Thanks Thanks:  4
Likes Likes:  13
Page 1 of 3 123 LastLast
Results 1 to 15 of 41
Thread: cacheex
    Default cacheex
    A aparut o optiune noua incepand cu versiunea #6039
    oscam.user
    cacheex
    parameter is optional
    NEW svn6039:11/26/2011
    cacheex = 0|1
    1  =  enable cache exchange
    0  =  default
    cache exchange must be enabled on local and remote oscam reader!
    oscam.server
    cacheex
    cacheex = 0|1
    0  =  default
    cache exchange, see also on oscam.user!
    Ma gandesc ca ar permite schimbul de cache intre 2 oscam...
    da interesantnu e rea ideea,insa eu momentan raman pe 6020 sau 5983,astea noi iara sant prostii pe banda rulanta,doar aceasta ultima optiune ce reprezinta interes
    Standard RSP member Znuff's Avatar
    14 Apr 2010
    La mare
    Am pus cache exchange intre 2 servere. Nu e mare chestie, din ~200.000 ECM-uri face hit la aproape ~2000, deci 1% cache hits.
    Nu e cine stie ce, dar mai bine decat deloc. Presupun ca ar merge si mai bine daca as avea peste 100 de useri pe fiecare server.
    de cate ori ai dat reshare?
    eu daca dau reshare o data adica doar clientilor din server nu face mare lucru si merge ok dar daca dau reshare de 2 ori sa te ti ce bataie e pe cache asta indiferent de vers astea noi cu functia cache sau cele vechi
    14 Apr 2010
    La mare
    mda, am reshare doar 1 hop
    source: trunk/module-cccam.c @ 7981
    Last change on this file since 7981 was 7981, checked in by theparasol, 3 hours ago
    • Fixes for cacheex exchange over CCcam protocol
    * All cache-ex partners need to update to this version *
    If a partner isnt updated yet they will see a cachex 'old format' in their logs
    In your server logs you will see a ignore due to 'wrong format.
    source: trunk/oscam.c @ 7982
    Last change on this file since 7982 was 7982, checked in by corsair, 10 hours ago
    - cacheex-matcher fix
    Se pare ca s-a "copt"
    Doua exemple:
    Nu-i mai place localu' de loc!
    29 Mar 2009
    Austria - TM
    La ce versiune ?
    Pune si un config , stiu ca depinde de fiecare server dar na e bine de vazut
    14 Apr 2010
    La mare
    Intre 2 servere, ambele cu multi useri si ambele doar cu CAID-uri 1880, 1802 si 0B02 avea un cache-hit undeva la 60-70%.
    Dupa un restart, inainte de a se stabiliza, o ora, doua, imi statea hit % la 600-700%!! (Un CW primit prin cacheex era refolosit de 6-7 useri de-ai mei in acelasi timp!), dar binenteles asta la orele de varf intre 18:00 si 23:00 ^^
    Acum am mai adaugat niste parteneri de sharing doar cu cache (cache-ex mode 3), si primesc mult mai mult cache, inclusiv pt. CAID-uri care nu sunt folosite de userii mei si procentul a scazut drastic (gen 2-3%). Dar totusi, daca numaram CW-urile cu hit, sunt destul de multe.
    Dupa un restart pe la ~4am:
    Total Push Total Got Total Hit Cache Size
    2535919 1088998 16749 (1.54%) 4238
    Da, procentul e infim de mic, dar daca stam putin sa ne gandim, in mai putin de 3 ore, cardurile mele locale au fost "scutite" de 16749 de cereri (in conditiile in care am primit peste 1 milion de CW-uri).
    Ce rezulta din asta?
    Albastrul sunt CW-uri servite din cache (cache-ul local oscam + cache-ex), verde e procentul servit direct de pe card! Se vede pe grafic la ce ora am dat restart
    ---------- Post added at 07:29 ---------- Previous post was at 07:15 ----------
    Quote Originally Posted by Diablo1 View Post
    La ce versiune ?
    Ce config? N-ai nevoie de nimic special.
    Tre' sa te decizi intai ce metoda de "schimb" vrei. Cache Ex mode 1, 2 sau 3. "3" e folosit pt. parteneri cu care faci doar schimb de cache.
    Nu prea inteleg mode 1, eu in general folosesc mode 2 cu partenerii cu care fac schimb de linii "normal", nu numai cache-ex, si 3 cu cei care fac doar schimb de cache.
    Tu ii dai un user lu X, X iti da tie un user pe care-l adaugi ca reader - protocol cccam, el te adauga, la fel, ca un reader cu protocol cccam.
    Va decideti in ce fel faceti "schimbul", puneti in ambele parti acelasi mod (2 sau 3), si gata. Nu trebuie sa mai faci nimic.
    Totusi nu recomand modurile 2 si 3 pe receptoare slabute, in special cu cei care au cache-uri masive pentru ca s-ar putea sa va treziti ca va ia OSCam ~50MB ram.
    In modurile 2 si 3, tot cache-ul care-l are userul X va ajunge si voua, indiferent daca a cerut un user de-al vostru sau nu asa ceva (si invers, binenteles).
    Presupun ca modul "1" e "la cerere"
    Na, uite, sa nu zici ca sunt rau, pun si un "config"
    OSCam User A:
    [reader]
    label = cache-userul_b
    protocol = cccam
    device = ip.user_b,port.user_b
    user = user_a
    password = parola
    cacheex                       = 2
    group                         = 1
    [account]
    user = user_b
    pwd = parola
    group = 1
    cacheex = 2
    OSCam User B:
    [reader]
    label = cache-userul_a
    protocol = cccam
    device = ip.user_a,port.user_b
    user = user_b
    password = parola
    cacheex                       = 2
    group                         = 1
    [account]
    user = user_a
    pwd = parola
    group = 1
    cacheex = 2
    OSCam Bootstrap: Un template modern pentru OSCam ? Builduri la zi de OSCam
    Daca cel care da cache mod 3 pune la user CAID iti vine doar respectivul caid indiferent ce setezi tu la readerul ex 3.
    14 Apr 2010
    La mare
    Uite asta nu stiam/incercasem.
    O sa probez maine sau poimaine sa vad cum e
    29 Mar 2009
    Austria - TM
    Bineinteles , nu trebuie lasat tot ce vine , pentru ca ar trebui sa ai un server cu trafic foarte mare
    La setari mai este destule de facut
    [global] disablelog = 1
    logfile = /tmp/oscam.log usrfileflag = 1
    clienttimeout = 4000
    fallbacktimeout = 1700
    clientmaxidle = 200
    bindwait = 40
    nice = 0
    serialreadertimeout = 1600
    maxlogsize = 8096
    waitforcards = 0
    waitforcards_extra_delay = 300
    preferlocalcards = 1
    readerrestartseconds = 3600
    dropdups = 1
    cacheexwaittime = 0
    block_same_ip = 0
    block_same_name = 0
    cwlogdir = /var/log/oscam/CW.log
    emmlogdir = /var/log/oscam/EMM.log
    lb_mode = 1
    lb_save = 5000
    lb_nfb_readers = 2
    lb_max_ecmcount = 4000
    lb_retrylimit = 2400
    lb_stat_cleanup = 12
    lb_max_readers = 10
    lb_auto_betatunnel = 0
    #Betatunnel verursacht unter großer Last auch große Probleme
    lb_savepath = /tmp/stat
    lb_retrylimits = 09:350
    failbantime = 1440
    suppresscmd08 = 1
    cwcycle_check_caid = 1702,1722,1830,1880,1802,.......................................................
    maxcyclelist = 4000
    keepcycletime = 15
    onbadcycle = 2
    max_cache_time = 6
    #max_cache_time trebuie 2 Sekunden mai mare decät
    clienttimeout max_cache_count = 5000
    [cccam]
    port = 1234
    [csp] port = 12345
    wait_time = 1702:700,1722:400,18:600
    #Diese Werte sind nur als Orientierung gedacht.
    [reader]
    label = name_frei_aussuchen
    protocol = camd35
    device = beispiel.dns.com,14500
    user = beispiel_user
    password = beispiel_pass
    inactivitytimeout = 0
    cacheex = 3
    reconnecttimeout = 1800
    #acest reconnecttimeout este important pentru a nu te conecta de 100 ori
    cacheex = 3
    cacheex_maxhop = 2
    group = 1,3,4,5,6,7,8,9,10,11
    dropbadcws = 1
    audisabled = 1
    oder
    [reader]
    protocol = cccam
    device = beispiel.dns.com,14503
    user = exemplu_user
    password = exemplu_pass
    cacheex = 3
    group = 15
    dropbadcws = 1
    cccversion = 2.3.0
    cccmaxhops = 0
    ccckeepalive = 1
    cccreconnect = 7000
    audisabled = 1
    oscam.user
    [account]
    user = user_cache
    pwd = user_pass
    uniq = 3
    cacheex = 3
    cacheex_maxhop = 2
    #sprecht mit eurem share partner, wieviele instanzen er nutzt - bei 2 instanzen muss da eine 2 hin
    cccmaxhops = -1
    #dies dient zum verbergen eurer lokalen karten - euer partner kriegt nur needinit angezeigt, erhält aber euren vollen cache
    Astea sänt doar exemple si trebuie pentru fiecare server modificate in funcie de necesitate
    Daca nu ai o setare adecvatä poate sa urce timpul la reader de te sperii
    14 Apr 2010
    La mare
    Personal nu ma deranjeaza traficul mare. Am fibra, am 2 x Dual-Core Xeon, am 6GB RAM, sa tot vina! Si-asa ca sta aproape nefolosita masina aia.
    Dar nu, nu trebuie neaparat sa faci restul de setari cum zici tu acolo. Se pare ca mai toti pasionatii de sharing pica in "plasa" asta a umblarea la cat mai multe setari, desi nu le sunt clare ce fac (nu ma refer la cineva in mod special, ci asa, in general).
    Poti sa lasi majoritatea pe default in 99% din cazuri. Abia cand observi probleme (timpi mari de raspuns, load avg. mare pe receptor, utilizarea memorie excesive etc.) ar trebui sa arunci o privire la parametrii "specializati".
    De exemplu tu ai postat acolo niste linii cu legatura la modulul CSP. Setari complet inutile in cazul in care esti interesat doar de Cache-Ex, pt. ca CSP nu are nici o legatura cu Cache-Ex (care se realizeaza numai intre oscam-uri), ci mai degraba cu Cache-ul in general.
    Alte exemple: reconnecttimeout, care e o setare "generica", fara legatura directa cu cache-ex, la fel si cccmaxhops care nu are efect pentru un schimb de cache-ex la mod 3, ci afecteaza actualul protocol cccam.
    max_cache_time este singura setare cu referire directa la cache-ex (de fapt la cache), pt. ca dicteaza cate secunde ramane CW-ul ala in cache, dupa care expira. 15 secunde e valoarea implicita, care este o valoare destul de "bun simt". In caz ca observi ca "ti se umple" cache-ul (vezi valoarea max_cache_count) repede si nu vrei sa maresti capacitatea (pt. ca pe un stb ai memorie limitata), poti sa scazi timpul pt. a expira mai repede si a face loc altor CW-uri mai "proaspete". Eu de exemplu em 15s cu 5000, iar momentan am ~2200 de CW-uri in cache.
    Clarificare: Modulul CSP din OSCam are rolul doar de a da cache-ul tau mai departe unor servere CSP.
    EDIT2: Mai e o chestie care mi se pare complet aiurea. Ai postat un reconnecttimeout de 1800 secunde! Asta inseamna o incercare de reconectare la 30 de minute! Extrem de mare si nu mi se pare practic. O valoare de 60-90 e mai sensibila.
    30 Mar 2007
    Setarile ce le folosesc eu pentru cacheex_3 la cardul de focussat :
    oscam.server
    [reader]
    label                         = cacheex_3
    protocol                      = cccam
    device                        = server,12000
    user                          = user
    password                      = pass
    inactivitytimeout             = 30
    cacheex                       = 3
    cacheex_maxhop                = 1
    cacheex_ecm_filter            = 0B02
    group                         = 10
    dropbadcws                    = 1
    cccversion                    = 2.0.11
    cccmaxhops                    = 0
    ccckeepalive                  = 1
    cccreshare                    = 0
    audisabled                    = 1
    oscam.user
    [account]
    user                          = client
    pwd                           = pass
    uniq                          = 2
    group                         = 10
    cacheex                       = 3
    cacheex_maxhop                = 1
    cccmaxhops                    = -1
    cccreshare                    = 0
