatii .
    S-a facut trecerea la player2 179 + mici corecturi.
    Versiunile vechi erau bazate pe player2 131.
    20 Sep 2008
    Cum descarci pluginurile direct din meniu la imaginea asta??
    VIP
    23 Sep 2008
    le bagi manual!
    Invatacel Visitor
    28 Jun 2009
    Buzau
    Ma puteti ajuta sa gasesc subtitrarea pe imaginea asta ?
    Multumiri anticipate !
    20 Sep 2008
    un oscam gata configurat pentru imagina asta cine are?
    27 Apr 2007
    Bayern, DE
    Pt. subtitrare : se apasa butonul galben de doua ori: (la prima apasare apare meniul de sunet si tot acolo arata cu buton galben Menu, deci se mai apasa o data galben si se va deschide lista de subtitrari disponibile)
    04 Jan 2010
    Default Informatii utile pentru cea mai stabila imagine
    Ca sa mearga automat oscamul sau ce emu lasati pornit cand dati restart trebuie ca dupa ce ati instalat emu manager sa copiati linia :
    /usr/lib/enigma2/python/Plugins/Extensions/EMUmanager/emustarter.sh
    la sfarsitul fisierului /etc/default/rcS
    linia e copiata din fisierul rcS care vine cu emu manager numai ca calea din emu manager era /etc/rcS nu etc/default/rcS .
    Daca vreti sa folositi swap la imagine editati fstab incat sa fie:
    /dev/sdaX none swap sw
    incat X-ul sa reprezinte partitia care o aveti ca swap.
    08 Sep 2010
    ìn IAD
    Default re
    Salut, multumesc pentru informatii, dar am incercat si nu-mi da voie sa editez fisierul /etc/default/rcS, primesc eroare 553. Am incercat sa-i dau atribut 755 si 777 dar tot nu reusesc. si am mai incercat sa-l editez in calculator apoi sa-l transfer, dar primesc aceeasi eroare. Momentan sunt pe Nightly Build 1.2.0
    04 Jan 2010
    Probabil ai imagine in flash.eu nu mai tin imaginile in flash de multa vreme dar stiu ca am reusit sa editez fisierele parca din consola.
    08 Sep 2010
    ìn IAD
    Da, este in flash, voi incerca sa le editez din telnet.
    ---------- Post added at 19:41 ---------- Previous post was at 19:11 ----------
    Nu reusesc cu vi, imi tot zice ca este only-read file. se pare ca ma voi intoarce tot la pkt.
    04 Jan 2010
    Cel mai simplu : nu mai pune imaginile in flash !.
    e read only cred pt ca tre sa schimbi userul(cred) cu su .
    08 Oct 2010
    Default Sifteam
    Quote Originally Posted by technomate View Post
    Citesc si eu tote astea , si cate-o data nu inteleg de ce nu vine de exemplu si fisieru asta corect ,doar sa , trebuiasaca copiat la locul lui si gata... Sau de ce nu le pune pe un addons server ca si plugin sa fie mai usor pt utilizatorii. Da in tradevar eu inca nu prea stiu lucruriile astea ,dar sunt multe chestii care s-ar putea rezolva foarte usor, si iata ca nu sunt asa facute.
    Am o intrebare , noi nu am putea face un addon-s din cea ce avem de ex. emumanager-u, si sa le transformam in tar.gz, ca sa dam un install si sa le puna automat la locul lor tot ce trebe ?
    Ce ziceti e greu de facut asa ceva? Nu are nimeni experienta? Dac se pote o explicatie, eu sunt consumator pt. asa ceva.! Daca m-am exprimat gresit , iertati-ma! Multumesc?
    Alta chestie ,cu swap. Eu pana zi nu inteleg ce este si ce rol are? daca nu ruleza ce se intampla?
    Eu am pe usb 4 partitii din care sdb1=PKT , sdb2=AAF, sdb3=sifteam, sdb4 =swap am facut
    mkfs.ext2 -L swap /dev/sdb4
    mkswap /dev/sdb4
    swapon /dev/sdb4
    este bine asa sau nu, Pot sa fac si pe sdb1, dar e nasol pt boot, nu prea sunt multibooturii pt sdb2 /USB/E2/Partitia 2/ si din cauza asta am pus la sfarsit, ca prima data din E2 trebe sa am un plugin bootplus ca sa pot face optiuni pt partitile care folosesc. Ce parere aveti?
    E bine asa? nu e bine? Daca pun swap pe hdd , asta insemna ca se invarta non stop?
    Multumesc pt. rabdare acordata!
