Results 1 to 12 of 12
Thread: Server Sifteam
    17 Jul 2008
    Bucharest
    Default Server Sifteam
    Stie cineva cand se va remedia problema serverului de la Sifteam? Incerc de 2 zile sa ma conectez la el cu ipbox-ul si nu reusesc.
    Mersi mult!
    Razvan
    IPBOX 9000 HD + offset 1.85 + lnc INVACON
    O zi frumoasa! Snow's Avatar
    Default Re: Server Sifteam
    Nu se stie nimic clar, cel putin o saptamana va fi down
    02 Feb 2007
    Somewhere in Aegean Sea!!
    1-3 decembrie o sa revine server.Asa spune ei....
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    17 Jul 2008
    Bucharest
    A trcut si ziua de 3 dec si mi-e teama ca o sa treaca si cea de 4 si tot nu merge serverul. Ati mai auzit cea nou?
    02 Feb 2007
    Nu am auzit nimic...Si la forum sifteam tot scrie pina la 3 Decembrie.Din ce am inteles muta pe server in alte locatia....Dar nu exista caz sa fie inchis server sau forum....Sunt probleme technice!!!!Stai linistit.
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    27 Nov 2008
    Hi,
    please can you write in english about info on Server Sifteam?
    Previous information talks about a server online between 1 and 3 december...
    But now on the 6 decemeber the server still down...
    Nobody knows the reason?
    Best regards,
    Frank
    Nobody knows nothing,yet.Seems that they are gonna change the server,too.
    Modify:
    /var/etc/SifTeam/tmp/url
    ..replace
    ftp://9000.sifteam.eu/9000HD/
    ..with
    http://dreambox.sifteam.eu/9000HD/9000HD/
    enjoy
    online din nou
    31 Aug 2008
    Cluj-Napoca, Romania
    Este on line forumul, serverul unde se leaga panelul sif inca nu.
    Nu va grabiti sa instalati sif.
    citeste postul 8 e valabil inca
    31 Aug 2008
    regula12
    Credeam ca merge pe direct pe linckul din box, asta mergea oricum.
    Nu stiu daca se actualizeaza in locatia asta...
