Vad ca a facut K3 AU pe thor, e 01 cheie noua.
Cu asta nu merge nici sa il bati @Laleauaneagra,incercat si curat,fara "balarii" cum spui tu, nu vrea nici de al dracu sa deschida...enigma2-plugin-softcams-oscam-11392_blackhole_armv7ahf-vfp-neon in schimb cu varianta de oscam al lui @Mesteru a luat-o din prima.
da...da dar doar Atlantic a schimbat..restu la mine merge pe inca pe 00 abcd
---------- Post added at 14:36 ---------- Previous post was at 14:34 ----------
am postat aici ce si cum...fara balarii...curat lacrima http://sateliti.info/showthread.php/32017-How-to-PV
cu scuzele de rigoare am reeditat toate linkurile in forma bruta
am verificat toate se deschid
succes tuturor
Am incercat sa fac setarile d-lui @laleaua dar n-am avut parte decat de blackscreen, chiar daca arata ca deschide
Eu am lumina pe 15w, 1w, 4,8e etc, fara AFN si pptv cu urmatoarea configuratie: Vu Ultimo4k, BlackHole 304, oscam 11399
Afn imi merg fara probleme din share.
Code:[reader] label = emulator protocol = emu device = emulator caid = 090F,0500,1801,0604,2600,FFFF,0E00,4AE1,1010 detect = cd ident = 090F:000000;0500:000000,023800,021110,007400,007800;1801:000000,007301,001101,002111;0604:000000;2600:000000;FFFF:000000;0E00:000000;4AE1:000011,000014,0000FE;1010:000000 group = 2 emmcache = 2,1,2,1 saveemm-unknown = 1 saveemm-u = 1 saveemm-s = 1 saveemm-g = 1 emu_auproviders = 0604:010200;0E00:000000;4AE1:000011,000014,0000FE;1010:000000 [dvbapi] enabled = 1 au = 1 pmt_mode = 0 request_mode = 1 delayer = 60 user = desired-user read_sdt = 2 write_sdt_prov = 1 extended_cw_api = 1 boxtype = dreambox [account] user = desired-user au = 1 group = 1,2
ce face fiecare si cum....eu nu stiu....mai mult de ata nu pot face....
---------- Post added at 22:40 ---------- Previous post was at 20:56 ----------
ma ajuta cineva cu o keye ptr discovery 12303.....mersi frumos
---------- Post added at 23:57 ---------- Previous post was at 22:40 ----------
Sa lamurim....prin metoda descrisa de mine.....FUNCTIONEAZA DOAR AFN....restu de pe 1W...4.8E.....NIMIC....ca sa nu va chinuiti degeaba...de ce?inca nu imi dau seama dar pana la urma doar afn conteaza ptr mine...si nci asta asa de mutl
---------- Post added 14-02-18 at 00:17 ---------- Previous post was 13-02-18 at 23:57 ----------
In schimb restu merg in STREAM...curat direct din keya din emulator....decodare directa......
Hai sa pun cum imi merge mie
Asta e configuratia pentru receptoarele cu procesor ARM (Ultimo4k, Solo4k etc)Code:in oscam.server [reader] label = emulator protocol = emu device = emulator caid = 090F,0500,1801,0604,2600,FFFF,0E00,4AE1,1010 detect = cd ident = 090F:000000;0500:000000,023800,021110,007400,007800;1801:000000,007301,001101,002111;0604:000000;2600:000000;FFFF:000000;0E00:000000;4AE1:000011,000014,0000FE;1010:000000 group = 2 emmcache = 2,1,2,1 emu_auproviders = 0604:010200;0E00:000000;4AE1:000011,000014,0000FE;1010:000000 in oscam.conf [streamrelay] stream_relay_enabled = 0 stream_emm_enabled = 0 [dvbapi] enabled = 1 au = 1 pmt_mode = 0 request_mode = 1 delayer = 60 user = user read_sdt = 2 write_sdt_prov = 1 extended_cw_api = 1 boxtype = dreambox in oscam.user [account] user = user au = 1 group = 1,2
Pentru receptoarele cu procesor MIPS in loc de
extended_cw_api = 1
vom pune
extended_cw_api = 2
Pentru aceasta configuratie folosesc o conpilatie de softcam facuta de mine la repezeala din mai multe softcamuri, pentru ca pe un softcam nu mergeau decat discovery, pe altul doar afn, pe altul nu mergeau sis de pe 4,8 e , samd.
Cu aceasta configuratie merg espn 15w, discoverys 1w, sis 4,8e, anumite canale cum ar fi SRG Swiss, ceva Biss.......... AM SCOS KEYLE AFN din softcam, pentru ca merge perfect din share fara alte balarii in config.
Numai bine
ptr afn local...merge fara nici o balarie postata pe toate forumurile....dar am postat deja la HOW TO PW...
faci un reader de cache fara streamrealy...fara cwapi...il mai dai si in share ca si local....
doar afn conteaza pana la urma..nici asta asa de mult restu e chiar can-can....cat si keyle din softcam
asa cum spui ca iti merge din share...renunti la tot ca le vezi din share oricum si iti faci localul tau de afn.....fara nici o balarie si o setare in plus
In alta ordine de idei..oscam emu o cam da in balarii...la general vb nu ma refer la pw....ma refer la share
mai urmaresc dar trec inapoi la oscam 11399 unde totu e bine si frumos ptr 7 canale mediocre nu se merita
A aparut vreun keyuploader mai nou, functional ?
Confirm, AFN duduie.
Nu folositi ultima versiune de oscam, e putin parlita.
folositi xxxx39.
Știți cumva de ce apare următoarea eroare in cazul canalelor Discovery?
La restul canalelor PW gen AFN sau Diva nu apare nici o eroare.14385A79 c (dvbapi) ERROR: ioctl(CA_SET_DESCR_MODE): Invalid argument
14385A79 c (dvbapi) ERROR: ioctl(CA_SET_DESCR): Invalid argument
