Likes Likes:  1
Results 1 to 7 of 7
Thread: TBS6522 Multi-standard Dual Tuner PCI-e Card
    Thumbs up TBS6522 Multi-standard Dual Tuner PCI-e Card
    TBS6522 is a Dual PCI express TV tuner card that supports multiple digital TV standards including DVB-S2X/S2/S/T2/T/C2/C/ISDB-T, four RF IN is independent with each other, with this multi-standard TV tuner card, a switchover between different digital TV signals is much easier, you just need to plug another signal cable instead of taking out the card from your server. With two tuners, the TBS6522 enables you to watch TV channel from one transponder/satellite while recording another channel from another transponder/ satellite at the same time.
    Benefits:
    Fast scanning functionality for all media, including efficient bliand scan for satellite and cable
    Support VCM, CCM, QPSK, 8PSK, 16APSK, 32APSK;
    Up to 173M/bps(TS Data Rate)
    Supportable maximal symbol rates: 45M for 8PSK、16APSK, 40M for 32APSK
    Power consumption (each demod):<440 mW in DVB-S2 modes; 360 mW in DVB-T2 modes; <190mW in ISDB-T, DVB-T, and DVB-C modes
    Automatic spectral inversion detection for all media
    Dual flexible TS interfaces with serial or parallel single outputs with tri-state and cross-bar features
    3.3 and 1.2V power supplies
    Applications:
    Data receiving
    IPTV streaming
    Media monitoring
    Digital content distribution
    ISDB-T 6,7 and 8 MHz bandwidth
    Partial reception supported
    Carrier recovery:±600 kHz
    Timing recovery:±200 ppm
    DVB-T2 and T2-Lite Bandwidth: 1.7, 5, 6, 7 or 8 MHz
    DVB-T2 versus DVB-T automatic detection
    Carrier recovery: ±600 kHz
    Timing recovery: ±200 ppm
    DVB-T Bandwidth: 6, 7, 8 MHz. ACI filtering for 7 MHz channels enables use of a fixed 8 MHz IF filter
    Supports all C.R.; G.I.;LP and HP streams
    Advanced terrestrial channel equalizer
    DVB-C2 Notch management
    Advanced cable channel equalizer
    DVB-C and ITU-T J.83 Annex B DFE equalizer specific for cable network
    Carrier recovery: ±11% of Symbol rate
    Timing recovery: ±1000 ppm
    DVB-S/S2/S2X Enhanced immunity to co-channel interferers
    Programmable carrier recovery range
    Power consumption
    Input/ Power: 12V/6~18W
    temperature 0°~ 60°
    Other information:
    System Requirements Windows XP / Vista/ 7/8/10, Linux
    Available PCI Express x1, x4, x8 or x16 slot
    Digital TV signal (ISDB-T/DVB-T2/C2/S2X/S2/T/C/S)
    Dimension:
    TV tuner card size 130mm*92mm
    Net weight 115g
    Gift Box Size 200*130*30mm
    Weight 210g
    Package Contents 1 x TBS6522
    1 x DC cable
    2 x F-IEC adapter
    TBS6522 Multi Standard Dual Tuner PCI-e Card
    US$149.00 tbsiptv.com
    US $159.99 aliexpress.com
    US$149.00 tbsiptv.com,ebay uk
    £149.00 ebay uk
    £149.00 amazon uk
    154,00 € tbs.de
    http://www.tbsdtv.com/download/docum...ser_munual.pdf
    https://sourceforge.net/p/crazyscan/wiki/Info/
    First DVB-S2X reception by Peon (Onacila) with TBS 6522.
    https://wxw.satellites.co.uk/forums/...s-6522.169655/
    http://wxw.tbsdtv.com/forum/viewtopic.php?f=195&t=10021
    :thankyou: @sato ,@ Peon (alias Onacila)
    http://www.ebay.de/itm/262713045558
    EUR 111,30
    Thumbs up StreamReaderEx-BDA 1.2.4.4000 for TBS 6522
    http://crazycat69.narod.ru/sattelite...erExEx-BDA.rar
    28 Nov 2007
    Salut, link-ul nu mai merge. Te rog updateaza-l.
    StreamReaderEx-BDA 1.2.4.4000 for TBS 6522---update
    https://www.mediafire.com/file/55g8c...x-BDA.rar/file
    http://www.girlshare.ro/3769838972.9
    ---------- Post added at 11:00 ---------- Previous post was at 10:18 ----------
    ERATA:
    StreamReaderExEx-BDA_1.2.3.1381
    deocamdata nu gasesc aceasta versiune nici pe net si nici la mine
    am sa mai caut la mine poate il voi gasi
    aici vei gasi numai ultima versiune 1.2.4.83
    28 Nov 2007
    Salut,
    Încerc să folosesc tbs6522 în Ubuntu 19 dar am probleme cu setare tunere cu configuraţia 1 dvb-c şi 1x dvb-s. Pe cablu scanez programele dar când încerc să scanez pe satelit îmi dispare configuraţia (folderul cu STI...) şi nu mai vede tunerul.
    Ma poate ajuta cineva să îl configurez?
    Mulţumesc şi o zi buna!
