Results 1 to 6 of 6
Thread: Ajutor _ SBox cu 2 cartele
    31 Mar 2008
    AR( RO.), KA( DE )
    Default Ajutor _ SBox cu 2 cartele
    Sanatate la toata lumea
    asi avea nevoie de ajutor la un DM 7020- cu Sbox& Cccam
    este vorba - daca merg 2 cartele de diggi in Slot
    Problema la mine este- ca UNA merge - dar din Moment ce o pun pe a 2_a
    Slot0- de ex- dupa citeva sec ca: 1 min mi se intrerupe chiar si legatura de FTP
    31 Mar 2008
    AR( RO.), KA( DE )
    ce am gresit in urmatoarea config ??
    [main]
    server_only=1 # 0=mixed mode 1=only server
    log=0 # 1=no log 1=log to /tmp/sbox.log //ALWAYS USE 0//
    logudp=192.26.0.1:3354 # server ip:server port
    userspath=/var/bin/users.sbox # users list
    channelinfo=/var/bin/sbox.channelinfo # channel info
    webinterface=1 # 1=web interface on 0=web interface off
    webadmin=admin:bambolina # userass for webinterface
    webport=8181 # web interface port
    rdgserver=0 # 0=radegast server off 1=radegast server on
    rdgport=16050 # radegast server port
    use_nagra=1 # 1=use as nagra card 0=use as irdeto card (only for nagra over irdeto cards)
    prio=1880:2111
    # prio caid for dvbapi, caid1rov1;caid2rov2rov1
    cccam=0:18000 # 0=cccam server off - 1=cccam server on : cccam server port
    betatunnel=1 # 0=betatunnel support disabled 1=betatunnel support enabled
    [slot1]
    active=1 # 0=inactive 1=active
    sci=/dev/sci1 # lower
    # card reader /dev/sci1 (oben )
    # card reader /dev/sci0( unten )
    ncdserver=1 # 0=newcamd server off 1=newcamd server on
    deskey=0102030405060708091011121314 # newcamd deskey
    port=15050 # newcamd port
    mhz=368 # Mhz for card in this reader, DON'T WORK ON PHOENIX INTERFACE. Example: mhz=357, mhz=368
    reader=1 # 0=phoenix, 1=sci (internal reader), 2=smartreader
    cache=0 # how many ecms can be cached, 0 or less=cache disabled
    portlist=1 # use portlist or no
    portlistpath=/usr/keys/port.list # path from port.list
    # How to ADD RSA for TIGER/NCMED cards
    # If your card is a ROM TIGER547 Rev124 (for example)
    # [TIGER547] <- this is the rom version from your card
    # rsa=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    # ONLY THIS, for config bloquer, portlist, etc, look at the examples above!
    #Nagra2/3 Example
    [TIGER003]
    [Card ] # nagra2 camid (4 bytes)
    rsa=xxxxxxxxxxxxxxxxxxxx RSA yyyyyyyyyyyyyyyyyyyyyyyyyyyy
    boxkey=bbbbbbbbbb BOX ID mmmmm
    emm=0 # 0=accept all 1=block emms 2=block emmu 4=block emmg
    [slot0]
    sci=/dev/sci0 # lower
    deskey=57AFDAC75BB07DBC55255AFCEA94 # newcamd deskey
    port=11050 # newcamd port
    reader=1 # 0=phoenix, 1=sci (internal reader), 2=smartreader, 3=omnikey pcsc reader
    #Nagra2/3 Example
    [TIGER003]
    rsa=ffffffffffff RSA kkkkkkkkkkkkkkkkkk
    boxkey=wwwwwwwww BOX ID oooooooooo
    Ai pus camid la fiecare card?
    31 Mar 2008
    AR( RO.), KA( DE )
    da am pus- scuze te rog am trecut numai Card in loc de camd id
    [TIGER003]
    [Card ]
    Incearca doar cate una si vezi daca e ok.
    Daca merg pe rand trebuie sa mearga si amandoua.
    31 Mar 2008
    AR( RO.), KA( DE )
    separat- merg amindoua
    dar amindoua deoadata NU merg
