Thanks Thanks:  6
Likes Likes:  2
Results 1 to 6 of 6
Thread: TBS5925 USB DVB-S2 Professional TV Box
    Default TBS5925 USB DVB-S2 Professional TV Box
    Description:
    TBS5925 USB DVB-S2 Professional external TV Tuner box, built with the highest industry standard, with its rock reliability is the device that any personal enthusiasts or engineers in digital satellite TV industry dream to have. The applying of an unique DVB-S2 demodulator chipset makes it possible to receive special streams broadcasted with ACM, VCM, Multi Input Stream(MIS), 16APSK, 32APSK, which most satellite receiving devices can’t support. The built in hardware blind scan feature allows scanning of unknown satellite transponder with symbol rate as low as 200ksps, while most satellite receiving device can receive no less than 1Msps symbol rate. With use of dedicated TBS tools or Crazyscan, those special streams can be captured. Both Windows BDA driver and Linux driver up to the latest kernel 3.X are provided.
    TBS5925 is the USB version of its’ equivalent device: TBS6925 PCIe DVB-S2 Professional TV Tuner card
    Main Feature:
    DVB-S2/S Transponders Receiving
    CCM, VCM,ACM and Multi Input Stream Support
    Wide range symbol rates support from 200Ksps to 45Msps
    High-speed Data download via Satellite
    Unicable/One Cable compatible
    Blindscan
    High reliability
    Applications:
    Satellite feed hunt
    Satellite Data download
    Lock of special transponders
    Specification:
    Receiving Frequency: 950~2150 MHz Tuning Range
    Input level: -69~-23dBm
    DVB-S2/DVB-S 8PSK QPSK 16APSK 32APSK Demodulator
    Symbol Rate:
    DVB-S QPSK 0.2~45Msps
    DVB-S2 QPSK/8PSK 0.2~45Msps
    Carrier Capture Range: ±10MHz
    8PSK Puncture codes: 3/5,2/3,3/4,5/6,8/9,9/10
    QPSK Puncture codes: 1/2,3/5,2/3,3/4,4/5,5/6,8/9,9/10
    16PSK Puncture codes: 2/3,3/4,4/5,5/6,8/9,9/10
    32PSK Puncture codes: 3/4,4/5,5/6,8/9,9/10
    Support Data Burst & Tone Burst
    Support DiSEqC2.X and Motor
    TV Box Size: 78x64x26mm (Length x Width x Height)
    TV Box Weight: 137 Gram
    Package Gift Box Size: 200x162x55mm (Length x Width x Height)
    Package Gift Box Weight: 647 Gram
    System Requirements:
    Windows 2000/XP/Vista/7 or Linux
    DirectX9.0 or later Version
    Available USB2.0 Port
    Satellite Dish and LNB
    For DVB-S:
    1GHz CPU or above
    256MB RAM or above
    Graphic Card with at least 16MB RAM
    For DVB-S2 HDTV:
    Dualcore CPU
    1GB RAM or Above
    Graphic Card with at Least 64MB RAM
    Package Content:
    1 x TBS5925 USB DVB-S2 TV Box
    1 x remote control
    1 x Power Adapter
    1 x USB Cable
    1 x Software CD
    Thumbs up TBS 5925 now implemented on Enigma2/mipsel receivers
    We are happy to announce that in our SatDreamGr images we have managed to finally incorporate support for TBS tuners, especially TBS5925 and TBS5980 using Crazycat's work as a base.
    After a long period of testing, the first receiver fully scanning all Multistream channels and ACM/VCM 16APSK/32APSK channels as well is Edision OSmini. Soon enough we will extend functionality to all receivers we support that run in kernels higher than 3.8.
    So far, scanning and zapping through MIS is seamless and very fast. We are working hard to also implement blindscan features and investigate direct T2-MI encapsulation.
    Our patches will be available soon in openPLI (on which SatDreamGr images is based) with hope that more developers/coders will create new plugins such as Crazyscan for Enigma2 to extend these cards' capabilities.
    Here is a video which demonstrates scanning and zapping on my own OSmini receiver.
    https://www.youtube.com/watch?v=kprD4tplCgw
    Thanks to glamourservices for this info
    hxxp://www.satdreamgr.com/forum/cmps_index.php?pageid=satdreamgr-images&tabid=577
    Thumbs up Multistream reception on 5W using TBS5925 on Enigma2 SDG image OSmini
    https://www.youtube.com/watch?v=V8kxwuhrJC0
    your xml file:
    http://speedy.sh/rphpx/satellites.zip
    TBS 5925 Usb and Vu+Duo2
    Thanks to Digitalbi for this info
    TBS 5925 DVB-S2 TV Tuner USB-----214,90 EUR-------2 bucati pe stoc
    se poate achizitiona din germania de la magazinul lui @Ponny (satshop24.de)
    ATENTIE:
    este indicat sa fie cumparat de catre cineva care are domiciliul/rezident in germania deoarece transportul va costa --Versandkosten 5,00 EUR---
    in caz contrar transportul din DE----RO este foarte scump (der Versand uber DHL Express Worldwide nach Rumänien beläuft sich auf 80,00 Euro.)
    succes tuturor
    27 Oct 2014
    salut ma poate ajuta si pe mine cineva?am si eu un vu solo4k si un tbs 5925 usb s2 tuner si nu reusesc sa il fac sa mearga cu vu solo!
