Thanks Thanks:  9
Likes Likes:  2
Results 121 to 124 of 124
Thread: HD Glass 16 !
  1. #121
    Thumbs up HD Glass 16 ver. 10.89
    - fix detection audio type
    update is available online (setup and website)
    http://speedy.sh/ypSjp/enigma2-skin-...89-all.ipk.zip
    http://speedy.sh/3xaRx/enigma2-skin-...89-all.deb.zip
  2. #122
    Thumbs up HD Glass 16 ver. 11.06
    - fix date in some extrascreens and base infobar
    - added to translation text from help pictures
    - help: updated en, sk, cz translations
    - added in "INFOBAR": TP type(color), TP info(color), Video resolution(color)
    - updated pl, sk, cz, en, ru, de, it, uk, pt, tr, es, fa, al, ro, hu, nl, et, lt
    - added screens def.: autotimer plugin
    - display info about new version as "Changelog"
    http://s9.dosya.tc/server/cfirur/eni...l.deb.zip.html
    http://s9.dosya.tc/server/qu1xmw/eni...l.ipk.zip.html
  3. #123
    Thumbs up HD Glass 16 ver. 11.22
    - updated enhanced weather translations
    - changed User defined path to selection of dir by using Location box, if is
    Picons/Icons path used as User defined path the one will be set to default value
    and you can set your prefered options after autorestore
    - updated help sk, cz, en, lt
    - setup of the skin: added moving to last item/section if is active first item
    press Up/Ch + and moving to first item/section if is active last item press
    Down/Ch -
    - fix TP info a ECM status
    - added new option: Calculation of channel numbers - static/dynamic, section OTHERS
    static - recommended for old HW
    - added color "grey 5" at all color selection
    - added new option: Date format - in sections: INFOBAR/EXTRA INFOBAR, OTHERS,
    CHANNEL SELECTION, MENU
    - splitted section INFOBAR to sections: INFOBAR,EXTRA INFOBAR,INFOBAR/EXTRA INFOBAR
    - added new options: Date (color), Time (color), Seconds (color) in section
    EXTRA INFOBAR
    - added autodetection of possible OLED type by hw
    - fix detection of decoding type - dynamic icons
    - added autohiding of options unusable in image/hw
    https://www.sendspace.com/file/5bu22y
    https://www.sendspace.com/file/v5nbie
  4. #124
    HD Glass 16 ver. 11.60
    - fix saving of weather location
    - OLED: added OLED type - only time 2
    - added alternative method to detection tuner type in some types of enigma
    Thanks @Shammann
    enigma2-skin-hdglass16_11.60_all.ipk.zip
    https://mega.nz/#!fBsiSQKL!88nGqyzL4...h8X7EWA0DwtA_c
    enigma2-skin-hdglass16_11.60_all.deb.zip
    https://mega.nz/#!fMF3hRYY!SI6RnrjBL...cLsFdY6bCihn7Y
