Results 1 to 6 of 6
Thread: Imagini DM 500+
    O zi frumoasa! Snow's Avatar
    Default Imagini DM 500+
    38 Post(s)
    Default SifTeam 1.9.3C 500plus
    SifTeam 1.9.3C 500plus vom 19.12.08
    http://www.mediafire.com/?4j2lxz4mylg
    02 Feb 2007
    Somewhere in Aegean Sea!!
    Default Gemini 4.60 DM500plus
    Gemini v4.6:
    Technical Infos:
    * Enigma of: 19.12.2008
    * GCC 3.4.4 Original CVS
    * Web Interface: 6.0.4-Expert
    * Busybox 1.01
    * Tuxtxt V1.104
    * CIFS 1.44
    Remotecontrol:
    * BLUE - Blue Panel (BP)
    * 2x BLUE - BP -> Extras/Settings
    * YELLOW - Quick-Button (can be configured via BP)
    * RED - EPG list for active channel
    * 2x RED - EPG style menu
    * GREEN - subservices
    Addons:
    * own Addon-Server via Internet
    * adding additional functions via internet from the Gemini-Server and install them automaticly
    * Personal Addon-Server can be used (configuration via /var/etc/useraddon.xml)
    * Create your own Satellites.xml, which only contains the Satellites you realy need
    Camd:
    * Different Camd´s can be linked to channels/provider (Autocam)
    * Changeing the name and settings via own menu.
    * Creation of a 2nd socket (/tmp/cam1.socket)
    Daemon / Server / Clients:
    * Automatic test wehter the box is connected with the internet or not (Well be shown in the infobar)
    * Dropbear (SSH) now switchable (DM500 - DM7000: Standard->off)
    * added editor to configure the cron-daemon
    * Little Apache (HTTP-Server based on HTTPD)
    * Upnp Client and Server (for DM500/56x0 must be installed from Gemini-Server as addon)
    * Inadyn (Daemon for different DYNDNS-Services)
    * Settings for syslogd
    * Dreambox can be used as printserver (BP->Extras/Settings->Printer (LPD), FAQ can be found in the database
    * Automount, for examples have a look at: /var/etc/automount.conf. Devices, NFS or CIFS will be automatically mounted. Ideally for DVD- or Net- Drives (Editor can be found in the BP)
    * NFS-Server (based on the NFS-Kernel-Modules, nor for DM500, DM500+ and DM56xx)
    Infobar / OSD / Skin / Background-Pictures:
    * Position of the Infobar can be changed without editing the skin files
    * Provider, Frequencies, Symbolrate and FEC can be displayed in the Infobar (If the Skins matches this function)
    * Display of EMM, ECM or "Expertinfos" are switchable
    * Picon (displaying the Channel-Logo)
    * Extensions for Skins (Thumbnails, 3D-Font, Pictures for Progressbar)
    * Background picture can be turned off (Plasma - Fix)
    * Backgroundpictures (Radio- and File Mode) can be used as Screensaver.
    * Changing Bootlogo via menu ( 7020 only)
    * Backgroundpictures and Bootlogos can be created, testet and used direct on the Box (out of JPG, BMP, GIF or PNG)
    * Showing Onlinestatus when the Box is connected to the Internet (must be activated in Expert Menu -> Network)
    * Moved Gemini events (Ripper, Calendar, email-Checker) from BluePanel Menu into the infobar (eLabel-Name = geminievent)
    Files / Devices
    * Support for CDROM/DVD no matter using IDE or USB
    * Random function for all kind of soundfiles
    * Backup function
    * 2 new root entries for music and pictures can be created in the filemenu (BP->Extras/Settings->Root-Entry)
    * support for the bigger remotecontrol on 500 and 500+ (normaly shipped with 70XX/600pvr - activate on BP->Extras/Settings)
    * Support for FLAC, OGG/Vorbis and WAV (please install codecs in the BP)
    * Functions for SWAP (virtual memory). Create, delete, size and location.
    * Device-Manager for HDD / DVD / CF / USB
    * Drivers for USB-Cardreaders are now included in the Image but are not loaded!
    EPG
    * additional functions (e.g. dishnetwork, cache, location)
    * search all channels for an event or an own string. Timers can be added immediatly (Press "Menu" in the epg or use use BP -> extras -> EPG-Refresh)
    * Infos of the recorded movies can be shown without starting the movie
    * refresh EPG using the enigma-timer (BP -> extras - EPG-Refresh)
    * autosave for EPG-cache ( BP -> Extras/Settings -> EPG-Settings)
    * Duration of current event in the programm overview ( Menu -> Info -> EPG)
    * general information about the EPG Data (BP -> Info-> EPG-Settings)
    * a time period for the EPG Data can now be defined (BP -> Extras/Settings -> EPG-Settings)
    Extras:
    * Dreamnetcast (shoutcast-player) with Streamripper (direct recording from server and coding into mp3´s) (for DM500/56x0 must be installed from Gemini-Server)
    * RSS und Weather Plugin (for DM500/56x0/7000 must be installed from Gemini-Server)
    * System Info: Many extra box infos like HDD temprature, stream-rates (>=7000) or kernel-, memory- and prozessinfos.
    * Own scripts can be started via Blue Panel
    * Changing the recording parameters (extra before- and after- recording time, storage location and recover-function for your records)
    * change the settings for recording (before Time, after-recording time,, location and recover-function)
    * Create your own satellites.xml including only the satellites you really need.
    * Quick-Button-Menu: Many extra features for the yellow button (e.g permanent clock in OSD, freeze Image, audio selection)
    * alarm-clock with volume offset playing own WAV-Files
    * Calendar for iCalendar format + reminder ( Supported by MAC, KDE, Thunderbird, Goole calander, Rainlendar...). Standard folder is /var/etc/ical (for DM500/56x0 must be installed from Gemini-Server)
    * Support for DreamDVD no matter wether a DVD-Drive is available or not
    * New screenshot routines (have a look at the Webif)
    * eTorrent - a torrent client based on ctorrent. Can be managed completly over the OSD (for DM500/56x0/7000 must be installed from Gemini-Server)
    * disable the TV - output while taking a recording, streaming a movie and manually (usefull for boxes with very low lan-speed)
    * update system time via transponder or internet ( Protocol RFC868 )
    * eMail-Checker extended with SSL support (Overview of your POP3 or IMAP accounts)
    * create password using the BP (BP -> Extras -> Pwassword)
    * rotate al kind of pictures. Also automatic rotation using EXIF (must be activeted using the menu)
    * Re-Zapp, zapps after X-minutes to the actual Channel (BP -> Re-Zapp)
    * Displays, wether the box is an original one or not (using MAC adress, BP -> System -> Dreambox -> Manufacturer)
    * the Jukebox, Please install as addon.
    Recordings:
    * records into different folders ( the settings have to be done in the Timer-Menu)
    * LED´s are flashing during record (Boxes without display). Must be set in BP -> Extra -> Record
    * import of recorded movies every time you enter the Video-Menu or only once when the Box ist starting (BP -> Extras -> Record)
    * Records can now be done in the new Eniga2 format (*meta files) or as usal as "recordings.epl" (BP -> Extras -> Record)
    New:
    * Webcam Viewer for viewing images from the Internet, configureable via XML config (only Still, no interval as we have at E2)
    * Now you can perform a network-settings test (new construction + wizard)
    Fix + update:
    * Dreamnetcast
    * RSS-Reader
    * Jukebox
    * Changed OSD & Video grabbing
    * have a look in the CVS
    Interfaces WebIF:
    http://127.0.0.1/cgi-bin/GeminiInfo
    http://127.0.0.1/cgi-bin/StopCam?ZAHL (ZAHL = number of cam)
    http://127.0.0.1/cgi-bin/StartCam?ZAHL (ZAHL = number of cam)
    http://127.0.0.1/cgi-bin/InitCam
    http://127.0.0.1/cgi-bin/ResetCam
    http://127.0.0.1/cgi-bin/setKey?typ=...est&val=blabla
    http://127.0.0.1/cgi-bin/getKey?typ=...tedvb/int-test
    We'd like to thank everybody who paricipated in the "Gemini suggestion" thread. Unfortunatly many things can not be realized from our side.
    This images doesn't contain any keys or softcams. Backups or other modified Images are not from us and won't be supported!
    Gemini Images may only be used on receivers of the manufacturer Dream-Multimedia-TV.
    The use of this Image is on your own risk.
    Recommendation:
    If you don't install the Image in flash memory, the flash image shouldn't be of a old version. A swap file/partition (>= 16MB) should be present
    if several processes running in background. We assume no liability for direct or indirect damage.
    http://rapidshare.com/files/17676202...192051.nfi.zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    13 Feb 2007
    Earth
    Post NewNigma2-image-dm500plus-v2.3.1
    NewNigma2 V2.3.1 DM500Plus
    .... English ....
    Data:
    · Enigma2 : 27.01.2009
    · Enigma2-plugins : 27.01.2009
    · NewNigma2-plugins : 27.01.2009
    · Treiber: 22.08.2008
    · Secondstage: „66“
    Changes:
    · Minor bugfixes
    · New version of UShare
    · New drivers
    List:
    * dreambox-dvb-modules
    * ushare 1.1a
    * enigma2
    * enigma2-plugin-extensions-webinterface
    * enigma2-plugin-extensions-autotimer
    * enigma2-plugin-extensions-epgrefresh
    * enigma2-plugin-extensions-cdinfo
    * enigma2-plugin-systemplugins-videomode
    * enigma2-plugin-systemplugins-positionersetup
    * enigma2-plugin-systemplugins-satfinder
    * enigma2-plugin-extensions-graphmultiepg
    * enigma2-plugin-extensions-fritzcall
    * enigma2-plugin-newnigma2-picon
    * enigma2-plugin-extensions-imdb
    * enigma2-plugin-newnigma2-menu
    * enigma2-plugin-newnigma2-usbmanager
    * e2fsprogs-mke2fs
    * e2fsprogs-e2fsck
    * dosfstools
    * gst-plugin-cdio
    * kernel-module-cdfs
    * libcddb
    * libcdio
    download :
    http://www.sendspace.com/file/w19w5h
    02 Feb 2007
    Default Sifteam 1.9.3D dm500 plus
    SifTeam 1.9.3 Dm500plus
    CAMBIAMENTI:
    1) Cambiato il CVS alla versione 13.02.2009 (con supporto a piu' file audio, .ogg ecc..)
    2) Nel parental Control si puo' bloccare l'accesso al pannello EMU
    3) In tutte le versioni sono presenti i comandi "ifup" e "ifdown"
    4) Per guadagnare spazio sono stati rimossi:
    "streamts" ..si deve installare dal pannello
    il secondo boot-logo ..si puo' installare dal pannello
    5) Si puo' scegliere di non eliminare i pacchetti scaricati (menu' avanzato)
    6) Aggiornato la libreria libc.so.6 (a tutti i modelli, ex: samba non funzionava piu')
    7) Modificato script avvio Qbox-one (ora il wifi si riavvia bene)
    8) Nel 200 e' stato inserito l'eseguibile e diverse librerie dell'openvpn
    9) Aggiunto nel pannello la possibilita' di montare un disco esterno USB (per la presa posteriore nel Qbox-one)
    NOTE:
    Per la versione ipbox-200@64mb si deve:
    1) Installare l'immagine del 200 normale
    2) Installare il file "serial_uboot_64.img"
    ..entrambi con Flashtools o Flasher
    Programmi:
    Per avviare programmi personali, valido per tutte le immagini SifTeam: Aggiungere il comando voluto in /var/etc/rcS.d/S99user_start.sh in fondo al file (ci sono gia' presenti diversi esempi pronti all'uso, basta decommentarli rimuovendo il simbolo #)
    Tips:
    Per entrare nel Pannello di Controllo se ci si trova nel Pannello Emu basta premere il bottone giallo, funzione aggiunta per l'uso nella WebIf.
    Per aprire il menu' Script mentre ci si trova nel Pannello di Controllo basta premere lo 0 (zero).
    Errori:
    In caso si presenti l'errore "..curl_global_init.." con qualche plugin, dopo l'installazione del medesimo, basta riavviare enigma o il decoder. (deve rileggere la nuova libreria installata dal plugin)
    * L'opzione Muovi OSD non e' piu' presente in enigma perche' la DreamMultimedia ha occupato
    il bottone rosso nelle opzioni OSD
    Si puo' installare come plugin esterno.
    ** Il Qbox-one non ha ancora tutte le funzioni degli altri modelli, ad esempio il firewall per
    ora non funziona (altrimenti il kernel non e' compatibile con il modulo wifi della duolabs)
    ...diciamo work in progress ...ma e' perfettamente utilizzabile con le funzioni base.
    Forse la cosa che manca di piu' e' la funzione del tasto
    premuto per >1sec. (per piu' di un secondo), per entrare nel pannello di controllo si deve
    passare da: tasto blu -> tasto giallo
    English
    Changes:
    - CVS updated to 02.02.2009(more audio files are supported)
    - Now you can block ,trought parental control,the access to emu panel
    - commands 'ifup' and 'ifdown' are available
    - Re:"streamts" that is available on online panel
    the second bootlogo is available also by online panel
    re(only on ipbox versions)some files...they are always available online
    - You are now able to left downloaded addons(advanced menu)
    - Libc.so.6 updated
    - start script of qbox one fixed(wifi won't lose settings at reboot)
    - 200 image has already buil-in executable and any library of openvpn
    -you can mount an external hdd on qbox(added option on advanced panel)
    Note:
    For the version ipbox-200@64mb you must:
    1)install the normal img for ipbox200
    2)install "serial_uboot_64.img"
    both with flashtools or Flasher
    * About Programs:
    For all sifteam images, on /var/etc/rcS.d/S99user_start.sh you can choose a program to start(there are already some commented examples..remove "#" to active them)
    Tips
    To enter in Control Panel from Emu panel you can press the yellow button (added also on webif)
    The menu Script can be opened from Control panel pressing 0(zero)
    To change the positions of Channel name or Clock you can modified by telnet the values
    (Horizontal)(50 & 80 are the default values)
    echo 50 > /var/etc/SifTeam/conf/altOraOSD
    echo 80 > /var/etc/SifTeam/conf/altCanaleOSD
    (Vertical)(10 is the default value)
    echo 10 > /var/etc/SifTeam/conf/oriOraOSD
    echo 10 > /var/etc/SifTeam/conf/oriCanaleOSD
    Errors:
    If the following message appear "..curl_global_init.."...please restart enigma(Menu-5-restart enigma)
    * The option Move OSD is no longer available but you can install it as external plugin
    To use the old /Var you should edit the file /var/tuxbox/config/enigma/config
    and change the text "s:/ezap/ui/skin=/*****/tuxbox/enigma/skins/golden.esml" in
    "s:/ezap/ui/skin=/*****/tuxbox/enigma/skins/bluzzy3_adv.esml"
    ** The Q-box has not all the functions of the other boxes...for example to open the Control Panel you must press blue>yellow
    Enjoy Sif-team fans
    http://rapidshare.com/files/20591973...00plus.nfi.zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default PLi® Jade2 Dm500plus 20090317 Rev.6300
    [22-03-2009] PLi® Jade2 Enigma1 images released
    A new Enigma1 PLi® Dreambox release is available for download.
    The Original Enigma1 PLi® Jade2 suite contains the following images:
    * PLi®-Jade2-DM500 (regular and maxvar)
    * PLi®-Jade2-DM500+ (Plus)
    * PLi®-Jade2-DM600
    * PLi®-Jade2-DM5600/5620
    * PLi®-Jade2-DM7000
    * PLi®-Jade2-DM7020
    Use the downloadsection on our website to be sure to download our original PLi® images.
    Direct download: http://www.pli-images.org/downloads.php
    See below for fixes & features since the initial PLi® Jade release
    New features highlights:
    - New tuxtxt plugin
    - Tuxtxt subtitling (enable tuxtxt caching to get this feature)
    - Current and next EPG can be switched in service selector using audio key
    - Added "browse" selection in various menus
    - Timeshifts can be recorded on a separate location now
    - Selectable remote control channel
    More new features:
    - CVS Repository 11/01/2009
    - PLi® Repository 18/03/2009
    - Update to CCcam 2.0.11 for normal DM500 image and DM56x0 image
    - Default CCcam selected in cam setup for non-maxvar DM500, DM56xx
    - Updated encoding.conf
    - Removed movieplayer in DM500 maxvar image(image became too large, it's downloadable now)
    - Disable AC3, teletext stream recording added
    - web-x-tv: added support for vlc 0.9.x
    - Automatic LinuxExtensions correction for cifs mounts. Improves NAS compatibilty
    - Added teletext as programmable yellow/blue button
    - Support for slave harddisk on DM7020
    Fixes:
    - Web interface timer menu fixes
    - Let exit key on a DM500 repeat to quit menus quickly
    - Take time start and stop offsets into account if a recording is added using webif
    - Fixed the save button (Green button) if unintentionally pressed in sat config screen
    - Harddisk format fixes
    - Default small silver remote for the DM500 and DM500+
    - Zapstream fixes
    - Solved wrong genre in webif channel EPG
    - "x% in use" updated in filemode now
    - Fixed service selector too near to window border
    - Fixed possible problems if /var is moved to a network share
    - RSS plugin fixes
    - Fixed dropbear plugin
    - Backup/restore fixes
    - MV fix for illegal date/time
    - Remove timeshift options for boxes which cannot timeshift
    Languages:
    - Spanish language update by Corvus
    - Estonian language update by Indrek
    - Dutch language update by dAF2000
    - Czech language update by ims
    Known bugs:
    - Picons may not work if a satellite has both Ku and C band channels
    - Unmounting network shares may not work all times
    - Network settings may not be restored in backup/restore
    See our PLi® Wiki for more answers on your questions...
    Many low level changes fixes and other updates...
    http://www.pli-images.org/downloads....download_id=58
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
