Thanks Thanks:  2
Likes Likes:  2
Results 1 to 14 of 14
Thread: receiver HD la cel mai bun raport calitate-pret
    08 Jan 2009
    Smile receiver HD la cel mai bun raport calitate-pret
    Ceau.Puteti sa-mi spuneti daca am vreo sansa sa gasesc un receiver hd la un pret ok?ok-pana in 300 RON.Am citit un review ok despre Alma S2100 cum ca ar fi superok si pt canale cu emisie slaba.Cam asta stie sa faca:
    • Full HD Digital Satellite Receiver
    • Conax Embedded card reader
    • DiSEqC 1.0, 1.2 and USALS compatible
    • Dolby Digital BitStream out via S/PDIF & HDMI
    • Channel Recording to External Storage Devices
    • TimeShift Support
    • MKV, AVI, MPG, MOV, MP3 playback support
    • Automatic Install function
    • 4 (7 segment) digit LED display
    • Powerful Channel Management tools (Lock, Edit, Move, Skip, Delete)
    • Favourites
    • User Friendly On-Screen Display (OSD)
    • Multi-Language support
    • Subtitles support (DVB/TXT)
    • Software Upgrade Support via USB & RS232
    • <1W Power Consumption in Stand-By mode
    System standard: Fully MPEGII/DVB Compliant
    Input Frequency: 950~2150Mhz
    RF Input level: -65~-25dBm
    LNB Control: DiSEqC1.0/1.2
    LNB Power:13V/18V (Max, 400mA)
    LNB tone switch: 22KHZ
    Waveform: 8PSK / QPSK (SCPC, MCPC capable)
    Symbol rate: 2~90Msps
    Video format: MPEG-II Main prole/Main level
    Audio format: MPEG-II layer I&II
    Aspect Ratio: 16:9, 4:3
    Audio sampling rate: 32,44.1, 48kHz
    Audio Type: Left / Right / Stereo / Mono
    Graphic display: 1920×1080, 1280×720, 720x480
    Processor: 400MHz based CPU
    RAM: 128Mb DDR
    FLASH: 8 Mb
    Supply Voltage: Free Voltage (175~250V AC, 50/60Hz)
    Supply Power: Max.30 W
    Stand-By Power: <1W
    Operating temp: 0°C~40°C
    Display: 4Digit (7-segment) LED display
    Dimensions: 260(W) x 150(D) x 45(H)mm
    Satellite IF input: F-type (Digital)
    Satellite IF loop out: 950-2150MHz
    1 SCART TV (RGB, CVBS)
    RCA/Composite Audio Left & Audio Right
    0/12V Output
    RS232: 9 way D RS232 DCE serial port
    S/PDIF: Coaxial
    HDMI
    USB
    Daca nu vreau sa vad decat canalele fta SD si HD,e o alegere buna?
    Este. Dar ia 2200 ... sa nu-ti para rau mai tarziu.
    23 Jun 2008
    Eu am atat 2200 cat si 2250 si arca merge mai bine 2250.
    21 Oct 2009
    Cauta ceva detalii si despre Optibox Spider HD si poate esti multumit !
    叛徒 kosar's Avatar
    25 Feb 2013
    覆盆子灌木
    Eu am un Alma s2200HD si sint foarte multumit de el.
    Daca stii ce sa-i dai functioneaza ireprosabil. Acum i-am pus si un adaptor wireless si de cateva ore este in teste si in asemenea conditii. Deocamdata pot sa spun ca si pe wireless merge bine, insa inca nu am avut timp sa-l testez destul in asemenea conditii.
    Ideal e sa-ti cumperi un receptor care sa aiba si retea, fara retea o sa fi repede dezamagit.
    Nu spun ca e cel mai bun receiver, dar la pretul lui face toti banii.
    Sensibilitate excelenta a tunerului, o imagine de exceptie prin cablul HDMI, pe scart imaginea este mediocra, cel putin la mine asa era, dar a doua zi mi-am luat si cablul HDMI.
    Legat de servere newcamd se comporta ireprosabil pe retea.
    24 Oct 2009
    Targoviste
    Default receiver hd
    Buna ziua .Puteti sa-mi spuneti care din receiverele hd : Openbox X5, Openbox S10,Optibox Spider sauAlma s2200HD sunt mai stabile in ccam copmparativ cu calitate pret( toate sunt aproape ca pret= 280- 320 lei)
    叛徒 kosar's Avatar
    25 Feb 2013
    覆盆子灌木
    Alma s2200 HD accepta doar 4 linii CCcam si 4 linii Newcamd insa acestea pot avea fiecare mai multe porturi.
    Cu servere newcamd deschide foarte repede si foarte stabil, indiferent de varianta software folosita.
    Cu servere CCcam functioneaza extrem de stabil si deschide relativ repede cu software-ul 1.20B2*, cu versiuni mai noi parca nu este atat de stabil. Testez varianta CCcam de doua zile cu aceasta versiune de software, si de doua zile nici un freeze nici un restart nimic, cu receptorul destul de butonat, timeshift activat etc...
    Singurul dezavantaj al aceste versiuni fata de versiuniile mai nou aparute, este skin-ul vechi, si faptul ca nu functioneaza youtube ca si pe ultima versiune aparuta acum.
    1.20.b2* este ultima versiune cu skin-ul vechi, dupa aceasta versiune au aparut unele probleme care au fost frumos corectate cu ultimele versiuni, dar parca stabilitatea Cccam la aceasta versiune merge atat de bine, incat nu cred ca exista vre-o versiune cu skin-ul nou care sa egaleze in functionare aceasta versiune.
    Daca folosesti doar servere newcamd dupa cum am scris la inceput, poti folosi orice versiune de software. Stabilitatea cu aceste linii este exemplara.
    24 Oct 2009
    Targoviste
    Default receiver hd
    Care receivere HD accepta mai multe linii Newcamd si CCcam.
    14 Feb 2007
    Nu se poate ieftin, de calitate si mult, dar poti lega daca ai deja un vechi si bartan DM500 cu un HD ieftin de generatie noua care nu duce atatea N sau C cate iti dorestii. Ori alegi varianta receptoarelor "consacrate" si potente care costa ceva mai mult, insa trebuie sa fii realist ... cu 300 lei nu stiu daca ai sa obtii vreodata "cat mai multe" .
    21 Oct 2009
    Quote Originally Posted by stanescu View Post
    Optibox Spider 16 linii.
    01 Feb 2010
    am si eu o intrebare pt cel care face investitia...daca tot vrei un receiver care este doar client...crezi ca vei strange 16 "buni samariteni" care sa te serveasca pe tine constant cu liniutze fara sa primeasca de la tine nimik ?
    07 Sep 2013
    https://t.me/blackhatshiller
    Un clound ibox am auzit ca merge ok si nu stiu daca sare de 300-350 ron si e si server.
    Oricum pt cei care au rec doar client(adica se uita la tv) cautati-ma ca sunt singurul samaritea de pe aici cred...si va dau eu tot ce va trebuie.
    O sa vad cum e ibox2 asa de curiozitate peste 2 sapt si daca nu e prea tarziu o sa revin cu o parere despre el.
    Stiu doar ca are PAL/NTSC auto si daca sunteti prin america(US/CA/MX)..sare singur pe standard EU si trebuie conectat la tv prin euroscart si setat pe manual altfel se vad 1 milion de liniute pe tv
    Spider daca-l fortezi se blocheaza...
    Am testat unul cu 5 C in el si cand am inceput sa editez canalele ..a spus NU
    Singura metoda de resuscitare e power on/off Hard(din priza)
    15 Feb 2007
    Poate are omul deja un server si pe acest receptor il va folosi doar ca client in alta locatie.
    20 Mar 2009
    Iasi
    Din august pana acum sigur a gasit.....
    Quote Originally Posted by stupidman View Post
    HH/1m
