Thanks Thanks:  40
Likes Likes:  22
Page 1 of 4 1234 LastLast
Results 1 to 15 of 56
Thread: VITMOD-LE K1 Plus S2/T2-C
    Default VITMOD-LE K1 Plus S2/T2-C
    Azi am testat VITMOD-LE v.1.0 si am avut surpriza !
    Scaneaza si deschide perfect DVB-C !
    In scurt timp revin cu detalii!
    ---------- Post added at 17:05 ---------- Previous post was at 15:59 ----------
    Se instaleaza imaginea VITMOD-LE-K1plus.aarch64-1.0
    ---------- Post added at 17:43 ---------- Previous post was at 17:05 ----------
    ssh e pornit pe imagine, user:root, pass:root
    #                 VITMOD-LE                  #
    #                  (c)2016                   #
    VITMOD-LE (release) Version: 1.0
    Merge DVB-C in Kodi cu VDR Plugin, si in Neutrino.
    ---------- Post added at 19:41 ---------- Previous post was at 17:43 ----------
    Pentru inceput vedeti in imagini cum treceti Kodi in Engleza.
    free upload image
    Apoi cum scanam DVB-C:
    screen shot
    Continuarea:
    19 May 2007
    Da functioneaza foarte bine, am scanat UPC dar cu alta metoda direct cu vdr , am comparat canalele de pe tv LG si au fost scanate toate.
    Nu stiu pe RDS cum merge si daca vezi ceva in plus
    DM500, DM800HD, KATHREIN UFS910 si altele
    17 Jan 2008
    Merge bine si pe rds, acum sa-mi bat capul cu un emu pentru restul de canale. Un punct de pornire , daca se poate, ma ajuta cineva? Multumesc.
    Daca tunerul este capabil dvb-c, poate s-ar putea face ceva si pentru DTV-ul android. Asteptam de la cine se pricepe, pentru mine este prea complicat.
    Imi place mai mult neutrino decat VDR, dar nu are suport de subtitle.
    Nici eu nu am reusit a "deschid" pe cablu, o sa mai incerc.
    20 Jan 2017
    For several days I have K1 Plus (at S905). I tried to set VITMOD-LE-K1plus.aarch64-1.0.img with VDR and with oscam or wicardd, but so far without positive result. I have message "Channel encoded (2)" (oscam) or "channel no data" (wicardd)
    My wicardd.conf:
    [global]syslog = 1
    daemon = 0
    debug = 1
    [webif]
    port = 8100
    debug = 0
    [dvb]
    active = 1
    type = aml
    emm_filter_mode = 0
    filter = dvb,emm,ecm
    ecm_info = 2
    sdt = 1
    auto_update = 1
    debug = 3
    [reader]
    active = 1
    name = chiny_test2
    type = cccam
    account = my_user:my_pass@ip: port
    keepalive = 300
    debug = 3
    [account]
    login = vdr
    password = vdr
    auto_update = 1
    [filter]
    name = dvb
    rule = caid=0100,0B01;accept
    rule = reject
    Did any of the more experienced colleagues could handle as I have set cooperation with the VDR wicardd or oscam?
    Cu TVheadend merge?
    @ skom27
    http://vitmod.ru/forum/index.php?topic=2.0
    @livs
    TVheadend merge cu oscam asa cum am explicat aici.
    Nu am testat inca.
    20 Jan 2017
    @ zildan
    Thank you for your answer
    So I've done
    1. I installed the image
    2. change skin to Confluence
    3. Change language
    4. installed VDR PVR Backend
    5. scanned the Hotbird
    6. I set wilcardd.conf (as in my previous post)
    7. The FTA programs are ok, but scrambled channel I have a message "Channel: no data"
    20 Jan 2017
    @ zildan
    ps. All the time file /tmp/camd.socket has 0 bytes size, nevermind if I want watch FTA or not
    0 size is ok for camd.socket.
    20 Jan 2017
    OK, when and where I make the wrong step?
    Am reusit sa deschid cablu in neutrino.
    Am pus o line N 1801 in wicardd.
    Cu linie C nu am reusit.
    Trebuie sa mai studiez si in VDR ce nu e in regula.
    ---------- Post added at 02:03 ---------- Previous post was at 00:18 ----------
    Merge emulatorul si in Kodi (VDR) dar diferit de ce am prezentat mai sus.
    Maine fac un minitutorial.
    Am reusit sa pun OSemu pe aparat, sa il leg in wicardd si sa deschid cablu in neutrino fara probleme, in VDR vine keya, confirma wicardd ca e ok, da nu se aprinde lumina decat cand are chef.
    Mai studiez si urmeaza sa va dau un patch pentru imaginea Vitmod-LE.
