Results 1 to 15 of 19
Thread: HOW TO gbox in Dreambox
    Default HOW TO gbox in Dreambox
    Aceasta pagina este un mic ajutor pentru utilizatorii Dreambox & Gbox.
    pagina realizata de L_DM500s
    Va poate ajuta si : http://www.sateliti.org/showthread.php?t=952
    Aveti nevoie de:
    Gbox - sunt citeva versiuni disponibile: 2.1b, 2.20, 2.22, 2.23, 2.24, 2.25... Recomand 2.1b sau 2.25 daca primiti <500 cartele virtuale.
    DCC - Dreambox Control Center
    optional plugin G-Box Center
    Instaleaza DCC in PC si seteaza comunicatia cu Dreambox-ul.
    Acum poti incepe instalarea fisierelor in Dream.
    copiaza fisierul gbox in dream in dir: var/bin.
    Seteaza attributul 755 pentru acest fisier.
    - daca ai si urmatoarele fisere copiaza-le si seteaza atributele 755 si pentru ele:
    s2issuer.b
    s2provid.b
    copiaza scriptul gbox_cam.sh in dream in dir: /var/script
    acest script este folosit pentru lansarea in executie a gbox-ului.
    aceasta este o lista a acestui script:
    # start gbox_cam.sh listing
    #!/bin/sh
    ###### Powered by The Gemini Team ######
    ### http://www.i-have-a-dreambox.com ###
    # camid #
    # 0000 = Commom Interface #
    # 0001->0199 = for User Experiment #
    # 0199 = Dccamd #
    # 0200->0299 = Fbiss #
    # 0300->0399 = Camd3 #
    # 0400->0499 = Camx #
    # 0500->0599 = Camx-radegast-cs #
    # 0600->0699 = Evocamd #
    # 0700->0799 = Evocamd-ronlad-cs #
    # 0800->0899 = Mgcamd #
    # 0900->0999 = Mgcamd-ronald-cs #
    # 1000->1099 = Newcamd #
    # 1100->1199 = Newcamd-ronald-cs #
    # 1200->1299 = Newcamd-spider #
    # 1300->1399 = Radegast #
    # 1400->1499 = Ronald-cs #
    # 1500->1599 = Scam #
    # 1600->1699 = Scam-ronald-cs #
    # 1700->1799 = Cardserver #
    # 1800->1899 = Mgcamd with Cardserver #
    # 9800->9899 = reserved #
    # 9900->9999 = reserved #
    CAMNAME="Gbox"
    USERNAME=""
    ZAPTIME=6
    CAMID=970
    DVBSET=1
    INFOFILE="ecm.info"
    # end
    # This method cleans up /tmp folder of gbox files
    remove_tmp ()
    rm -rf /tmp/*info* /tmp/*gbox* /tmp/*online* /tmp/*share* /tmp/Newcs* /tmp/atack* /tmp/debug*
    # This method starts Gbox
    start_cam ()
    /var/bin/gbox &
    # This method stops Gbox and then calles the tmp cleanup method
    stop_cam ()
    touch /tmp/gbox.kill
    /bin/prockill gbox
    remove_tmp
    case "$1" in
    start)
    echo "[SCRIPT] $1: $CAMNAME"
    start_cam
    stop)
    stop_cam
    restart)
    echo "Restarting $CAMNAME"
    stop_cam
    start_cam
    "$0" stop
    exit 1
    esac
    exit 0
    # end gbox_cam.sh listing
    copiaza fisierele de config si key in dir: /var/keys
    - fisiere de configuratie:
    gbox_cfg
    cwshare.cfg
    softcam.cfg
    rom02.b
    rom02eep.b
    rom02ram.b
    rom03.b
    rom03eep.b
    rom03ram.b
    rom07.b
    rom07eep.b
    rom07ram.b
    rom10.b
    rom10eep.b
    rom10ram.b
    rom11.b
    rom11eep.b
    rom11ram.b
    - fisiere optionale cu key:
    conax
    irdeto
    nagra
    seca
    via
    - alte fisiere optionale:
    ident.info - in acest fisier sunt datele operatorilor; respectiv codurile asignate cu numele lor pentru afisare usoara cu G-Box Center.
    ignore.list - pentru a ignora anumiti operatori sau cartele vechi, false.
    knowns.ini
    priority.list
    replace.list
    Acum va trebui sa repornesti Dreambox-ul.
    Mergi in Blue Panel si selecteaza Gbox, apoi selecteaza Start/Restart Cam pentru a activa Gbox cam-ul.
    Default Re: HOW TO gbox in Dreambox
    Pentru ca Gbox-ul sa functioneze corect trebuie sa ai in dir: /var/keys anumite fisiere de configuratie:
    gbox_cfg, softcam.cfg and cwshare.cfg (
    cwshare.cfg -este important sa-l setezi cu datele tale ).
    Aici este listingul gbox_cfg pe care poti sa-l copiezi si sa-l inserezi intr-un fisier text si apoi sa-l salvezi cu numele: gbox_cfg daca nu cumva il ai deja.
    # start gbox config file
    # Trace/Debug
    # xx yz ; xx=00 no konsole output
    # xx yz ; xx=01 konsole output
    # xx yz ; y=0 debug output (don't use)
    # xx yz ; y=1 no debug output
    # xx yz ; z=0 ouput to konsole
    # xx yz ; z=1 output to /var/tmp/debug.txt
    # xx yz ; z=2 Output to UDP (to capture with gboxt)
    Z: { 00 12 } 192.168.1.4 8024
    # Task type
    # 00 ** normal mode gbox mode (no season, use Multicam instead)
    # 01 ** Season Emulation in a Irdeto allcam chid 0602 nonZ
    # 10 ** Season Emulation in a Irdeto allcam chid 1702 nonZ
    # 11 ** Season Emulation in a Irdeto allcam chid 1702 Z
    # 12 ** Season Emulation in a Irdeto allcam chid 1722 Z
    # 13 ** Season Emulation in a Irdeto allcam chid 1762 Z
    # ** *1 Com port to use for season emulatiom (1 or 2)
    # ** 0* Use CTS fur RST detection
    # ** 1* Use DCD fur RST detection
    # ** ** 9600 = Baudrate to be used (working only on dbox2)
    W: { 00 00 } 9600
    # gbox working mode
    # 00 pure Emu
    # 01 pure SoftCam (when card inside), Emu (when no card inside)
    # 02 pure Net Client
    # 03 Mixed mode !!!!! always use this !!!!!
    G: { 03 }
    # Display ECM messages on Konsole
    # 00 don't show any ECM's
    # 01 show only valid ECM's
    # 02 show valid and bad ECM's with complete data display
    C: { 01 }
    # Display EMM messages on Konsole
    # *0 don't show any EMM's
    # *1 show only valid EMM's
    # *2 show valid and bad EMM's with complete data display
    # 1* Log any tier change on PW-Nagra-17xx cards into /var/keys/pwupdate.log
    M: { 01 }
    # AutoUpdate
    # 00 is ignored (default)
    # 01 enable AU
    # 02 Auto AU !!!!! always use this !!!!!
    A: { 02 }
    # Key update
    # 01 update only new keys, default setting
    # 02 update all keys (used for valid PMK checking)
    U: { 02 }
    # Hash pids
    # 00 hash all pids, DO NOT USE THIS OPTION, IT IS ONLY FOR TESTING STUFF
    # 01 hash only pids with implemented algos and available keys !!!!! always use this !!!!!
    H: { 01 }
    # Key files folder
    # 00 keyfiles in /var/keys
    # 01 keyfiles in /var/tmp
    T: { 00 }
    # On Screen Display for the Multysystemcam on com1/com2
    # 00 No OSD (default)
    # 01 display Smartcard messages in Neutrino
    # 02 display Smartcard messages in Neutrino new nhttpd format
    # 03 display Smartcard messages in Enigma
    # mypass (use user=root and pass=mypass for nhttpd)
    O: { 03 } 192.168.1.2
    # Logger and NET-mode UDP port Init
    # 00 do not init UDP port
    # 01 Init UDP port for IP, port, UDP
    L: { 00 } 10.0.0.3 8017
    # demux, multicam/comport configuration
    # *x ** ; x = device nummber to be used (0= default)
    # D* ** ; force use of /proc/bus/gtx for cw write operations
    (in the dbox2 the gbox writes directly the CW's, 00 is the
    recommended mode ! No drivers are required) use D* ** ONLY if
    you have Problems. 0* ** should be prefered !!!
    # F* ** ; write CW's in both devices (used for PVR in STB04xxx devices)
    # ** y* ; y=0001b (0x1*) use slot1 as Multicam (only on STB04xxx)
    # ** y* ; y=0010b (0x2*) use slot2 as Multicam (only on STB04xxx)
    # ** y* ; y=0011b (0x3*) use slot1 and slot2 as Multicams (only on STB04xxx)
    # ** *z ; z=0001b (0x*1) use com1 as Multicam
    # ** *z ; z=0010b (0x*2) use com2 as Multicam
    # ** *z ; z=0011b (0x*3) use com1 and com2 as Multicams
    # ** yz ; yz=00110011b (0x33) use slot1+slot2+com1+com2 as Multicams
    # ** *z ; z=0100b (0x*4) invert CTS detection on com1
    # ** *z ; z=1000b (0x*8) invert CTS detection on com2
    # example: yz = 0x0A = 00001010 (use com2 with inverted CTS detection line)
    V: { F0 10 }
    # extra options to override default seting in case you expirience Problems,
    # normaly these setings are not required.
    # cpu, api, cw write method
    # 00 auto
    # 01 80X86
    # 02 MPC823
    # 03 IBM STB04xxx
    # 00 auto
    # 01 ibm
    # 02 api2
    # 03 api3
    # 00 cw write style = use internal routine (only dbox2)
    # 01 cw write style = CA_SET_DESCR type1 (dbox2, vdr)
    # 02 cw write style = CA_SET_DESCR type2
    # 03 cw write style = CA_SET_DESCR type3
    # 04 cw write style = 16 byte /proc/bus/gtx
    # 05 cw write style = 4096 byte /proc/bus/gtx, cw offset=0x04D0
    # xx write cw in 1st device with index=xx
    # yy write cw in 2nd device with index=yy
    # 01 means with .index=0 (default)
    # 02 means with .index=1
    # 03 means with .index=0 and .index=1
    # .. any bitwise combination ...
    # FF means with all 8 indexes (0-7)
    #J: { 01 00 00 01 01 }
    # Files, folders, devices
    # folder/device comment
    #F: { 01 } /var/tmp/pmt.tmp // pmt file
    #F: { 02 } /var/tmp/emm.info // key update log file
    #F: { 03 } /var/tmp/ecm.info // ecm info file
    #F: { 04 } /var/tmp/atack.txt // atack info file
    #F: { 11 } /var/keys // folder for config files
    #F: { 12 } /var/tmp // folder for temporary file
    #F: { 13 } /var/keys // folder for keyfiles
    #F: { 21 } /dev/dvb/card0/ca0 // ca device
    #F: { 22 } /dev/dvb/card0/dvr0 // dvr device
    F: { 23 } /dev/dvb/card0/demux0 // demux device
    #F: { 31 } /dev/dvb/adapter0/ca1 // second ca device to write cw's (recording)
    #F: { 41 } /dev/sci0 // STB04xxx slot1
    #F: { 42 } /dev/sci1 // STB04xxx slot1
    #F: { 43 } /dev/tts/0 // rs232 com1
    #F: { 44 } /dev/tts/1 // rs232 com2
    # For overclocking freaks, Clocking internal STB04xxx slots with:
    # 1=7.80MHz 2=6.30MHz 3=5.25MHz 4=4.50MHz 5=3.94MHz 6=3.50MHz 7=3.15MHz
    # Irdeto works fine on 7.8MHz, all other fine on 6.30MHz or 5.25MHz
    # The Dream has not a clean clock signal, some cards that are sensitive will
    # refuse to work even on 3.5MHz, thats why 3.15MHz is the default value there.
    # On other STB04xxx recievers the same cards work with 6.30MHz
    #F: { 51 } 02 // irdeto
    #F: { 52 } 03 // seca
    #F: { 53 } 03 // viaccess
    #F: { 54 } 03 // nagra
    #F: { 55 } 03 // crypto
    #F: { 57 } 03 // conax
    #F: { 58 } 03 // nds
    # end gbox config file
    Aici este listingul softcam.cfg pe care poti sa-l copiezi si sa-l inserezi intr-un fisier text si apoi sa-l salvezi cu numele: softcam.cfg daca nu cumva il ai deja.
    # SoftCam EMM Log configuration
    # Save EMM data
    # 00 Don't save anything (default)
    # 01 Save processed EMMs (/var/tmp/emmproc.bin)
    # 02 Save rejected EMMs (/var/tmp/emmblock.bin)
    # 03 Save both EMMs
    L: { 00 }
    # Check additional OSC Frequency !!! ONLY FOR DBOX2 !!!
    # 00 No Check (default)
    # >0 Check on, Value in KHz , example 8MHz=08000
    F: { 00 }
    # Check additional Baurate for ATR !!! ONLY FOR DBOX2 !!!
    # >0 Check on, Value in bit/s, example 81861
    B: { 00 }
    # Enable TPScrypt Support
    # *0 TPScrypt off
    # *1 TPScrypt on (default)
    # 1* don't use PTS on Viaccess cards
    # 2* don't use PTS on Cryptoworks cards
    # 3* don't use PTS on Viaccess and Cryptoworks cards
    Y: { 01 }
    # Empty RS232 buffer before writing
    # 00 No reset
    # 01 Reset Buffer (default)
    E: { 01 }
    # SoftCam Blocker/Filter definition
    # 00 = Allow EMM (default for all)
    # 01 = Block EMM addressed to:
    # all card
    # | shared address/provider
    # | | unique address/hex_serial
    I: { 00 00 00 } Irdeto All SA UA
    V: { 00 00 00 } Via - SA UA
    S: { 00 00 00 } Seca - SA UA
    N: { 00 00 00 } Nagra All SA UA
    C: { 00 00 00 } Crypto All SA UA
    O: { 00 00 00 } Conax - SA UA
    D: { 00 00 00 } NDS All SA UA
    # Timeout Definitions
    T: { 00 02 01 } ATR timeout (normal*X), instruction timeout (normal*X)
    # com1/com2 delays, all delays to be entered in decimal !
    # Do NOT touch !!!!!!!!!!!!!!!!!!
    # all timings should be 0, change only if you have problems.
    T: { 01 00000 000 } Irdeto : byte delay (1e-6 s), instruction delay (1e-3 s)
    T: { 02 00000 000 } Seca
    T: { 03 00000 000 } Viaccess
    T: { 04 00000 000 } Nagra
    T: { 05 00000 000 } CryptoWorks
    T: { 06 00000 000 } Geldkarte
    T: { 07 00000 000 } Conax
    T: { 08 00000 000 } NDS
    # Use Crypto card bug to decode any CW, no matter of chid
    # Cxxx configuration (is aktiv for the provider only if a config line is present)
    # (ECM sample to be used to get the cw's with Cxxx)
    # Provider provider chid - that is present on the card for that provider
    # UPC-Astra
    8: { 8D } A4 4C 00 00 2E 20 00 2B 83 01 8D 8C 03 20 01 00 8E 02 00 00 C5 01 00 DB 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 DF 08 00 00 00 00 00 00 00 00
    # Digiturk
    8: { C1 } A4 4C 00 00 31 28 00 2E 83 01 C1 8C 03 89 19 19 8E 02 00 00 8F 01 A9 91 01 55 DB 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 DF 08 00 00 00 00 00 00 00 00
    # Use constant CW's for
    # caid pid CW0 ... CW1 ...
    0: { 09 61 2E E5 { F0 07 84 7B F2 24 E9 FF 00 00 00 00 00 00 00 00 }
    0: { 09 61 C3 57 { 86 FA 87 07 33 F2 AF D4 00 00 00 00 00 00 00 00 }
    0: { 26 00 03 EB { 2D 4E 53 CE 6A 42 5F 0B 2D 4E 53 CE 6A 42 5F 0B }
    0: { 26 00 03 E9 { 2D 4E 53 CE 6A 42 5F 0B 2D 4E 53 CE 6A 42 5F 0B }
    0: { 26 00 03 EA { 2D 4E 53 CE 6A 42 5F 0B 2D 4E 53 CE 6A 42 5F 0B }
    0: { 26 00 03 EC { 2D 4E 53 CE 6A 42 5F 0B 2D 4E 53 CE 6A 42 5F 0B }
    0: { 26 00 03 ED { 2D 4E 53 CE 6A 42 5F 0B 2D 4E 53 CE 6A 42 5F 0B }
    0: { 26 00 03 EE { 2D 4E 53 CE 6A 42 5F 0B 2D 4E 53 CE 6A 42 5F 0B }
    0: { 26 00 03 EF { 2D 4E 53 CE 6A 42 5F 0B 2D 4E 53 CE 6A 42 5F 0B }
    0: { 26 00 03 F0 { 2D 4E 53 CE 6A 42 5F 0B 2D 4E 53 CE 6A 42 5F 0B }
    0: { 26 00 00 01 { 10 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00 }
    0: { 26 00 00 04 { 18 AA 00 00 C2 D3 28 00 18 AA 00 C2 C2 D3 28 00 }
    0: { 26 00 00 03 { B9 8A C0 00 DE 11 03 00 B9 8A C0 00 DE 11 03 00 }
    0: { 26 00 00 05 { AB CD EF 67 FE DC BA 94 AB CD EF 67 FE DC BA 94 }
    0: { 26 00 1F 06 { 11 11 11 33 11 11 11 33 11 11 11 33 11 11 11 33 }
    0: { 26 00 00 63 { 13 24 35 6C AC BD EF 58 13 24 35 6C AC BD EF 58 }
    0: { 26 00 00 06 { 10 10 10 30 10 10 10 30 10 10 10 30 10 10 10 30 }
    0: { 26 00 00 07 { 1A 2B 3C 00 4D 5E 6F 00 1A 2B 3C 00 4D 5E 6F 00 }
    0: { 26 00 00 67 { DB A5 45 00 FD E3 62 00 DB A5 45 00 FD E3 62 00 }
    #MINSK TV 53E
    #0: { 26 00 00 01 { 10 09 19 32 36 24 62 BC 10 09 19 32 36 24 62 BC }
    #ENTV 22W
    #0: { 26 00 00 04 { 11 00 00 00 00 00 00 00 11 00 00 00 00 00 00 00 }
    #TV7 INDO 108E
    #0: { 26 00 00 04 { 44 C4 DE 00 7B 94 32 00 44 C4 DE 00 7B 94 32 00 }
    Acum despre fisierul cwshare.cfg :
    in linia M:
    va trebui sa introduci numele taudyndns ( sau adresa de Internet IP ) apoi parola ta din 8 caractere in format HEX ( adica: cifre 0-9 si litere A-F ).
    * Important parola ta trebuie sa fie unica, deci sa nu se mai regaseasca in alta linie D. Nu faceti confuzie intre aceasta parola si parola dyndns , dreambox, sau router.
    * Prin dyndns iti vei asigna numelui tau adresa de internet IP, asfel incit daca IP-ul tau internet se schimba vei actualiza dyndns-ul cu noul IP.
    in linia D:
    vei introduce detaliile partenerului de share: nume dyndns, portul tau UDP, portul lui UDP, parola lui si parametrii de share.
    * Portul tau UDP va trebui sa fie directionat catre IP-ul intern al dreambox-ului;
    pentru aceasta va trebui sa folosesti Router si sa-l configurezi ca pachetele UDP care ajung pe portul dorit ( yyyy ) catre IP-ul tau de internet
    sa fie directionate catre acelasi port UDP ( yyyy ) spre IP-ul local al dreambox-ului.
    Cum sa construiesti linia ta D sa o poti da altor parteneri:
    D: { numele_tau_dydns_sau_ip { xxxx yyyy { parola_ta { local_card_dist virtual_card_dist }}}}
    in xxxx partenerul tau de share va introduce portul lui, las-o necompletata, ca si xxxx.
    yyyy - este portul tau UDP.
    parola_ta = parola din linia M.
    local_card_dist = A5 aceasta este distanta la care vrei ca sa fie vizibil cardul tau local, A este pentru cartele speciale NDS, de ex: SKY UK/IT.
    virtual_card_dist = A5 aceasta este distanta la care vrei sa fie vizibile cardurile tele virtuale care iti vin de la parteneri, A este pentru cartele speciale NDS, de ex: SKY UK/IT.
    * Atentie sa nu confunzi linia ta D care o dai prietenilor tai cu liniile tale D din cwshare.cfg
    * Atentie sa nu faci publice liniile tele D&M sau liniile D din cwshare
    # start cwshare.cfg config file
    # allow maximum 06 share level for recieved card data
    I: { 06 }
    # 01 repeat EMM's
    # 00 consider every EMM only once
    # 01 restart pid on overflow
    # 1* reset ENX on every channel change
    # *1 check/reset ENX freezes on FTA
    # *2 check/reset ENX freezes on PayTV
    # *3 check/reset ENX freezes on FTA and PayTV
    # 00 write nothing in atack.txt
    # 01 write into atack.txt: password is wrong
    # 02 write into atack.txt: ID unknown
    # 04 write into atack.txt: IP is wrong
    # 08 write into atack.txt: port is worng
    # 10 write into atack.txt: share.stat
    # 20 create online.log for online/offline logging
    # 3F write everything. (combine bits for other combinations)
    # 4000 send ecm again after 4 Seconds if no reply.
    # 6000 resync decode after 6 Seconds if net decode failed
    N: { 00 01 03 1F 4000 6000 }
    # Send ECM's at maximum 5 cards (please use this as default)
    X: { 05 }
    # Send ECM's in any case to these card ID's, even they are more then X:
    # some examples ...
    #G: { 17020000 1234 }
    #G: { 0B000000 ABCD }
    #G: { 05021510 AB34 }
    #G: { 0D03A000 A234 }
    # For W: please read the cwshare.txt, here only some examples
    # use card 1 only for the following pids
    #W: { 01 02 02 } 1022 100A 100B 102B 1009 101D 1029 1014 1011 101B
    # don't use card 2 for the following pids
    #W: { 02 03 03 } 1008 1016
    # S: is the same as W:, just using the SID instead of the ECMPID
    # cwshare.cfg --- dbox1 --- Internet und Lokales Netzt
    # password
    M: { mydbox2.homeip.net { AA242456 }}
    # Internet Friends port range password cod
    D: { friend1.homeip.net { 8010 8010 { B142AB11 { 5 5 }}}}
    D: { friend2.homelinux.net { 8010 8010 { 81BFF901 { 5 5 }}}}
    # other local boxes
    D: { 192.168.0.51 { 8020 8020 { AB333441 { 5 5 }}}}
    D: { 192.168.0.52 { 8020 8020 { BA334B24 { 5 5 }}}}
    # end cwshare.cfg config file
    G-Box Center este un utilitar care iti afiseaza informatii despre partenerii de share si cartelele virtuale
    Fereastra cu status-ul liniilor D, ver gbox, adresa IP... selecteaza o linie si apasa OK pentru a avea mai multe informatii
    Aici poti vedea cite cartele iti vin si de la ce distanta, teoretic distanta mai mica inseamna o viteza de raspuns mai buna
    Daca o cartela are Level 0 nu va mai fi redistribuita mai departe, cartelele cu Level 1 vor fi redistribuite o singura data, Level 2 de doua ori pina vor ajunge la level 0... etc
    Aici este afisat ce provideri pot fi accesati si cite cartele sunt in retea pentru fiecare provider
    Cum sa instalezi manual G-Box Center:
    copiaza egboxcenterd in /var/bin si seteaza atributul 755
    copiaza urmatoarele fisiere in /var/tuxbox/plugins
    egboxcenter.cfg
    egboxcenter.so -seteaza atributul 755
    Apoi mergi in Blue Panel - Plugins si selecteaza G-Box Center pentru a-l porni
    Tips
    * Daca vei avea atacuri de genul bad port o cauza poate fi faptul ca folosesti v 2.20-2.25 si primesti >1024 carduri. Foloseste PC log-er pentru a verifica aceasta problema.
    Pentru a corecta eroarea ai doua optiuni:
    instaleaza gbox v 2.1b sau
    coboara valoarea parametrului I la 04 sau 03 astfel I: { 03 } si verifica parametrul X sa nu fie prea mare; valoarea narmala este X: { 05 }
    * Daca in linia ta M vei introduce adresa ta sub forma de IP atunci nu poti avea in liniile D nume cu dyndns, doar IP-uri.
    * Aici ai lista mea ident & ignore.
    verifica cit de multe catele virtuale ai inainte si dupa ce instalezi ignore-ul; aceasta lista va ignora cardurile vechi sau false din retea.
    download ident & ignore list
    Instaleaza in dir: /var/keys si reporneste gbox-ul.
    Multumiri speciale lui;
    Alextm
    pentru ca ne-a pus la dispozitie acest link;
    http://www.phones-direct.ro/public/d.../gboxhelp.html
    de unde am extras materialul de mai sus si nu in ultimul rand multumiri autorului;L_DM500s pe care din pacate nu am avut posibilitatea de a il contacta pentru a avea acordul publicarii acestui material,sper ca va intelege ca materialul acesta este de un real folos intregii lumi satelitare,inca o data multumiri!
    Super Member
    11 Feb 2007
    e unul iti multumesc;am mai invatat ceva mai mult decat stiam eu.si felicitari!!!
    Quote Originally Posted by sergiu View Post
    Multumesc,dar nu am facut mare lucru decat sa postez un material facut de altii in speranta ca va ajuta pe toti membri acestui forum care utilizeaza receivere cu linux printre care si eu.
    30 Nov 2007
    on the edge
    Thumbs up Re: HOW TO gbox in Dreambox
    Perfect trebuia pus si aici oricum e de mare ajutor pentru toti utilizatorii!!!
    Default scripturi GBOX.
    pagina realizata de L_DM500s.
    Aici vei invata despre scripturi GBOX
    Ce am facut pentru a imbunatati gbox-ul ptr mine:
    Am realizat citeva script-uri care imi permit sa selectez distanta de unde gbox-ul primeste cartelele
    aceasta poate fi util daca ai citeva servere bune la distanta mica dar si alte citeva cartele interesante la distanta mare si pe care vei dori sa le folosesti din cind in cind.
    Poti folosi Auto-Cam pentru a automatiza procesul si a selecta automat scriptul corect dependent de distanta cardului ptr operator
    Idea este sa ai citeva fisiere cwshare_cfg configurate cu diferite linii I ( si X daca este necesar ):
    Cu un text editor copy/paste si salveaza fisierul cu numele corect.
    Copiaza scripturile in /var/script si seteaza atributul 755.
    Copiaza toate fisierele cwshare in dir keys.
    Reporneste DM-ul si apoi in Blue Panel vei putea vedea toate scripturile.
    Am folosit 3 fisiere de configurare aproape identice, exceptie este parametrul de distanta I: { 0N }
    cwsharb2.cfg are I: { 02 }
    cwsharb3.cfg are I: { 03 }
    cwsharb4.cfg are I: { 04 }
    Atentie fisierul meu gbox este redenumit in
    gbox_21b deoarece foloesc si ver. gbox_225 cu alt script.
    daca vei dori sa folosesti ambele versiuni de gbox: 2.1b &2.25 este necesara o versiune modificata a lui gbox_21b.
    Atentie la linia rosie, aceasta linie va copia cwshare-ul corespunzator si va realiza schimbarea.
    Acesa este scriptul ptr Gbox21b distanta 2.
    file: gbox_21b2_cam.sh
    CAMNAME="Gbox21b dist2"
    USERNAME=
    ZAPTIME=6
    CAMID=002
    DVBSET=1
    INFOFILE="ecm.info"
    remove_tmp ()
    # This method starts cardserver_6.1 > CS2Gbox > Gbox (That order)
    start_cam ()
    cp -f /var/keys/cwsharb2.cfg /var/keys/cwshare.cfg
    /var/bin/gbox_21b &
    # This method stops newcs cs2gbox and gbox and then calles the tmp cleanup method
    stop_cam ()
    touch /tmp/gbox_21b.kill
    /bin/prockill gbox_21b
    remove_tmp
    case "$1" in
    start)
    start_cam
    stop)
    stop_cam
    restart)
    stop_cam
    start_cam
    "$0" stop
    exit 1
    esac
    exit 0
    Acesa este scriptul ptr Gbox21b distanta 3:
    file: gbox_21b3_cam.sh
    USERNAME=
    ZAPTIME=6
    CAMID=002
    DVBSET=1
    INFOFILE="ecm.info"
    remove_tmp ()
    start_cam ()
    cp -f /var/keys/cwsharb3.cfg /var/keys/cwshare.cfg
    /var/bin/gbox_21b &
    stop_cam ()
    remove_tmp
    case "$1" in
    start)
    start_cam
    stop)
    stop_cam
    restart)
    stop_cam
    start_cam
    "$0" stop
    exit 1
    esac
    exit 0
    Acesa este scriptul ptr Gbox21b distanta 4:
    file: gbox_21b4_cam.sh
    USERNAME=
    ZAPTIME=6
    CAMID=002
    DVBSET=1
    INFOFILE="ecm.info"
    remove_tmp ()
    start_cam ()
    cp -f /var/keys/cwsharb4.cfg /var/keys/cwshare.cfg
    /var/bin/gbox_21b &
    stop_cam ()
    remove_tmp
    case "$1" in
    start)
    start_cam
    stop)
    stop_cam
    restart)
    stop_cam
    start_cam
    "$0" stop
    exit 1
    esac
    exit 0
    Am realizat o alta versiune de scripturi.
    Pentru a folosi aceasta versiune inlocuieste in scripturile anterioare linia rosie cu liniile noi.
    In aceasta noua versiune vei avea doar un singur fisier cwshare.cfg si parametrul I si X va fi inlocuit in functie de datele din fiecare script.
    Aceasta este mult mai usor deoarece nu va trebui sa modifici fiecare fiser cfg dupa o mica schimbare.
    Acesa este scriptul ptr Gbox21b distanta 2 -
    sed -e "s/I: { 0.*/I: { 02 }/" /var/keys/cwshare.cfg > /var/keys/cwshartmp.cfg
    sed -e "s/X: { 0.*/X: { 05 }/" /var/keys/cwshartmp.cfg > /var/keys/cwshare.cfg
    Acesa este scriptul ptr Gbox21b distanta 3 -
    sed -e "s/I: { 0.*/I: { 03 }/" /var/keys/cwshare.cfg > /var/keys/cwshartmp.cfg
    Acesa este scriptul ptr Gbox21b distanta 4 -
    sed -e "s/I: { 0.*/I: { 04 }/" /var/keys/cwshare.cfg > /var/keys/cwshartmp.cfg
    ~ multumim autorilor care au realizat gbox sw pentru efort ~
    Member Addicted Member
    11 Feb 2007
    Șoseaua Kiseleff nr. 10
    Un tutorial interesant ptr acei care vor sa vada filmele de pe pc pe tv prin dreambox: http://www.dreambox.it/faq_ENG_divx_...vlc_client.htm
    Am pus IP static,sa speram ca asa voi putea porni Gbox-ul mai incerc inca o data duminica.
    16 Sep 2007
    Interesant ,te-a costat ceva acest ip fix? De unde ai net?
    Quote Originally Posted by gelu_dh View Post
    Nu costa nimic,doar 2E la RTC
    16 Sep 2007
    Da asa am si eu credeam ca ai net din alta parte.La mine a durat 20 ore cca pana l-am obtinut.Am inteles ca alti operatori nu ofera ip fix,o fi adevarat?
    38 Post(s)
    Cool Re: HOW TO gbox in Dreambox
    Daca faci un cont la no-ip sau dyndns (acesta din urma cu mari probleme) nu ai nici o treaba cu IP-ul ca e dynamic.Gbox trebuie sa porneasca.Deci,nu asta e problema ta.
    12 Aug 2007
    Care este limita maxima de peers si cartele la gbox 2.1 B ? Sa stiu cand sa ma apuc de facut curatenie prin cwshare.
    O zi frumoasa! Snow's Avatar
    250 insa nu-ti recomanda atatia. o sa-ti mearga prost. eu ajunsesem la 160 si se misca foarte prost, de cand stau in jurul a o 100, totul e perfect. totul e sa-ti propui un numar de carduri ptr fiecare pachet (ex: max=7 carduri) si sa verifici sa mentii aceasta suma.
    numarul cardurilor in varianta 2.1b fara patch ajung la 1024 (25), varianta cu patch permite mai multe. insa, daca ai un ignore list foarte bun si la zi, ai sa vezi ca stai undeva pe la 600 de carduri.
    pe langa asta conteaza cum iti setezi si liniile x si i
