Thanks Thanks:  3
Likes Likes:  1
Results 1 to 8 of 8
Thread: Easy BlindScan--CjCr
    Thumbs up Easy BlindScan--CjCr
    Easy BlindScan is a software for make it easy the satellite blind searching.
    A userfriendly GUI for BLScan and StreamReader project by CrazyCat.
    Requirements
    One of these supported devices.
    Windows XP/2003/2008/Vista/7/8 (x86/x64).
    DotNET Framework 4.0
    Internet connection for first registration (Offline activation is also available for special cases).
    Computer with at least P4 3.0+ GHz, 2 GB RAM
    12.5.0.0 (stable) [22 feb 2015]
    - The margin for duplicate transponder is now configurable for 1-10 Mhz method (is also applied to BLScan2 mode)
    - Margin for duplicate transponder is now setup automatically for greek scan methods for better results.
    - Added an option to Ranges to delete selected items & some improvements.
    - Windows 10 detection fix (?).
    - Minor fix for EBSpro Mobile.
    https://www.sendspace.com/file/muon07
    in atentia tuturor userilor
    se poate descarca aplicatia EBSpro gratis
    surpriza este ca odata descarcata/instalata aceasta aplicatie va aparea EBSpro (Lite)15.1.0.1
    succes tuturor
    Thumbs up EBSpro v16.0.0.0
    AFTER A LONG BREAK
    February 26, 2017 cjcr 11
    EBSpro v16 has been released …and now, it is freeware!
    You can use it without any limit. Everywhere.
    The things have been changed, so, I decided that this is the way to go now.
    Your license key will still work in old versions, but after v16 (included) you don’t need to register it. It simply will work.
    Not so much changes this time, but well, it includes great fixes and improvements … and also, a new feature that is in my to-do list looooong time ago.
    Edit (feb 27, 2017):
    Maybe you’re asking yourself why EBSpro is freeware now …
    The main reason is time. I don’t have the free time that I had before, so I can’t offer the kind of support and updates like I did over the years …
    So, to reduce costs and time that I need to dedicate to this, I removed SatFeeds and DVBHispano and also, the support and updates speed of EBSpro.
    Doing this, now I can make EBSpro free of charge.
    As you may know, this means less support and less updates. The donators have been enjoyined of this over the years, but the new users doesn’t have this now, at least not like the costumers.
    Making the EBSpro project alive is what it matters now. I fight for it.
    Highlights
    Now is freeware (all features unlocked)
    Auto dish adjustment (beta) feature in positioner console
    Fixes and improvements.
    Notes
    SatFeeds removed from EBSpro.
    16.0.0.0 (stable) [26 feb 2017]
    - EBSpro is now freeware (all features is now unlocked for all).
    - Added auto dish adjustment (beta) feature in positioner console.*
    - Added SNR bar in positioner console.
    - Removed SatFeeds' related things from EBSpro. Isn't supported anymore.
    - Now shows in a tooltip the ID and status of the selected tuner in the device list.
    - CTRL+F now works in SidePanel Scanner (to search a scanned service or frequency)
    - Fixed MIS detection issues in DT with AU mode (in SA Window)
    - Fixed a potential crash selecting the MIS Id (SA)
    - Fixed a problem with DiSEqC 1.1 when the DiSEqC mode is set to Auto.
    - Fixed a potential lockup of the main UI due to unsafe thread calls.
    - Changed the current "new transponder" sound (yes, the annoying ka-boom) by another one a bit more cool.
    - Some minor fixes and improvements.
    - Updated: StreamReader.dll to 1.2.4.1406.
    * A quick and easy way to fine tune a dish that is connected to a 1.2 DiSEqC (motor). It finds the best signal available checking the SNR value and moving the dish in little steps. P.D: For making it working well, you need at least more than 1-2 dB of SNR and of course, a dvb card that support SNR reading and Diseqc 1.2 support.
    SmartUpdater specific (v2.0.0.3):
    - Fixed an indexOutOfBounds error when the server script isn't working as it should.
    Download: http://cjcr-soft.com/ebspro/EBSpro_s...p_16.0.0.0.exe
    Thumbs up EBSpro BETA v17.0.0.0
    17.0.0.0 (beta) [3 jan 2020]
    - New installer.
    - Move the Ini file handling code to a new library (https://github.com/Cjcr/inifile-vb-csharp)
    - Added initial support to import INI files of transponders from third party applications.
    - Added PotPlayer Auto-Config for media players (https://potplayer.daum.net/)
    - Added MPC-BE Auto-Config for media players (https://sourceforge.net/projects/mpcbe/)
    - Some improvements in TSGrabber UI.
    - Extend rolloff, modulations and FEC list (mainly for DVB-S2X)
    - Maximum symbol rate increased to 70000 Ks.
    - Remove Combo from PLS Mode list.
    - Sometimes "Add" new scan range button doesn't work. Fixed.
    - Some improvements handling satellite profiles.
    - Fixes in copy to clipboard code.
    - Workaround to detect x64 apps in Auto-Config.
    - StreamReader updated to version 1.2.4.83.
    - Some minor improvements and fixes.
    TSA specific (v1.6.0.3):
    - Fixed buffer overflow crash scanning TS in some cases.
    SmartUpdater specific (v2.0.0.5)
    - General optimizations and more faster UI response.
    - Some bugs are fixed.
    http://ebspro.net/download/
    http://cjcr-soft.com/ebspro/EBSpro_b...p_17.0.0.0.exe
    EBSpro_beta_setup_17.0.0.0.exe.zip
    https://mega.nz/#!nVFW3CJD!30X2thyzO...nEqFy1zJ107zYY
    EBSpro BETA v17.0.0.1
    Citar
    17.0.0.1 (beta) [17 april 2020]
    - Added support for *BISS-1 and DCW using VLC as video player. Also reports in status bar if the key is set when playing a stream.
    - Added a more visible option to add a transponder manually to the favorites list with the context menu.
    - Fixed the way that keys are sent to vlc.
    - Fixed a problem saving profile scans (thanks to @Alek and @paolo for reports)
    - Some minor bugs are fixed.
    - StreamReader updated to version 1.2.4.96.
    EBSpro_beta_setup_17.0.0.1.exe
    https://mega.nz/file/zYd2GQKY#nWBVkv...16TMhHqS3Ffi_k
    EBSpro ALPHA v18.0.0.0 (changelog) – Feb 25, 2022 – NEW!
    - Added experimental audio/video *player in Signal Analyzer (can be used from SidePanel and from TS Analyzer)
    - Added internal PID filtering support (no need to unmark "No PID filtering" in streamreader.ini, now this work is done in ebspro's engine).
    - Added link-margin support for SA, Main Window and Positioner (with red-bar autoadjust)
    - Show input bitrate in SA. - Improved search field in the SidePanel Scanner (press ESC to clean a search).
    - Detect no data input in TSA scanning for SidePanel (this bypass the TSA timeout that takes longer.)
    - Added SNR-bar in status bar of main window (also, small redesign of status bar)
    - Abort scanning if PAT table reach timeout (don't wait for other tables in this case). This make scan much faster for some transponders.
    - SidePanelScanner now stops scanning process faster when is needed. - Improved TCP stream connection handling
    - Added support for PLS code in the SEARCH_RESULT structure (Up-to date StreamReader.dll needed -included-, old versions don't will work well).
    - Detect FFTScan support in Device Info. - Improved support and handling of allsats.txt database.
    - Improved handling of device info from streamreader.log and also add temperature reading if is supported by device.
    - Fixed a bug that doesn't save/remember the last checked status of the scan ranges.
    - Fixed a bug handling TSA Streaming that can make some timeouts scanning dvb tables.
    - Fixed encoding mode when handling streamreader.ini file that causes streamreader.dll don't read settings well.
    - Fixed MISSel crash and continuous calls to MIS selection function in DT-Mode that make stream unstable.
    - Fixed potential crash using diseqc under some circumstances. - Small improvement in USALS calcs.
    - Some small fixes here and there. - Update AllSats.txt database.
    - StreamReader updated to version 1.2.4.124 (new cards supported: 6902SE, 6904SE, 5930, 6903X(v2), ...)
    __________________
    EBSPRO V18.0.0.2 (RC) HAS BEEN RELEASED june 3, 2022 – NEW!
    Highlights
    Best database handling and load times for big DBs
    Bug fixing and improvements.
    Known issues
    AVIRA Antivir is showing an alert. Seems that heuristic cause a false-positive with Installer (disable Avira, install and then enable it again)
    here the new adress and Webhoster! http://ebspro.cjcr-soft.com THX 4 ALL and BYE!
    http://cjcr-soft.com/ebspro/EBSpro_s...p_18.0.0.4.exe
    cjcr
    @Cjcr07
    Follow
    We moved to http://ebspro.cjcr-soft.com instead of http://ebspro.net and also changed the webhosting. Almost all should work now.
    4:55 PM · Aug 22, 2023
