Results 1 to 7 of 7
Thread: Tutorial install iptv Stalker Portal
    24 Mar 2009
    Thumbs up Tutorial install iptv Stalker Portal
    1. INFO
    This tutorial is made for fresh installed Ubuntu and Debian
    2. INSTALLING STALKER PORTAL (Apache2)
    apt-get update && sudo apt-get -y upgrade && sudo apt-get install -y -u apache2 memcached mysql-server php5 php5-mysql php-pear nodejs upstart && sudo pear channel-discover
    apt-get install -y unzip
    apt-get install -y git
    pear channel-discover pear.phing.info
    pear install phing/phing
    cd /var/www/html
    wget https://github.com/azhurb/stalker_po...v4.9.28-r2.zip
    unzip v4.9.28-r2.zip
    rm -r v4.9.28-r2.zip
    mv stalker_portal-4.9.28-r2 portal
    mysql -u root -p
    create database stalker_db;
    grant all on stalker_db.* to 'YOURUSERNAMEHERE' identified by 'YOURPASSWORDHERE';
    GRANT ALL PRIVILEGES ON stalker_db.* TO stalker@localhost IDENTIFIED BY '1' WITH GRANT OPTION;
    exit
    nano /var/www/html/portal/server/config.ini
    edit these values
    mysql_user = stalker
    mysql_pass = 1
    to
    mysql_user = YOURUSERNAMEHERE
    mysql_pass = YOURPASSWORDHERE
    cd /var/www/html/portal/deploy/
    phing
    echo "max_allowed_packet = 32M" >> /etc/mysql/my.cnf
    echo "short_open_tag = On" >> /etc/php5/apache2/php.ini
    a2enmod rewrite
    apt-get purge libapache2-mod-php5filter
    cat /dev/null > /etc/apache2/sites-available/000-default.conf
    nano /etc/apache2/sites-available/000-default.conf
    <VirtualHost *:88>
    ServerAdmin webmaster@localhost
    DocumentRoot /var/www/html/portal
    <Directory /var/www/html/portal/>
    Options -Indexes -MultiViews
    AllowOverride ALL
    Require all granted
    </Directory>
    ErrorLog ${APACHE_LOG_DIR}/error.log
    CustomLog ${APACHE_LOG_DIR}/access.log combined
    </VirtualHost>
    nano /etc/apache2/ports.conf
    change 80 to 88
    service apache2 restart
    go visit to http://host:88
    username: admin
    password: 1
    Enjoy
    08 Sep 2010
    ìn IAD
    Salut, ceva nu-mi merge bine, cad ii dau:
    phing
    primesc:
    No se ha encontrado la orden «phing», quizás quiso decir:
    La orden «ping» del paquete «inetutils-ping» (universe)
    La orden «ping» del paquete «iputils-ping» (main)
    phing: no se encontró la orden
    Si urmand toate comenzile, la urma primesc:
    Not Found
    The requested URL / was not found on this server.
    Apache/2.2.22 (Ubuntu) Server at 192.168.1.104 Port 88
    Ceva idei unde gresesc?
    ---------- Post added at 17:36 ---------- Previous post was at 17:05 ----------
    partial am rezolvat, nu aveam phing instalat, nici nu reuseam, dar s-a rezolvat;
    $ pear channel-discover pear.phing.info
    $ pear install [--alldeps] phing/phing
    08 Sep 2010
    ìn IAD
    Porneste acum serverul, dar cu eroare:
    * Restarting web server apache2 [Mon Nov 21 09:14:41 2016] [warn] NameVirtualHost *:88 has no VirtualHosts
    ... waiting [Mon Nov 21 09:14:42 2016] [warn] NameVirtualHost *:88 has no VirtualHosts
    Deci chiar nu-i dau de cap, ma poate ajuta cineva?
    ---------- Post added at 10:11 ---------- Previous post was at 09:16 ----------
    root@localhost:/var/www/html/portal/deploy# service apache2 status
    Apache2 is running (pid 32064).
    root@localhost:/var/www/html/portal/deploy# netstat -ltnp | grep :88
    tcp 0 0 0.0.0.0:88 0.0.0.0:* ESCUCHAR 32064/apache2
    08 Sep 2010
    ìn IAD
    nu stiu cum o fi .... dar la mine nu merge
    It works!
    This is the default web page for this server.
    The web server software is running but no content has been added, yet.
    konstantine's Avatar
    " Contentu' " necesita o plata a unui "abonament". Cine a deschis topicul , ar fi trebuit sa specifice.Pe kodi era un plugin " clone iptv stalker" care era free.
    08 Sep 2010
    ìn IAD
    Eu vreau sa-l instalez dintr-un singur motiv; ma gandesc sa renunt la antena parabolica si la cele 8 receivere telekom (si toate firele intinse prin casa), sa-mi fac un singur abonament de cablu si sa-mi creed propriu server intranet cu care sa ma duc prin casa la toate televizoarele (in fiecare camera am mufa rj45). Momentan sunt la faza cu instalarea serverului, dar ma gandesc ca n-o fi compatibil cu ubuntu 12.04
    08 Sep 2010
    ìn IAD
    Nu stiu, poate ma ajuta cineva.. cand ii dau setarile
    <VirtualHost *:88>
    AllowOverride ALL
    Require all granted
    </Directory>
    </VirtualHost>
    primesc eroare 500,
    iar cand ii dau :
    <VirtualHost *:88>
    DocumentRoot /var/www/htmt
    AllowOverride ALL
    Require all granted
    </Directory>
    </VirtualHost>
    imi apar fisierele situate in /var/www/html
