Thanks Thanks:  6
Likes Likes:  6
Results 1 to 15 of 25
Thread: KodiLite for Enigma2
    Thumbs up KodiLite for Enigma2
    kodilite_2.0
    whats new:
    -now dependencies included during installation so be sure ur connected to ur image feed to install dependencies when it ask during installation.
    -latest updates from @pcd ( skin.xml )
    -some latest plugins ytplus,Exodus,DCSports added inside.
    thanx @pcd
    https://mega.nz/#!nd9W0CJT!gdY2AregB...dRYLKT-mqZ4n6A
    To activate the subtitles option with KodiLite please unzip the attached script.module.SubsSupport and ftp it to folder :-
    /usr/lib/enigma2/pthon/Plugins/Extensions/KodiLite/scripts
    and Restart enigma. To use subtitles with any movie or show - do the following :-
    1. Start film (from a KodiLite addon)
    2. Select yellow button (Subtitles). Film will pause.
    3. Choose 'Search subtitles' (screenshot1)
    4. Down->Title - input film name(screenshot2)
    5. Blue button - Settings (screenshot3)
    6. Select language&Save (green button)(screenshot4)
    7. Select 'Update' Red button (screenshot3)
    8. Repeat 4 - back to screenshot2.
    9. Select subtitle. Film starts again.
    After some time - some subtitles sources may need to be renewed. So - if you see less options than before - please ask. I will update the script module if necessary.
    Regards, pcd.
    20170306
    New version of script.module.SubsSupport attached. Providers titlovi and opensubtitles working. Please unzip the attached and ftp it to folder :-
    and Restart enigma.
    Regards, pcd.
    https://www.sendspace.com/file/ocyl6l---------script.module.SubsSupport20170123.zip
    https://www.sendspace.com/file/8ftji2--------- script.module.SubsSupport-20170305.zip
    https://www.sendspace.com/file/229sdk------ service.subtitles.titlovi-master.zip
    The current update enigma2-plugin-kodilite-update20170313.zip is attached below
    Metod for installation:
    Ftp the .zip file to /tmp. Then give the telnet command :-
    unzip -o -q /tmp/*.zip -d /usr
    Restart enigma.
    Código:
    https://mega.nz/#!aZ9klDZB!4-RvG1b11...8wxPra989U6CcI
    New addon
    plugin.video.jizzplanet-18+-1.0.0 - Adult - Must setup cachefolder in Config (KodiLite first screen yellow button)
    Thanks pcd.
    Código:
    https://mega.nz/#!HE8yhLBC!7lMTK8WJg...c7x_S73p03Ciwg
    New addons
    plugin.video.exodus-1.0.7 - Movies - thanks @Nitro123
    plugin.video.specto.1.0.4 - Movies - thanks @Nitro123
    plugin.video.tvalacarta-1.0.0 - Spanish
    plugin.video.vstream-1.0.0 - French - mystream, nowvideo, exashare worked.
    plugin.video.xstream-nightly-1.0.2 - German - thanks @Nitro123 - openload (with pairing) and streamcloud worked.
    Regards, pcd.
    Código:
    https://mega.nz/#!XdMFlbZK!dsheTFVle...4v_4X9dq043w0o
    New addon
    plugin.video.Catoal-1.0.0 - Spanish
    Thanks pcd.
    Código:
    https://mega.nz/#!KVVATBBJ!9z2Gk971V...caaphyL2NUz-BM
    New addon for KodiLite attached below.
    plugin.video.exodus-1.0.5
    Thanks pcd.
    Código:
    https://mega.nz/#!LYUHGQJC!IotmauEyu...Gr9_04qgnIFWA8
    2017.03.06
    Please unzip the attached and ftp it to folder :-/usr/lib/enigma2/pthon/Plugins/Extensions/KodiLite/scripts
    and Restart enigma.
    Regards, pcd.
    https://mega.nz/#!PFcyxJjB!MOAuaRNN8...CoW2oUdSl0-z-s
    New addons 17/06/2017
    ADDON INSTALL METHOD : Ftp the .zip file to folder /tmp. Next start plugin KodiLite -> Install addons (green button) -> Install from/tmp.
    plugin.video.uwc - Adult 18+
    plugin.video.adulthideout - Adult 18+
    plugin.video.ukturk - TV and Sports
    plugin.video.SportsDevil - Sports - not updated by the author for some months - a few items still working.
    https://mega.nz/#!eBlgUILQ!zz0akCngD...QyAgGKfCyFcUXw
    New & Updated Addons
    23.09.2017
    -Plugin.video.xxx-dus-1.0.0 Adults
    -Plugin.video.danymedia-1.0.0 tv shows & movies
    -Plugin.video.filmcube-1.0.0
    https://mega.nz/#!bI8TWZ6T!vBt9kdeFS...igjjSBIfas2Dhc
    26.09.2017
    plugin.video.AdultTV-1.0.4 - Adult 18+
    plugin.video.covenant-1.1.16 - Movies
    plugin.video.evilkingplus30-5.0.2 - Italian
    https://mega.nz/#!XI03XQyT!Dj6SfIZqY...F86c25tNDSRlUk
    11.11.2017
    Attached below are five updated Albanian addons which work in both KodiLite 4.0 and Kodi.
    plugin.video.azfilma-al-1.0.1.zip
    plugin.video.ckamekqyr-1.0.0.zip
    plugin.video.tvseriale-1.0.0.zip
    https://mega.nz/#!DJsySYrY!dkgq5NZUl...RwJMIXWW9vk_R4
    19.11.2017
    plugin.video.tvseriale-1.0.2
    https://mega.nz/#!7I8DhBhD!ZN9Qxu4z3...QaNa_3hIjBIrS0
    11.01.2018
    plugin.video.movies - needs script.module.covenant. openload and thevideo need pairing.
    https://mega.nz/#!KA9zxZ5T!B5q3hpam0...WSawntunCPZ7Lo
    New and updated addons
    02.05.2019
    (ftp to folder /tmp and install via KodiLite ->Install addons -> zip -> /tmp) :-
    plugin.video.AdultTV-1.0.8 - IPTV Adult 18+ channels
    plugin.video.jizzplanet-2.1.0 - Adult 18+ videos
    plugin.video.madnessporn-1.0.0 - Adult 18+ videos
    plugin.video.tvseriale-1.0.4 - Albanian tv
    plugin.video.tvseriale-1.0.4.zip
    Código:
    https://mega.nz/#!yEFGiIID!-kYLHHSjm...a5UUhuLCnBUz3Q
    plugin.video.madnessporn-1.0.0.zip
    Código:
    https://mega.nz/#!uMcEDSII!AKfL8KvUA...lPYXguMPaZq9J0
    plugin.video.jizzplanet-2.1.0.zip
    Código:
    https://mega.nz/#!7dNEVART!jqiQJBGBX...sNYL8MeGWP_8PA
    plugin.video.AdultTV-1.0.8.zip
    Código:
    https://mega.nz/#!LdUAlKab!EF5pmRpvE...pHxIzqKupfOYbw
    Regards, pcd.
    Hello Friends,
    New and updated addons (install via KodiLite ->Install addons -> KodiLite list) :-
    plugin.video.exodus-8.0.4 - Movies
    plugin.video.streamondemand-pureita-5.4.91 - International-Italian
    plugin.video.SportsDevil-2018.09.20 - Sports
    plugin.video.tvseriale-1.0.4 - International-Albanian
    plugin.video.AdultTV-1.0.8 - Adult 18+
    openload videos need pairing with h**ps://olpair.com/
    Regards, pcd.
    New addons (install via KodiLite ->Install addons -> KodiLite list) :-
    plugin.video.Diabolik441--2.0.0.zip
    plugin.video.dplay-1.0.6.zip
    plugin.video.Diabolik441.zip
    Código:
    https://mega.nz/#!2ZdQCQKQ!NrwtgAIw_...HatOAYTGYu1NB4
    Código:
    https://mega.nz/#!qJMA2Qpa!ZLIvDtUO8...dVr6ka0blAsFLw
    Regards, pcd.
    Updated addons (attached) :-
    plugin.video.avelip-1.0.2 - Adult 18+
    plugin.video.hypnotube-1.0.1 -Adult 18+
    plugin.video.manporn-1.0.1 - Adult 18+
    plugin.video.pornheed-1.0.1 -Adult 18+
    plugin.video.specialtube-1.0.1 - Adult 18+
    plugin.video.twanza-1.0.0 - Adult 18+
    plugin.video.avelip-1.0.2.zip
    Código:
    https://mega.nz/#!2M1GiKCA!JU81qxIh1...b1dvZUwK4Q1B58
    plugin.video.hypnotube-1.0.1.zip
    Código:
    https://mega.nz/#!TYtgBKYS!fXy9YWXkE..._OCuheatfrsBs4
    plugin.video.manporn-1.0.1.zip
    Código:
    https://mega.nz/#!LItEQaLR!RbhjvjJ1Y...3g59asaxOgUAgQ
    plugin.video.pornheed-1.0.1.zip
    Código:
    https://mega.nz/#!DJ0GzQxB!h1_HUhpoc...lQIR1mevW8UHPo
    plugin.video.specialtube-1.0.1.zip
    Código:
    https://mega.nz/#!TZs2BIaY!ileKG2IoZ...f0tfYTGZsyDvh0
    plugin.video.twanza-1.0.0.zip
    Código:
    https://mega.nz/#!qVtWgayL!epdNJlBvW...QpOoMJW503l4tY
    Regards, pcd.
    Thumbs up 2019-12-23.
    20191223
    Updated addon (attached) :-
    plugin.video.xrysoi-1.0.1 - American/English movies with Greek subtitles
    script.module.resolveurl-5.0.37 - updated (required by xrysoi)
    script.module.resolveurl-5.0.37.zip
    Código:
    https://mega.nz/#!PdMATKQa!sg9AejmEg...UTHdeCVojK0SLg
    plugin.video.xrysoi-1.0.1.zip
    Código:
    https://mega.nz/#!DcEwjaSS!kwisC2vt7...IvBYmXgb-ncZBY
    Regards, pcd.
