Thanks Thanks:  70
Likes Likes:  72
Dislikes Dislikes:  1
Page 1 of 21 1234511 ... LastLast
Results 1 to 15 of 313
Thread: Zgemma H7S H7C 4K Combo DVB-S2X
    Thumbs up Zgemma H7S H7C 4K Combo DVB-S2X
    coming soon first zgemma 4k with S2X Tuners - OpenATV supported and ready
    FEATURES
    Linux Operating System
    Multimedia plug-in supported
    CVBS video mit R/L Audio
    Spdif Optical Audio
    USB3.0 and USB2.0
    1 Gbit Ethernet Interface
    Advanced EPG (Electronic Program Guide​
    User-friendly linux Menu syste
    Full automatic service scan
    Various OSD skins supported​
    ​Various Channel Editing Programs​
    Easy and fast software-upgrade via USB or Internet​
    4-digit 7segment display LED
    Low deep-standby power consumption under 1 W
    Specification
    ARM Brahma 15 Dual Core 1700Mhz 12K DMIPS
    ​BCM7251S Dual Core Mainchipest
    More than 4.10* linux kernel
    2*DVB-S2/S2X + DVB-T2/C Hybrid tuner built-in
    HD Connection
    AV Connection
    Support 4K- 2160p
    MPEG-2 / H.264 and H.265 Hardware Decoding
    HD HEVC / H.265 2160p60 Main-10 multi-format decoder
    1 x Smartcad-Reader
    1 x Common Interface slot
    1 x USB3.0 and 2 x USB2.0
    SPDIF for digital bit stream out(optical)
    4GB EMMC NAND Flash/ 1GB DDR3
    Timeshift
    Electronic TV programmes ( EPG ) support
    Parental Control
    Plugin Service
    OSD into many languages and graphics (Skins)
    Webinterface, WEB Remotcontrol
    DISEqC 1.0, 1.1, 1.2, 1.3 22Khz and USAL's
    External power supply12V 2.5A
    PACKING
    1 x Zgemma H7S box
    1 x Remote Controller
    1 x Power Supply
    1 x HDMI Cable
    1 x User Manual
    Price estimated should be around 200€ (I don't have confirm)
    http://i66.tinypic.com/330tqiq.jpg
    Zgemma H7 Series:
    Zgemma H7 box----180€
    Zgemma H7S box----230€
    Zgemma H7C box----270€
    thanks to:@maumixio
    Daca intr-adevar este cu chipsetul BCM7251S , ceva e gresit in specificatii
    Iata cateva diferente intre BCM7251S si BCM7252S
    Key Features of the Broadcom® BCM7251S Ultra HD SoC :
    l High-performance dual-core Brahma15 10k DMIPS CPU
    l 2.7Gpix/s OGLES2.0 3D GPU
    l Dual 800 Mpix/s 2D GPUs
    l 4Kp60 HEVC and VP9 decode
    l Quad 1080p60 HEVC and VP9 decode
    l Advanced security core for HD and Ultra HD content, including watermarking
    l High-performance connectivity peripherals, including USB 3.0, SATA III and Gigabit Ethernet
    l PCIe connectivity to Broadcom BCM4366 4x4 carrier-grade Wi-Fi
    l High Performance 32-bit DDR3/DDR4 system memory interface
    l HDMI 2.0 transmit and receive with HDCP 2.2
    Key Features of the Broadcom® BCM7252S Ultra HD SoC :
    l High-performance dual-core Brahma15 12k DMIPS CPU
    l Next-generation 2.7Gpix/s 3D OGLES3.1 GPU
    l Dual HD AVC encode
    l Additional 32-bit DDR3/DDR4 system memory interface
    19 May 2007
    Pana la urma am luat acest receiver din UK cu 210 lire Zgemma H7S 4K Combo DVB-S2X + DVB-T2, avantajul este ca are 3 tunere 2 dvb s2 si un tuner cablu si t2.
    Placa de baza este aceeasi ca in Mut@nt ULTRA HD HD51, OCTAGON SF4008 4K, AX 4K-BOX HD51.
    Versiunea H7s are tunerul de cablu lipit si tunerul dublu S2X se poate schimba.
    Functioneaza multiboot: 4 imagini in flash (am pus si de SF4800) si daca puneti a doua egami-8.0.4 la bootare-a acestei imagini veti avea multiboot de pe hdd sau usb.
    Suportul este acelasi ca la OCTAGON SF4008 mergand acelasi soft.
    Decripteaza cu oscam si merge perfect pe 5W.
    DM500, DM800HD, KATHREIN UFS910 si altele
    19 May 2007
    Astazi am scris pe partitia interna numarul 4 imaginea openATV-6.1-zgemmah7-20171001 care merge foarte bine cu PIP de pe oricare din cele 3 tunere, am incercat PIP cu canal UHD de pe Astra si Antena 3 HD de pe cablu,
    merge perfect
    Pentru setari am folosit backup-ul de la imaginea din partitia 1.
    Nu stiu de ce nu citeste cu nici o imagine temperatura CPU, acum toamna se comporta acceptabil ca regim termic si nu face nici un zgomot daca hdd-ul este ssd
    27 Oct 2014
    stiti cumva suporta si functia lnb unicable?
    19 May 2007
    Tunerele sunt FBC deci 2 tunere FBC sunt un total de 8 tunere de satelit plus un tuner de cablu care nu stiu daca suporta functia, am sa verific cand ajung acasa.
    PS:Am intrat remote si suporta
    Ceva exemple configurare?
    16 Feb 2009
    13 Post(s)
    La partea de CI, poti testa daca recunoaste camul CI+ de la Orange? Mutant HD 51 merge perfect cu camul de Orange, dar as vrea un receptor cu 3 tunere, nu cu 2 ca Mutant.Pe Ocatgon 4008 nu merge camul de Orange, de aiai sunt curios de Zgemma....
    Cred ca ''incompatibilitatea'' CI+ de la portocala tine mai mult de drivere/soft/imagine folosita , decat de hw
    05 May 2008
    CIMPIA TURZII
    @blondu poti sa imi zici o adresa de unde l-ai cumparat
    IPBOX 91HD antena 1.8 petale MST LNB INVERTO 0.3DB FLANSA.Digitv dublu antena 0.9 LNB INVERTO 0.0DB TWIN
    19 May 2007
    Vezi in PM
    05 May 2008
    CIMPIA TURZII
    Default Zgemma
    Ok ms.
    19 May 2007
    Cine dispune de un link cu LNB uri UNICABLE mai ieftine, eu am gasit la 180Ron fara transport.
    Multumesc..
    Thumbs up PurE2 6.2 .usb Zgemma H7 4K
    12 Jul 2007
    in sud la dunare
    @blondu poti sa imi zici si pentru mine adresa de unde l-ai cumparat?
    RAPIDIST PUR SINGE
    imi cer scuze ca ma bag in seama.....nu arunca banii.....ia un mutant 4k
    eu nu stiu fratilor...dar voi nu citit formurile de specialitate...gen...openpli...atv..vix....etc..
