Results 1 to 10 of 10
Thread: Ajutor configurare emu Enigma2 NightlyBuild 1.1.1 IPBOX 910HD
    20 Sep 2008
    Default Ajutor configurare emu Enigma2 NightlyBuild 1.1.1 IPBOX 910HD
    Am instalat Enigma2 NightlyBuild 1.1.1 pe un receptor IPBOX 910HD totul ok pana la emu, nu reusesc sa fac sa functioneze oscam am pus emu manager v4.0 pornesc Oscam-ul dar nu vrea sa mearga. Exista alta metoda de a pune oscam pe imaginea asta??
    19 Post(s)
    pai cel mai simplu ar fi sa ne arati oscam,conf si oscam.user ...precis ai o problema acolo !
    altfel ...asa din avion ...ce-am putea intelege ? eu folosesc aceasta versiune si merge fara
    repros !
    20 Sep 2008
    oscam.conf
    # main configuration
    [global]
    nice = -1
    WaitForCards = 1
    # logging
    pidfile = /var/run/oscam.pid
    logfile = /var/log/oscam/oscam.log
    usrfile = /var/log/oscam/oscamuser.log
    cwlogdir = /var/log/oscam/cw
    # monitor
    [monitor]
    port = 988
    aulow = 120
    monlevel = 1
    # web interface
    [webif]
    httpport = 8888
    httpuser = myusername
    httppwd = mypassword
    # anti-cascading
    [anticasc]
    enabled = 1
    numusers = 1
    sampletime = 2
    samples = 5
    penalty = 1
    aclogfile = /var/log/oscam/aclog.log
    denysamples = 9
    # protocols
    [newcamd]
    key = 000102030405060708090A0B0C0D
    port = 10000@0100:FFFFFF;10001@0200:FFF000,FFFF00;10002@0300:FFFFFF
    [radegast]
    port = 20000
    user = user1
    allowed = 192.168.0.0-192.168.255.255
    [cs378x]
    port = 30000@0100:FFFFFF;30001@0200:FFF000,FFFF00;30002@0300:FFFFFF
    [cccam]
    port = 40000
    version = 1.2.3
    build = 1234
    reshare = 2
    [gbox]
    password = password1
    maxdist = 4
    cardinfos = card.infos
    ignorelist = ignore.list
    onlineinfos = online.infos
    locals = 01000000,02000000,0300FFFF
    [serial]
    device = user2@/dev/ttyS0?delay=1&timeout=300
    [dvbapi]
    enabled = 1
    user = user1
    socket = /tmp/camd.socket
    oscam.user
    # user configuration
    # user for group 1 with Betacrypt tunnel, no monitoring, only one connection possible, AU enabled
    [account]
    user = user1
    pwd = password1
    monlevel = 0
    uniq = 1
    group = 1
    au = reader1
    services = services1
    betatunnel = 0300.FFFF:0100,0400.FFFF:0100
    ident = 0100:000000
    caid = 0100
    # user for group 2 with monitor access, AU enabled
    [account]
    user = user2
    pwd = password2
    monlevel = 1
    uniq = 0
    group = 2
    au = reader2
    services = services2
    ident = 0200:000000
    caid = 0200
    # user for group 2 without monitor access, AU disabled, account disabled
    [account]
    user = user3
    pwd = password3
    disabled = 1
    group = 2
    ident = 0200:000000
    caid = 0200
    # user for group 3 without monitor access, only one connection possible, AU disabled, multiple idents
    [account]
    user = user4
    pwd = password4
    monlevel = 0
    uniq = 1
    group = 3
    ident = 0300:000000,FFFFFF;0400:FFFFFF
    caid = 0300
    # user for group 5 with anti-cascading, only 1 logging allowed, send fake CWs as penalty
    [account]
    user = user5
    pwd = password5
    group = 5
    services = services5
    ident = 0500:000000
    caid = 0500
    numusers = 1
    penalty = 1
    08 Sep 2010
    ìn IAD
    Default Emu Manager 4.0
    Daca cineva foloseste aceasta versiune de emu manager, rog sa spuna daca stie cum se activeaza pornirea automata a emulatoarelor. am facut chmod 755 la toate fisierele dupa ce le-am copiat. daca pornesc manual, totul ok fara probleme, inclus dupa restart-gui, dar dupa un reboot la tot aparatul sau daca mai faca astia vreo faza si taie curentul, tre sa fiu atent pe aparat, sa-i dau un start la emu. nici pluginurile care sunt acolo nu apar la meniul pluginuri, si mai mult de atat, butonul galben pe care selectional subtitrarea s-a dezactivat de cand am copiat si acel keymap.xml; toate acestea pe un cuberevo 250 hd
    02 Feb 2008
    Pentru a porni emu la restart pui in var/etc/rcS_user asta /var/bin/oscam & sau cum e emulatorul denumit in var/bin adica /var/bin/nume_emu &
    08 Sep 2010
    ìn IAD
    Default re
    multumesc pentru sfat, dar tot nu vrea. am incercat si cu panel 3.0, dar se pare ca nu reusesc. am mai adaugat eu cateva linii in acel script, dat nu porneste nimic automat
    # add here your own commands to be launched at enigma2 starts
    #!/bin/sh
    /usr/lib/enigma2/python/Plugins/Extensions/EMUmanager/emustarter.sh
    /usr/lib/enigma2/python/Plugins/Extensions/EMUmanager/start_oscam.sh
    /var/bin/oscam &
    insmod /lib/modules/cifs.ko
    mount -t cifs //192.168.1.101/dreambox /hdd -o username=dreambox,password=dreambox
    exit 0
    #-------------fine mod mario sat
    Am vazut ca si AAf Multimedia 2 e ceva mai nouá. Merge cu oscam?
    08 Oct 2010
    Default ip box
    Mege oscam bine pe AAF, stabila imagine de data asta, si merge si PKT cel mai nou e stabila ca si siftemu 1.1.1 de mai sus, cu skyn gold Hd.
    01 Feb 2008
    niste mizerii. si nightly build si extreme. fara suport emu, scripturi de start-stop poti sa te p*i*s* pe ele. alt receptor pus deoparte pentru "piese". adio SH4! back to vu+!
    succesuri!
    04 Jan 2010
    Pacat,sa stii ca sunt cele mai stabile si rapide imagini de pana acum !
    Daca te chinuiai putin puneai emu pe ele .
    01 Feb 2008
    pai.... am pus! cu problemele de rigoare!
    stii reclama aia la iaurt (parca): prea tare, prea moale, prea acru... aici (vorbim de imaginile pomenite mai devreme) devine prea complicat! eu am inteles ca grupurile de "dezvoltare" incearca sa indeparteze incepatorii si nestiutorii de C S, da' nici in halu' asta! trebuie sapat pana in China ca sa aflii 2-3 proceduri. nu-mi vine chiar la indemana. cand ajung la performanta sa ma apuce 2 dimineata punand o imagine si pregatind-o pentru "viata de zi cu zi", nu mai e performanta si nici tentant. vremurile in care: a) imagine up pe rs232, b) configurare video, c) download emu, d) configurare, e) vizionare placuta s-au dus. probabil ca aici se opreste si partea de hobby. le fac sa mearga (trebuie sa satisfac toata familia la capitolul asta) si la revedere!
    scuze de offtopic da' nici cafeaua nu ma trezeste la ora asta!
    succesuri!
