Thanks Thanks:  7
Results 1 to 3 of 3
Thread: Amiko Americas 1.2.69 for Alien/Alien2
    RSP - TEAM
    03 May 2007
    Default Amiko Americas 1.2.69 for Alien/Alien2
    Cel mai probabil ca deja stiti despre asta, cei de la Amiko au publicat pe site-ul lor, imaginea Spark cu versiunea 1.2.69
    Abia am descarcat-o, nu am ajuns inca sa o pun pe receiver, asa ca nu am inca de facut comentarii, m-am grabit sa dau de veste, poate mai intereseaza si pe altii.
    Amiko Americas 1.2.69 for Alien/Alien2 (download/notes)
    Note: As of 09:45ET 29 Nov 1.2.68 Americas is not yet on Spark Online. It will be available for Spark Online later on.- For authorized NA,SA,NZ,AU STB only!
    - New Amiko graphics & interface, WebTV reloaded
    - NEW MANUAL PID SYSTEM
    - New Import/Export E2 list feature
    - Fixed some bad English
    - EPG event progress on Info bar. (mainly for NZ/AU)
    - Timer fix
    Instructions
    BEFORE DOING ANYTHING!!!
    MAKE A FULL BACKUP OF YOUR ALIEN/ALIEN2! IF YOU CHOSE NOT TO DO SO AND SOMETHING GOES WRONG IT MIGHT HAVE TO COME BACK TO BE RESTORED WHICH IS NOT COVERED BY WARRANTY. BY MAKING A BACKUP YOU CAN FIX ANY ISSUE YOURSELF IN ABOUT 8 MINUTES.
    INSTRUCTIONS: http://www.amikonorthamerica.info/backup
    USB Upgrade Instructions
    1. Unzip the file to the root of your USB flash drive.
    2. Plug into your Alien/Alien2.
    3. Go to MENU > SYSTEM > UPGRADE > UPGRADE FROM USB
    4. Leave upgrade type as “App”
    5. Arrow down to folder and press OK
    6. Navigate to the folder where the upgrade is, select the version.xml, press OK
    7. Press red key to start the upgrade
    DISCLAIMER
    ALL SOFTWARE/FIRMWARE IS USE AT YOUR OWN RISK!
    Amiko Alien (7111): LINK
    Amiko Alien2 (7162): LINK
    18 Jan 2010
    Pitesti
    Buna seara, se pot monta aceste imagini de Spark cu un program de virtualizare?
    E pur si muove
