Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
Thread: Focus sau Dolce cu Phoenix via USB -RS232
    Standard RSP member c0c010's Avatar
    03 Feb 2008
    @bobbob schimba frecventele la reader:
    mhz = 600
    cardmhz = 600
    testat acum pe doua imagini PKT si BPanther's Neutrino si ruleaza f.bine..
    Succes.
    @coco am schimbat si frecventa , tot nu merge
    @f11 uite raportul , nu poate sa deschida /dev/ttyUSB0 , adaptorul HL 340 functioneaza , am pus o imagine cu el prin nullmodem in kathi si a functionat , phoenixul cred ca merge este nou , led-urile sunt aprinse , cardul focus l-am verificat in receptorul focus unde a fost activat .
    2011/12/17 11:01:13 0 s >> OSCam << cardserver started, version 1.20-uns table_by_EasyBuild_svn, build #6034 (sh4-linux)
    2011/12/17 11:01:13 0 s version=1.20-unstable_by_EasyBuild_svn, build #60 34, system=sh4-linux-
    2011/12/17 11:01:13 0 s client max. idle=120 sec, debug level=0
    2011/12/17 11:01:13 0 s max. logsize=10 Kb, loghistorysize=4096 bytes
    2011/12/17 11:01:13 0 s client timeout=5000 ms, fallback timeout=2500 ms, cache delay=0 ms
    2011/12/17 11:01:13 0 s services reloaded: 0 services freed, 12 services loaded, rejected 0
    2011/12/17 11:01:13 0 s userdb reloaded: 5 accounts loaded, 0 expired, 0 disabled
    2011/12/17 11:01:13 0 s signal handling initialized (type=sysv)
    2011/12/17 11:01:13 0 s 1632 service-id's loaded in 88ms
    2011/12/17 11:01:13 0 s can't open file "/var/keys/oscam.tiers" (err=2 No such file or directory), no tier-id's loaded
    2011/12/17 11:01:13 0 s 3 provid's loaded
    2011/12/17 11:01:13 0 s 5 lengths for caid guessing loaded
    2011/12/17 11:01:13 0 s Starting listener 0
    2011/12/17 11:01:13 0 s newcamd: disabled
    2011/12/17 11:01:13 0 s cccam: Bind request failed, waiting another 119 s econds
    2011/12/17 11:01:14 0 s cccam: Bind request failed, waiting another 118 s econds
    2011/12/17 11:01:15 0 s cccam: Bind request failed, waiting another 117 s econds
    2011/12/17 11:01:16 0 s cccam: Bind request failed, waiting another 116 seconds
    2011/12/17 11:03:10 0 s cccam: Bind request failed, waiting another 2 seconds
    2011/12/17 11:03:11 0 s cccam: Bind request failed, waiting another 1 seconds
    2011/12/17 11:03:12 0 s cccam: Bind request failed, giving up
    2011/12/17 11:03:12 0 s Starting listener 0
    2011/12/17 11:03:12 0 s pandora: disabled
    2011/12/17 11:03:12 0 s http thread started
    2011/12/17 11:03:12 0 s reader check thread started
    2011/12/17 11:03:12 0 s check thread started
    2011/12/17 11:03:12 0 s creating thread for device /dev/ttyUSB0
    2011/12/17 11:03:12 0 s loadbalancer: can't read from file /tmp/.oscam/stat
    2011/12/17 11:03:12 0 s waiting for local card init
    2011/12/17 11:03:12 530DA0 h HTTP Server couldn't bind on port 84 (errno=98 Address already in use). Not starting HTTP!
    2011/12/17 11:03:12 52F640 r ERROR opening device /dev/ttyUSB0
    2011/12/17 11:03:12 52F640 r Cannot open device: /dev/ttyUSB0
    2011/12/17 11:04:12 52F640 r ERROR opening device /dev/ttyUSB0
    2011/12/17 11:04:12 52F640 r Cannot open device: /dev/ttyUSB0
    2011/12/17 11:05:12 52F640 r ERROR opening device /dev/ttyUSB0
    2011/12/17 11:05:12 52F640 r Cannot open device: /dev/ttyUSB0
    2011/12/17 11:06:12 52F640 r ERROR opening device /dev/ttyUSB0
    2011/12/17 11:06:12 52F640 r Cannot open device: /dev/ttyUSB0
    2011/12/17 11:07:12 52F640 r ERROR opening device /dev/ttyUSB0
    2011/12/17 11:07:12 52F640 r Cannot open device: /dev/ttyUSB0
    2011/12/17 11:08:13 52F640 r ERROR opening device /dev/ttyUSB0
    2011/12/17 11:08:13 52F640 r Cannot open device: /dev/ttyUSB0
    2011/12/17 11:09:13 52F640 r ERROR opening device /dev/ttyUSB0
    2011/12/17 11:09:13 52F640 r Cannot open device: /dev/ttyUSB0
    2011/12/17 11:10:13 52F640 r ERROR opening device /dev/ttyUSB0
    2011/12/17 11:10:13 52F640 r Cannot open device: /dev/ttyUSB0
    De ce nu poate sa deschida USB-ul ? Acum ceilalti readeri sunt disabled , dar cand sunt activi de ce nu merge sharingul in prezenta reader-ului Focus ?
    95 Post(s)
    Pentru ca e o optiune care tine oscamul pe loc pana initializezi cardul.
    Dezactivezi optiunea si nu mai ai aceasta problema.
    @Zildan , am priceput ....inseamna ca problema este din Phoenix , pe care oscam nu-l deschide, pt. ca nu-l vede in /dev/ttyUSB0 din cauza adaptorului care s-ar putea sa fie incompatibil . Am conectat adaptorul la PC cu O.S. Windows7 si-mi aloca portul COM3 ....sper Kathi sa nu aiba vreo problema in acest sens.
    Nu stiu ce sa fac as cumpara alt card-reader ....CHIAR NU A INSTALAT NIMENI PHOENIX by Geluvis in Kathi ?
    Mai are cineva v'o parere ?
    23 Apr 2007
    P3X-888
    Eu am incercat pe un router topex sa pun un card Focus intr-un phoenix by gelvis cu adaptor serial-usb si in oscam nu deschide din card dar din newcs merge corect ... personal am ajuns la concluzia dupa muuuulte nopti pierdute ca in combinatia de mai sus oscam nu deschide din focus si ca totul este de la oscam care nu stie sa lucreze corect in combinatia oscam + adaptor usb-serial + phoenix by gelvis + focus .
    Deci solutia ar fi sa instalez Newcs si sa ma leg in Oscam ...din panel la Newcs Config mi-au aparut doua fisiere 12001.list si newcs.xml cum le editez pt. kathi si cum pun readerul in oscam ? Adica unde gasesc un exemplu ?
    Alta alternativa ar fi sa cumpar un card-reader . Care este cel mai bun ? multivalent...
    03 Feb 2008
    @bobbob dupa cum am scris in thread anterior am testat phoenix by Geluvis+card focuss+adaptor usb-serial(STLab) pe doua imagini in Katy si se conporta la fel de bine pe amandoua....inclin sa cred ca la tine e problema de la versiunea de oscam pe care o fol...
    oscam pe Katy la mine....1.10rc-svn build #5983...pun si un log:
    >> OSCam << cardserver started at Mon Dec 19 08:41:09 2011
    2011/12/19 8:41:09 295737E0 s >> OSCam << cardserver started, version 1.10rc-svn, build #5983 (sh4-amino-linux)
    2011/12/19 8:41:09 295737E0 s version=1.10rc-svn, build #5983, system=sh4-amino-linux, nice=-1
    2011/12/19 8:41:09 295737E0 s client max. idle=120 sec, debug level=0
    2011/12/19 8:41:09 295737E0 s max. logsize=80 Kb, loghistorysize=4096 bytes
    2011/12/19 8:41:09 295737E0 s client timeout=5000 ms, fallback timeout=1500 ms, cache delay=120 ms
    2011/12/19 8:41:09 295737E0 s services reloaded: 0 services freed, 1 services loaded, rejected 0
    2011/12/19 8:41:09 295737E0 s userdb reloaded: 2 accounts loaded, 0 expired, 0 disabled
    2011/12/19 8:41:09 295737E0 s signal handling initialized (type=sysv)
    2011/12/19 8:41:09 295737E0 s 94 service-id's loaded in 4ms
    2011/12/19 8:41:09 295737E0 s can't open file "/var/keys//oscam.tiers" (err=2 No such file or directory), no tier-id's loaded
    2011/12/19 8:41:09 295737E0 s 880 provid's loaded
    2011/12/19 8:41:09 295737E0 s can't open file "/var/keys//oscam.ird" (errno=2 No such file or directory) irdeto guessing not loaded
    2011/12/19 8:41:09 295737E0 s monitor: initialized (fd=6, port=988)
    2011/12/19 8:41:09 295737E0 s camd33: disabled
    2011/12/19 8:41:09 295737E0 s camd35: disabled
    2011/12/19 8:41:09 295737E0 s cs378x: disabled
    2011/12/19 8:41:09 295737E0 s newcamd: disabled
    2011/12/19 8:41:09 295737E0 s radegast: disabled
    2011/12/19 8:41:09 295737E0 s http thread started
    2011/12/19 8:41:09 295737E0 s creating thread for device /dev/ttyUSB0
    2011/12/19 8:41:09 295737E0 s waiting for local card init
    2011/12/19 8:41:09 2A7634E8 h HTTP Server couldn't bind on port 8888 (errno=98 Address already in use). Not starting HTTP!
    2011/12/19 8:41:09 2AF634E8 r reader thread started (thread=2AF634E8, label=focuss, device=/dev/ttyUSB0, detect=cd, mhz=600, cardmhz=600)
    2011/12/19 8:41:12 2AF634E8 r focuss card detected
    2011/12/19 8:41:16 2AF634E8 r ATR: 3B 24 00 30 42 30 30
    2011/12/19 8:41:17 2AF634E8 r Maximum frequency for this card is formally 5 Mhz, clocking it to 6.00 Mhz
    2011/12/19 8:41:19 2AF634E8 r type: Conax, caid: 0B02, serial: xxxxxxxxxx, hex serial: xxxxxxxx, card: v64
    2011/12/19 8:41:19 2AF634E8 r Providers: 1
    2011/12/19 8:41:19 2AF634E8 r Provider: 1 Provider-Id: 000000
    2011/12/19 8:41:19 2AF634E8 r Provider: 1 SharedAddress: 00000000
    2011/12/19 8:41:19 2AF634E8 r found cardsystem conax
    2011/12/19 8:41:19 2AF634E8 r Package: 1, id: 1010, classes: 017FDF7F, date: 2011/12/01 - 2011/12/31, name: FocusSat
    2011/12/19 8:41:19 2AF634E8 r Package: 2, id: 1010, classes: 017FDF7F, date: 2011/11/01 - 2011/11/30, name: FocusSat
    2011/12/19 8:41:19 2AF634E8 r Package: 3, id: 2010, classes: 01000072, date: 2011/12/01 - 2011/12/31, name: ESS
    2011/12/19 8:41:19 2AF634E8 r Package: 4, id: 2010, classes: 01000072, date: 2011/11/01 - 2011/11/30, name: ESS
    2011/12/19 8:41:19 2AF634E8 r [conax-reader] ready for requests
    2011/12/19 8:41:20 295737E0 s init for all local cards done
    2011/12/19 8:41:20 295737E0 s anti cascading disabled
    2011/12/19 8:41:20 2A7634E8 c plain dvbapi-client granted (dvbapi, au=off)
    2011/12/19 8:41:20 2A7634E8 c dvbapi: 86 entries read from oscam.dvbapi
    2011/12/19 8:41:24 2A7634E8 c dvbapi: [ADD PID 0] CAID: 1815 ECM_PID: 1395 PROVID: 000000
    2011/12/19 8:41:24 2A7634E8 c dvbapi: [ADD PID 1] CAID: 0D02 ECM_PID: 14C1 PROVID: 000000
    2011/12/19 8:41:24 2A7634E8 c dvbapi: [ADD PID 2] CAID: 0B02 ECM_PID: 15E7 PROVID: 000000
    2011/12/19 8:41:24 2A7634E8 c dvbapi: [ADD PID 3] CAID: 0D97 ECM_PID: 1719 PROVID: 000000
    2011/12/19 8:41:24 2A7634E8 c dvbapi: [ADD PID 4] CAID: 0653 ECM_PID: 1844 PROVID: 000000
    2011/12/19 8:41:25 2A7634E8 c dvbapi: Start descrambling PID #2 (CAID: 0B02) 1
    2011/12/19 8:41:25 2A7634E8 c dvbapi (0B02&000000/78C2/4C:E1C4): cache2 (400 ms) by focuss (of 1 avail 1) - Cinemax2
    2011/12/19 8:41:25 2A7634E8 c housekeeping lb stats thread started
    2011/12/19 8:41:33 2A7634E8 c dvbapi (0B02&000000/78C2/4C:71FB): found (240 ms) by focuss (of 1 avail 1) - Cinemax2
    2011/12/19 8:41:43 2A7634E8 c dvbapi (0B02&000000/78C2/4C3F0): found (221 ms) by focuss (of 1 avail 1) - Cinemax2
    Ps. daca te mai intereseaza pot pune si configurile mele...
    23 Apr 2007
    P3X-888
    Chiar te rugam sa pui setarile , eu totusi tind sa cred ca cel mai probabil oscam nu se intelege cu adaptorul serial-usb .
    03 Feb 2008
    Seting Oscam Katy pt. Phoenix by Geluvis + card focussat
    oscam.conf
    [global]
    logfile = /var/log/oscam/oscam.log
    disablelog = 0
    fallbacktimeout = 1500
    cachedelay = 120
    nice = -1
    maxlogsize = 80
    preferlocalcards = 1
    saveinithistory = 1
    lb_mode = 1
    lb_save = 100
    lb_savepath = /var/log/oscam/oscam.stat
    lb_reopen_mode = 1
    lb_auto_betatunnel = 1
    dropdups = 1
    [monitor]
    port = 988
    nocrypt = 127.0.0.1,192.168.x.x-192.168.x.xxx
    aulow = 120
    hideclient_to = 0
    monlevel = 4
    appendchaninfo = 1
    [dvbapi]
    enabled = 1
    boxtype = ufs910
    user = dvbapi
    request_mode = 1
    [webif]
    httpport = 8888
    httpuser = root
    httppwd = oscam
    httprefresh = 5
    httpallowed = 127.0.0.1,192.168.x.x-192.168.x.xxx
    oscam.server
    [reader]
    label = Focuss
    enable = 1
    protocol = mouse
    device = /dev/ttyUSB0
    services = Focussat
    caid = 0B02
    detect = cd
    mhz = 600
    cardmhz = 600
    ident = 0B02:000000
    group = 1
    emmcache = 1,3,2
    lb_weight = 100
    cacheex = 1
    blockemm-unknown = 1
    blockemm-u = 1
    blockemm-s = 1
    blockemm-g = 1
    deprecated = 1
    audisabled = 1
    oscam.services
    [Focussat]
    caid=0B02
    provid=000000
    srvid=0029, 00CB, 00CC, 0B60, 0B77, 03EB, 03ED, 03EE, 03EF, 03F5, 03F6, 03F7, 03F8, 040F, 0407, 040A, 0412, 040B, 040E, 0411, 0410, 040D, 040C, 0648, 0726, 75FB, 106A, 1006, 7603, 7602, 7604, 7664, 76C2, 76C3, 76C4, 76C5, 76C6, 76C7, 76C8, 76C9, 76CA, 76CB, 76CC, 76CD, 76D0, 7725, 7726, 7727, 7728, 7729, 772A, 772B, 772C, 772D, 772E, 772F, 7730, 7731, 7733, 7789, 778A, 778B, 778C, 778D, 778E, 778F, 7790, 7791, 7792, 7793, 7794, 7795, 7797, 7798, 77ED, 77EE, 77F5, 77F6, 77F7, 77F9, 77FA, 7853, 7855, 7856, 7857, 7858, 7860, 785A, 785B, 785D, 785E, 785F, 78B5, 78B8, 78BA, 78BB, 78BC, 78BD, 78BE, 78C2, 78C3, 791F
    oscam.srvid
    0B02:0029 | UPC FocusSat | TLC Romania
    0B02:00CB | UPC FocusSat | Travel Channel
    0B02:00CC | UPC FocusSat | VH1
    0B02:03EB | UPC FocusSat | SportKlub Romania
    0B02:03ED | UPC FocusSat | VH1 Romania
    0B02:03EE | UPC FocusSat | Fishing and Hunting
    0B02:03EF | UPC FocusSat | DoQ
    0B02:03F3 | UPC FocusSat | FILMBOX
    0B02:03F5 | UPC FocusSat | Sky News
    0B02:03F6 | UPC FocusSat | Discov World
    0B02:03F7 | UPC FocusSat | Discov Science
    0B02:03F8 | UPC FocusSat | Discov Tra&Liv
    0B02:0648 | UPC FocusSat | Eurosport 2
    0B02:0726 | UPC FocusSat | Bloomberg
    0B02:0B60 | UPC FocusSat | Al Jazeera English
    0B02:0B77 | UPC FocusSat | ESPN America HD
    0B02:1006 | UPC FocusSat | Discovery HD
    0B02:106A | UPC FocusSat | History HD
    0B02:75FB | UPC FocusSat | Film+
    0B02:7602 | UPC FocusSat | TV2
    0B02:7603 | UPC FocusSat | ATV
    0B02:7604 | UPC FocusSat | Echo TV
    0B02:7664 | UPC FocusSat | Cool
    0B02:7666 | UPC FocusSat | Spektrum Home
    0B02:76C2 | UPC FocusSat | TVR 1
    0B02:76C3 | UPC FocusSat | TVR 2
    0B02:76C4 | UPC FocusSat | TVR Cultural
    0B02:76C5 | UPC FocusSat | Antena 1
    0B02:76C6 | UPC FocusSat | Prima TV RO
    0B02:76C7 | UPC FocusSat | Realitatea TV
    0B02:76C8 | UPC FocusSat | National TV
    0B02:76C9 | UPC FocusSat | Favorit TV
    0B02:76CA | UPC FocusSat | Diva Universal
    0B02:76CB | UPC FocusSat | Romantica RO
    0B02:76CC | UPC FocusSat | MTV Romania
    0B02:76CD | UPC FocusSat | Minimax
    0B02:76D0 | UPC FocusSat | FilmBox Extra1
    0B02:7725 | UPC FocusSat | Pro TV
    0B02:7726 | UPC FocusSat | Pro Cinema
    0B02:7727 | UPC FocusSat | Acasa
    0B02:7728 | UPC FocusSat | Sport.ro
    0B02:7729 | UPC FocusSat | Pro TV International
    0B02:772A | UPC FocusSat | Antena 3
    0B02:772B | UPC FocusSat | Filmbox Basic
    0B02:772C | UPC FocusSat | FilmBox Family
    0B02:772D | UPC FocusSat | Animal Planet RO
    0B02:772E | UPC FocusSat | National Geographic RO
    0B02:772F | UPC FocusSat | RTL Klub
    0B02:7730 | UPC FocusSat | Cartoon Network RO/TCM RO
    0B02:7731 | UPC FocusSat | AXN RO
    0B02:7733 | UPC FocusSat | Etno
    0B02:7789 | UPC FocusSat | B1
    0B02:778A | UPC FocusSat | Euforia Lifestyle
    0B02:778B | UPC FocusSat | N24
    0B02:778C | UPC FocusSat | Sport1 RO
    0B02:778D | UPC FocusSat | m1
    0B02:778E | UPC FocusSat | GSP TV
    0B02:778F | UPC FocusSat | m2
    0B02:7790 | UPC FocusSat | HirTV
    0B02:7791 | UPC FocusSat | Discovery RO
    0B02:7792 | UPC FocusSat | CNN
    0B02:7793 | UPC FocusSat | Antena 2
    0B02:7794 | UPC FocusSat | Reality ROM
    0B02:7795 | UPC FocusSat | Trinitas
    0B02:7797 | UPC FocusSat | HBO RO
    0B02:7798 | UPC FocusSat | VH1 Classic
    0B02:77ED | UPC FocusSat | Extreme Sports Channel
    0B02:77EE | UPC FocusSat | JimJam
    0B02:77F5 | UPC FocusSat | Cinemax
    0B02:77F6 | UPC FocusSat | Boomerang
    0B02:77F7 | UPC FocusSat | Nat Geo Wild
    0B02:77F9 | UPC FocusSat | Nota TV
    0B02:77FA | UPC FocusSat | TV5MONDE
    0B02:7853 | UPC FocusSat | ducktv
    0B02:7855 | UPC FocusSat | Hustler TV
    0B02:7856 | UPC FocusSat | Viasat History
    0B02:7857 | UPC FocusSat | MGM
    0B02:7858 | UPC FocusSat | ESPN America
    0B02:785A | UPC FocusSat | MTV Rocks
    0B02:785B | UPC FocusSat | AXN Crime
    0B02:785D | UPC FocusSat | STORY4
    0B02:785E | UPC FocusSat | HISTORY
    0B02:785F | UPC FocusSat | Disney ROM
    0B02:7860 | UPC FocusSat | SportM
    0B02:78B5 | UPC FocusSat | Eurosport
    0B02:78B8 | UPC FocusSat | Viasat Explorer
    0B02:78BA | UPC FocusSat | AXN Sci-Fi
    0B02:78BB | UPC FocusSat | MTV Dance
    0B02:78BC | UPC FocusSat | HBO Comedy
    0B02:78BD | UPC FocusSat | Daring!TV
    0B02:78BE | UPC FocusSat | Nickelodeon
    0B02:78C2 | UPC FocusSat | Cinemax2
    0B02:78C3 | UPC FocusSat | Blue Hustler
    0B02:78C4 | UPC FocusSat | Duna TV
    oscam.user
    [account]
    user = dvbapi
    pwd = dvbapi
    group = 1
    au = 0
    uniq=2
    betatunnel = 1833.FFFF:1702
    [account]
    user = monitor
    pwd = monitor
    monlevel = 4
    ######## end of file ########
    @cOcO10 ....cum ajung acasa integrez setarile....cele testate de mine cred ca nu erau complete , nu aveam toate fisierele
    oscam.services , oscam.servid , monitor....configul l-am luat din panel RSP....sper sa mearga setarile tale
    as fi fericit te anunt si Multe Multumiri ....de asemenea si lui @stargate .
    95 Post(s)
    Specificati ce versiuni de imagini aveti fiecare, poate ca nu merge bine adaptorul USB pe una din ele.
    Sal la toata lumea,
    Am pornit cardul , sunt incantat , dar a trebuit sa cumpar alt adaptor , in urma sfatului @cOcO ...am cumparat de la St-Lab U -224 (37 ron) cu Prolific Pl2303 care a functionat imediat ...voi posta intregul protocol dupa ce testez totul...trebuie sa ajute si pe altii....a trebuit sa repozitionez jumperii de pe Phoenix by Gelvis....In skimb nu-mi merge sharingul , pe langa setarile de la Coco in oscam.conf am adugat si
    [cccam]
    port = 12150
    reshare = 2
    ignorereshare = 0
    version = 2.2.1
    updateinterval = 240
    minimizecards = 0
    keepconnected = 1
    iar apoi am pus toti "readers" pe care ii am si bineanteles toti utilizatorii , dar nu mai functioneaza NICI CARDUL , NICI SHARINGUL....am mai modificat webif pe portul 84 , dar nu cred ca asta are importanta...
    Trebuie sa fac teste sa vad solutia finala
    @cOcO tu cum ai pus restul in sharing ?
    Mama cati nervi din cauza unui amarat de adaptor...dar ce m-a indus in eroare a fost ca l-am conectat cu Kathi si am pus imagine in flash din KCC...scarba ....nu-i place Phoenixul lui Gelvis...mai bine cumparam un reader destept din prima ...
    03 Feb 2008
    Imi pare bine ca ai rezolvat ..dupa cate vad doar partial...cu rabdare mult studiu tutun o sa rezolvi pb.
    Succes.
    23 Apr 2007
    P3X-888
    Quote Originally Posted by bobbob View Post
    Readerul este bun ... problema este la adaptor .
    Am instalat si acum functioneaza totul bine ...problema este ca OSCAM este f. stufos
    La instalarea Phoenix by Gelvis aveti grija la jumperi sa fie pusi pt. dreambox ...nicidecum pt. Kathi ....
    [IMG]D:\Phoenix layout[/IMG]
    Apoi dupa instalare trebuie startat Oscam , sa functioneze CCcam si apoi adaugat "reader" pt Focus , mie nu mi-a pornit din prima....este sensibil...trebuie testat foarte incet...
    mai postez din teste ulterior...
