Thanks Thanks:  14
Likes Likes:  6
Results 1 to 15 of 23
Thread: Update card focus cu oscam - setari
    14 Nov 2010
    Default Update card focus cu oscam - setari
    Fiindca mai multi au cerut setarile oscam pentru au card focus, pun aici setarile. Mentionez ca precis nu este cel mai bun setare oscam, dar functioneaza bine si face si au la cardul focus.
    oscam.server
    [reader]
    label = focus
    protocol = internal
    device = /dev/sci0
    caid = 0B02
    detect = cd
    mhz = 500
    cardmhz = 500
    group = 1
    emmcache = 1,3,15
    lb_weight = 300
    auprovid = 000B02
    oscam.user
    [account]
    user = username ce ai
    pwd = password ce ai
    group = 1,2,.... tu stii in cate grupe ai bagat liniile ce ai
    uniq = 2
    au = focus
    au = 1
    ident = 0B02:000000
    betatunnel = 1833.FFFF:1702,1834.FFFF:1722
    chid = 0604:000014,000069,0000F4,0000F5,0000FA
    cccmaxhops = 3
    keepalive = 1
    penalty = 0
    oscam.conf
    [global]
    logfile = stdout
    emmlogdir = /var/tuxbox/
    clienttimeout = 2000
    fallbacktimeout = 1800
    clientmaxidle = 99999
    failbantime = 6000
    cachedelay = 120
    nice = -1
    maxlogsize = 100
    preferlocalcards = 1
    saveinithistory = 1
    dropdups = 1
    lb_mode = 1
    lb_save = 100
    lb_nfb_readers = 3
    lb_savepath = /tmp/.oscam/stat
    lb_reopen_mode = 1
    [monitor]
    hideclient_to = 15
    appendchaninfo = 1
    [newcamd]
    port = 34000@0B02:000000
    keepalive = 1
    mgclient = 1
    [cccam]
    port = 12000
    reshare = 1
    ignorereshare = 1
    version = 2.1.4
    stealth = 1
    nodeid = 0CC517A410C01490
    reshare_mode = 1
    [dvbapi]
    enabled = 1
    au = 1
    boxtype = ipbox
    user = username ce ai tu
    pmt_mode = 1
    request_mode = 1
    [webif]
    httpport = 86 sau ce port ai pus tu
    httpuser = username ce ai tu
    httppwd = password ce ai pus
    httprefresh = 8
    httpallowed = 127.0.0.1,192.168.0.1-192.168.254.254
    httpdyndns =
    [anticasc]
    enabled = 1
    aclogfile = ./oscam_ac.log
    Parerea mea legat de ce trebuie sa aveti setat pentru AU:
    -La reader sa NU fie audisabled = 1 si nu setati nimic la emmcache.Cel mai bine nici sa nu fie puse liniile astea.
    -La dvbapi in oscam.conf trebuie pus un user,de exemplu :
    [dvbapi]
    enabled = 1
    au = 1
    boxtype = ipbox
    user = userdvbapi
    pmt_mode = 1
    request_mode = 1
    -Daca nu adaugati acel user in oscam.user nu aveti sanse sa primiti emm-uri la reader.Oscam va deschide local logat ca anonymous si cu AU trecut pe OFF.Vedeti asta clar in webif la sectiunea clienti,daca apare anonymous pe protocol dvbapi logat si cu AU off puteti sa asteptati ani de zile sa faca update cardul.
    De aceea acolo trebuie sa fie trecut userul "userdvbapi" pus mai sus la sectiunea dvbapi:
    [account]
    user = userdvbapi
    pwd =
    description = Dvbapi
    group = 1
    au = 1
    cccignorereshare = 0
    keepalive = 1
    Nu e nevoie de nicio parola.
    Suficient atat,nu are rost sa complicati setarile acestui user inutil,apoi adaugati ce alti useri vreti.Verificati in webif ca acum sa apara un user denumit "userdvbapi" cu AU pe ACTIVE,protocolul folosit dvbapi si ip (adress) 0.0.0.0.La reader "focus" de asemenea sa fie AU pe ACTIVE.
    Acum verificati ca la readerul (denumit mai sus "focus") sa curga emm-uri pe coloana "EMM written",ca exemplu la mine dupa foarte putin timp am:
    0 / 22 / 0 / 0
    Bineinteles ca trebuie sa fiti pe un program de la Focus sau ce alt provider aveti.
    Nu conteaza cardul sau receptorul folosit,tine doar de setarile din dvbapi si crearea acelui user cu drept de AU.Am mai scris asta si la sectiunea oscam.
    14 Nov 2010
    ZMEURA: Suna foarte intelept toate cele spuse de tine. Dar am o intrebare spre tine: ai incercat vreodata sa faci update cu cele spuse de tine?
    Eu am incercat, si nu am reusit.
    Metoda ce am descris eu, insa e una functionabil si testat cu card focus.
    Este decizia fiecarui ca ce face. Eu am vrut sa dau o mana de ajutor pentru cei ce au nevoie.
    Pai, se poate incerca prima data cele spuse de tine, nu are nimeni ce pierde. Tot ramane si metoda ce am descris eu.
    Sa aveti succes toti cu update focus!
    Nu am zis ca tie nu iti merge,doar ca la:
    oscam.user
    [account]
    e una si la:
    [dvbapi]
    e alta si nu se intelege de nicaieri ca de fapt in dvbapi treci un user cu o denumire la alegerea ta pe care apoi il adaugi (fara parola,ca nu stie nimeni la ce se refera "password ce ai") ca user nou in oscam.user dupa modelul pe care l-ai dat atat tu (cu toate ca unele setari nu sunt necesare) cat si dupa modelul dat de mine,mai simplificat.
    Eu am vrut sa adug o completare si lamuriri la ce am crezut ca poate genera neintelegeri.Mai tarziu imi fac timp sa iti fac o demonstratie cu screenshot-uri pentru ca vad ca te indoiesti de faptul ca ceea ce am adaugat eu ar fi corect sau util.Daca cineva copiaza EXACT ce ai postat nu ii va face update,daca totusi incearca sa modifice la user in acele sectiuni nu va sti ce sa treaca acolo si cum sa verifice daca e bine.
    14 Nov 2010
    Asa da, te inteleg si ai dreptate. S-ar putea sa-l complic pe unii mai incepatori in oscam.
    09 May 2007
    La 1x Card NDS sky V13 si 1x Card HD+ ID 1830, am setat la cineva pe VU+ Uno, oscam/cccam, doar prin protocolul ccccam, fara newcamd, fara Dvbapi. O linie C: din oscam.user catre cccam, si face AU. Imediat au primit cartelele emms. Doar ca pierzi 1x HOP.
    Poate ajuta si la cardul focus. Va rog sa testati, sau daca ati testat va rog sa ne scrieti.
    Numai bine
    14 Nov 2010
    Noi vorbim despre receptorul Alien, pe care cccam nu functioneaza in mod stabil. Pentru noi ramane oscam, care nu e deloc un emulator rau, doar noi trebuie sa invatam mai mult despre functionarea lui.
    Standard RSP member klausz's Avatar
    10 May 2007
    Este normal sa am doar 2 entitlements daca eu am 5 servicii active? Adica Familia, Moz, Cinema, Hd si Sport? Am vazut ca la un momentdat imi apareau 3.
    L.E. Eu am de fapt un Vu Solo2. Am vazut dupa unde am postat. Totusi nu cred ca probkema mea nu se incadreaza in topic.
    Emme Esse 115cm, h-h Stab 120,Vu+ Solo​2, Samsung UE40ES6710, tevii s660 dvb-s2
    14 Feb 2007
    Ai dreptate, nu sunt 2, nici 3 si nici 5... sunt 4. Focus + ESS pe luna in curs si inca odata Focus + ESS pe luna trecuta.
    Detalii
    Uniq 2 la userul dvbapi si sa fie Au enabled la reader. Ar fi bine sa opresti 3c de tot pana face AU
    LE Acest post a fost mutat din alt thread si trebuia sa fie raspuns la urmatorul post
    01 May 2013
    Default Ajutor va rog
    Salutam,
    dvbapi - 1 enabled in cccam, la dvbapi din oscam au 1 enabled 1 , restart dream si astept de 3 ore fara sa se faca update la entitlements. Rog ajutor, daca nu e cu suparare.
    14 Feb 2007
    Cam putine detalii si multe confuzii (dvbapi: -1 in 3C nu inseamna dvbapi enable ci disable), daca ai 3C si oscam nu poate avea decat 1 din ele dvbapi pornit. Asigura-te ca merge oscam pt AU, daca amesteci 2 EMU fara sa stii cum nu va face AU.
    01 May 2013
    la posturi consecutive apasa butonul Reply to Thread.. Regulament punctul 12
    Am setarile din postarea mea de mai sus plus ale tale si tot nu merge. Nu i-am dat de capat inca. Poate ma ajuta cineva.
    01 May 2013
    Te rog mult dMd sa intri pe mess yahoo. Nick: catalin_radio Acolo putem vbi mai rapid. Multumesc in avans.
    Deoarece vad ca multi intampina probleme, pun niste setari cu care am facut AU la mai multe carduri: nagra, via, conax, irdeto si nds
    Cu conditia sa vina emm-uri
    Oscam cu DVBAPI
    http://sateliti.info/showthread.php?27663-AU-cu-oscam
