Thanks Thanks:  3
Likes Likes:  2
Page 1 of 3 123 LastLast
Results 1 to 15 of 35
Thread: Dm500 hd clona
    Super Member lucrad's Avatar
    02 Aug 2007
    Default Dm500 hd clona
    Postez imaginile ...........si specificatiile tehnice.
    alta imagine
    si asta
    Uploaded with ImageShack.us
    http://img859.imageshack.us/img859/5531/500hd.jpg
    http://img64.imageshack.us/img64/5761/500hd1.jpg
    http://img845.imageshack.us/i/500hd2.jpg/
    dreambox 500HD
    Description:
    400 MHz processor, the Dreambox DM 500 HD supports the Linux TV API
    Have a look to HighDefinition TV on your Dreambox
    10/100MBit compatible Ethernet Interface
    HDMI connector
    eSATA
    Technical Features
    400 MHz MIPS Processor
    Linux Operating System
    2 LED status
    MPEG-2 / H.264 Hardware decoding
    Tuner: DVB-S2
    1 x Smartcard-Reader (Dreamcrypt CA)
    eSATA connector
    Mini USB for Service and software update
    10/100Mbit Ethernet Interface
    1 x Scart (RGB, FBAS, YUV or S-Video)
    HDMI
    analog modem
    S/PDIF Interface for digital bit stream out (AC-3)
    64 MByte Flash, 256 MByte RAM
    unlimited channel lists for TV/Radio
    channel-change time < 1 second
    automatic service scan
    directly bouquet-lists
    EPG (electronic program guide)
    multiple LNB-Switching control (supports DiSEqC)
    OSD in many languages and skin-support
    Videotext Decoder
    external 12V power supply
    DreamBox DM 500 HD technical data
    DBS-Tuner, DVB-S2:
    Frequency Range 950 .... 2150 MHz
    Demodulation DVB-S (QPSK); DVB-S2 (8PSK,QPSK)
    Symbol rate DVB-S: 2 ... 45 Mbaud/s, SCPC/ MCPC
    DVB-S2: 10 ? 31 Mbaud/s (8PSK) , 10 ?30 Mbaud/s (QPSK)
    Video decoder:
    Video Compression MPEG-2 and MPEG-1 compatible, H.246
    Video Formats 4:3 / 16:9
    Letterbox for 4:3 TV-Device
    Audio decoder:
    Audiokompression MPEG-1 & MPEG-2 Layer I and II, MP3
    Audio Mode Dual (main/sub), Stereo
    Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
    Output analog:
    Output Level L/R 0,5 Vss on 600 Ohm
    THD > 60 dB (1 kHz)
    Crosstalk < -65 dB
    Output digital:
    Output Level 0,5 Vss on 75 Ohm
    Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz
    S/PDIF-Output optical, Toslink
    Ausgang Video:
    Ausgangspegel FBAS 1 Vss +/- 0.3 dB an 75 Ohm
    Video parameter:
    Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm
    Teletext filter in conformity with ETS 300 472 Standard
    TV-Scart:
    Output: FBAS, YUV, RGB, S-Video
    MiniUSB service connector
    Function: Firmware update
    Ethernet:
    10/100 MBit compatible interface
    Analoge modem:
    analoge modem for Internet connection
    LNB power and polarisation per tuner:
    LNB Current 500mA max.; short-circuit-protected
    LNB Voltage vertical < 14V no load, > 11,5V at 400mA
    LNB Voltage horizontal < 20V no load, > 17,3V at 400mA
    Count of active satellite position:
    DiSEqC 1.0/1.1/1.2 and USALS - Rotor Control
    Power consumption:
    < 12W at 12V in operation
    < 1W in standby
    External PSU
    Input:
    110-240V AC / 50-60Hz / 0,6A
    Output:
    12V = / 3,0A
    02 Aug 2007
    Are
    ss83
    ferrari sim card
    si merge cu gemini 5.1 inclusiv
    23 Oct 2009
    Default hmm
    un pret ceva?un link....merge pus in bucatarie ...
    in bucatarie merge dar nu face si cartofi prajiti
    cam 150-170 Euro
    7 Post(s)
    ultima clona de care stiam la 500hd nu stie E2
    23 Apr 2007
    P3X-888
    era clona doar la aspect ... dreamer 500hd se numeste acea asa zisa clona
    02 Aug 2007
    Si nici procesorul nu era de 400 si avea si altele diferite.......asa-i ?
    Member Addicted Member
    11 Feb 2007
    Șoseaua Kiseleff nr. 10
    Quote Originally Posted by stargate View Post
    E doar o asemanare de nume. Nu e clona de dm500HD. E cineva care vinde asa ceva la shop. E doar o strutocamila. Plus ca nu merge decat cu firmware facut special de chinez ptr. el. Dreamer nu merita atentie.
    Iar legat de clona de dm500HD. Daca are acelasi (asa pare) hardware merita banii.
    23 Apr 2007
    P3X-888
    pai si eu cu ce am gresit in ce am spus ?
    11 Feb 2007
    Pai nu e clona de dm500 HD. Ce a postat lucrad pare a fi prima clona de dm500 HD. Adica identica si sa functioneze cu imagini pentru dm500 HD.
    23 Apr 2007
    P3X-888
    asa am zis si eu ... cred ca m-ai citat din greseala
    15 Feb 2007
    Pretul unui DM500 HD clona in UK este de 184 lire, pe saitul unui magazin . La noi cu toate taxele incluse posibil sa ajunga la 220-240 dolari, posibil sub acest pret.
    Cine are bani de dat pe o clona inca netestata e binevenit.
    38 Post(s)
    Dreamer 500hd nu este clona DM 500HD, este doar o asemanare:
    FBOX-500HDPVR
    DVB-S2/S, FTA
    HDMI port
    1* Smartcard Reader
    USB(PVR)
    Enternet, Linux System
    CPU: NXP
    Playback TS,AVI,DivX,XviD,VOB, etc
    38 Post(s)
    DM 500HD clona :
    Features: * 10/100MBit compatible Ethernet Interface * HDMI connector * eSATA for recording Technical Features. * 400 MHz MIPS Processor * Linux Operating System * 2 LED status * MPEG-2 / H.264 Hardware decoding * Tuner: DVB-S2 * 1 x Smartcard-Reader (Dreamcrypt CA) * eSATA connector * Mini USB for Service and software update * 10/100Mbit Ethernet Interface * 1 x Scart (RGB, FBAS, YUV or S-Video) * HDMI * analog modem * S/PDIF Interface for digital bit stream out (AC-3) * 64 MByte Flash, 256 MByte RAM * unlimited channel lists for TV/Radio * channel-change time 60 dB (1 kHz) Crosstalk ge horizontal 17,3V at 400mA Count of active satellite position: DiSEqC 1.0/1.1/1.2 and USALS - Rotor Control Power consumption: ysical specification: Ambient Temperature +15°C...+35°C Humidity
    ---------- Post added at 13:00 ---------- Previous post was at 12:48 ----------
    Se vad diferentele intre cele doua la procesoare ( NXP si MIPS ) si la iesirile de la tuner.
