Results 1 to 4 of 4
Thread: ..:::: DreamOSat Script ::::....
    Thumbs up ..:::: DreamOSat Script ::::....
    DreamOSat Script plugin
    ============ NEW VERSION 6.5-r0 ============
    ADD 15.02.2018
    - (3) pAnDaSaT bOaRd SotfCam Key Update by. Informed
    - (5) OSCam Free Server ALL
    - (53) INT 2017 Movies
    - (54) INT 2017 Movies 2
    - (55) pAnDaSaT Free IPTV
    - (56) MediaPortal Install
    - (56) MediaPortal GrayZone Install
    - (yedek) TechSat Keys, Download Keys
    - (yedek) TechSat Keys, Show Visible Channel
    - (yedek) SotfCam.Key Update satupdate.net
    - (yedek) SotfCam.Key, constant.cw, AutoRoll.Key softcam.tv
    FIX 15.02.2018
    - (0) DreamOSatScript info # bash dos2unix add,
    - (2) PowerVU ALL Keys # "MTN Worldwide TV" edit,
    - (2) PowerVU ALL Keys # "language" add,
    - (4) CCcam Free Server # "URL" add,
    - (52) INT IPTV # bash script edit,
    - PowerVu/sids # "MTN Worldwide TV" edit,
    - PowerVu/.au # "AFN AU Keys 9.0" EMM Key edit,
    - (60) ALL PiconTranparent 220x132 45.0W-85.1E # p7zip edit,
    DELETE 15.02.2018
    - (3) OSCam Free Server Freecline.com delete,
    - (6) N-Line Free Server Freecline.com delete,
    enigma2-plugin-extensions-dreamosat-script_6.5-r0_all.ipk
    https://mega.nz/#!SBdhRagb!H5YlEieRi...U0gXYRaYB0A2Lw
    enigma2-plugin-extensions-dreamosat-script_6.5-r0_all.deb
    https://mega.nz/#!KRsG0LAR!QUqdAzdXG...rWhh-4bccVqb8A
    DreamOSat Script 7.0-r2 new version
    Uyarı : Uydu alıcınızda mutlaka curl yuklu olması gerekiyor bazı scriptlerin saglıklı çalışabilmesi için
    Piconları indirebilmek için p7zip gereklidir
    ============ NEW VERSION 7.0-r0 ============
    ADD 01.03.2018
    - (--) Katagorilere ayrıldı,
    - (22) OSCam Free Server cccam3.com add,
    - (31) N-Line Free Server cccam3.com add,
    - (73) pAnDaSAT FREE ALL add,
    - (74) pAnDaSAT ITALIA add,
    - (75) pAnDaSAT INTERNATIONAL add,
    - (76) pAnDaSAT MEDIAPLAY add,
    - (77) pAnDaSAT SPORT add,
    - (78) pAnDaSAT MUSICA add,
    - (80) INT IPTV yilmaztv.com add,
    - (81) INT IPTV DIZI yilmaztv.com add,
    - (82) INT IPTV FILM yilmaztv.com add,
    - (123) Biperva Settings 46E-42E-19E-13E-4.8E-0.8W
    - (124) Chveneburi Settings 42E
    - (125) Chveneburi Settings 42E-19E
    - (126) Chveneburi Settings 42E-19E-13E
    - (127) Chveneburi Settings 42E-19E-13E-7E
    - (128) Chveneburi Settings 42E-19E-13E-7E-0.8W
    - (129) Chveneburi Settings 42E-19E-16E-13E-7E-0.8W
    - (130) Chveneburi Settings 42E-19E-16E-13E-7E-4.8E-0.8W
    - (131) Chveneburi Settings 42E-23E-19E-16E-13E-7E-4.8E-0.8W
    - (132) Chveneburi Settings 42E-23E-19E-16E-13E-7E-4.8E-1.9E-0.8W
    - (133) Chveneburi Settings 42E-39E-23E-19E-16E-13E-7E-4.8E-1.9E-0.8W
    - (134) Chveneburi Settings Motor 100.5E-30W
    FIX 01.03.2018
    - Python edit #Skins dosyaları kaldırıldı, python içerisine yazıldı..
    - (2) PowerVU ALL SotfCam.Key # Discovery EURO KEY UPDATER,
    - (62) MediaPortal GrayZone Install,
    - (20) CCcam Free Server # curl max-time <seconds> 10 add,
    - (21) OSCam Free Server ALL # curl max-time <seconds> 10 add,
    - (22) OSCam Free Server cccam3.com # curl max-time <seconds> 10 add,
    - (23) OSCam Free Server Testious.com # curl max-time <seconds> 10 add,
    - (30) N-Line Free Server Testious.com # curl max-time <seconds> 10 add,
    - (90) OSCam EMU Updater ALL [mipsel,arm] OE2.0 # OpenATV 6.2 FIX, bash curl add,
    - (91) OSCam EMU Updater dreambox_fpu OE2.0-OE2.5 # OpenATV 6.2 FIX, bash curl add
    - (92) OSCam EMU Updater mips-openpli40 OE2.0 # OpenATV 6.2 FIX, bash curl add
    - (93) OSCam EMU Updater [ARM] dreambox,vuplus,mutant,octagon,gigablue # OpenATV 6.2 FIX, bash curl add
    - (94) OSCam EMU Updater dm900 LIBUSB OE2.5 # OpenATV 6.2 FIX, bash curl add
    - (95) OSCam Updater armV7 (download.oscam.cc) # OpenATV 6.2 FIX, bash curl add
    - (96) OSCam EMU Updater mips-tuxbox OE2.0 # OpenATV 6.2 FIX, bash curl add
    - (98) NCam EMU Updater ALL [mipsel,arm] OE2.0 # OpenATV 6.2 FIX, bash curl add
    - (99) GCam EMU Updater ALL [mipsel,arm] OE2.0 # OpenATV 6.2 FIX, bash curl add
    DELETE 01.03.2018
    - Skin/menuhd.xml
    - Skin/menufullhd.xml
    enigma2-plugin-extensions-dreamosat-script_7.0-r2_all.ipk
    https://mega.nz/#!bVVmVbpB!MKnk5JiQE...tWjGFYN8jlvZKk
    enigma2-plugin-extensions-dreamosat-script_7.0-r2_all.deb
    https://mega.nz/#!WJ82CY6D!TzETTn_yi...mCNIkoJDUojfZU
    Thumbs up DreamOSat Dowloader 6.3
    * UPDATE *
    Python edit.
    curl system was passed ...
    UltraHD 4k skins added ...
    OE2.5 DreamOS Images / install
    Código:
    apt update; apt upgrade
    dpkg -i /tmp/*.deb
    apt-get -f --force-yes --assume-yes install
    OE2.0 Images / install
    Código:
    opkg update; opkg upgrade
    opkg install /tmp/*.ipk
    enigma2-plugin-extensions-dreamosat-downloader_20190514-r6.3_all.ipk
    Código:
    https://mega.nz/#!2dFkFSgC!-47zDe0LB...Upjatdhi_TjEEM
    enigma2-plugin-extensions-dreamosat-downloader_20190514-r6.3_all.deb
    Código:
    thanks audi06_19
    DreamOSat Script
    Version 10.3
    Citar
    - Updete the plugin
    - Add support python3
    - Fix some bugs
    - Language support added
    Artık python 2.7 ve python 3 ile tamamen uyumlu
    Now fully compatible with python 2.7 and python 3
    enigma2-plugin-extensions-dreamosat-script_20200808-r10.03_all.ipk
    https://mega.nz/file/7dtxWYZb#IKEToK...EpFjSU98-pdNWc
    thanks audi06_19
    DreamOSat Script 10.7
    pass: 2023
    enigma2-plugin-extensions-dreamosat-script_20230101-r10.07_all.ipk
    https://mega.nz/file/TVtWUAzb#NBuGfh...SBnn7BztnnaFhQ
    thanks audi06_19
