Results 1 to 14 of 14
Thread: OPENSPA 5.0.002 Vu+ Duo/Duo2 Image
    Thumbs up OPENSPA 5.0.002 Vu+ Duo/Duo2 Image
    - Improvements at spzPIPMenu
    - Fix spzTimeShift
    - Improvements at OpenSPA information screen
    - Fix MyTube
    - Fixes at spaqbutton (Keys Remap)
    - Other minor fixes and improvements.
    - New skin Full HD openSPA_JRLG1080 (by the moment, the only skin Full HD 100x100 compatible with OpenSPA). Not necessary OSD setting.
    - Updated French language - Thanks Pr2
    - Last Kernel
    - Gstreamer 1.6.1
    - Last Drivers (Except Solo2 y Duo2)
    http://openspa.webhop.info/Descarga%...151122_usb.zip
    Thumbs up OPENSPA 5.0.003 Vu+ Duo/Duo2 Image
    Thumbs up OpenSPA 5.0.004 for Vu+ Duo/Duo2 Image-------NEW UPDATE 2015-12-30
    - OpenEmbedded OE-A 3.2
    - Enigma2 28-12-15
    - GCC 4.9.2
    - GStreamer 1.6.x (Except Wetek/GigaBlue/ZGemma/GI ET-7000 MINI GStreamer 0.10)
    - WeTek Play : Kernel 3.10.93 and Drivers 07-12-15
    - Vuplus: Updated HbbTV to 20151213
    - Formuler F1: Added Kodi 15.2 ready to install
    - New Confluence skin: based in xbmc/kodi confluence skin by Jezz_X, Team Kodi
    - DeviceManager: Added SD cards support
    - Fixes full HD skins support
    - Info Panel : Fixed problem with SWAP (now it's shown)
    - DeviceManager: Fix to create and format devices partitions
    - Fixes MyTube : now you can play VEVO videos.
    - Translate improvements.
    - Other minor fixes
    Confluence skin is only installed in receivers with more than one core because it is a bit heavy and can produce lag. In receivers with one core, Basic retro skin is being installed, but Confluence skin can be installed optionally.
    Password FTP/Telnet : openspa
    http://openspa.info/resources/opensp...d?version=1677
    http://openspa.info/resources/opensp...d?version=1678
    Thumbs up OpenSPA 5.0.005 for Vu+ Duo/Duo2 Image-------NEW UPDATE 2016-02-16
    Changelog:
    - WeTek Play :
    Kernel 3.10.93 and Drivers 2016-01-29
    Improvements and fixes Enigma2
    New plugin Selection Remote Contorl with support in the Wizard
    - Gigablue:
    Kernel 4.0.1
    New drivers
    GStreamer 1.7.1
    - Zgemma:
    New drivers 2016-01-21
    - Kodi 15.2 for Vuplus Solo2, Solo SE, Duo2 and Solo 4K (thanks mx3l)
    - New OpenSPA updates wizard (Allows install new firmware keeping settings and data)
    - New skin Confluence 1080: based in Confluence_openspa
    - Updated skin OpenSPA_JRLG1080 (more screens included)
    - Updated plugin openSPA_JR (added new infobars, channel selection and chance to choose dark or light style)
    - Updated GStreamer 1.6.x to 1.7.1
    - Fixed issue with ecm line in infobars, because it was always shown in some skins.
    - Other minor fixes.
    To report bugs :http://openspa.info/forums/reportes-...n-openspa.265/
    http://openspa.info/resources/opensp...d?version=1762
    http://openspa.info/resources/opensp...d?version=1765
    Thumbs up OpenSPA 5.0.006 for Vu+ Duo/Duo2 Image-------NEW UPDATE 2016-03-18
    What is new?
    - Kodi 16 "Jarvis" for Vuplus Solo2, Duo2, Solo SE and Solo 4K
    - Fixes in EPG plugin to assign what screen you want to EPG button.
    - Added new wget to improve safety.
    - Fixes in OpenSPA updates wizard.
    - Fixes in spaqbutton (remap keys).
    - Added new renderer for better XPicons performance.
    https://openspa.webhop.info/#Descarg...genes%2FVuplus
    Thumbs up OpenSPA 6.0 Vu+ Duo/Duo2 Image
    User : root
    Pass : openspa
    Quote:
    What is new :
    - New OE-Alliance 3.4
    - Changes in EPG download, now is Movistar+ instead of D+
    - Fix weather info
    - Improvements at confluence 1080. Added new screens and plugins.
    - Improvements at spaqbutton (Remap keys) to add more remote buttons (fav, portal, etc)
    - Kodi 16.1 (Wetekplay/VuDuo2/VuSolo2/VuSoloSE/VuSolo4k)
    - GStreamer 1.8.1 Stable
    - VuDuo2/VuSolo2/VuSoloSE/VuSolo4k/VuZero/GigaBlue support iptables
    - Fixed error in DeviceManager when initialize device in ext3/ext4
    https://openspa.webhop.info/#Descarg...Vuplus%2Fvuduo
    https://openspa.webhop.info/#Descarg...uplus%2Fvuduo2
    https://openspa.webhop.info/Descarga...160916_usb.zip
    Changelog:
    - OpenSPA installation images using Flash Online. It is a completely online method without PC. Notice : if you install any previous release to 6.0.005, when image starts FlashOnline will not be available.
    - Improvements in spanewfirm (Installation Wizard OpenSPA), now it's compatible with FlashOnline.
    - Improvements in spaMetrixJR, now you can also configure/change OpenSPA menu icons.
    - Added secondinfobar screen with extended information in MetrixJR.
    - Improved EPG Movistar +.
    - Improvements in spzImdb, to make finding films information easier and faster .
    To report bugs :
    PHP Code:
    User : root
    Pass : openspa
    https://openspa.webhop.info/Descarga...161001_usb.zip
    Changelog openSPA
    Last update: 2016-09-30
    Last image version: 6.0.006
    CHANGELOG 6.0.006
    What is new
    - New kernel for Mut@nt receivers.
    - New zgemma drivers.
    - FlashOnline improvements to use every mounted device (pendrive, hdd, microSD, etc.). Network mounts can not be used
    - Improvements in spanewfirm (Installation Wizard OpenSPA), now it is also compatible with multidevices.
    - Changes in Confluence and MetrixJR skins.
    - Added stream port settings and stream authentication for more security in spzremotechannels
    - Added new M+ equivalences
    * NOTES:
    Data to connect telnet/ftp:
    User : root
    Pass : openspa
    UPDATE ONLINE FROM 6.0.005
    VU+ Solo.........................No
    VU+ Uno.........................No
    VU+ Duo.........................No
    VU+ Ultimo.....................No
    VU+ Zero........................No
    VU+ Solo2.......................No
    VU+ Duo2.......................No
    VU+ Solo SE...................No
    VU+ Solo 4K...................No
    · Bug report
    URL: https://openspa.info/forums/reportes...n-openspa.265/
    Thumbs up OpenSPA 6.0010 Vu+ Duo/Duo2 Image
    Thumbs up OpenSPA 7.0.003 Vu+ Duo/Duo2 Image
    https://openspa.webhop.info/Descarga...170301_usb.zip
    Thumbs up OpenSPA 7.0.004 Vu+ Duo2 Image
