Thanks Thanks:  2
Likes Likes:  3
Results 1 to 15 of 17
Thread: MediaArt7 - First Android Satelit Hybrid Set Top Box
    Moderator sorin8m's Avatar
    22 Apr 2007
    Default MediaArt7 - First Android Satelit Hybrid Set Top Box
    Full Compliant with DVB-S2
    Powerful Media Player
    Full Browsing with Flash Player Stable Streaming Protocol
    Application Market
    DLNA / Air Video
    Features and Strong Points
    1. World first Android Hybrid STB
    • World-first Android-based Satellite
    Hybrid set-top box.
    • World-first Smart Satellite Hybrid functionality.
    • Screen capture supported.
    2. Full browsing with Flash like PC
    • World-first Adobe Flash 10.3 certificate
    & plug-in (Full browsing).
    • Fast page loading, scrolling and zooming functions by RCU.
    3. Powerful media function
    • Various media codecs and container supported.
    • Powerful iMedia Player application.
    4. Powerful streaming protocol
    • World-first Android-based Adaptive HLS (HTTP Live Streaming) support.
    • Multicast / HLS VoD / HLS Live / HTTP
    VoD support.
    5. DLNA & Air Video
    • Contents sharing with PC, Smart Phone/ Pad, TV and so on.
    • DLNA 1.5 Compliant.
    6. Compliant with Android
    Applications
    • All kinds of Android applications are running with no modification.
    • APK Installer and Application Manager
    supported.
    7. Various Interface
    • USB, HDMI, AV OUT, ETHERNET, and
    Wireless LAN supported.
    • USB devices, Mouse, Keyboard supported.
    8. Application Market
    • Application Market Framework.
    • Application Market Server.
    9. OTN (Over The Network)
    • Automatically detect for the new software.
    • Easy to upgrade via Network.
    10. Pre-installed Android
    Applications
    • Browser, iMedia Player, YouTube, Weather Widget, HLS Player, Game, APK Installer, Music Player, DLNA, All STB Applications up, Facebook....
    Caracteristici:
    Operating System - Android
    Android Version - 2.7
    Chipset - ARM Cortex-A9
    Flash Memory - 512MB NAND
    Program DRAM - 512MB DDR2
    Flash - Adobe Flash Plug-in10.3 (up to 480i video)
    Wireless - Dongle type (separately-sold)
    F/W Upgrade - OTN (Network Upgrade)
    Tuner
    - FEC Modes Rate
    - 1/2, 2/3, 3/4, 5/6, 7/8
    - Input Connector
    - F type female (75 Ohm)
    - Frequency Range
    - 950MHz ~ 2150MHz
    - Symbol Rate
    - 2 ~ 45 Mbaud
    - Demodulation
    - QPSK/8PSK
    Codec
    - Video
    - MPEG 2, MPEG 4/H.264
    - Xvid, AVI, MKV
    - On2,
    - Audio
    - MP3, Sorenson, ACC, OGG, MPEG Audio
    - Photo
    - PNG, JPEG, BMP
    Front LED
    - Power LED (Red/Green)
    Rear Output Connectors
    - 2XUSB 2.0 host
    - HDMI 1.3a
    - ETHERNET
    - COM (Option)
    - AV OUT (Option)
    Dimension
    - ( W ) 180 mm x (D) 130 mm x (H) 30 mm
    Channel:
    RED button. Displays channel list. Alphabetical and satellite sorting. Changes the channel.
    Settings the “Add to FAVORITE”, “Lock”, or
    “Unlock”.
    Favorite:
    YELLOW button. Displays favorite list.
    You can remove the favorited items (Channel, App and Browser) setting.
    Internet:
    BLUE button. Displays bookmark list. You can add “FAVORITE” menu.
    Auto screen capture supported.
    Cursor and virtual keyboard supproted.
    Easy to recognize bookmarks with thumbnail images
    Screen capture:
    Press “«” button for 3 seconds for screen capture. ( Video screen capture is unavailable.) Captured image will replace the application icon image. Captured image is automatically saved into the external storage and you can check it with iMediaPlayer.
    YouTube:
    Enjoy all of HD movies on YouTube. Selects “YouTube” on APP menu.
    Internet Browser:
    iMedia Player:
    WHITE button. Displays EPG for 7 days. Alphabetical and satellite sorting. Displays the program information..
    23 Apr 2007
    P3X-888
    Interesant
    22 Apr 2007
    Accesorii:
    - USB wifi
    - Tastatura si telecomanda cu atingere
    - Tastatura și mouse-ul fără fir (aveți posibilitatea să conectați orice tastatura și mouse-ul fără fir, care este compatibil cu Android)
    Golden Member qwess's Avatar
    26 Oct 2009
    Walachia / Paname
    aplicatii .apk prezente in download pe site-ul oficial
    http://mediaart.cc/index.php/downloa...plication.html
    pret:179,90 €
    http://digitaldream.info/shop/en/61-media-art-7
    22 Apr 2007
    Ca sa puteti instala de pe google play aplicatii trebuie sa urmariti urmatoarea procedura de instalare.
    Instalare GooglePlay pe MediaArt7:
    1. In primul rand pentru a putea instala googleplay trebuie sa aveti cont pe gmail
    2. Descarcati GooglePlay de pe pagina www.mediaart.cc
    3. Mergeti in sectiunea Download si dupa aceea Appk Download, cum e aratat in poza
    4. Luati GooglePlay apasand butonul download sau Mirror1
    5. Dezarhivati si copiati totul pe USB memory stick
    6. Introduceti USB memory stick in una din cele 2 USB-uri din spatele receptorului
    7. Dupa aceea apasati butonul MENU pe telecomanda si alegeti folderul APP
    8. In meniul APP gasiti APKInstaller
    9. Deschideti APKInstaller si vor aparea urmatoarele 3 aplicatii
    10. Obligatoriu sa aveti grija de ordina de instalare
    11. Prima data instalati GoogleServicesFramework.apk
    12. Instalati GooglePlay Enabled ..
    Deschide aplicatia GooglePlay Enabled si apasati pe GooglePlay Install
    13. Dupa ce ati terminat cu instalarea lui GooglePlay este nevoie sa resetati receptorul MediaArt7
    Apasati butonul Power si il tineti mai mult de 3 secunde dupa care il porniti apasand butonul Power
    14. Dupa ce porneste receptorul gasiti in meniul APP programul PlayStore
    15. Porniti PlayStore si apasati pe YES ca si in poza de mai jos
    16. Apasati butonul NEXT
    17. Daca deja aveti cont pe gmail apasati butonul Sign In, daca nu atunci trebuie sa va faceti un cont prin apasarea butonului Create
    18. Introduceti datele de la gmail (userul si parola)
    19. Daca ati introdus bine datele atunci va va aparea Finish Setup, cum se vede in poza de sub
    20. Google Play este cu success activat si instalat, acuma puteti lua programe de pe google play si instala pe receptor.
    22 Apr 2007
    Exista si reprezentanta in timisoara care vinde astfel de receptoare la 220Euro cu tot cu tva. Pentru firme pretul la an gro e mai mic.
    http://www.artsatmedia.com/
    22 Apr 2007
    Default IPTV pntru MediaArt 7
    IPTV pentru MediaArt 7
    DOWNLOAD IPTV MediaArt7
    - EXYU Channel
    - ROMANIA Channel
    - Fix FTP root
    ( Asta este doar inceputul, in curand mai multe canale )
    OBSERVATIE : Ca iptv sa functioneze corect este necesar sa aveti FirmWare minimum 2.7.3, dupa care urmariti etapele urmatoare
    1. Meni - App - IPTV (No channel List)
    2. Porniti IPTV MediaArt7
    3. Introduceti IP adresa mediaart7 in IPTV mediaart7 program ( la PC )
    4. Dati klik pe canalele iptv dorite
    5. Asteptati ca procesul sa termine
    6. Iesiti in meniul principal si intrati din nou in IP aplicatie, canalele selectate anterior pe PC vor fi afisate.
    27 Apr 2007
    Bayern, DE
    Pretul a scazut e 866 lei acum.
    05 Mar 2010
    Momental e promotie la MediaArt7 , pretul acum este de 742 RON TVA inclus. Se primeste cadou USB WIFI.
    22 Apr 2007
    Cum a scris si damir mai sunt, receptorul momentan este la oferta la 170Euro bucata (cu tot cu tva).
    Cei interesati ma pot contacta pe PM.
    22 Apr 2007
    Am revenit cu teste la acest receptor, si cu noutati.
    Pentru inceut am luat ultima versiune firmware entru acest recetor: versiunea 2.8.3
    Noutati la aceasta versiune:
    -introduse noi meniuri
    -adaugat 18 grue de favorite
    -meniu ascuns App
    -si multe altele
    http://www.smart-box.org/index.php?a...a=view;down=60
    ---------- Post added at 00:49 ---------- Previous post was at 00:38 ----------
    Pentru sharing se intrebuinteaza softul IPCam. El contine CCcam 2.0.11, 2.1.4, 2.2.1 si , newcamd si mgcamd.
    26 Oct 2009
    Walachia / Paname
    ai incercat o compilare/ test oscam pe el?
    ipcam l-am testat pe telefon si vad ca e doar client
    http://www.streamboard.tv/wbb2/threa...tuser=0&page=1
    22 Apr 2007
    Nu am incercat, un timp am avut probleme (deces in familie) si am intrerupt testele/
    Acuma am revenit si am luat sa un ultimele versiuni de soft si sa testez ca am ramas un pic in urma
    Last edited by sorin8m; 21-06-13 at 20:21. Reason: corecturi, ca sa nu ma mai criticati :)
    Vezi ca ti- a murit tasta T.
    22 Apr 2007
    Default Instalarea IPCam pe receptor
    Instalare IPCam pe receptor:
    1. faceti download la ultima versiune de IPCam de aicea http://www.smart-box.org/index.php?a...ownloads;cat=5
    2. Copiati fisierul .apk pe memory stick si introducetil in receptor
    3. aplicatia se instaleaza cu utilitarul APK Install din meniul APP
    4. Activati optiunea REMOTE Config HTTpd
    5. deschideti un browser si introduceti ip-ul receptorului, ca si in exemplu 192.168.2.211:18000
    Atentionare: la versiuni mai noi decat 2.4.1 aveti
    user:admin
    password:0000
    la versiuni mai vechi nu se introduce nimica.
    ---------- Post added at 17:05 ---------- Previous post was at 17:03 ----------
    mai adaug si un tutorial video cum se face update de firmware la acest receptor, si cum se instaleaza aplicatii eu zic necesare.
