Page 1 of 5 12345 LastLast
Results 1 to 15 of 62
Thread: Imagini DM 8000
    13 Feb 2007
    Earth
    Post Imagini DM 8000
    Gemini2 v3.9:
    Technical Infos:
    * Engima from: 29.11.2008
    * Busybox 1.0.1
    * Tuxtxt 1.95
    Function Buttons:
    * BLUE - Blue Panel (BP)
    * long BLUE -> PiP (DM7025)
    * 2x BLUE - BP -> Extras/Settings
    * RED - Record
    * GREEN - Quickbutton / Subservices
    * Yellow - Timeshift
    Addons:
    * Own Addon-Server via internet.
    * Download and installation of additional features via internet from Gemini server.
    * Use your own Personal addon server (configure it in /etc/useraddon.xml).
    * Create your own Satellites.xml which only includes the satellites you need.
    Camd:
    * Assign different Camds to Stations/Providers (AutoCam).
    * Change of the name and different functions over own menu. Daemon / Server / Clients:
    * Dreambox can be used as printserver (BP->Device Settings->Printer (LPD), FAQs in the database).
    * Dropbear (ssh) now switchable (BP->Extras->SSH).
    * Upnp Server / Client
    * automount, examples in /etc/automount.conf. Devices, NFS or CIFS get automatically mounted. Ideally for DVD- or Net- Drives (Editor can be found at BP->Extras->Automount).
    * Inadyn (Daemon for various DYNDNS-Services).
    * little Apache (HTTP-Server based on HTTPD).
    * NFS-Server (based on the NFS-Kernel-Modul).
    * Editor to configure Cron-Deamon
    Infobar / OSD:
    * HD-Skin preinstalled (DM80..)
    * Provider and Satellite will be shown in the Infobar (depending on the skin).
    * EMM, ECM or "ExpertInfos" Display switchable.
    * Picon (displays the station logo)
    * Show Onlinestatus when the Box is connected to the Internet (has to be activated in the BP -> Extras/Settings/Online)
    * Spinner (response time now adjustable, 0 is off)
    * Picons can be changed between Gemini and DMM format
    * the position of the infobar can be changed
    * HDTV-Logo in the Infobar (DM80..)
    Files / Devices:
    * Device Manager (format, mount and other functions)
    * Support for CDROM/DVD no matter if it is IDE ur USB
    * HDD- temperature and performance visible in the menu.
    * HDPARM values for harddisks disk can be changed by menu.
    * SWAP setup and start automatically.
    * Hotplug for USB-Devices (are shown in the OSD - Can be mounted using the Device-Manager)
    EPG:
    * EPG-autosave- Saves the EPG data at a defined time
    * additional EPG-Infos (BP -> Info)
    * Duration of current Event in the programm overview ( BP -> Info -> EPG)
    * EPG-Serch. Search by Title, description or own text.
    Extra:
    * Dreamnetcast (shoutcast-player) with Streamripper (direct recording from server and coding into mp3s).
    * Weather Plugin with 10 days forecast.
    * RSS/RDF reader with TOP list from RSS-scout.
    * Webcam-Viewer with FullScreen mode.
    * Alarm clock(plays mp3s at a fixed time)
    * System Info: Many extra receiver infos like stream-rates, kernel-, memory- and processinfos.
    * Own Scripts can be started via Blue Panel.
    * Kernel modules can be reload separately.
    * Password can be changed by menu.
    * EPG Cache and EPG Refresh (updates the EPG at the night) adjustable over BP.
    * flashing clock when recording in standby.
    * Calendar for the iCalendar format + Reminder (supported by MAC, KDE, Thunderbird, Google calendar, Rainlendar…) , Standard-folder is /etc/ical.
    * eTorrent - a torrent client based on ctorrent. Can be managed completly over the OSD
    * eMail-Checker (Overview of your POP3 or IMAP accounts + SSL)
    * overview of the different Scrambling systems that the current station uses.
    * Quickbutton
    * Turning of pictures, also automatically by EXIF data.
    * "The GP2 Controlr" Firefox Extension to access functions of the Box.
    * ReZapp, Switch back to a channel on a fixed time (BP-> Extra-> ReZapp)
    * Summary of the HDTV-Channels in the Channellist->Satellites (DM80..)
    New:
    * customization for the 8000, partly internal
    * Jukebox, Soundplayer supports MP3, OGG, FLAC and WAV. With Playlist-organizer and display of the cover. It's insignificant where the image is placed (Soundfile or in the same folder) It's still beta, same new functions will be added with the next image...
    Fix + Updates:
    * RSS reader with title images and new XML
    * Webcam-Viewer cataloged in sub folders and new XML
    * folder for Autofs changed. (customization at DMM's Autofs-System). New folder is "/autofs", config-file is "/etc/auto.hotplug". Editor in the BP can be used further on.
    * Network Hardware added to the Devices Manager
    * see CVS
    http://www.satscreen.tv/forum/showth...9565#post89565
    13 Feb 2007
    Earth
    Lightbulb scvs-image-dm8000-20081129135458
    am: 29.11.2008 22:06
    Description:
    Enigma = 29.11.2008
    Plugins = 29.11.2008
    Treiber/Module = 28.11.2008
    Second Stage Bootloader = 69
    Kernel = 2.6.12-r9
    - Eigene SCVS Bootlogo's by yvessun und Skin / zusätzlicher HD-Skin by kerni
    - satellites.xml - enigma² by IhaD
    - angepasste terrestrial.xml
    - AC3 Fix
    - incl. liba52 (nur bei der DM7025)
    - USB, USB HID, USB MON Treiber im Kernel
    - Smargo USB Cardreader Unterstutzung FTDI_SIO und PL2303
    - MHW EPG
    - .recordings patch
    - pmt.patch
    - AIO / Grab Screenshot
    - dccamd nicht mehr im Image, sowie dccamd und wdog aus bootup entfernt
    - Folgene Softcams incl. Startscript welches unter /usr/script/ installiert wird per Internet installierbar:
    * CCcamd 2.0.10
    * CCcamd 2.0.10 incl. NewCS 1.62
    * CCcamd 2.0.10 incl. MPCS 0.9d
    * dccamd 1.1 incl wdog
    * Evocamd 2.17
    * Evocamd 2.17 incl. NewCS 1.62
    * MGcamd 1.31
    * MGcamd 1.31 incl. NewCS 1.62
    * rqcamd 1.0
    * SCAM 3.42
    * Camd3 3.902
    * incubusCamd 0.50
    Ausserdem noch:
    * enigma2-plugin-scvs-userscripts_1.5
    * enigma2-plugin-extensions-cccaminfo_0.7_all
    * enigma2-plugin-extensions-permanentclock
    * HD Picon by ismail.demir
    * HD Picon 36E
    * enigma2-plugin-skin-nemesis.blackbox
    * enigma2-plugin-skin-nemesis.blueline
    * enigma2-plugin-skin-nemesis.blueline.extended
    * enigma2-plugin-skin-nemesis.blueline.single
    * enigma2-plugin-skin-nemesis.chromeline
    * enigma2-plugin-skin-nemesis.chromeline.cobolt
    * enigma2-plugin-skin-nemesis.flatline
    * enigma2-plugin-skin-nemesis.flatline.blue
    * enigma2-plugin-skin-nemesis.glassline
    * enigma2-plugin-skin-nemesis.greenline
    * enigma2-plugin-skin-nemesis.greenline.extended
    * enigma2-plugin-skin-nemesis.greenline.single
    * enigma2-plugin-skin-nemesis.greyline
    * enigma2-plugin-skin-nemesis.greyline.extended
    * enigma2-plugin-skin-nemesis.greyline.single
    * enigma2-plugin-skin-nemesis.shadowline
    Neu:
    - Treiber/Module = 28.11.2008
    - User Scripts 1.5 THX @ gutemine fur das Bereitstellen. Damit konnen installierte Softcams nun gestoppt, gestartet usw. werden!
    Ich habe das Experimental, also 2.6 aktiv gesetzt bei Enigma, Plugins und Skins und das neue git nun aktiv
    NOTE: build 200811291454: started
    OE Build Configuration:
    BB_VERSION = "1.6.8"
    OE_REVISION = "8fd1127a6c246e5437a478dac8f745fa21ecc30c"
    TARGET_ARCH = "mipsel"
    TARGET_OS = "linux"
    MACHINE = "dm8000"
    DISTRO = "opendreambox"
    DISTRO_VERSION = "1.5.0"
    TARGET_FPU = "soft"
    http://www.satscreen.tv/forum/showthread.php?t=21761
    13 Feb 2007
    Earth
    Post Dreambox 8000 ....
    New official release date from DMM is now next week.
    Quote:
    Original von Jurgen (DMM) 08.12.2008 11:56
    Die Testphase ist noch nicht ganz abgeschlossen.
    So wie es mit Stand von heute aussieht werden die ersten Boxen nächste Woche an verschiedene Händler gehen.
    Quote:
    Original von Jurgen (DMM) 08.12.2008 15:35
    I hope you can also buy in your country next week, but please don't ask me which dealer will have boxes, I am from the technical team.
    13 Feb 2007
    Earth
    13 Feb 2007
    Earth
    Post Re: Dreambox 8000 ....
    PLi® DM8000 Jade2
    The Original Enigma2 PLi® Jade2 suite contains the following images:
    * PLi®-Jade2-DM7025(Plus)
    * PLi®-Jade2-DM800
    * PLi®-Jade2-DM8000
    Use the downloadsection on our website to be sure to download our original PLi® images.
    Direct download...
    Highlights:
    - Tuxtxt 1.108, with teletext caching support
    - Freesat EPG, thx to sousoux
    - DVB-C, Network-ID scanning
    - PiP zapping (note: only 7025 and 8000 supports PiP)
    - Discrete On/Off keys
    Warning:
    - Online update from Jade to Jade2 is not supported, the feed has been renamed from 'jade' to 'jade2'
    (the changes are such that the online update cannot handle them)
    - For editing a Enigma2 (HDTV) channellist, you will need a channeleditor which supports fully the service4 type lamedb file, like for example: DreamBoxEdit 3.0 or Dreamset v2.20
    Enigma2:
    - EliteDVB repository December 23rd 2008
    - PLi® repository December 27th 2008
    Drivers:
    - Bootloader #61 for DM7025(Plus)
    - 20081025 drivers for DM7025(Plus)
    - Bootloader #70 for DM800
    - 20081210 drivers for DM800
    - Bootloader #70 for DM8000
    - 20081209 drivers for DM8000
    Plugins:
    - Latest Henksat settings 25-12-2008
    - AIO Grab version 0.8
    Skins:
    - Converted to latest enigma2
    Mounts:
    - support to mount CF and/or USB from fstab (for picons)
    Languages:
    - Several translations updated
    Support:
    - Online update support (IPKG feed)
    - Global satellites.xml updated December 26th 2008 (DVB-S: FEC = Automatic; DVB-S2: FEC = Normal)
    Known general Enigma2 Issues:
    - USB SD card detection size: (, -1MB free)
    - Automatic mounts of a CF card fails: you can add it via 'fstab' which is located in /etc/
    - First time entering PLugins menu: Mediaplayer : a known hotplug __init__.py problem
    - Slow C-Band Scan in Asia: due to the empty feed transponders
    - Network wizard: DM800 LCD screen is hard to read under several wizard settings
    - Picons don't work on all satellites which contains different bands: due to the orbital position of the various bands (S,C,Ku) (serviceref)
    See our PLi® Wiki for more answers on your questions...
    Many low level changes fixes and updates...
    Detailed info, Wiki, FAQ's, HowTo's, TechNotes and information about this and the previous PLi® releases can be found on the PLi® Website:
    download :
    pli-enigma2-jade2-dm8000-20081227-6048.zip
    http://www.megaupload.com/es/?d=K5J74C99
    13 Feb 2007
    Earth
    Post The Gemini2 Project 4.00 DM8000
    All the files kept here are for expermintal and educational purpose only please read rules
    Note:Viewing Pay Tv without a Valid Subscripion is Illegal!
    Gemini2 v4.0:
    Technical Infos:
    * Engima from: 28.12.2008
    * Busybox 1.0.1
    * Tuxtxt 1.95
    Function Buttons:
    * RED - Record
    Addons:
    Camd:
    Inf***r / OSD:
    * Provider and Satellite will be shown in the Inf***r (depending on the skin).
    * the position of the inf***r can be changed
    * HDTV-Logo in the Inf***r (DM80..)
    Files / Devices:
    EPG:
    Extra:
    * Quickbutton
    New:
    * Freesat EPG eg. for BBC (thx @sousoux)
    * EPG for MHW, Freesat and Private(eg. Premiere) now switchable, Private activated by default (BP->Extra->EPG-Setup).
    * File-Manager (acting all possible formats, regardless of whether images, sound, film material, or playlists, Torrents, scripts, DVDs)
    * neue Aufnahmen kann man sich markieren lassen (BP->Extra->General)
    * manual installation of Addons now via the File-Manager
    Fix + Updates:
    * Jukebox, Dreamnetcast
    * see CVS
    This Images doesn't contain any keys nor softcams.
    Backups or other modified Images are not from us
    and won't be supported!
    download :
    http://www.sendspace.com/file/n1yjet
    13 Feb 2007
    Earth
    Post Nabilosat DM8000 Pure Flash 01JAN09, with ....
    Nabilosat DM8000 Pure Flash 01JAN09, with Barry Allen 4.6.52
    What is the Nabilosat DM8000 Pure Flash ?
    This image is a simple, pure CVS image to install to flash memory. It is reccomended to those who like the multiboot option with Barry Allen. It is light, fast, reliable and, most of all, upated. Therefore, it is the best solution for multiboot purposes.
    What is included in this image ?
    This image is including the latest available edition of Barry Allen: 4.6.52
    Why should I install this image in flash ?
    Because it includes all the latest drivers and kernel modules required to install new images in multiboot. Nabilosat team is about to release version 0.6 of its Black Hole image. If installed to multiboot, the new Black Hole v0.6 requires an updated image in the flash memory. For this reason, Nabilosat team prepared this Pure version for you.
    How do I install Barry Allen with this image ?
    Barry Allen will be automatically installed at the end of the default wizard
    Will I loose the images already installed on my media ?
    No, you will not loose any of your favourite images, already installed to your media. You will reboot and find them again, ready to be used.
    How do I install it to flash ?
    You can install it via WebInterface or via serial. However, it is important that you read the simple instructions reported here under.
    Release Details
    NEW Nabilosat HD JPG logo by MaximoII. Bootlogos by Army
    Barry Allen 4.6.52 included
    TARGET_OS = "linux"
    MACHINE = "dm8000"
    TARGET_FPU = "soft"
    COMPILED DATE = "27 december 2008"
    ENIGMA2_CVS_DATE = "27 december 2008"
    ENIGMA2_VERSION = "2.6 experimental"
    DRIVERS = "09 December 2008"
    SECOND STAGE = "70"
    BARRY_ALLEN_VERSION = "4.6.52"
    Instructions
    1) Flash your DM 8000 with Web Interface or DreamUp and serial cable
    2) Complete the Default Wizard to setup the basic steps
    3) Upon Wizard completion, you will be prompted to press OK to install Barry Allen
    4) Press OK once, and wait for the Wizard to install Barry Allen
    5) When Barry Allen is updated, the Default Wizard will be completed.
    6) Reboot your Dreambox
    Barry Allen will have been updated. You will find your previous images listed, choose your favorite as always.
    Instructions
    HTML Code:
    http://rapidshare.com/files/17876341...sh_01jan09.zip
    13 Feb 2007
    Earth
    Post Nabilosat Enigma2 Black Hole - DM8000 v0.6
    What is new in this version 0.6 ?
    Nabilosat Exclusive: Enigma2 Integrated Sky IT and Sky Uk EPG
    Nabilosat Team is proud to announce a new feature available exclusively through its image Black Hole v0.6. Download Sky It and Sky Uk weekly EPG and have them integrated to Enigma2. Sky IT is available for download from Marco Polo or other channels on the same transponder. Sky Uk is available for download from Hip Hop Radio channels. By MaxZ4. Great job MaxZ4
    EPG DYNAMIC SYSTEM POPUP
    A popup will dynamically provide information about titles and descriptions found and downloaded
    CHANNEL LIST EPG SELECTION AVAILABLE
    Select and download the EPG only for your preferred channels. Exclude unwanted channels, and speed up the download.
    CHANNEL LIST UPDATE OPTION
    Automatically update the channel list after any provider retuning.
    New skin Nabilosat HD Zero by Matrix10
    Matrix10 released a brand new HD skin for this new version of Black Hole. Great job Matrix10
    Bootlogos
    New Bootlogos and New Bootlogo JPG. By ^^MaXiMoII^^
    NOTE
    You can install this image to flash, without any further support.
    You can install this image to multiboot. In this case, you must have the Nabilosat Pure Flash 01JAN09 installed to flash. This is necessary because the flash image must include the second stage #70
    Nabilosat DM 8000 Pure Flash dated 01 January 2009 is available http://www.sat-universe.com/showthre...147#post313147
    Enigma2 CVS date
    27/12/2008
    Drivers date
    09/12/2008
    OSD with Channel Number
    The OSD Info Bar will now display the channel list number.
    OSD with Orbital Position and Satellite Name
    The OSD Extra Info Bar will now display the Satellite name and orbital position
    Web Interface
    Button icons fixed. Now you know what to press on your remote control.
    Grabber
    The Grabber version is the latest available
    Latest Plugins tested and integrated in the image
    autoresolution
    autotimer
    dvdburn
    dvdplayer
    emailclient
    epgrefresh
    fritzcall
    googlemaps
    httpproxy
    lastfm
    ofdb
    passwordchanger
    simplerss
    startuptostandby
    trafficinfo
    unwetterinfo
    vlcplayer
    webcamviewer
    werbezapper
    youtubeplayer
    zaphistorybrowser
    positionersetup
    cutlisteditor
    configurationbackup
    satfinder
    videotune
    mediascanner
    webinterface
    graphmultiepg
    skinselector
    pictureplayer
    mediaplayer
    hotplug
    networkwizard
    NOTE
    Most plugins will be available in MENU>PLUGINS or Nabilo Green Panel. Other plugins will be available in the Extesions Menu ( long press blue button )
    Main Function Keys
    Button 1xOK = Light Info Skin
    Button 2xOK = Extra Info Skin
    Button Blue = Nabilo Blue Panel
    Button Blue-Long-Push = Extensions
    Button Green = Nabilo Green Panel
    Button Green-Long-Push = Subservices
    Button Red = Start Record
    Button Yellow = Time Shift
    Addons
    Dedicated Addons Server
    Download and install additional packages from Nabilosat server
    Infobar/OSD
    Enigma2 Analogic Clock
    Channel Orbital Position
    Signal SNR, BER
    Infobar Picons
    LCD/OLED Picons
    Advanced EMU information
    Nabilo Panels features
    1) Blue Panel
    Setup
    OSD Settings
    Nabilosat E2 EPG Settings
    NEW LCD Settings
    Fast Plugin Settings
    Inadyn Settings
    Swap File Settings
    Hard Disk Setup
    Nabilo Mount Wizard
    OpenVPN Panel
    Samba/Cifs Panel
    NFS Server Panel
    Telnet Panel
    FTP Panel
    Info
    CCcam Info
    Memory Info
    Available Space
    Processes
    Service Info
    Enigma2 Settings
    About
    Save
    Select/Start/Restart EMU
    2) Green Panel
    Shoutbox
    Fast Plugin
    Addons
    Addons Download Manager
    Manual Install Nab packages
    Manual Install IPK packages
    Addons Uninstall Panel
    Nabilosat Statistics
    Scripts
    Many thanks to 2tone, adga, snakie, jchv13 for tests and reports
    Nabilosat Team
    Black33, ^^Corrado^^, Maximo II, greg, snakie, Matrix10, Porto, Nabilo, Army, Piefav, Franzjuve, Willow, fbrassin, Neri73, paribas, astemio, lorenzo64, frimmino, nixus, robyhummy, DeepDiver
    Credits
    E2 Sky Epg loader integration by MaxZ4.
    Matrix10 for the new HD Zero skin.
    ^^MaXiMo^^ and Army for bootlogos.
    Many Thanks to lukkino (VDR-Italia) for opentv source code.
    Backups or other modified Images are not supported!
    WARNING.
    This image includes second stage #70. Therefore, if you install it to multiboot, it will not work with any previous image in flash. If you install it to multiboot, you must install the Nabilosat Pure Flash DM 8000 dated 1st of January 2009.
    download :
    http://www.sendspace.com/file/e0mjr4
    13 Feb 2007
    Earth
    Post Re: Nabilosat Enigma2 Black Hole - DM8000 v0.6
    Nabilosat Enigma2 Black Hole - DM8000 v0.7
    What is new in this version 0.7 ?
    Nabilosat Black Hole v0.7 is highly optimized to offer an HD skin with best performance, speed and reliability.
    EPG Loader
    Updated OpenTV EPG Loader by MaxZ4
    NEW EPG SEARCH FEATUREs
    Open the TV channel selection list and use keys 1,2,3 and 4 to launch the new options
    KEY 1 will launch the EPG Search for titles
    KEY 2 will shortcut the single channel EPG. Move the cursor to select the channel and press 2
    KEY 3 will shortcut Multi EPG.
    KEY 4 will list the last search keywords. Use it to repeat previous or favorite searches.
    NABILO E2 EPG - Enable/Disable Pop Up Window
    A new setting is added to the Nabilo E2 EPG. Set it to NO if you want to hide the EPG download Pop Up window
    NABILO INFO PANEL - HDD Temperature
    A new information is added to the panel. Press the Blue button, then the Yellow button and select HDD temperature to check how hot your hard disk is.
    NEW SKIN
    High resolution skin HD-ONE by Matrix10
    NEW HD BOOT LOGOS
    High resolution bootlogos by MaximoII
    NEW WEB INTERFACE
    This new image includes the latest version of the Enigma2 Web Interface.
    Enigma2 CVS date
    16 January 2009 2.6 experimental
    Drivers date
    05/01/2009
    Second Stage #70
    Plugins Date
    18 January 2009
    Plugins will be available for download from the Addons Panel. Many thanks to our BIG brother franzjuve for packing them
    NOTE
    You can install this image to multiboot. In this case, you must have installed to flash an image with DVB drivers dated 05/01/09
    Images with previous versions of DVB drivers will cause malfunction.
    Main Function Keys
    Addons
    Infobar/OSD
    Signal SNR, BER
    Infobar Picons
    LCD/OLED Picons
    1) Blue Panel
    Setup
    OSD Settings
    LCD Settings
    Inadyn Settings
    Swap File Settings
    Hard Disk Setup
    Nabilo Mount Wizard
    OpenVPN Panel
    Samba/Cifs Panel
    NFS Server Panel
    Telnet Panel
    FTP Panel
    Info
    CCcam Info
    Memory Info
    Available Space
    Processes
    Service Info
    Hard Disk Temp
    Enigma2 Settings
    About
    Save
    2) Green Panel
    Shoutbox
    Fast Plugin
    Addons
    Scripts
    Many thanks to the Beta Testers Team
    Black33, ^^Corrado^^, Maximo II, greg, Matrix10, Porto, Nabilo, Army, Piefav, franzjuve, Willow, fbrassin, Neri73, paribas, astemio, lorenzo64, frimmino, nixus, robyhummy, snakie, DeepDiver
    Credits
    Matrix10 for the new HD One skin.
    ^^MaXiMo^^ for bootlogos.
    WARNING: THIS IMAGE HAVE TO BE INSTALLED IN FLASH.
    Black Hole images supprt to BA is suspended because of recent Barry Allen additions and system controls.
    Black Hole Images are now intended to be installed in flash without Barry Allen.
    IF YOU WANT TO USE THIS IMAGE IN MULTIBOOT YOU NEED TO HAVE IN FLASH AN IMAGE WITH DVB-DRIVERS OF 05.01.2009 OTHERWISE BLACK HOLE IMAGE WILL NOT WORK PROPERLY.
    download :
    http://www.sendspace.com/file/u3shq7
    13 Feb 2007
    Earth
    Post LT - The Fifth Campaign SP5 DM8000
    Hey LT-fans,
    you have been waiting since a long time for an update, and here it is. Today we can present you a lot of changes and some new features with our SP5 for the LT Fifth Campaign image. There is no online-update available so you have to reflash your box.
    LT SVN 2111
    Enigma2 20090128
    Drivers:
    dm7025 20090116
    dm8000 20090126
    dm800 20090126
    Secondstage
    dm7025 61
    dm800 70-r1
    dm8000 70-r1
    New:
    -Added Automount-Editor
    -Added Bootup-Music plugin (bootup will take longer! don't use if you don't like)
    -TextEditor, will be called from the Media-Center - File-Browser
    -Added lock/unlock movie functions to the MoviePlayer
    -Handle locked/unlocked movies in MoviePlayer
    -Added new convert-types to LTServiceToText Converter: Number, NumberName and NumberNameOrbital
    -New configs (Show service number in InfoBar: yes/no)
    -Added new configs (Show service number in LCD / Show orbital position in LCD)
    -Added LTAnalogClock Renderer... not used yet
    -New config for LT ZapHistoryBrowser / InfoBar: Picon size (70x53, 100x60, 100x75)
    Changes:
    -Added Automount-Editor to QuickMenu
    -Handle /etc/auto.hotplug instead of /etc/automount.conf in Link-Manager
    -Don't handle automount.conf any more on bootup
    -Completly rewritten HDD-Info. Doesn't read from fixed device=/dev/ide/host0/bus0/target0/lun0/disc
    -Check zap-history position after changing the zap-history in LT Zap-History-Browser
    -Use new grab v0.8 versions in image
    -Norweigan translation errors corrected, missing lots of %s
    -Removed SleepTimer in Shutdown-Menu since it is now in the CVS-code
    -Fix crash while getting event-infos if there is no event (Channel-Selection)
    -Calculate skin sizes and move windows to the screen-center (needed for HD/SD skins)
    -Added Hutten's new grabbers with his cache stuff
    -Added es translation. Thanks to titovich
    -Added ST3500820AS to hddtemp database
    -Subservice/Recording pixmaps position fix (LT GlassLine.II)
    -FIX zPosition in LT GlassLine.II skins (InfoBar and TimeshiftState). Timeshift state was not visible
    -Removed non more working 'remove all py-files script'
    -LT Stream2Dream v2.6 with new config (mounttype: cifs/samba)
    -FIX: Non working LCD/OLED picons using other skins than the GlassLine.II PiG skin
    -Speedups in reading orbital position in LTPiconHelper and LTServiceToText
    -FIX: non working picons for 28.2E (reading 28.4E from fe-info)
    Changes MC:
    -Show flac, divx and m4a files in MediaList
    -Use new async ePicLoad commands in Webcam-Viewer and Picture-Player
    -Disabled configs: 'Thumbnail listview' for FileBrowser (Picture-Player)
    -Use new CVS getExif function (MC Picture-Player)
    -Use new ePicLoad function and show also embeddedCoverArt if present in MP3-Player
    -Use new ePicLoad function and show also embeddedCoverArt if present in Screen-Saver
    -Use cdtextinfo to show the filelist (Play AudioCD)
    -Added NRK1 and NRK2 to InternetTV. Thanks to Ibanez99
    -Added divxcrawler plugin to StreamPlayer+
    -Check if movie has been already watched in recording-list. We need nice icons for watched/not watched movies... not shown in list at the moment
    -Read movie-tags from meta files instead of /etc/enigma2/movietags
    -Added PIN lock function in Recordings. Will use the same PIN like the Setup-lock.
    -Handle scripts, packages and text-files in MC-FileBrowser (cfg, ipk, log, sh, tar.gz, tar.bz2, txt)
    -Play DVD function (DVD-Player plugin must be installed)
    -Added '9 Israel' to Internet TV. Thx to Michael
    -Added new ScreenSaver: Analog Clock
    -Give the user the posibility to start streaming while caching with OK-button (StreamPlayer and StreamClient)
    -New function in FileBrowser: Mountpoints
    A big thanks to our beta-tester that are doing an amazing job.
    ~Ryu~, AVR-rulez, codejunkie, DerMicha, DJ-Power, dsd1036, Gotcha_GT, Jimdefruit, kosmo, kosy, M@$terBl@$ter, mr_secret, mrvalley, Muaitai, ottar, s_a, shshadm, snakie, t40t40, tunhj1, Zeranovsky
    http://rapidshare.com/files/19168479...m8000.nfi.html
    02 Feb 2007
    Somewhere in Aegean Sea!!
    Default PLi® Jade2 - DM8000 31.01.2009
    31.01.2009
    Highlights:
    Warning:
    'jade' to 'jade2' (the changes are such that the online update cannot handle them)
    Enigma2:
    Drivers:
    Plugins:
    Skins:
    Mounts:
    Languages:
    Support:
    http://www.upload-drive.com/7656/pli...90131-6234_nfi
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default experimental-dm8000_06-02-2009.nfi
    06.02.2009
    http://www.upload-drive.com/7916/exp...0_20090206_nfi
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    13 Feb 2007
    Earth
    Post boxman-image-dm8000-20090206
    OE_REVISION = "<unknown>"
    TARGET_OS = "linux"
    MACHINE = "dm8000"
    TARGET_FPU = "soft"
    Treiber vom 06.02.2009
    SecondStage-Version: 70
    Frontprozessor-Version: 5
    satellites.xml - enigma² by Reinh@rd vom 06.02.2009
    - with Skin Kerni-HD1
    md5 fur das Image: 0655c8fe8f4c5f62397a904f5571c48d
    download :
    http://rapidshare.com/files/19505471...0-20090206.nfi
    13 Feb 2007
    Earth
    Post gemini 2 project ver 4.1 DM 8000
    Gemini2 v4.1
    DM7025 = Enigma from 06.02.2009
    DM800 and DM8000 = Enigma from 07.02.2009
    Most Functions are described in our Wiki.
    Gemini-Wiki
    Function Buttons:
    * 2x BLUE - BP -> Gemini Extras
    * BLUE RED -> File Manager
    * RED - Record
    * Yellow - Timeshift (not for DM8000)
    Extras:
    * Cryptinfos of the Stations. Assign different Camds to Stations/Providers (AutoCam).
    * Manage many Daemons / Server (BP - Services/Daemons)
    * Visual improvements such as HD-Skin, icons or additional adjustments to the station list
    * Manager for formatting, setting up or integration of devices (BP-> Device Manager)
    * additional EPG functions, such as Autosave, Refresh, or connect different EPG formats
    * Own Addons e.g. Dreamnetcast, jukebox, calendar, e-mail or eTorrent to name just a few
    * Quick button (select the function of the green button via the menu)
    * detailed information about your Dreambox (Menu-> information)
    * File Manager, it is possible to handle all formats, regardless of whether images, sound, film material, playlists, Torrents, scripts or DVDs (BP-> File Manager)
    Many other functions, such as "the GP2 Controlr" Rezapp or the many options can in IHAD board or our Wiki to be read.
    New:
    * File-Manager extended (Information, display and favourites). It´s now eaysier to achieve, simply press BLUE-RED
    * In the channel list, the distance between the stations and the actual EPG event can be changed by yourself (BP-> Settings-> General)
    * At Dreamnetcast and the jukebox you can chose the background
    * Menu´s extra/settings seperated. BP has partly new construction (Addons are now at BP-> Settings to find)
    * Discrete OFF(Standby) by shift-0, ON by shift-1, OFF (Deep Standby) by shift-2 (DM8000 not with original Remotecontrol)
    Fix + Update:
    * Formatting the Harddisk
    * Dreamnetcast, Jukebox
    * see CVS
    Known problems:
    * Bootpictures
    * fast changing of tracks in the jukebox when covers from internet is activated
    DOWNLOAD :
    http://rapidshare.de/files/45032058/...4.nfi.zip.html
    02 Feb 2007
    Default experimental-dm8000 11-02-2009
    experimental-dm8000_11-02-2009.nfi
    11.02.2009
    http://www.upload-drive.com/8162/exp...0_20090211_nfi
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
