Thanks Thanks:  13
Likes Likes:  19
Page 1 of 5 12345 LastLast
Results 1 to 15 of 73
Thread: Vu+ Duo II ( second edition ) info
    29 Nov 2008
    Cu capu' in nori
    Default Vu+ Duo II ( second edition ) info
    DUO BCM7424
    Full-Resolution HD 3DTV Set-Top Box SoC Solution
    Produced in 40 nanometer (nm) process technology, the BCM7424 is a high definition (HD) full-resolution 3DTV set-top box (STB) system-on-a-chip (SoC) solution designed for residential video gateways. It is the industry's first SoC to combine a 1.3 GHz dual-threaded MIPS® applications processor with the latest transmission efficient H.264/MPEG Scalable Video Coding (SVC), and Multiview Video Coding (MVC) standards for enabling 1080p60/50 content distribution and full-resolution HD 3DTV.
    It also features a 1G pixel per second OpenGL® ES 2.0 3D GPU for advanced 3D graphics acceleration, and whole-home connectivity that includes Digital Living Network AllianceSM (DLNA®) support and integrated Ethernet MII and PHY support for connectivity with Broadcom's Wi-Fi and powerline solutions. Providing these high levels of integration and performance, the BCM7424 is designed to meet the needs for the next-generation connected home experience including a compelling and leading video content experience, more web-based software applications and the ability to stream content and connect devices in the home and on-the-go.
    FEATURES:
    • Ultra-high performance BRCM 5000 MIPS-based applications processor with 3000 DMIPS of applications processing performance supported by unique and powerful 2D and OpenGL ES 2.0 3D GPU's to further enhance web-based software platforms
    • Distributed processing set-top box architecture featuring an additional 3000 DMIPS (total of 6000) of multiple high-performance sub-system processors and hardware
    • Lower power and higher performance 40nm CMOS silicon technology
    • The MPEG industry standard, SVC, that supports full-resolution HD 3DTV, and also enables a 40 percent bandwidth savings for backward-compatible 1080p60/50 content distribution to new and legacy STBs
    • Integrated Ethernet MII and physical layer (PHY) capabilities for connectivity with Broadcom's Wi-Fi and powerline solutions. and available DLNA server/player software stack to support multi-room DVR services for 5 or more IP STB client devices enabling a simpler and cost effective home architecture that dramatically lowers capital costs
    • Customized high performance (430MHz) VLIW (very long instructional word) DSP (digital signal processing) for audio processing
    • A broad array of time-to-market web-based connected home STB software applications environments including Adobe Flash® Platform for TV, Webkit HMTL 5.0, Java, Nokia's Qt Framework including QtWebkit, DLNA 1.5, and DirectFB application libraries
    • Unique HD FastRTV™ channel change acceleration technology that improves channel change speeds by up to 500 percent
    • Integrates a real-time HD transcoder that converts broadcast, over-the-top (OTT) and user-generated content into a wide range of resolutions, formats and bit rates that enable seamless content distribution to connected devices both in the home and on-the-go, and also provides advanced services, such as video conferencing
    29 Nov 2008
    Cu capu' in nori
    Vu+ team is delighted to invite you to ANGA Cable 2012
    At the upcoming event in Cologne, Germany, Vu+ team will release several announcements at the stand.
    First of all, we will introduce the 2nd generation models of our best sellers: Vu+ DUO, Vu+ SOLO.
    At the Vu+ stand, you will see:
    • Vu+ DUO2 integrated with the new chip-set
    • Vu+ SOLO2 integrated with the new chip-set
    And a lot more including HBBTV support.
    We are looking forward to seeing you in Hall 10.1 Stand S21
    Vu+ Team
    Din fisele tehnice reiese ca si receptoarele de satelit devin niste pc-uri personalizate si probabil cat de curand nu o sa se mai poata face diferenta intre ele si un HTPC
    04 Apr 2009
    sa vedem si ce scor are, din punct de vedere hardware pare OZN fata de ce exista acum pe piata.
    29 Nov 2008
    Cu capu' in nori
    Vu+ Duo II
    Attached Files Attached Files
    24 Jun 2009
    Hamburg
    arata foarte bine si din ce se scrie va fi foarte tare, dar sa vedem cat costa
    cred ca se va duce la 7-800
    29 Nov 2008
    Cu capu' in nori
    ---------- Post added at 22:35 ---------- Previous post was at 22:17 ----------
    ---------- Post added 13-06-12 at 00:06 ---------- Previous post was 12-06-12 at 22:35 ----------
    29 Nov 2008
    Cu capu' in nori
    04 Apr 2009
    ceva noutati in legatura cu data lansarii si pretul?
    Decembrie2012-ianuarie2013 data lansarii doar zvonuri deocamdata nimic concret.
    Sent from my MB525 using Tapatalk 2
    am citit pe un forum din anglia
    Duo2 launches October, expect in the shops by end of October or early November.
    The price.... £450-500
    7 Post(s)
    mi se pare exagerat petru duo2 450lire pretul propus de cei de pe forumul BH e maxim 399 euro.
    24 Jun 2009
    Hamburg
    care este sau va fi cel mai bun produs de la vu: vu+ duo2 sau vu+ ultimo?
    29 Nov 2008
    Cu capu' in nori
    Stai sa iasa pe piata Vu+ Duo2 si vedem atunci.
    7 Post(s)
    "VU+ DUO2" desigur face ce face ultimo, si are un atu in +...... LCD color pe langa cele 3 tunere...deci....
