Results 1 to 3 of 3
Thread: MultiCS r80
    95 Post(s)
    Default MultiCS r80
    MultiCS r80
    * added option to check for via. ecm
    ECM CHECK: <YES/NO>​
    * added option to enable/disable cache filter.
    CACHE FILTER: <YES/NO>​
    * added filter to check for incoming cw from servers/cache with previous stored cws.
    * extended CACHE AUTOADD to enable/disable cache peers after adding them.
    CACHE AUTOADD: YES, <YES/NO>​
    * restructured cache database for memory/cpu optimizations.
    * new http option to download/show in browser some files from your server.
    HTTP FILE: "/var/etc/multics.cfg", "/config" # url = http://server_ip/config​
    tired of payservers and their constantly complaining, added anti-payservers module in cccam and mgcamd servers (the server will suspend if the number of clients watching the same channel reach 100)
    Please test before reply,
    Good night to all.
    Updated stb targets (arm, ppc, mips, sh4, sparc, alpha)
    * changed socketpair() with pipe() due to 'bus error' (thanks to amant for testing mipsel version)
    * removed anti-payserver module as payservers generally use (x32 & x64) versions
    07 Sep 2013
    https://t.me/blackhatshiller
    A se folosi cu cache-ex dat din oscam!
    Merge foarte bine!
    02 Sep 2010
    Earth
    Merge cel mai bine !
    Atentie la configurile pentru multics mai vechi de 80 !!!
    Modificati ca atare parametrii noi.
