Thanks Thanks:  6
Likes Likes:  5
Results 1 to 13 of 13
Thread: Vu+ Zero 4K Image
    Thumbs up Vu+ Zero 4K Image
    Black Hole 3.0.5 Quad PiP​ Vu+ Zero 4K Image
    What is new ?​
    - Update and fix CrossEPG
    - Fix Timer recording bug
    - Fix USB recording
    - Add Overlayfs for new kernel (Uno4KSE, Zero4K)
    - Add Uno4KSE support
    - Add Zero4K support (beta)
    - Add VP9 Support (Ultimo4K, Uno4KSE, Uno4K, Zero4K)
    - Add Dvb-S2X support (Zero4K)
    - Add Multistream/PLS support (Zero4K)
    - Add Blindscan support (Zero4K)
    - Update Drivers (Ultimo4K, Uno4KSE, Uno4K, Solo4K, Zero4K, Duo2, SoloSE, Solo2, Zero)​
    BlackHole-3.0.5-vuzero4k_usb_release_20171224_610e58d.zip
    https://mega.nz/#!SB00FBLT!evJmRfZu7...7TghKbQfwW7NMQ
    Thumbs up Black Hole 3.0.5.A Quad PiP Vu+ Zero 4K Image
    What is new ?
    Update drivers(4k models)
    - Fix demux problem
    [bluetoothsetup/util] update for solo4k.
    [vuplus-blindscan-utils] update TT2L08/TT3L10
    [Scan] Fix DVB-T2 Network Scan. (need update libdvbsi++ 0.3.8)
    - Fix HDR/HLG problem
    - Fix grab problem
    - Fix demux problem
    - Improve overall performance
    - Update kernel config
    - Adjust driver memory allocations
    update kodiegl/chromium/directfb.
    [libdvbsi++] update to 0.3.8
    [dvbmediasink] update EXTRA_OECONF (solo4k, uno4k, ultimo4k, uno4kse).
    update driver(zero4k)
    - Fix DVB-CI problem
    - Fix PLS
    - Improve demux
    This is available as an online update from 3.0.5 or as a full flash update.
    https://mega.nz/#!vZFWzTJA!k_W5dSxzl...0pFHY6--IwboEw
    Thumbs up Black Hole 3.0.5.E Quad PiP Vu+ Zero 4K Image
    Black Hole 3.0.5.E
    What is new ?
    update drivers(uno4k, uno4kse, ultimo4k)
    - Fix DiSEqC timing
    - Support Dual DVB-S2X FBC tuner(needs E2 update)
    update drivers(solo4k, uno4k, uno4kse)
    - Fix media playback(24Fps)
    Fix default recording path and usb recording.
    [dvbapp] update.
    [autofs] remove sync option for broken recording issue for ext4 filesystem.
    [udev] fix automount.
    https://mega.nz/#!GBE2FJwb!69iPiwJMf...cF1QGiEUbJrkyc
    Thumbs up Satdreamgr-6.0 Vu+ Zero 4K Image
    http://sgcpm.com/satdreamgr-images-6/vu/
    24 Mar 2009
    Black Hole 3.0.6​
    What is new ?
    Completely re-written the BH EPG system.
    Added EPGImport support
    Added FreeSat, Netmed, ViaSat and Virgin EPG
    Updated Sky EPG
    Added options to Load-Save-Delete epg.dat
    Updated CrossEPG
    Fixed DVB Subtitles issue on some channels
    Swapped Buttons around in BH panels to match layout of other images
    Various Skin updates from MX10
    Please Note:
    Due to limited resources some end of life models will no longer be supported from BH 3.0.6 onwards. If you want to use BH with these receivers please use version 3.0.5
    The following is a list of the receivers that will not be supported in version 3.0.6 onwards:
    Vu+ Zero
    Vu+ Ultimo
    Vu+ Uno
    Vu+Duo
    Vu+ Solo
    This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
    This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
    - Integrated OpenEpg
    - CrossEPG supported
    - EPG Import supported
    Yellow button = Audio menu
    Addons
    Infobar / OSD
    Analog Clock Gui
    Channel orbital location
    Signal SNR, BER
    Infobar picons
    Blue Panel
    Extra Settings
    Black Hole Speed Up
    Devices Manager
    Usb Format Wizard
    Telnet Panel ( Telnet Panel)
    FTP Panel ( FTP Panel)
    UPnP Client Djmount
    UpnP Server Minidlna
    Pcsc Panel
    Tuner Server
    Network Browse & Mountpoints
    Info Panel
    3 - About (info)
    Memory (Memory)
    Space (capacity)
    CPU (processor)
    Process (process)
    EPG Panel
    Green Panel
    Addons (added)
    Online Feeds Settings update
    Red Panel
    BlackHole
    Avalon
    Chaos
    Ghost
    Credits
    Thanks to plnick for help obtaining missing Ultimo4K files.
    Thanks to Pedro_Newbie for Backup script.
    DISCLAIMER
    LICENSE (TERM OF USE)
    This is free hobbyist software and it comes with absolutely no warranty. Use it at your own risk.​
    download BlackHole-3.0.6-vuzero4k_usb
    https://www.mediafire.com/file/vznxa...uplus.rar/file
    24 Mar 2009
    Black Hole 3.0.7
    What is new ?
    • Many bug fixes
    • Added new feature to let you know when an online update is avaliable
    • Changed default Skin to MX Black Sea
    • New Bootlogo
    • New defualt Spinner
    • Improved Wi-Fi setup
    • Added Duo4K support
    • Reintroduced Support for Solo, Duo, Uno, Ultimo and Zero
    • This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
      Addons
      Infobar / OSD
      Analog Clock Gui
      Signal SNR, BER
      Infobar picons
      Blue Panel
      Extra Settings
      Black Hole Speed Up
      Devices Manager
      Usb Format Wizard
      UPnP Client Djmount
      Pcsc Panel
      Tuner Server
      Info Panel
      3 - About (info)
      Memory (Memory)
      Space (capacity)
      CPU (processor)
      Process (process)
      EPG Panel
      Green Panel
      Addons (added)
      Red Panel
      BlackHole
      Avalon
      Chaos
      Ghost
      Credits
      DISCLAIMER
    • download
    • https://www.mediafire.com/file/u3bci...35459.zip/file
    Link-uri catre imagini "la zi" pentru acest receptor; sunt doar cateva, puteti adauga si altele care credeti ca merita testate.
    https://openpli.org/download/vuplus/Zero+4K
    http://pur-e2.club/OU/images/index.php?dir=6.2/vuplus/
    http://images.mynonpublic.com/openat...?open=vuzero4k
    Thumbs up The latest BlackHole image is 3.1.0 Multistream Vu+ Zero 4K Image
    BlackHole-3.1.0-vuzero4k_usb_release_20201005_b5f1952.zip
    https://mega.nz/file/bMcVBC7a#UeEWhJ...j_vpTU-G2CPe8M
    24 Mar 2009
    egami-10.2.r5-vuzero4k-2022.11.04
    https://www.mediafire.com/file/dch4t...4_usb.zip/file
    24 Mar 2009
    EGAMI 10.3 / OE-A 5.2
    Based on OE 4.1 Langdale
    Openembedded-core - OpenEmbedded Core layer
    Meta-openembedded - Collection of OpenEmbedded layers
    New Python 3.11, GCC libs ets..
    OpenSSL 3.0.7
    Kodi 20 (Node js, Qt - LATER with static-feed)
    OpenVpn 2.5.8
    GST 1.20.4
    OpenWebIf 2.0.1
    And more...
    https://www.mediafire.com/file/nt36g...3_usb.zip/file
    24 Mar 2009
    EGAMI 10.3 VU+ ZERO 4K / 10.04.2023 10.3 - R15
    OpenSSL 3.0.7
    OpenVpn 2.5.8
    GST 1.20.4
    OpenWebIf 2.0.1
    And more...
    https://www.mediafire.com/file/dzzhg...y-usb.zip/file
    24 Mar 2009
    EGAMI 10.4 R1 / OE-A 5.3
    Basato su OE 4.2 Langdale
    Openembedded-core - Livello OpenEmbedded Core
    Meta-openembedded - Raccolta di livelli OpenEmbedded
    Nuovo Python 3.11.2, librerie GCC ecc..
    OpenSL 3.1.0-r0.1
    Open VPN 2.5.8
    GST 1.22.0
    https://satup.net/download.php?id=23...qGyJi&download
