Thanks Thanks:  16
Likes Likes:  11
Page 1 of 5 12345 LastLast
Results 1 to 15 of 66
Thread: Qviart Unic
    Thumbs up Qviart Unic
    General Features
    General
    2x DVB-S/DVB-S2 Satellite Compliant (MPEG-II/ MPEG-IV/ H.264).
    SCPC & MCPC receivable from Ku and C band satellites.
    Universal, Single, Single S & C Band Wideband LNB.
    Compatible Code Rates: 1/2, 3/5, 2/3, 3/4, 4/5, 5/6,7/8, 8/9 and 9/10.
    DiSEqC 1.0/1.1/1.2/1.3(USALS).
    Unicable Surpported.
    Blind search supported.
    Multi satellite search, network search, PID search, manual search and Multi-TP Search.
    Fast Scan on Astra(19.2), Polsat, TNK.
    Auto DiSEqC Search.
    PAL/NTSC.
    Variable aspect ratio(4:3,16:9)with PAN&SCAN vector or letter BOX option.
    Output Resolution: 480p&480i,576p & 576i, 720p50&60HZ,1080i50&60HZ, 1080P50&60HZ.
    16 bits on screen display (OSD).
    Storing memory: 100 satellite, 3000 transponders and 6000 channels.
    Support satellite add, delete, move, rename.
    Support transponder add, delete, edit.
    8 favorite groups, favorite group rename and parental lock supported.
    Support programme lock, delete, move(group move),rename, swap.
    Support multi-language menu(English, Franch, Russia, Greek, Italian, Arabic, Farsi, Ukrain, Swedish, Spanish, Turkish, German etc).
    Support list of programmes, have sort function: FTA>CAS, transponder, alphabet, favor.
    support multi epg language.
    Easy functions such as Group Move/Recall History.
    Multi-language audio.
    Multi-language DVB Subtitle output.
    7 days Electronic Program Guide (EPG).
    Teletext output through VBI and OSD.
    Software(data, app, channels) upgrade through USB or Ethernet.
    2 * USB 2.0 Interface.
    S/PDIF Interface for digital bit stream out (AC-3 or DTS).
    10/100 MBit compatible Ethernet Interface.
    1 * CA.
    Timer
    Support setting timer by manual or auto, you can add up more than 20 timer events.
    Support watch/record timer event.
    Support customized sleep time.
    Etehernet
    FTP Download s/w, channel data, music, picture, media files etc to memroy for upgrade or to USB.
    URL Play function [Only http].
    Weather Forecast.
    RSS.
    Currency converter.
    Stock.
    Youtube.
    Groove Shark.
    Google Map.
    Prayer Times.
    USB (FAT, FAT32 and NTFS)
    Delete, create folders, Format and set recording path.
    Upload and download channel list, system data, software.
    Support picture files: bmp, jpg.
    Support music files: mp3, wav.
    Support media files: avi, mkv, dat, ts, vob, mp4, 3gp, mpg, flv.
    Support USB->WIFI(Only Ralink 5370).
    Support USB->3G Card Reader.
    USB PVR
    Watching one channel (FTA/Scramble) and Recording another channel (Scramble/FTA) in the same TP. During recording, can switch the channel in the same TP.
    Timeshift when watch or record.
    Support FAT & FAT32, NTFS format.
    Chipset Specificatións
    General Features
    Targeted for high definition set-top box solutions.
    DVB_S2 SOC.
    3.3V, 1.8V /1.5V and 1.0V power supply.
    Power down control.
    Power save mode for every module.
    CPU Related Features
    Dual High Performance 32-bit CPU Architecture. Each core is about 600MHz.
    Memory and Bus Interfaces
    16-bit DDR2/DDR3 DRAM interface.
    Dram frequency up to 1108Mhz.
    Maximum DRAM size of the system provided: 256 Mbytes.
    Maximum S-FLASH sizes supported: 128M bits.
    Video Decoder
    ISO/IEC 11172-2 MPEG1.
    ISO/IEC 13818-2 MPEG2 MP@HL.
    ISO/IEC 14496 MPEG4 compliant Support SP@L3 to ASP@L5.
    H.263 (short Header).
    DivX3.11/DivX4/DivX5/DivX6(Optional).
    Xvid.
    ISO/IEC 14496-10 AVC high profile@level 4.1 main profile@level 4.1.
    RealVideo 8/9/10(Optional).
    JPEG base-line.
    Supports out-loop de-blocking for MPEG1/2/4.
    Supports Dview function.
    Supports de-interlace flag generation.
    Supports 3:2 pull down detection.
    Display Engine
    Up to 2 video planes and 2 graphic planes (BG + Main video + Auxiliary video + Graphic 1 + Graphic 2).
    High quality scaling for both HD and SD outputs.
    Built-in video enhancements.
    High quality motion adaptive and EPEC (edge preserve and edge compensation) de-interlace.
    High efficient solution for dual output applications.
    Up to 32bit aRGB true color and CLUT graphic planes input.
    High quality scaling with EP(edge preserve) for both graphic planes.
    Advanced algorithms of anti-flicker for both graphic planes.
    Graphic Engine
    Command DMA to speed up graphic operations.
    Multiform Source Format for up to 32bit true color and CLUT.
    Multiform Destination Format for up to 32bit true color and CLUT.
    Supported operations.
    Color expansion, correction and color space conversion.
    Draw horizontal line, draw rectangular window with or without color filling.
    Bitblt operation.
    BOP (bit operation).
    Alpha blending and dithering.
    Resize.
    RLE8/RLE16/RLE24/RLE32 decoder.
    Flexible mask layer to support arbitrary application.
    Audio Decoder
    Volume(Target volume can be set by 8 bits [7:0]).
    Fading(Increase/Decrease speed can be set by Fade speed) (how many samples inc/decrease at one time).
    SCR counter(Two SCR counters, driven by 27MHz clock).
    PTS check(there is a threshold for PTS check, if(SCR>=(PTS-THR)), music plays; else music pauses).
    DVBS2
    Integrates dual 8-bit ADC supporting differential and single-end modes.
    Supports DVB-S QPSK.
    Supports DVB-S2 QPSK/8PSK/16APSK/32APSK.
    Supports DVB-S2 pilot signal.
    Integrates LDPC and BCH decoders.
    Supports DVB-S2 QPSK FEC code rates 1/4, 1/3, 2/5, 1/2, 3/5, 2/3, 3/4, 4/5, 5/6, 8/9, 9/10.
    Supports DVB-S2 8PSK FEC code rates 3/5, 2/3, 3/4, 5/6, 8/9, 9/10.
    Supports DVB-S2 16APSK FEC code rates 2/3, 3/4, 4/5, 5/6, 8/9, 9/10.
    Supports DVB-S2 32APSK FEC code rates 3/4, 4/5, 5/6, 8/9, 9/10.
    Supports DVB-S QPSK FEC code rates 1/2, 2/3, 3/4, 5/6, 7/8.
    Supports DiSEqC 2.0.
    Qviart unic este un receptor satelit dvb-s2 HD de dimensiuni mici
    suportul tehnic este asigurat de catre TEAM Prometheus
    functioneaza pe baza sistemului IKS
    poate fi conectat la internet prin intermediul antenei wifi
    actualizarea firmware se poate face online sau prin intermediul unui stick usb
    ca media player este capabil sa reproduca si fisiere MKV 1080
    are integrat unele functii auxiliare ca de exemplu:
    -iptv
    -youtube
    -youporn
    -grooveshark
    -meteo
    -media player
    -aplicatii web
    -jocuri
    -wifi
    in partea din fata se gasesc butonul pe pornit/oprit ,senzorul optic al telecomenzii si o clapeta unde in interior gasim o intrare usb
    in partea din spate se gasesc urmatoarele:
    - intrare pentru conectarea antenei parabolice
    - iesire loop
    -intrare usb destinata antenei wifi
    -intrare rs232
    -mufa rca coaxial
    -intrare hdmi
    -intrare euroscart
    -cititor card
    -intrare lan
    -buton general pornit/oprit
    -cablu de alimentare
    telecomanda este de dimensiuni mici si subtire
    antena wifi conectata prin intermediul mufei usb situata in spatele receptorului dezactiveaza mufa lan
    acest receptor a fost achizitionat in spania la pretul de 119 euro iar cablul hdmi fiind oferit ca (regalo)cadou la achizitionarea unui receptor satelit indiferent de pret/model
    aceasta este o practica frecventa la unele magazine de specialitate din spania
    mai demult au fost oferite busole,cablu null-modem,adaptor ubs-rs232,lnb inverto eco
    7 Post(s)
    O noua clona bazata pe cpu ali destul de stabila pentru cine se multumeste ca, si client.
    este lumina si la nordici 1W
    inclusiv canale HD
    verificat zi de zi in fiecare saptamana
    thx to@Prometheus
    ---------- Post added at 22:10 ---------- Previous post was at 21:04 ----------
    atasez foto cu lista de canale
    cine doreste sa achizitioneze un astfel de receptor satelit are ocazia sa-l achizitioneze din finlanda la pretul de €69.00 +transport
    hxxp://www.satshop.fi/digiboksit/dvb-s2/qviart-unic.html
    din pacate in spania este mai scump Euro 119,00 +transport
    succes tuturor
    Lista cu sateliti care functioneaza pe serverul Prometheus in receptoarele din familia QVIART (iks)
    Hispasat [30.0W]
    NSS 7/4 [22.0W]
    Nilesat [7.0W]
    Eutelsat 5 [5.0W]
    Amos 2/3 [4.0W]
    Thor 5/6 [1.0W]
    Eutelsat 3C [3.0E]
    Astra 4A [5.0E]
    Eutelsat 7A [7.0E]
    Eutelsat 9A [9.0E]
    Hotbird [13.0E]
    Eutelsat 16A [16.0E]
    Astra1 [19.2E]
    Badr 4/5/6 [26.0E]
    Astra 2 [28.2E]
    Eutelsat36A/B [36.0E]
    Hellas Sat 2 [39.0E]
    Intelsat 12 [45.0E]
    10:Iraq LocalSAT [1.0E]
    30:Eutelsat 3C [3.0E]
    50:Astra 4A [5.0E
    70:Eutelsat 7A [7.0E]
    90:Eutelsat 9A [9.0E]
    130:Hotbird [13.0E]
    160:Eutelsat 16A [16.0E]
    192:Astra1 [19.2E]
    260:Badr 4/5/6 [26.0E]
    282:Astra 2 [28.2E]
    360:Eutelsat36A/B [36.0E]
    390:Hellas Sat 2 [39.0E]
    450:Intelsat 12 [45.0E]
    560:Bonum 1 [56.0E]
    600:Intelsat 904 [60.0E]
    685:Intelsat 7/10 [68.5E]
    750:ABS 1 [75.0E]
    785:Thaicom 5 [78.5E]
    850:Intelsat 15 [85.0E]
    915:Measat 3/3a [91.5E]
    950:NSS 6 [95.0E]
    1320:Vinasat 1 [132.0E]
    1400:Express AM3 [140.0E]
    2410:Anik F3 [119.0W]
    2500:EchoStar10/11 [110.0W]
    2690:Nimiq 1 [91.0W]
    2710:Galaxy 28 [89.0W]
    2900:Star One C2 [70.0W]
    2990:EchoStar 12/15 [61.0W]
    3020:Intelsat 9/16 [58.0W]
    3170:Intelsat 11 [43.0W]
    3300:Hispasat [30.0W]
    3380:NSS 7/4 [22.0W]
    3530:Nilesat [7.0W]
    3550:Eutelsat 5 [5.0W]
    3560:Amos 2/3 [4.0W]
    3590:Thor 5/6 [1.0W]
    sursa : prometheus-team
    si acum sa verificam sateliti din lista de mai sus
    850:Intelsat 15 [85.0E]------------in banda KU nimic
    750:ABS 1 [75.0E]-----------------in banda KU nimic
    685:Intelsat 7/10 [68.5E]----------in banda KU nimic
    11635 V DVB-S2/8PSK MPEG-4 29700 2/3--- fta now
    11675 V DVB-S2/8PSK MPEG-4 29700 2/3--- fta now
    560:Bonum 1 [56.0E
    este o singura frecventa in lista dar inactiva si cu acoperire numai pe Siberia
    Express-AT1 @ 56° East ------------in banda KU nimic
    450:Intelsat 12 [45.0E]--------------in banda KU nimic
    11135 V DVB-S2/8PSK MPEG-4 30000 2/3------Arena Sport 1 ,Prva Srpska TV
    11488 H DVB-S2/8PSK MPEG-4 2510 5/6-------Kentron TV (cu key biss)
    12524 H DVB-S/MPEG-2 30000 7/8------Planeta TV, bTV, Nova TV Bulgaria, KinoNova, Diema--(cu key biss)
    12565 H DVB-S/MPEG-2 30000 7/8------Disney Channel Bulgaria (cu iks), DM Sat (cu iks) , Fox Bulgaria, (cu key biss)
    12688 H DVB-S/MPEG-2 30000 7/8------Diema Family, National Geographic Channel Bulgaria, Nova Sport Bulgaria, AXN Bulgaria, Fox Life Bulgaria, Fox Crime Bulgaria, -- (cu key biss)
    12092 R DVB-S/MPEG-2 27500 3/4----------------History Russia, Travel Channel Europe,Sport 1 (Russia), Sport Russia, Boytsovskiy Klub,Telekanal 2x2 (0h)-----(cu iks)
    12476 R DVB-S/MPEG-2 27500 3/4 ----------------toate -----(cu iks)
    282:Astra 2 [28.2E]--iks
    11224 V DVB-S/MPEG-2/DVB-S/MPEG-4 27500 2/3--NickToons Ireland
    11261 H DVB-S/MPEG-2 27500 2/3--Star Plus UK, Star Gold UK, 3e, Crime & Investigation Network UK, TCM UK +1
    11307 H DVB-S/MPEG-2 27500 2/3--Movies 24 UK,
    11344 H DVB-S/MPEG-2 27500 2/3--E! UK
    11389 H DVB-S/MPEG-2 27500 2/3--Investigation Discovery Europa, Animal Planet Europe +1,Discovery Science Channel UK +1, DMAX UK,Quest +1, Discovery History +1,Discovery Shed,TLC UK +1,Discovery Home & Health UK +1. (toate dar cu sacadari)
    11817 V DVB-S/MPEG-2 27500 2/3--Home, Eden, GOLD UK, Yesterday, Dave UK,(Drama-cu sacadari)
    11836 H DVB-S/MPEG-2 27500 2/3--toate
    11876 H DVB-S/MPEG-2 27500 2/3--toate
    11895 V DVB-S/MPEG-2 27500 2/3--toate
    11914 H DVB-S/MPEG-2 27500 2/3--toate
    11992 H DVB-S/MPEG-2 27500 2/3--Dave Ireland
    12051 V DVB-S/MPEG-2 27500 2/3--SET Asia
    12070 H DVB-S/MPEG-2 27500 2/3--Sky Sports Active Lo 8
    12110 H DVB-S/MPEG-2 27500 2/3--Sky Sports 1 UK, Fox UK, Sky Sports F1, Sky Sports 2 Ireland, Sky Sports 3, Sky Sports 1 UK,PBS America
    12148 H DVB-S/MPEG-2 27500 2/3--Sky Sports 1 Ireland, Sky Sports 1 in Pubs (Mon, Sat, Sun),Sky Sports News Ireland,Sky Sports 4,
    12188 H DVB-S/MPEG-2 27500 2/3--At The Races UK, Fox News Channel, Crime & Investigation Network UK, National Geographic Channel UK ,Nat Geo Wild UK
    12207 V DVB-S/MPEG-2 27500 2/3--Sky 1 Ireland, Sky 2 UK
    12285 V DVB-S/MPEG-2 27500 2/3--Sky One UK, Chelsea TV, Sky Living HD UK (SD),
    12460 H DVB-S2/QPSK/MPEG-4 29500 3/4--Sky News HD,
    12480 V DVB-S/MPEG-2 27500 2/3--Channel 4 Ireland
    12663 H DVB-S/MPEG-2 22000 5/6--Nollywood Movies
    Astra 3B @ 23.5° East [ 23.5E]
    11739 V DVB-S2/8PSK 27500 2/3--NPO Politiek (06-1, NPO Best (18-06), NPO Doc, JimJam Europe, Animal Planet Benelux, Disney Channel Benelux, NPO 2 HD, SBS 6 HD, Fox Sports Eredivisie 1 HD, HBO 2 Nederland, HBO 3 Nederland
    11798 H DVB-S2/8PSK MPEG-4 27500 5/6--toate
    11836 H DVB-S/MPEG-2 27500 5/6--toate--con flores-STV1 (Jednotka), STV2 (Dvojka)
    11856 V DVB-S2/8PSK MPEG-4 27500 2/3--toate ,infara de VTM HD, Viasat History HD
    11895 V DVB-S/MPEG-2 27500 5/6-toate
    11914 H DVB-S/MPEG-2/4 27500 5/6--Discovery CZ, Disney CZ, Film+CZ, Fine Living, Hustler HD (00-06 CET),
    11934 V DVB-S2/8PSK MPEG-2/4 27500 3/4--EroX HD, RTVS HD, CT 1 HD,
    11973 V DVB-S/MPEG-2/4 27500 5/6--TV Fanda, Nova Cinema,
    12032 H DVB-S2/QPSK 27500 9/10-AutoMotorSport HD
    12070 H DVB-S/MPEG-2 27500 3/4--toate
    12110 H DVB-S2/8PSK 27500 3/4-- toate ,infara de dokuCS, Eurosport HD, Travel Channel HD, kino CS, Film Europe Channel,
    12129 V DVB-S2/8PSK MPEG-4 27500 2/3--todos pero sin PTV, TLC Nederland, Jim, Kanaal Z (Timesharing)
    12168 V DVB-S/MPEG-2 27500 3/4--WAU
    12188 H DVB-S2/8PSK MPEG-4 27500 2/3-- toate ,infara de Fox Sports Eredivisie 2 HD
    12207 V DVB-S2/8PSK MPEG-4 27500 5/6--M2, The Fishing and Hunting Channel, HBO 2 Central Europe, Cinemax Central Europe, Universal Channel Czechia,
    Sport 1 Czechia, Brava HDTV, iConcerts, Nat Geo Wild Europe HD, National Geographic Channel HD Europe
    12525 V DVB-S/MPEG-2 27500 3/4-- toate ,infara de -CT 1 Jizni Morava , CT 1 Cechy, CT 2, CT Sport,
    Astra1 [19.2E]
    10729 V DVB-S2/8PSK MPEG-4 22000 2/3---AXN España HD, Canal+ Comedia HD, Canal+ Liga HD,
    10758 V DVB-S/MPEG-2 22000 5/6-- toate ,infara de México Travel Channel
    10773 H DVB-S2/8PSK MPEG-4 22000 3/4--Nickelodeon Deutschland HD, N 24 HD
    10803 H DVB-S2/8PSK MPEG-4 22000 3/4--Disney Channel Deutschland HD
    10818 V DVB-S2/8PSK MPEG-4 22000 2/3--toate
    10832 H DVB-S2/8PSK MPEG-4 22000 2/3--toate
    10876 V DVB-S/MPEG-2 22000 5/6--toate
    10921 H DVB-S/MPEG-2 22000 7/8--toate
    10936 V DVB-S2/8PSK MPEG-4 22000 2/3--toate
    10964 H DVB-S2/8PSK MPEG-4 22000 2/3--TLC HD Deutschland
    10979 V DVB-S/MPEG-2 22000 5/6--toate
    11038 V DVB-S/MPEG-2 22000 5/6--toate
    11068 V DVB-S/MPEG-2/4 22000 5/6--L'Équipe 21
    11082 H DVB-S2/8PSK MPEG-4 22000 3/4--RTL HD Österreich, RTL Nitro HD,
    11127 V DVB-S2/8PSK MPEG-4 22000 2/3--todos
    11156 V DVB-S/MPEG-2 22000 5/6--Disney XD España,Cosmopolitan TV Europa,Canal de Historia,TVI Internacional, D Cine Español, Canal 24 Horas
    11244 H DVB-S/MPEG-2/4 22000 5/6--toate
    11259 V DVB-S2/8PSK 22000 2/3--toate
    11303 H DVB-S2/8PSK 22000 2/3--toate
    11318 V DVB-S/MPEG-2 22000 5/6-- toate ,infara de Nova, El Garage TV
    11332 H DVB-S2/8PSK MPEG-4 22000 3/4--Sky HD FanZone, Sport1 US HD, Fox Deutschland HD, AXN HD Deutschland,
    11377 V DVB-S2/8PSK 22000 2/3--toate
    11421 H DVB-S/MPEG-2 22000 5/6--Sat.1 Emotions,
    11436 V DVB-S2/8PSK 22000 2/3--toate
    11464 H DVB-S2/8PSK 22000 2/3-- toate ,infara de ProSieben MAXX HD
    11479 V DVB-S/MPEG-2 22000 5/6--toate ,infara de M6 Music Hits, Pink TV, Libido TV,
    11538 V DVB-S/MPEG-2 22000 5/6--toate
    11553 H DVB-S2/8PSK MPEG-4 22000 3/4--toate
    11568 V DVB-S/MPEG-2 22000 5/6-- toate ,infara de OMTV, OL TV
    11597 V DVB-S/MPEG-2 22000 5/6--RMC Découverte
    11686 V DVB-S/MPEG-2 22000 5/6--toate
    11720 H DVB-S/MPEG-2 27500 3/4--Sky Sport News, Sky Hits Deutschland, The MGM Channel Deutschland, Sky Nostalgie
    11739 V DVB-S/MPEG-2 27500 3/4--toate
    11758 H DVB-S/MPEG-2 27500 3/4--Junior, Heimatkanal,Disney Junior Deutschland ,Disney XD Deutschland,Sky Atlantic,Syfy Deutschland, GoldStar TV
    11778 V DVB-S/MPEG-2/4 27500 3/4--Chérie 25 HD
    11798 H DVB-S/MPEG-2 27500 3/4--toate
    11817 V DVB-S2/8PSK MPEG-4 29700 2/3--MTV Base HD France, MTV France HD, Planète + Thalassa HD,OCS Choc HD, Jimmy HD France
    11856 V DVB-S/MPEG-2 27500 3/4--toate
    11876 H DVB-S2/8PSK MPEG-4 27500 3/4--Universal Channel HD, ProSieben Fun HD
    11895 V DVB-S/MPEG-2 27500 3/4--toate
    11914 H DVB-S2/QPSK MPEG-4 27500 9/10-Nat Geo Wild HD Deutschland, Sky Sport HD, Discovery HD Deutschland, Sky Cinema HD,
    11934 V DVB-S/MPEG-2 27500 3/4-- toate ,infara de Voyage
    11973 V DVB-S/MPEG-2 27500 3/4--toate
    11992 H DVB-S2/QPSK MPEG-4 27500 9/10-Sky Atlantic HD, Disney Cinemagic Deutschland HD,National Geographic Channel Deutschland HD, Sky Sport HD 2 Deutschland, 13th Street Deutschland HD
    12012 V DVB-S2/8PSK 29700 2/3--toate
    12032 H DVB-S/MPEG-2 27500 3/4-- toate ,infara de Blue Movie Info
    12051 V DVB-S/MPEG-2 27500 3/4--Puls 4 Austria
    12070 H DVB-S/MPEG-2 27500 3/4-- toate ,infara de Blue Movie 1/2/3
    12090 V DVB-S2/8PSK MPEG-4 29700 2/3-- toate ,infara de Non Stop People HD, Eurosport 2 HD
    12129 V DVB-S2/8PSK MPEG-4 29700 2/3-- toate ,infara de Brava HD, Penthouse HD
    12168 V DVB-S2/8PSK 29700 2/3--toate
    12188 H DVB-S/MPEG-2 27500 3/4--RTL Living
    12207 V DVB-S2/8PSK 29700 2/3-- toate ,infara de Djazz TV HD
    12246 V DVB-S2/8PSK MPEG-4 29700 2/3--toate
    12304 H DVB-S2/QPSK MPEG-4 27500 9/10-Sky Bundesliga 1, Sky Hits Deutschland HD, Sky Sport News HD, MGM HD Channel Deutschland, Syfy Deutschland HD
    12324 V DVB-S/MPEG-2/4 27500 3/4--Cartoon Network France, TiJi,
    12382 H DVB-S2/QPSK MPEG-4 27500 9/10-History Deutschland HD, Sky Action HD Deutschland, Sport1+ HD, TNT Serie HD, Eurosport Deutschland HD
    12402 V DVB-S/MPEG-2 27500 3/4--toate
    12441 V DVB-S2/8PSK 29700 2/3-- toate ,infara de Mezzo Live HD, M6 Music Player HD
    12515 H DVB-S/MPEG-2 22000 5/6--toate
    12522 V DVB-S/MPEG-2 22000 5/6--toate
    12545 H DVB-S/MPEG-2 22000 5/6--Kabel 1 Classics
    12552 V DVB-S/MPEG-2/4 22000 5/6--NT1
    12574 H DVB-S2/8PSK MPEG-4 22000 2/3--Tele 5 HD, DMAX HD
    12581 V DVB-S/MPEG-2 22000 5/6--toate
    12610 V DVB-S/MPEG-2 22000 5/6--toate
    12640 V DVB-S/MPEG-2 22000 5/6--toate
    12670 V DVB-S2/8PSK MPEG-4 22000 5/6--****+ 24/24, Multisports 1,
    12692 H DVB-S/MPEG-2 22000 5/6--toate
    12699 V DVB-S/MPEG-2 22000 5/6--toate
    12722 H DVB-S2/8PSK MPEG-2/4 23500 2/3--Één, 2BE, VIER, VIJF, Sportdigital TV, La Une HD, La Trois, RTL-TVi HD, Club-RTL, Hustler TV Europe
    ---------- Post added at 19:42 ---------- Previous post was at 17:50 ----------
    10720 H DVB-S/MPEG-2 27500 3/4-- HRT 2, HRT 3
    10845 H DVB-S2/8PSK MPEG-4 30000 3/5--SuperSport HD 1
    11151 V DVB-S2/8PSK MPEG-4 13268 2/3--Pink Premium
    11400 V DVB-S2/8PSK MPEG-2/4 13845 3/4--toate
    11426 V DVB-S2/8PSK MPEG-4 27500 3/4--toate
    11512 H DVB-S2/8PSK MPEG-4 30000 3/4--toate
    11595 H DVB-S2/8PSK MPEG-4 30000 3/4--Nickelodeon, AXN Adria, Arena 2 HD, Sport Klub 1, Extreme Sports Channel,E! Entertainment TV,CMC ,VH1 Classic Europe, Disney Channel Croatia, Fox Adria, Fox Movies, HRT 1,
    11678 H DVB-S2/8PSK MPEG-4 30000 3/4--Crime & Investigation Network, Viasat Nature East, 24 Kitchen, TLC Europe, Klasik TV,RTL Hrvatska,Nova TV Croatia,RTL 2 Croatia, Doma TV,Arena 1 HD
    130:Hotbird [13.0E]
    10719 V DVB-S/MPEG-2 27500 5/6-- toate in afara de MiniMini+, Strefa Abonenta nc+,
    10723 H DVB-S/MPEG-2 29900 3/4--BRAZZERS TV EUROPEpps:pps:pps:
    10758 V DVB-S2/8PSK MPEG-4 27500 3/4--VOD 152,VOD 161, VOD 165,E! Entertainment TV,Da Vinci Learning,CBS Action, TVP Rozrywka, TV Republika,FilmBox Arthouse
    10775 H DVB-S/MPEG-2 29900 5/6--toate in afara de Fox Crime Italia +2, JimJam Italia +1,Planet Kids, Nick Jr Italia +1, DeA Kids +1
    (Fox Life +2 Italia,Fox Life +1 Italia----freeze)
    10796 V DVB-S/MPEG-2 27500 5/6--toate in afara de TVP Seriale,
    10815 H DVB-S/MPEG-2 27500 5/6--Baby TV Europe
    10834 V DVB-S2/8PSK MPEG-4 27500 3/4--HBO Comedy HD Polska,HBO 2 HD Polska,Motowizja TV, BBC Knowledge HD,BBC HD Nordic,TVP Historia
    10873 V DVB-S/MPEG-2 27500 3/4--Al Aoula Maroc (con flores biss)
    10892 H DVB-S/MPEG-2 27500 3/4--toate in afara de Domo+
    10911 V DVB-S/8PSK MPEG-4 27500 3/4--toate in afara de Sundance Channel Europe HD
    10949 V DVB-S/MPEG-2 27500 3/4--toate
    10971 H DVB-S2/8PSK 29700 2/3--toate
    10992 V DVB-S/MPEG-2 27500 2/3--Rai Movie, Rai 4
    11075 V DVB-S/MPEG-2 27500 3/4--toate in afara de Viva Polska,Viacom Blink!
    11117 V DVB-S/MPEG-2/4 27500 3/4--toate
    11137 H DVB-S/MPEG-2 27500 3/4--Crime + Investigation UK
    11158 V DVB-S/MPEG-2 27500 5/6--toate
    11179 H DVB-S/MPEG-2 27500 3/4--PRIVATE TV
    11219 H DVB-S/MPEG-2/4 29900 5/6--(Disney Junior Italia +1,Cartoon Network Italia,Disney XD Italia,Lei TV,Disney Junior Italia +1,Caccia e Pesca-freeze)
    11240 V DVB-S/MPEG-2 27500 3/4--EuroSport International,Greek(2577),ESP2 Serbia, EuroSport PL,ESP3NE Serbian
    11258 H DVB-S2/8PSK 27500 3/4--TVP HD, Animal Planet Europe HD, Nat Geo Wild Europe HD,Eurosport 2 North-East HD,
    11278 V DVB-S2/8PSK MPEG-4 27500 3/4--MiniMini+ HD,Canal+ HD Polska,Eurosport HD,Eurosport HD PL,National Geographic Channel HD Polska,Canal + Sport HD
    11334 H DVB-S/MPEG-2 27500 3/4--toate
    11355 V DVB-S/MPEG-2 29900 5/6--(Discovery Science,Discovery Travel & Living Europe,Nick Junior,MTV Music,MTV Dance,MTV Classic,LEI +1 no freeze )
    11373 H DVB-S/MPEG-2 29900 3/4--Canale 5,Iris,Boing,TOPcrime.
    11393 V DVB-S/MPEG-2 27500 5/6--toate
    11411 H DVB-S2/8PSK MPEG-4 27500 5/6-- toate in afara de Ale Kino!+ HD,Kuchnia+ HD.
    11449 H DVB-S2/8PSK MPEG-4 27500 3/4--MGM HD, nSport+ HD,Romance TV Polska HD,TVP 1 HD,Discovery Channel HD Polska.
    11471 V DVB-S/MPEG-2/4 27500 5/6--Nickelodeon HD,Nick Junior Eastern Europe.
    11488 H DVB-S/MPEG-2 27500 5/6-- toate in afara de CBS Drama.
    11508 V DVB-S2/8PSK MPEG-4 27500 3/4--toate in afara de Puls 2,Adventure TV HD,test6.
    11526 H DVB-S/MPEG-2/4 27500 3/4--toate
    11541 V DVB-S/MPEG-2 22000 5/6--Deejay TV,La 7,MTV Italia
    11585 V DVB-S/MPEG-2 27500 3/4--TV Globo Internacional Europa-África (cu key )
    11623 V DVB-S/MPEG-2/4 27500 3/4--Mezzo
    11662 V DVB-S2/8PSK MPEG-2/4 27500 3/4--Redlight 3D-HD,Hustler HD 3D, :fiesta::fiesta:
    11681 H DVB-S2/8PSK MPEG-4 27500 3/4--toate
    11727 V DVB-S/MPEG-2/4 27500 3/4--toate
    11766 V DVB-S/MPEG-2/4 27500 2/3-- toate pps:pps:pps:
    11785 H DVB-S2/8PSK MPEG-2/4 29900 3/4--(Fox Italia HD,Fox Crime Italia HD,Crime + Investigation Italy HD,Sky Atlantic HD -no freeze )
    11804 V DVB-S/MPEG-2 27500 2/3--Rai Premium
    11843 V DVB-S2/8PSK MPEG-4 29900 3/4--(Fox Sports Italia HD,Sky Cinema Max +1 HD,Sky Cinema +1 HD,Sky Calcio 8 HD,Sky Calcio 7 HD -no freeze )
    11862 H DVB-S/MPEG-2 29900 5/6--(Sky TG24,Sky TG 24 Rassegne,Sky TG24, POKERItalia24 cu freeze )
    11881 V DVB-S/MPEG-2 27500 3/4--National Geographic Channel Italia
    11900 H DVB-S2/8PSK MPEG-4 29900 3/4--(Sky Sport F1 HD,MosaicoFormu1HD, Sky Uno HD, On Board Sky HD, ON Board Mix HD,Sky Moto GP Fake -no freeze )
    11958 V DVB-S/MPEG-2 27500 3/4--(Sky Sport 1,Sky Sport 2, Sky SuperCalcio, Sky Sport 24, no freeze ) ,----------(Sky Sport Active 1, cu freeze )
    11977 H DVB-S/MPEG-2 29900 5/6--(The History Channel Italia,Fox Crime Italia,Fox Life Italia, Cinema Cult,Nat Geo Wild Italia,Fox Italia, no freeze ) ----------(Sky News International, cu freeze )
    11996 V DVB-S2/8PSK MPEG-4 29900 3/4-- toate no freeze
    12034 V DVB-S/MPEG-2 29900 5/6-- toate in afara de TV 2000,AXN Sci-Fi Italia,AXN Italia +1
    12054 H DVB-S/MPEG-2 29900 5/6--toate in afara de MTV Hits Italia,MTV Rocks,Cinema itv,Sky Prima Fila 20.
    12073 V DVB-S/MPEG-2 29900 5/6--Sky Prima Fila 3,Eurosport 2 Italia.
    12092 H DVB-S2/8PSK MPEG-4 29900 3/4--(Gambero Rosso HD,Fox Life HD ,Nat Geo People HD,Cinema Cult HD no freeze )
    12188 V DVB-S/MPEG-2 27500 5/6-- toate in afara de Polsat Viasat Explorer , Polsat Viasat History,Discovery Channel Polska.
    12207 H DVB-S2/8PSK 29900 3/4-- toate no freeze , in afara de Sky 3D Italia
    12265 V DVB-S2/8PSK MPEG-4 27500 3/4-- toate in afara de Polsat Sport Extra HD,Cinemax 2 Central Europe HD.
    12284 H DVB-S/MPEG-2 27500 5/6-- toate in afara de MTV Rocks UK
    12303 V DVB-S2/8PSK MPEG-4 27500 3/4--Equidia
    12322 H DVB-S/MPEG-2 27500 3/4--Dorcel TVpps:pps:pps: ,RTV International Europe
    12341 V DVB-S2/8PSK 29900 3/4--(Sky Cinema 1 HD,Sky Calcio 3 HD,Sky Cinema Max HD ,Sky Calcio 4 HD. no freeze )
    12360 H DVB-S2/8PSK MPEG-4 29900 3/4-- toate no freeze
    12399 H DVB-S/MPEG-2/4 27500 3/4--toate
    12418 V DVB-S2/8PSK MPEG-4 29900 3/4--Calcio1Magaz HD,Sky Calcio 2 HD,Sky Calcio 5 HD,Sky Calcio 6 HD
    12466 V DVB-S/MPEG-2 29900 5/6--Sky Sport F1,Sky Sport Plus, no freeze
    12476 H DVB-S2/8PSK MPEG-2/4 29900 3/4--FRENCHLOVERpps:pps:pps:
    12597 V DVB-S/MPEG-2 27500 3/4--CNN International Europe,JSTV 1 (Japan Satellite TV).
    12616 H DVB-S/MPEG-2 29900 5/6--(Nickelodeon Italia,Baby TV Europe, Boomerang Italia +1 no freeze ) ( ,Discovery Channel Italia +1, cu freeze )
    12635 V DVB-S/MPEG-2 29900 5/6--(Disney XD Italia +2,Disney Channel English, DeASuper!, Animal Planet Italia, no freeze ) ------------ (Disney XD Italia +1, cu freeze )
    12673 V DVB-S/MPEG-2 29900 5/6--(Sky Prima Fila 22pps:pps:pps:, Sky Prima Fila 2, no freeze )
    12692 H DVB-S2/8PSK MPEG-2/4 27500 3/4--toate
    12713 V DVB-S/MPEG-2 DVB-S/MPEG-4 29900 5/6--Sky Prima Fila 23,24,25,26,27 pps:pps:pps:pps:
    12731 H DVB-S2/8PSK MPEG-4 29900 3/4-- toate no freeze , in afara de DeA Sapere HD
    17 Nov 2008
    ALBA
    Pe 1w deschide ceva?
    Thor 5/6 [1.0W]
    10809 V DVB-S/MPEG-2 24500 7/8--TV 8 Sweden, Disney Channel Skandinavien, Disney XD.
    10934 V DVB-S/MPEG-2 24500 7/8--Nickelodeon Scandinavia (06-1, Motors TV,
    10934 H DVB-S2/8PSK 25000 3/4--C More First HD Nordic, Canal 9 Denmark HD.
    11216 V DVB-S/MPEG-2 24500 7/8--TV4 Fakta
    11229 H DVB-S/MPEG-2 24500 7/8--Animal Planet Scandinavia.
    11261 H DVB-S/MPEG-2 24500 7/8--C More Live.
    11278 V DVB-S/MPEG-2 24500 7/8--C More Sport,C More First.
    11727 V DVB-S/MPEG-2 28000 7/8--toate
    11747 H DVB-S/MPEG-2 28000 5/6--Nickelodeon Hungary,The Fishing and Hunting Channel,DoQ,MTV Europe,Filmbox Extra.
    11766 V DVB-S/MPEG-2 28000 7/8--toate
    11785 H DVB-S2/8PSK 30000 3/4--Nat Geo Wild Europe HD,Animal Planet Europe HD
    11804 V DVB-S/MPEG-2 28000 7/8--todos,pero sin Ócko TV,Spektrum Home.
    11823 H DVB-S2/8PSKMPEG-4 30000 5/6--M1 HD,Digi Sport 1 HD Hungary,Digi Sport 2 HD Hungary,TV 2 HD Hungary.
    11843 V DVB-S2/8PSK 30000 3/4-- toate ,in afara de HBO HD Czechia info card
    11900 H DVB-S/MPEG-2 28000 5/6-- toate ,in afara de Filmbox Extra,Story 5,Agro TV.
    11938 H DVB-S/MPEG-2 28000 7/8--toate
    11996 V DVB-S/MPEG-2 28000 7/8--toate
    12015 H DVB-S2/8PSK 30000 3/4--Discovery HD Showcase,History HD UK,Travel Channel HD Europe.
    12034 V DVB-S2/8PSK 30000 3/4--Sport 1 Hungary HD,RTL Klub HD,Sport 2 HD Czechia
    12073 V DVB-S/MPEG-2 28000 7/8--toate
    12092 H DVB-S/MPEG-2/4 28000 7/8--AXN White,AXN Central Europe,AXN Czechia
    12111 V DVB-S/MPEG-2 28000 7/8--toate ,in afara de TVR 3,Slovak Sport 2,Euforia Lifestyle,Discovery World (SVT) , Discovery Science (SVT)
    12188 V DVB-S/MPEG-2 28000 7/8--toate ,in afara de Megamax RO
    12226 V DVB-S/MPEG-2 27500 5/6--Paramount Channel Hungary,Viva TV Hungary,Comedy Central Hungary,Nickelodeon Europe,MTV Europe,VH1 Europe A,MTV Hits International,MTV Dance International, VH1 Classic European.
    12265 V DVB-S/MPEG-2 28000 7/8--toate
    12380 V DVB-S/MPEG-2 28000 5/6--TLC Rômania,Universal Channel Czechia
    12456 V DVB-S/MPEG-2 28000 7/8--Look Plus
    12527 H DVB-S/MPEG-2 27500 3/4--toate
    12563 H DVB-S/MPEG-2 27500 3/4--Disney Channel Hungary & Czechia,
    Music Channel Hungary,Sport 1 Hungary,M1,HBO Hungary.
    12563 V DVB-S/MPEG-2 27500 3/4--Magyar Sláger TV.
    12607 H DVB-S/MPEG-2 27500 3/4--DigiFilm,Digi Sport 1 Romania,Travel Channel UK (04-23 Cet), Kanal D Romania .
    12643 H DVB-S/MPEG-2 27500 3/4--DigiFilm HU,TV 2 Hungary,RTL Klub,Digi Sport 2 Hungary,Digi Sport 1 Hungary.
    12643 V DVB-S/MPEG-2 27500 3/4--Digi Sport Slovakia
    12687 H DVB-S/MPEG-2 27500 3/4--EuroSport
    12687 V DVB-S/MPEG-2 27500 3/4--TV Nova,Music Box Slovakia.
    12723 H DVB-S/MPEG-2 27500 3/4--Discovery Science
    11747 H DVB-S2/8PSK MPEG-4 27500 2/3--Digi Sport 1 HD Hungary
    12073 V DVB-S2/8PSK MPEG-4 27500 3/4--Minimax Hungary (06-20),Viasat Nature East.
    12360 H DVB-S2/8PSK MPEG-2/4 27500 2/3--Animal Planet Deutschland,Spiegel TV Wissen HD
    Eutelsat 7A [7.0E]
    10804 V DVB-S/MPEG-2/4 29900 3/4--toate
    10845 V DVB-S/MPEG-2 30000 3/4--toate
    10928 H DVB-S/MPEG-2 30000 3/4--toate
    11455 V DVB-S/MPEG-2 20050 3/4--Bugun TV,Beyaz TV,A Spor
    11471 H DVB-S/MPEG-2 30000 3/4--(NTV Spor,Disney Junior Turkiye,cu iks)(24 TV,TV Net,Ülke TV,MinikaGo,MTV Hits,Cine5, Mehtap TV,Planet Çocuk,cu key)
    11492 V DVB-S/MPEG-2 30000 3/4--(GS TV, cu iks )-------------)TurkMax Gurme,İdman Azerbaijan,Baby TV Europe, cu key)
    11513 H DVB-S/MPEG-2 29900 3/4--(Flash TV, cu iks) -----------(iz TV,Power Turk TV,Samanyolu Haber, cu key)
    11534 V DVB-S/MPEG-2 30000 3/4 --toate ,in afara de Moviemax Premier
    11554 H DVB-S/MPEG-2 30000 3/4--(TV2,Nickelodeon,Turkiye,Investigation Discovery Turkiye, Yumurcak TV ,Duck TV ,Discovery Channel Turkiye ,Discovery Science ,cu iks)--------------(Kanal A,cu key )
    11575 V DVB-S/MPEG-2 30000 3/4--(Show TV,Kanal D Turkiye,Disney XD Turkiye (06-22.45),Show Max,cu iks)---(Bloomberg TV Europe,cu key )
    11596 H DVB-S/MPEG-2 30000 3/4-- (Nick Junior Turkiye,cu iks)-------------(FB TV,Eurosport News,cu key)
    11617 V DVB-S/MPEG-2 30000 3/4--Home TV,National Geographic Channel Turkiye,NAT GEO WILD,si inclusiv toate posturile de radio : 45 buc
    11637 H DVB-S/MPEG-2 30000 3/4--( TGRT Haber, Bloomberg HT,cu iks)-------------------( BJK TV,MGM Channel,TV em,BabyFirst TV,cu key )
    11667 V DVB-S2/QPSK MPEG-4 30000 5/6--BBC HD Nordic
    11678 H DVB-S/MPEG-2 30000 3/4--(Fox Turkiye,ATV Turkiye,Kanal 7 Turkiye, EuroSport, Disney Channel Turkiye, cu iks) -------(360,A Haber,cu key)
    Astra 4A [5.0E]
    11727 H DVB-S/MPEG-2 27500 5/6--Viasat Golf,TV 2 News,DR Ramasjang
    11766 H DVB-S/MPEG-2 27500 3/4--(1+1 International,cu key)
    11804 H DVB-S/MPEG-2 27500 3/4--Viasat Sport Baltics
    11843 H DVB-S/MPEG-2 27500 3/4--Perviy Baltijskyi kanal Latvija,Ren TV Lietuva
    11862 V DVB-S/MPEG-2 27500 3/4--(TV1000 Action East-solo sonido),Viasat Fotboll, Viasat Motor
    11900 V DVB-S/MPEG-2 27500 3/4--toate ,in afara de STS Baltic,Nick Jr Sverige (06-18).
    11938 V DVB-S/MPEG-2 27500 3/4--History Channel Eastern Europe, Ohota i Rybalka,TV 4 Sweden
    11958 H DVB-S/MPEG-2 27500 3/4--TV 3 Latvia,3+,TV 6 Latvija,TV 3 Lietuva, TV 6 Lietuva, LNT Latvia
    12034 H DVB-S/MPEG-2 27500 3/4--VFilm Comedy,Disney XD Scandinavia.
    12054 V DVB-S/MPEG-2 27500 3/4--Disney Junior Scandinavia (06-18),TV 6 Sweden, Cartoon Network Nordic, VFilm Drama
    12130 V DVB-S/MPEG-2/4 27500 3/4--(Ukraina, Football 1 , Ohotnik i Ribolov HD (SD), Football 2,cu iks)-----------(TRK Ukraina SD,NLO TV,cu key)
    12245 V DVB-S/MPEG-2 27500 3/4--TV 1 Lithuania, LNK TV ,Lietuvos Rytas TV,ETV 2 Estonia
    12608 H DVB-S/MPEG-2 27500 3/4--TV1000 Russkoe Kino.
    Eutelsat 3C [3.0E]-------------------nimic in banda KU zero barat
    Amos 2/3 [4.0W]
    10722 H DVB-S/MPEG-2 27500 3/4--Kyïv TV
    11258 H DVB-S/MPEG-2 27500 5/6--toate
    11336 H DVB-S/MPEG-2 27500 5/6--toate ,in afara de Usadba Telekanal, English Club TV , Sony Sci-Fi Russia
    Eutelsat 5 [5.0W]
    11096 V DVB-S2/8PSK 29950 3/4--TF 1 HD, France 2 HD , M6 HD
    11512 V DVB-S/MPEG-2 29950 7/8--ACTION,ANIMAUX,CHASSE ET PECHE
    11554 V DVB-S/MPEG-2 29950 7/8--TF 1,D8, W9, NT1, NRJ 12,BFM TV, D17, Gulli
    Nilesat [7.0W]-----------------antena de 1.90m pe care o detin se dovedeste a fi mica pentru receptia a tuturor frecventelor de pe acest satelit
    NSS 7/4 [22.0W]---------------nimic in banda KU zero barat
    Hispasat [30.0W]
    11731 V DVB-S/MPEG-2 27500 3/4--Caza y Pesca, Cosmopolitan TV Europa, Canal 24 Horas,D Cine Español, cu freeze
    11811 V DVB-S/MPEG-2 27500 3/4--Nick Jr. España,Discovery MAX,Antena Neox,Real Madrid TV Español,Antena 3,PARAMOUNT Channel.
    11851 V DVB-S/MPEG-2 27500 3/4--toate
    11891 V DVB-S/MPEG-2 30000 5/6--toate ,in afara de El Garage TV
    11931 V DVB-S/MPEG-2 27500 3/4--Canal+ Liga Campeones 2,Canal+ LCampeones 2
    12092 V DVB-S/MPEG-2/4 27500 3/4--Disney Channel Portugal
    12130 H DVB-S2/8PSK MPEG-4 27500 3/4-- toate ,in afara de MUTV, Real, Madrid TV Español , Food Network ,C-Music
    12169 H DVB-S2/8PSK MPEG-4 27500 3/4--SIC, SIC Notícias, Syfy Portugal, Sport TV 2, Sporting TV,Motors TV, Discovery Channel Iberia, Sport, TV 3,TVCine 1
    ,TVCine 3,Disney Channel Portugal , Trace Urban English, TVI Ficção (TVI Fiction), A Bola TV , Record News, TPA Internacional
    12207 H DVB-S2/8PSK MPEG-4 27500 3/4--toate ,in afara de Bloomberg TV Europe,RFM TV.
    12226 V DVB-S/MPEG-2 27500 3/4--Divinity,Energy, Motors TV , Canal de las Estrellas Europa
    12246 H DVB-S2/8PSK MPEG-4 27500 3/4--Canal Hollywood Portugal HD,Sport TV 1 HD, Sport TV 2 HD, Sport TV 4 HD, National Geographic Channel HD UK, AXN Portugal HD, Fox Portugal HD, Benfica TV 2 HD.
    12284 H DVB-S2/8PSK MPEG-4 27500 3/4--toate ,in afara de The MGM Channel Portugal,TV Séries, Localvisão TV
    12303 V DVB-S/MPEG-2 27500 3/4--Nickelodeon España
    12322 H DVB-S/MPEG-2 27500 3/4--toate
    12360 H DVB-S/MPEG-2 27500 5/6--toate
    12380 V DVB-S/MPEG-2 27500 3/4--toate
    12398 H DVB-S2/8PSK MPEG-4 27500 3/4--toate
    12437 H DVB-S2/8PSK MPEG-4 27500 3/4--TVCine 4 HD, Discovery HD ,Showcase , Mov HD, E' HD, TVCine 1 HD,SIC Caras.
    12456 V DVB-S/MPEG-2 30000 5/6--Telecinco, Clan TVE, TVE La 1 Madrid, TNT España,Factoria de Ficción, TVE La 2.
    12476 H DVB-S2/8PSK MPEG-4 27500 3/4--SIC Mulher, Fox Movies Portugal, Bio España & Portugal, VH1 Europe A, Mezzo, TVE Internacional Europe, Biggs, EuroNews, Sport TV 5, Toros TV, Disney Junior Portugal.
    cine doreste sa achizitioneze un astfel de receptor satelit are ocazia sa-l achizitioneze din germania la pretul de 129,00 € *+transport
    hxxp://www.satking.de/Empfangstechni...r-Schwarz.html
    succes tuturor
    cine doreste sa achizitioneze un astfel de receptor satelit are ocazia sa-l achizitioneze din italia la pretul de 129,00 € *+transport
    hxxp://www.cesarex.com/decoder-satellitari-qviart-c-148_73_207.html?osCsid=530f64b8c4ca4780e26f5cf7f91904b8
    succes tuturor
    10 Oct 2010
    Mai este de actualitate acum acest receptor?
    IKS este limitat pe o anumita perioada de timp?(un an sau mai mult)
    Qviart Unic
    ---IKS NU este limitat pe o anumita perioada de timp?(un an sau mai mult)----
    acest receptor nu are o anumita perioada/timp predeterminat pentru a functiona pe canale $$$$$$
    numele canalelor care sant marcate cu culoare galbena semnifica vizionarea lor prin sistemul IKS
    este lumina pe mai multi sateliti, dar mai bine priviti pozele de mai jos care au fost facute azi 05.02.2016 la orele care apar in poze
