Results 1 to 15 of 24
Thread: IPBOX 900 **NLB firmware**
    02 Feb 2007
    Somewhere in Aegean Sea!!
    Default IPBOX 900 **NLB firmware**
    Aica o sa gasiti firmware de la NLB pentru Ipbox 900HD...
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default NLB r7473
    NLB release for IP900 using SVN7473 for CubeRevo mini. It has been tested and verified.
    Get it here - nlb7473mini
    Upgrade box using usb key.. image file should be named "usb_update.img"
    PS: Known issue on first boot startup of box. DHCP not working. You need to go into ip setup and choose save in ip setup for DHCP or STATIC, then all is ok.
    For the people who are thinking of testing every option from the WEBIF, please have the following warning in mind:
    Don't use MGC**D v1.29a or 1.29a patched since that will hang the receiver. If you use it, you can't change channels and when you kill it the receiver hangs hard. No panic on the display, only a poweroff will work. When you use 1.29a, you won't be able to reboot the receiver from webif. That will hang the receiver to.
    If you have selected 1.29a or the patched version. Remove the file /var/etc/use_mgcamd129 or /var/etc/no_lib_mgcamd using a telnet or SSH session. Then shutdown the receiver. That will give you the new and good MGC**D version
    In all other options, the image is very stable
    http://www.upload-drive.com/1481/nlb7473mini_zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default NLB r7927
    WEBIF
    login: root
    password: relook
    rename usb_update_nlb7927mini.img to usb_update.img and update using usb pendrive.
    nlb7927mini
    * Updated to SVN 7927mini
    * fixed: EVOCAMD script now support /var/bin/evocamd
    * fixed: MGC**D script fixed to work with binary /var/bin/mgcamd
    * fixed: network DHCP correctly initiated at first boot only
    * fixed: skin blue/grey - channel search not working
    * fixed: firmare upgrade from webif
    * included: cool,nlb_blue_nlb_grey skins from @crash
    * --------- no downloads needed
    * --------- nlb_blue is default used now
    * included plugin: hddtemp v0.0.6 by kneubi
    * included plugin: script v0.0.2 by kneubi
    * updated: Danish menu language file
    * * remember to upload configs/files into /var/keys
    http://rapidshare.com/files/136009983/nlb7927mini.zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default NLB r8022
    * DHCP bug fixed
    * SVN update to 8022
    ***Link pentru firmware asta e scos, din cauza ca reprezinta probleme si nu booteze.Ei care il au sa nu il foloseste pt ca o sa pierde pe timpul lor...***
    ****- LINK REMOVED -- Image does NOT work (funktioniert nicht!) asa au scris si ei de la NLB si au scos pe firmware.E din pacat sa scoate firmware NLB fara sa il testeze.Din cauza asta eu insist sa folosim Sifteam sau ABCOM sau DGS firmware...****
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    O zi frumoasa! Snow's Avatar
    Default Re: NLB r8022
    Quote Originally Posted by otheitis View Post
    * DHCP bug fixed
    http://rapidshare.com/files/141535571/nlb8022mini.zip
    are bug imaginea - PANIC
    02 Feb 2007
    Default NLB r8022 v3 mini
    include: mbox 10.09.2008
    changed: mbox fix for viasat channels
    -------: restarting mbox did not clear channel without change channel
    changed: soft update script now correctly uses /var/bin/soft
    -------: selectable from -assign button- menu too
    http://rapidshare.com/files/144496881/nlb8022v3mini.zip
    **Am facut update pe link cu nou software pt ca exista o problema cu kernel care a fixat-o acuma NLB..Acuma NLB r8022 v3 functioneaza fara probleme**
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    Default NLB r8107 mini
    nlb8107mini
    Changes:
    * include: svn8107 from DGS
    * include: mbox 17.09.2008
    * included: Deutsch translation from svn8022
    * include: Documentation on nlb mod features included.
    Remember to download skins update on network update
    http://rapidshare.com/files/148393765/nlb8107mini.zip
    02 Feb 2007
    Default NLB r8107mini
    include: mbox 3.10.2008 (0.4 Build 0005)
    fixed: cam scripts
    -----: if img file was found on usb stick, cam script closed
    -----: causing freeze or no decoding
    fixed: skins
    fixed: /var/bin/soft reference
    fixed: IP9 USB Stick setup as HDD, must be above 2GB,
    ------ 128MB swap is allocated.
    updated: reversed to busybox from previous release DGS SVN8022.. killall did not work
    updated: Multiboot is updated to support usb stick changes
    updated: Full German translation update (Byti)
    updated: Full Danish translation update (pen1010b)
    updated: Documentation on nlb mod features.
    http://rapidshare.com/files/150641044/nlb8107v2mini.zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default Bootup change ip900/ip9000
    A possible fix for usb_update.img with ip900
    AND
    removal of "NLB BOOTING" info.
    Attached you find small image for ip900 and one for ip9000.
    Fastest way is to upload .img file to your /tmp folder and through webif do a firmware upgrade... file is ONLY 132KB..
    It takes only 2 second..
    usb_env900.zip for ip900 users
    usb_env9000.zip for ip9000 users
    usb_env900.zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default NLB r8340 mini
    nlb8340mini
    * fixed: skin update - show resolution in additional info banner
    * added: NLB Panel (start with green button) onscreen menu, webif alternative
    * added: Incubus camd v0.5 (not configured! will crash box if not configured)
    * added: mount usb stick or Harddrive with Windows filesystem at bootup
    * added: format usb stick with Windows filesystem in Webif
    * added: hdd sleep period configure option
    * added: restore var from usb
    * added: switch between nlb and dgs webif (dgs webif has WebTV support!)
    * added: plugins - tetris,pong,sudoku,weather
    * updated: cam scripts
    * updated: mbox Build 0015
    * updated: format usb stick with Linux filesystem for multiboot in webif
    * updated: Full German translation update (Byti)
    * updated: Full Swedish translation update (Wikings1)
    * updated: Full Danish translation update (pen1010b)
    * updated: Documentation on nlb mod features.
    * fixed: mount usb stick with Windows filesystem
    * fixed: multiboot - now supports usb_all and usb_all_noboot images
    * Thanks to Byti,Spiderman,Wikings1,teleka for intensive testing and reports
    http://www.upload-drive.com/3355/nlb8340mini_zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default NLB r8421 (beta) mini
    WEBIF
    login: root
    password: relook
    Prepared by : Dexter
    Release date : November 3. 2008
    Changes:
    * updated: SVN8421 update with fixed DIVX player (libsync issue fix)!!
    * updated: nlb panel with internet update
    * updated: mgcamd 1.31 included (fixes old need for mgcamd130, and this is now gone)
    * fixed: swap setup with HDD and USB
    * fixed: skins updated to 3.3, thanks to zbigzbig and Crash for making quick updates
    * added: NLB Panel 1.33 (start with green button) onscreen menu, webif alternative
    * added: plugins added - WebEPG 0.1 (Readme in the /data folder)
    * updated: cam scripts with bigger timeout
    * updated: mbox Build 0015 (the one with gbox support)
    * updated: Full German translation 8421 update (Byti)
    * updated: Full Danish translation 8421 update (pen1010b)
    * included: Documentation on nlb mod features.
    * added: HDD Swap enable/disable at bootup.
    http://rapidshare.com/files/16047765...1-v1.0mini.zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    Default Re: IPBOX 900 **NLB firmware**
    nlb8421mini (v1.110)
    Release date : November 9. 2008
    Changes:
    * fixed: DGS application patch to keep EPG when changing TP, DGS delete them.
    * updated: NL language files (Gman2006)
    * updated: USB scripts updates
    * update: nlb panel v1.36 emu changing works now.
    * - option to set changable delay during boot with newcs
    * - Some cards requires longer initialisation than others.
    * - Those without should just use like 3 seconds.
    * updated: Webepg v0.6 now works with patched DGS application
    * - option to dump favorites as webepg.list
    http://rapidshare.com/files/16209232...ini-v1.110.zip
    02 Feb 2007
    Default NLB r8478 mini v1.2
    CubeRevo nlb8478-910 (v1.2)
    WEBIF
    login: root
    password: relook
    NOTE: it seems box still freezes at first "language" selection, please just reboot and
    all is ok.
    Release date : November 29. 2008
    Changes:
    * added: NFS mount replacement for HDD SD media recording folder
    - Read "nlb_image_features.txt" to understand how to configure NFS media folder.
    * - Thanks to DGS for assistance on kernel fix.
    * - HD Recordings on NFS works too, but will studder! so you are warned.
    Reason - MPEG4 recording can be upto 20Mbyte/second, and network is max. 6MByte right now on ipbox.
    so its never going to work with only 100Mbit network card.
    - can be enabled disabled under IP9000 -> change NFS/HDD media in webif.
    * updated: newcs.xml added boxkey code to support German *** cards.
    http://rapidshare.com/files/168620912/nlb8478mini.zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default NLB r8630 mini
    CubeRevo nlb8630 for ip900(Cuberevo mini) and ip910
    WEBIF
    login: root
    password: relook
    Release date : December 16. 2008
    Changes:
    * added: - can be enabled disabled under IP9000 -> change NFS/HDD media in webif.
    * - HD Recordings works too, but will studder! so you are warned.
    * fix: NFS mount on boxes without internal hdd.
    * fix: Slow NFS mount fix (thanks to semack for the help).
    * added: - delay option in panel for Nagra3 cards.
    * added: - Germans with nagra card should use 20 seconds and it decodes at bootup
    * added: ushare for sharing through UPnP protocol (like to PS3) Thanks to Kneubi
    * -----: enable/disable/restart in Webif->system options
    * added: Option to run boot scripts from /var/etc in hotfix situation.
    * plugins: bitrate 0.0.2 and favpip 0.7 .
    * updated: newcs.xml added boxkey code to support German NDS cards.
    http://rapidshare.com/files/174022545/nlb8630mini.zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
