Thanks Thanks:  2
Likes Likes:  1
Page 1 of 4 1234 LastLast
Results 1 to 15 of 47
Thread: YouTube Plugin by Taapat
    Thumbs up YouTube Plugin by Taapat
    Quote:
    Those who are looking at the receiver youtube, you can try to feed of the first version of my test a plug youtube
    Do not beguiled, youtube instead youtubeplayer.
    I started doing it by the fact that unfortunately MyTube license does not allow to use it on other receivers except drimboksa.
    I did not finished yet, and so far is only the basic functions. I myself do not use actively youtube encouraged by the comments and suggestions, as well as maybe necessary to correct the translation.
    Plugin works completely with youtube api v3, by the authentication is now does not work as before. Before that you have given plugin, for example for youtube, your login and password. But the plug-so gets full control over all your akountami and dannimy on google. In fact now you do not have to give your details and allow the plugin to use only the necessary service.
    If the settings (button menu) including authentication, then for authentication need to be in your Web browser under your akountom open the homepage, enter the code which will show a plug-and allow plugins to use your akount on youtube. By the turn only if you can do it. After authentication, you can use your own fidi and subscriptions.
    23.03.2016
    Quote:
    - YouTubeUi: try fix video download - Replace / in download file name
    - Create id.po - Add Indonesian translation.
    - Update et.po
    - Remove comments in German translation
    - German Translation
    - Fix some PEP8 style guide errors in plugin.py
    THX @Taapat
    http://speedy.sh/8Sbvs/enigma2-plugi...89d-r0-all.zip
    youtube_h1+git316+2066e3a-r0.0
    27.05.2017
    - YouTubeVideoUrl: Fix identitation
    - YouTubeVideoUrl: Fix DASH manifest signature decryption - Modernize, thx Protuhj & dstftw
    - [jsinterp] Add support for quoted names and indexers - Fix typo and cleanup regexes, thx dstftw
    thx @ Taapat
    https://mega.nz/#!KZ0UXaDT!aIhtKteY-...9S6XQ6S0fyfrtA
    youtube_1 + git239 + ea6b8be-r0
    - plays any 4k ultra formats
    thx @ Taapat
    https://mega.nz/#!vMkHiCaB!OwVlLvooX...XIXkvc16JNzA-s
    youtube_h1+git354+920d86c-r0.0
    - Update language files after adding Greece in settings
    - Regenerate YouTube.pot after adding Greece in settings
    - Typo: change greek to Greece - We use country instead of language in our settings
    - Add greek in search region and search language
    thx @ Taapat
    https://mega.nz/#!3A9zkZCJ!HFbn7u_TR...2zL1ipE00tGMDI
    Youtube_h1+git370+8b6ccec-r0.0 ---------20180929
    - YouTubeVideoUrl: use DASH video on all resolution (fix #42)
    It looks like youtube is no longer using mp4 video also in resolutions less than 1920x1080 in many clips. I hope there are no active images that does not support set suburi via service reference path string
    - YouTubeSearch: fix suggestions on OpenPLi develop - Add aditional function processSelect witch replace okClicked on OpenPLi develop
    - YouTubeVideoUrl: fix extraction, thx dstftw (fix #40)
    - YouTubeVirtualKeyBoard: use also "prompt" in updateSuggestions
    - FR translation 2018-06-25 (#38) - French translation for YouTube plugin.
    - Create + Update sk.po (#37) - Slovakian translation for YouTube plugin.
    - Create it.po (#36) - Italian translation for YouTube plugin.
    - YouTubeVirtualKeyBoard: try fix GSOD if youtube search is not available - This is try to fix #35
    I have not able to repeat this, but it seems that if youtube search in the web is not available, then the suggestions are delayed and updateSuggestions are called after closing the YouTubeVirtualKeyBoard window. I hope this could fix this error.
    - Update hu.po (#34) - Hungarian translation for YouTube plugin.
    - Create bg.po - Bulgarian translation for YouTube plugin.
    - YouTubeSearch: intruduce HelpWindow move
    - YouTubeSearch: remove functions showHelpWindow and hideHelpWindow
    help_window.instance always exists, so no need check for this to hide or show help_window.
    Remove functions with this check and use help_window.instance.hide() or help_window.instance.show() instead of these functions.
    - YouTubeSearch: use Exception for HTTPConnection exceptions. Fix #32
    - YouTubeVideoUrl: try fix live streams extraction
    - YouTubeVideoUrl: add 300 and 301 HLS format
    thx @ Taapat
    enigma2-plugin-extensions-youtube_h1+git370+8b6ccec-r0.0_all.ipk
    Código:
    https://mega.nz/#!iN1XAabI!i2PKUMZHB...EUE0mm6qtFqkmA
    youtube h1 + git376 +c8077fb r0.0 19.11.2018
    - [translation] Portuguese translation for Youtube enigma2 plugin - update
    - Estonian update (#44)
    - Implement downloaded file merge.
    Use FFmpeg to merge downloaded DASH video and audio files.
    By default disabled to not install FFmpeg without reason, who takes up a lot of space.
    When change settings it is suggested to install or remove FFmpeg.
    enigma2-plugin-extensions-youtube_h1+git376+c8077fb-r0.0_all.ipk
    https://mega.nz/#!7E0hRaoB!1G4SXXkPs...2ukdFlAyEI0TXw
    thx @ Taapat
    youtube h1+git387+df32af0-r0.0
    * YouTubeVideoUrl: extend JS player signature function name regexes
    enigma2-plugin-extensions-youtube_h1+git387+df32af0-r0.0_all.ipk
    Código:
    https://mega.nz/#!rAV0mKgT!xvEcX3IFc...X6FEHSObpaXKuA
    thx @ Taapat
    Thumbs up youtube h1+git389+5834a0c-r0.0
    - PEP8 fixes: remove spaces for keyword arguments in functions - No code changes.
    - YouTubeVideoUrl: add vp9 4k formats
    Now after these changes e2iplayer/exteplayer3@c5fec50 using exteplayer can play 4k content with vp9 codec on official openpli images.
    Thefore add vp9 4k formats.
    - YouTubeVideoUrl: small optimization in url definition
    enigma2-plugin-extensions-youtube_h1+git389+5834a0c-r0.0_all.ipk
    Código:
    https://mega.nz/#!fEEGQCaB!R3-oTbfcz...fH8KgVCrdnnNvY
    thx @ Taapat
    o intrebare...e acelasi plugin ce e compilat la ora actuala in enigma?ca daca da....nu merge fluid...
    Thumbs up YouTube Plugin by taapat h1+git405+7ce18be-r0.0
    YouTubeVideoUrl: Update signature function patterns, thx dstftw
    Based on: ytdl-org/youtube-dl@abefc03
    ytdl-org/youtube-dl@31ce6e9
    enigma2-plugin-extensions-youtube_h1+git405+7ce18be-r0.0_all.ipk
    Código:
    https://mega.nz/#!fI8hEIKK!pbwQvKC2s..._TKzlXBAbiPXzw
    thx @ taapat
    enigma2-plugin-extensions-youtube_h1+git420+e7fd267-r0.0_all.ipk
    -YouTubeVideoUrl: fix is_live extraction
    Código:
    https://mega.nz/#!7VdFmaha!uYUCNEU0Y...V8u9Q5a0HSEoZo
    thx @ Taapat
    enigma2-plugin-extensions-youtube_h1+git448+61ec441-r0.0_all
    -Regenerate and update language files after latest changes
    -Follow YouTube branding guidelines ..
    Use YouTube logo for displayed YouTube content.
    Thefore in YouTubeMain screen move text widget content to title, to shown YouTube logo instead of text.
    Skiners, please use YouTube logo in skin instead of text widget to follow YouTube branding guidelines.
    Also changes images that are similar with YouTube icon.
    enigma2-plugin-extensions-youtube_h1+git448+61ec441-r0.0_all.ipk
    Código:
    https://mega.nz/file/3Vs1jJQA#zGCiHC...2SewV-TArDY3kY
    thx @ Taapat
    enigma2-plugin-extensions-youtube_h1+git471+eaead75-r0.0_all
    -Add more teste in test_plugin
    -Move travis bash commands in file
    To reduce unnecessary log lines in the travis report.
    -Onather optimizations in travis.yml
    -Cosmetic changes in travis.yml
    -Use pytest for Travis CI plugin functions test
    -Removes unnecessary in travis script
    -Change test.py permissions
    enigma2-plugin-extensions-youtube_h1+git471+eaead75-r0.0_all.ipk
    https://mega.nz/file/TA9BCIgS#m80X2o...fBF5QIYZTyOmtU
    thx @ Taapat
    enigma2-plugin-extensions-youtube_h1+git489+64c358f-r0.0
    - Add a config option to select player for YouTube media playback, close …
    This allows choose default media player, exteplayer or gstplayer if a plugin ServiceApp is installed
    - [2to3] cleanup Code for Python3
    Co-authored-by: Captain
    enigma2-plugin-extensions-youtube_h1+git489+64c358f-r0.0_all.ipk
    https://mega.nz/file/vUVTzK6I#v5iEpQ...2Ae70y9NLkuPBs
    thx @ Taapat
    youtube_h1+git515+5e240e4-r0.0 от 13.06.2020
    Citar
    - YouTubeUi: add key menu to call setup screen with menu button in menu…
    - update cs.po (plurals)
    - Update latvian translation
    - Regenerate translations after added ngettext
    - Add ngettext for true plurals, thx @ims21
    - Remove location strings in cs translation
    - Update tr.po
    - added cs translate
    enigma2-plugin-extensions-youtube_h1+git515+5e240e4-r0.0_all.rar
    https://mega.nz/file/OdVESIrY#XiiHLJ...Jwm0CMUbHFWDTU
    thx @ Taapat
