Thanks Thanks:  4
Likes Likes:  5
Results 1 to 15 of 16
Thread: OSEmu for VITMOD OS
    94 Post(s)
    Default OSEmu for VITMOD OS
    Stirea bomba vine de la Andrea
    LE:
    Acest Oscam nu are DVB-api compatibil 100% cu VITMODOS, in concecinta nu deschide!
    August 25th, 2016 at 22:01 | #137
    Reply | Quote
    I released also OSEmu for VITMOS. Same folder as oscam.
    http://www.costan.org/K1Plus/OSEmu
    This should allow for EMU fuctionality inside Oscam directly. Please read the manual on github for configuration:
    https://github.com/oscam-emu/OSEmu
    Also prepare a startup script similar to oscam one if you want to avoid to login after each reboot.
    Andrea
    August 23rd, 2016 at 20:08 | #125
    Reply | Quote
    The URL to download:
    http://www.costan.org/K1Plus/oscam
    Just save the binary on the K1Plus running VITMOS (ssh access using root/root) under /usr/local/sbin and create all the config files under /usr/local/etc.
    For autostart just go under /etc/init.d and create a script named S51oscam like the other startup file (I have one on the box, but I’m not at home at the moment).
    If you’re just impatient, for quick tryout, launch
    /usr/local/sbin/oscam -b
    and it should have started.
    You can also remove wicardd from the startup, it’s not needed anymore (and possibly may clash with DVBAPI interface socket).
    Also note that wicardd is not working with DNS, since the libc is dynamically trying to call libnss that is not available on this platform, while this oscam has a statically linked nss in the statically linked libc and thus DNS is working again.
    sursa
    94 Post(s)
    Nu sunt convins ca merge, da acceasi eroare ca vechile versiuni cand pune keya.
    Am postat o intrebare pe cnx.
    94 Post(s)
    Nu e nimic senzational cu oscamul de mai sus, e versiunea cu DVB-API pentru Box type: wetek (generic), pe care am mai testat-o si care nu e compatibila cu descramblerul din imaginea VITMOD.
    Unix starttime: 1472389841
    Starttime:      28.08.2016 16:10:41
    Version:        oscam-1.20-unstable_svn-r11272
    Compiler:       arm-unknown-linux-gnueabi-static
    PID:            257
    TempDir:        /tmp/.oscam
    ConfigDir:      /usr/local/etc/
    WebifPort:      8888
    Web interface support:                   yes
    LiveLog support:                         yes
    jQuery support intern:                   yes
    Touch interface support:                 yes
    SSL support:                             no
    DVB API support:                         yes
    DVB API with AZBOX support:              no
    DVB API with MCA support:                no
    DVB API with COOLAPI support:            no
    DVB API with COOLAPI2 support:           no
    DVB API with STAPI support:              no
    DVB API with STAPI5 support:             no
    DVB API read-sdt charsets:               yes
    Irdeto guessing:                         yes
    Anti-cascading support:                  yes
    Debug mode:                              yes
    Monitor:                                 yes
    Loadbalancing support:                   yes
    Cache exchange support:                  yes
    CW Cycle Check support:                  yes
    LCD support:                             no
    LED support:                             no
    Clockfix with realtime clock:            yes
    IPv6 support:                            no
    camd 3.3x:                               no
    camd 3.5 UDP:                            yes
    camd 3.5 TCP:                            yes
    newcamd:                                 yes
    CCcam:                                   yes
    CCcam share:                             yes
    gbox:                                    yes
    radegast:                                yes
    scam:                                    yes
    serial:                                  yes
    constant CW:                             yes
    Pandora:                                 yes
    ghttp:                                   yes
    Reader support:                          yes
    Nagra:                                   yes
    Irdeto:                                  yes
    Conax:                                   yes
    Cryptoworks:                             yes
    Seca:                                    yes
    Viaccess:                                yes
    NDS Videoguard:                          yes
    DRE Crypt:                               yes
    TONGFANG:                                yes
    Bulcrypt:                                yes
    Griffin:                                 yes
    DGCrypt:                                 yes
    cardreader_phoenix:                      yes
    cardreader_drecas:                       yes
    cardreader_internal_azbox:               no
    cardreader_internal_coolapi:             no
    cardreader_internal_coolapi2:            no
    cardreader_internal_sci:                 yes
    cardreader_sc8in1:                       yes
    cardreader_mp35:                         yes
    cardreader_smargo:                       yes
    cardreader_pcsc:                         no
    cardreader_smartreader:                  no
    cardreader_db2com:                       yes
    cardreader_stapi:                        no
    cardreader_stapi5:                       no
    cardreader_stinger:                      yes
    Eroarea apare in log asa:
    2016/08/28 16:10:41 368FA974 c   (dvbapi) dvbapi channelcache loaded from /usr/local/etc/oscam.ccache
    2016/08/28 16:10:41 368FA974 c   (dvbapi) Detected /dev/dvb/adapter0/demux0 Api: 0, userconfig boxtype: 0 maximum amount of possible filters is 13 (oscam limit is 32)
    2016/08/28 16:10:42 368FA974 c   (dvbapi) Demuxer 0 ecmpid 0 CAID: 1813 ECM_PID: 0958 PROVID: 000068
    2016/08/28 16:10:42 368FA974 c   (dvbapi) Demuxer 0 ecmpid 1 CAID: 0100 ECM_PID: 0958 PROVID: 000068 PBM: FFFFFFFFFFFFFFF DATE: 0-0-2014
    2016/08/28 16:10:42 368FA974 c   (dvbapi) Demuxer 0 ecmpid 2 CAID: 0B01 ECM_PID: 0890 PROVID: 000000
    2016/08/28 16:10:42 368FA974 c   (dvbapi) Demuxer 0 ecmpid 3 CAID: 0500 ECM_PID: 0A20 PROVID: 032A00
    2016/08/28 16:10:42 368FA974 c   (dvbapi) Demuxer 0 ecmpid 4 CAID: 1884 ECM_PID: 08F4 PROVID: 000000
    2016/08/28 16:10:42 368FA974 c   (dvbapi) Demuxer 0 ecmpid 5 CAID: 1803 ECM_PID: 098A PROVID: 000000
    2016/08/28 16:10:42 368FA974 c   (dvbapi) Demuxer 0 ecmpid 6 CAID: 1861 ECM_PID: 09BC PROVID: 000000
    2016/08/28 16:10:42 368FA974 c   (dvbapi) Demuxer 0 ecmpid 7 CAID: 186C ECM_PID: 0AE8 PROVID: 000000
    2016/08/28 16:10:42 368FA974 c   (dvbapi) Demuxer 0 found 8 ECMpids and 5 STREAMpids in caPMT
    2016/08/28 16:10:42 368FA974 c   (dvbapi) Demuxer 0 found channel in cache and matching prio -> start descrambling ecmpid 5
    2016/08/28 16:10:42 368FA974 c   (dvbapi) Demuxer 0 trying to descramble PID 5 CAID 1803 PROVID 000000 ECMPID 098A ANY CHID PMTPID 0444 VPID 0250
    2016/08/28 16:10:42 368FA974 c   (dvbapi) Demuxer 0 found 8 ECMpids and 5 STREAMpids in PMT
    2016/08/28 16:10:42 368FA974 c   (dvbapi) ERROR: ioctl(CA_SET_DESCR): Invalid argument
    2016/08/28 16:10:42 368FA974 c        (-) -- Skipped 1 duplicated log lines --
    2016/08/28 16:10:42 368FA974 c      (ecm) k1 (1803@000000/0000/0E08/92:0F3E1D125933833FBB610837B5C95FB4): found (55 ms) by xxx (P/4/4/4)
    2016/08/28 16:10:48 368FA974 c   (dvbapi) ERROR: ioctl(CA_SET_DESCR): Invalid argument
    2016/08/28 16:10:48 368FA974 c      (ecm) k1 (1803@000000/0000/0E08/92:D6C4AE4C969849D241D6DA705DF2187D): found (1633 ms) by yyy (P/4/4/4)
    2016/08/28 16:10:57 368FA974 c   (dvbapi) ERROR: ioctl(CA_SET_DESCR): Invalid argument
    Am inceput sa citesc detalii despre DVB-api-ul Amlogic.
    05 Nov 2011
    You could test Build it now
    oscam-svn11273-arm-a9-wibf
    REMOVED
    -add patche emu and softcam.keys
    oscam-svn11273-arm-a9-emu-softcam-patched
    REMOVED
    94 Post(s)
    error while loading shared libraries: librt.so.1: wrong ELF class: ELFCLASS64
    root@vitmod-os$ ls -l librt*
    -rwxr-xr-x    1 root     root         27304 May 24 04:21 librt-2.23.so
    lrwxrwxrwx    1 root     root            13 May 23 21:24 librt.so.1 -> librt-2.23.so
    root@vitmod-os$ uname -a
    Linux vitmod-os 3.14.70 #1 SMP Tue May 24 07:20:55 +06 2016 aarch64 GNU/Linux
    05 Nov 2011
    thnks,
    REMOVED
    94 Post(s)
    7 Post(s)
    Nul gaseste ca, si nume copiaza versiunea 2.23 si editeaza numele punel inapo in box si merge
    94 Post(s)
    Cred ca ce compileaza el e pe 32 biti si librariile mele sunt pe 64 !
    05 Nov 2011
    ok,build_dir_x86_64
    REMOVED
    94 Post(s)
    I have the same error message.
    Oscam from #1 post does not use the librt.so.1 library !
    konstantine's Avatar
    ExifTool file metadata
     MIMEType
    application/octet-stream
    CPUByteOrder
    Little endian
    CPUArchitecture
    32 bit
    FileType
    ELF executable
    ObjectFileType
    Executable file
    CPUType
    Unknown (40)
    05 Nov 2011
    .thanks,Build for arm-v7
    DELETED
    #3
    PID: 257
    WebifPort: 8888
    94 Post(s)
    error while loading shared libraries: libpthread.so.0: wrong ELF class: ELFCLASS64
    05 Nov 2011
    The last attempt,
    REMOVED
