Thanks Thanks:  1
Results 1 to 8 of 8
Thread: Imagini DM 800 SE (original)
    29 Mar 2009
    Austria - TM
    Default Imagini DM 800 SE (original)
    Newnigma2 team proudly presents:
    Newnigma2 v3.1.6
    Basics:
    • Enigma2 2.6: 03.03.2011
    • Enigma2 Plugins 2.6: 03.03.2011
    • Newnigma2 Plugins: 03.03.2011
    DM 800 HD se
    Changes:
    • Bugfix: configsaver crashed with SD skins
    • Bugfix: webradio shoutcast search
    • Bugfix: some ecamdctrl fix
    • Bugfix: some small things Kerni-HD1R2 fixed
    • Update: DMConcinnity-HDpicon_default.png changed
    • Added: a new version of bitrateviewer
    Änderungen:
    • configsaver: fix crash on SD skins
    • webradio: fix shoutcast suche
    • bitrateviewer: neue Version
    • ecamdctrl: bugfix
    • DMConcinnity-HD: neues picon_default.png
    • Kerni-HD1R2: einige bugfixe
    Multiboot: No support for multiboot. Not planned. No need for such a tool.
    G3wizard: No support for g3wizard. Probably not running. Not needed in Newnigma2 enviroment.
    Onlineupdate from v3.1(.x) is possible.
    Ein Update von v3.1(.x) ist per Softwareverwaltung moglich.
    Hinweis: Sollte es beim Update zu Problemen kommen und beim Neustart Error im Display stehen dann muss der SecondStage mit Dreamup neu geflasht werden.
    Notice: If u have problems after update and the display shows "Error", then u have to flash the SecondStage with dreamup.
    Image:
    29 Nov 2008
    Cu capu' in nori
    Default DM 800 HDse Newnigma2 v3.2
    Newnigma2 v3.2
    Basics:
    • Enigma2 2.6: 24.03.2011
    • Enigma2 Plugins 2.6: 24.03.2011
    • Newnigma2 Plugins: 24.03.2011
    DM 800 HD se
    • driver: 09.03.2011
    • secondstage: 82
    • kernel 2.6.18
    Changes:
    • Bugfix: some small fixes in ecamdctrl
    • Update: xmltvimport plugin and sources/channels updated
    • Added: driver for Realtek 802.11n USB wireless LAN controllers
    • Added: enigma2-plugin-extensions-serienfilm
    • Added: enigma2-plugin-extensions-webbouqueteditor
    Notice: No update possible. U have to flash our new image. The new kernel and secondstage update for the Dreambox 8000 allows you to use the full flash size of 256MB.
    GP3wizard: No support for gp3wizard. Probably not running. Not needed in Newnigma2 environment.
    Download :
    http://www.newnigma2.to/wbb2/jgs_db....ad_id=135&sid=
    29 Mar 2009
    Austria - TM
    Default Merlin2-Excalibur Image für die Dreambox 800se (OE1.6)
    Merlin2-Excalibur Image fur die Dreambox 800se (OE1.6)
    Auf den Feeds liegen Updates bereit.
    Enigma2: 20110404
    Enigma2-Plugins: 20110404
    Enigma2-Skins: 20110404
    Merlin2:
    + new function: custom plugin-sort-order for extension menu
    + DreamCC show current entry and its status in lcd (reverted, because not working)
    + some Renderer fixes
    29 Mar 2009
    Austria - TM
    Default OoZooN Image for DM 800 SE
    OoZooN-Image-DM800se-20110731
    Hier kommt ein neues DM800se Image aus dem Enigma² “experimental” OE 1.6 zweig.
    Enigma stand ist 31.07.2011
    die plugins sind vom 31.07.201
    die treiber vom 06.05.2011
    neuer kernel 2.6.18-r12.0.1
    secondstageloader ist 82
    änderungen an Enigma² konnen Hier verfolgt werden
    meine änderungen am oe:
    eigene bootlogo’s, artwork von skywatcher
    mit satellites.xml – enigma² by Reinh@rd
    änderung des dccamd start
    dccamd nicht im image enthalten, kann online nachinstalliert werden
    (*) enthalten
    (**) uber den plugin-download verfugbar
    systemplugins:
    automaticcleanup (**)
    automatictimerlistcleanup (**)
    automaticvolumeadjustment (**)
    autoresolution (**)
    cleanupwizard (**)
    crashlogautosubmit (**)
    crossepg (**)
    defaultservicesscanner (**)
    diseqctester (**)
    dvbtime (**)
    hotplug (*)
    ledmanager (**)
    mphelp (**)
    networkbrowser (*)
    networkwizard (*)
    positionersetup (*)
    satelliteequipmentcontrol (**)
    satfinder (*)
    setpasswd (**)
    skinselector (*)
    softwaremanager (*)
    startupservice (**)
    videoenhancement (**)
    videomode (*)
    videotune (*)
    wirelesslan (**)
    vps (**)
    plugins:
    aihdcontroller (**)
    ambx (**)
    antiscrollbar (**)
    appletrailer (**)
    atmolight (**)
    audiosync (*)
    autotimer (**)
    autotimeshift (**)
    b00k (**)
    babelzapper (**)
    barryallen (**)
    bartallen (**)
    blockcontent (**)
    bonjour (**)
    buliticker (**)
    bwmon (**)
    captain-shell (**)
    cdinfo (**)
    cooltvguide (**)
    covermanager (**)
    cronmanager (**)
    cutlister (**)
    cvsnews (**)
    dccamd (**)
    deamonmanager (**)
    dflash (*)
    djmount (**)
    dmvidsdirect (**)
    dreamexplorer (**)
    dreamirc (**)
    dvdbackup (**)
    dvdburn (**)
    dvdcontroller (**)
    dvdplayer (**)
    dyndns (**)
    easymedia (**)
    emailclient (**)
    enhancedmoviecenter (**)
    epgrefresh (*)
    epgsearch (**)
    extendedserviceinfo (**)
    fantastic (**)
    filebrowser (**)
    flashbackup (**)
    flashcheck (**)
    freeze (**)
    fritzcall (**)
    ftpbrowser (**)
    fstaber (**)
    genuinedreambox (*)
    googlemaps (**)
    graphmultiepg (*)
    growlee (**)
    hddtemp (**)
    hdmon (**)
    housekeeping (**)
    httpproxy (**)
    imdb (*)
    iprec (**)
    kiddytimer (**)
    lancontrol2 (**)
    lastfm (*)
    lcdskin (**)
    ledctl (**)
    letterbox (**)
    livescore (**)
    logomanager (**)
    lottoextended (**)
    lottozahlen (**)
    mediacenter (**)
    mediadownloader (**)
    mediaplayer (*)
    mediascanner (*)
    meldetimer (**)
    merlinepg (**)
    merlinepgsearch (**)
    merlinmusicplayer (*)
    metacafedirect (*)
    meteoitalia (**)
    modem (*)
    mosaic (**)
    mountie (**)
    mountie-light (**)
    moviecut (*)
    movieepg (**)
    moviejukebox (**)
    movielistpreview (**)
    movieplayer (**)
    movieretitle (*)
    movieselectionquickbutton (**)
    movie-splitter (**)
    movietagger (*)
    multimediathek (**)
    multiquickbutton (**)
    multirc (**)
    myspacedirect (**)
    mytube (**)
    myvideo (**)
    namezap (**)
    netcaster (**)
    nfidump (**)
    nfsserver (**)
    nstreamplayer (**)
    ofdb (*)
    off (**)
    openpanel (**)
    orfat (**)
    orfteletext (**)
    partnerbox (**)
    passwordchanger (**)
    pauli (**)
    permanentclock (**)
    permanentrecording (**)
    permanenttimeshift (**)
    planerfs (**)
    pluginsort (*)
    pictureplayer (*)
    podcast (**)
    project-valerie (**)
    puremp3player (**)
    pzyemail (**)
    quickbutton (**)
    quicktv (**)
    reconstructapsc (**)
    remotetimer (**)
    remotetv (**)
    rsdownloader (**)
    sambaserver (*)
    screensaver (**)
    secondinfobar (**)
    seekbar (**)
    sherlock (**)
    showclock (**)
    shoutcast (*)
    simplerss (**)
    smargo (**)
    socketmmi (**)
    spinnerselektor (**)
    sportinfos (**)
    startuptostandby (**)
    suduko (**)
    swapscript (**)
    tager (*)
    timeshiftsave (**)
    timeupdate (**)
    trafficinfo (**)
    translator (**)
    tuxcom (**)
    tvcharts (**)
    tversity (**)
    unwetterinfo (**)
    updatecheck (*)
    upnp (**)
    userscripts (*)
    ushare (**)
    valixdcontrol (**)
    vierg (**)
    virtualzap (**)
    vlcplayer (**)
    wallywest (**)
    wetherplugin (**)
    wethersat (**)
    webbrowser (**)
    webcamviewer (**)
    webinterface (*)
    webradiofs (**)
    webvideoplayer (**)
    werbezapper (**)
    xmltvimport (**)
    youtubeplayer (**)
    yttrailer (**)
    zaphistorybrowser (**)
    zapstatistic (**)
    zdfmediathek (**)
    Skins:
    basic hd (**)
    blackbox (**)
    blueline (**)
    blueline.extended (**)
    blueline.single (**)
    brushed alu hd (**)
    chromeline (**)
    chromeline.cobolt (**)
    dmconcinnity-hd (**)
    dmm-hd (**)
    dreammm-hd (**)
    dreamtv-hd (**)
    dtv-hd (**)
    dtv-hd-reloaded (**)
    elgato-hd (**)
    flatline (**)
    flatline.blue (**)
    glassline (**)
    greenline (**)
    greenline.extended (**)
    greenline.single (**)
    greyline (**)
    greyline.extended (**)
    greyline.single (**)
    kerni-hd1 (**)
    kerni-hd1r2 (**)
    lt6-hd (**)
    shadowline (**)
    simple (**)
    swain (**)
    swain.hd (**)
    ultraviolet (**)
    vali.hd (**)
    vali.hd.atlantis (**)
    vali.hd.nano (**)
    vali.hd.nano.mod (*)
    vali.hd.warp (**)
    vali.xd (**)
    yads.hd (**)
    picon hd (*)
    picon 01.0e 3d hd (**)
    picon 04.0e 3d (**)
    picon 04.8e 3d hd (**)
    picon 07.0e 3d (**)
    picon 07.0e 3d hd (**)
    picon 09.0e 3d (**)
    picon 09.0e 3d hd (**)
    picon 13.0e 3d (**)
    picon 13.0e 3d hd (**)
    picon 16.0e 3d (**)
    picon 16.0e 3d hd (**)
    picon 19.0e 3d (**)
    picon 19.2e 3d hd (**)
    picon 23.5e 3d (**)
    picon 23.5e 3d hd (**)
    picon 28.2e 3d (**)
    picon 28.2e 3d hd (**)
    picon 39.0e 3d (**)
    picon 39.0e 3d hd (**)
    picon 42.0e 3d (**)
    picon 42.0e 3d hd (**)
    picon kd.3d (**)
    picon kd.3d.hd (**)
    picon um.3d (**)
    picon um 3d hd (**)
    änderungen an enigma:
    MHW epg aktiviert
    load patch fur crossepg
    bouquet button patch
    video preview patch (by parsurimi)
    spinner fix patch (by adenin)
    .recordings patch
    echtheitszertifikatscheck (by Dr.Best) <- dieses image läuft nur auf original dmm hardware!
    das image ist uber einstellungen -> softwareverwaltung uber das internet aktualisierbar!
    OE Build Configuration:
    BB_VERSION = “1.8-dream”
    TARGET_ARCH = “mipsel”
    TARGET_OS = “linux”
    MACHINE = “dm800se”
    DISTRO = “opendreambox”
    DISTRO_VERSION = “1.6.0″
    TARGET_FPU = “soft”
    DOWNLOAD
    02 Sep 2010
    Earth
    Default Imagine Italysat 5.1 svn 122 (original +A8P)
    -122-
    New Pcsc 1.8.10
    New Ccid 1.4.14
    Fix NetworkBrowser with wlan0/eth1/ra0
    Fix OpenVPN start module at Boot
    New skin in ChannelSelection
    —120-
    Fix DVB-T E3HD Audio
    Fix DVB-T on Gigablue SE/UE Plus - Now Work!!!
    Update Picon by MMark with last 03/01/2014
    New Script for generate a /tmp/log.txt
    Update isettingE2 to v3.1.2
    Update E3HD driver DVB-C support
    Update transmission and airplayer plugins
    Update Mediastream to v2.0.0
    Fix mount in Image and Setting Backup
    Merge enigma2 with last version of OpenPLI
    Bug Conosciuti:
    • Plugin datati potrebbero causare crash
    • Lo scarico del meteo nella skin e quindi nella infobar potrebbe rallentare sporadicamente il cambio canali se durante lo zapping c'è anche un aggiornamento meteo
    • Nella ricerca canali DVB-T potreste avere un crash, che crediamo sia causato da lcnsanner integrato, perchè è un vecchio codice adattato per questa immagine. Abbiamo preferito lasciarlo visto che il crash è sporadico ma almeno abbiamo la possiblità di usare lcnscanner per ordinare la lista canali, è un compromesso finchè il codice non verrà sistemato
    DOWNLOAD
    http://repository.italysat.it/index....reambox-800se/
    Oltenia
    Ok,imi place imaginea dar am tri probleme din ce tasta setez subtitrarea ,ora si sa pun valcea la meteo nu merge codul de Rm. Valcea
    ---------- Post added at 11:58 ---------- Previous post was at 10:47 ----------
    Ok rezolvat cu timpul si subtitrarea mai am sa gasesc water id pe zona mea
    02 Sep 2010
    Earth
    Se gaseste in menu subtitrarea aia tampa, generala.
    Foloseste Ddamir pentru filme. 3.28 merge din pannel de la ei.
    openpli-9.5-dm800se-original-20230106​
    -DM800se - original
    -GCC 9.5.0
    -Glibc 2.31
    -GStreamer 1.18.6
    -Python 2.7.18
    -OpenSSL 1.1.1s
    -Busybox 1.31.1
    -Linux kernel 3.2.102
    -OSCAM-EMU 11717-798
    -Feeds server is working
    -Full-HD Teletext
    -Front LED blink speed Setup
    -ZapMode (black and hold)
    -new AudioSelection
    -Build date: 2023-01-06
    ftp & telnet:
    user : root
    password : dreambox
    https://www.file-upload.net/download...30106.zip.html
