Results 1 to 10 of 10
Thread: Enigma2 Plugin: AutoResolution
    RSP Enigma Team EnF70's Avatar
    18 Nov 2008
    Default Enigma2 Plugin: AutoResolution
    [English]
    Description:
    A plugin for automatically changing the video mode according to the format of the selected channel.
    Install:
    1) Copy AutoRes.tgz on Kathy in /tmp
    2) Execute: tar zxvf /tmp/AutoRes.tgz -C /
    3) Invoke "Restart GUI" from Menu
    Config:
    Menu -> Setup -> System -> Autoresolution...
    Contribution:
    I've adapted and tested this plugin for E2 Kathy. (minor changes, just to get it running)
    (I've kept the original plugin as 'plugin.py.orig' for reference)
    Notes:
    1) "iServiceInformation.sProgressive" is not implemented in E2 rev.600 and
    hence there is no difference yet between "576i" and "576p" - only one of them will work
    720p and 1080i are ok as they don't have both "i" and "p".
    2) "576i" cannot be selected as target by default as it's missing from
    /usr/lib/enigma2/python/Plugins/SystemPlugins/Videomode/VideoHardware.py
    You'll need to add this video mode manually if you want to use it:
    For instance (in VideoHardware.py)
    modes["HDMI"] = ["576i", "576p", "720p", "1080i", "1080p"]
    widescreen_modes = set(["576i", "576p", "720p", "1080i", "1080p"])
    You'll see that "576i" is not present in these two lists.
    (Caution: Some TV sets don't support this video mode)
    [Romana]
    Se poate folosi acest plugin pentru schimbarea automata a modului video
    in functie de formatul canalului selectat.
    Instalare:
    1) Se copiaza AutoRes.tgz pe Kathy in /tmp
    2) Se executa: tar zxvf /tmp/AutoRes.tgz -C /
    3) Se da "Restart GUI" din menu
    Configurare:
    Am adaptat si testat acest plugin pentru E2 Kathy.
    Modificari minime, cat sa functioneze bine.
    (am pastrat plugin-ul original sub numele 'plugin.py.orig')
    Note:
    1) "iServiceInformation.sProgressive" nu este implementat in E2 rev.600 si din
    acest motiv nu se poate face deocamdata distinctie intre 576i si 576p.
    720p si 1080i sunt ok - pentru ca nu au si "i" si "p".
    2) Pentru cine doreste "576i" in loc de "576p", acest mod trebuie adaugat in
    De exemplu (in VideoHardware.py)
    O sa vedeti ca "576i" nu apare in lista (Atentie: unele TV-uri nici nu-l suporta).
    AutoRes.zip
    03 Jun 2008
    Default Re: Enigma2 Plugin: AutoResolution
    Super!! Chiar ma intrebam cand o sa para asa ceva?
    Craciun fericit !!
    @EnF70
    Felicitari !!
    Sa iti dau imaginea viitoare sa vezi ce am facut sa iti dai cu parerea la ce ar mai fi de facut.
    27 Dec 2008
    @EnF70
    Thank you!
    Felicitari si sarbatori fericite
    26 Jul 2007
    @EnF70
    E facut de tine?
    Ca pe AAF-board spun ca e polonez si daca e al tau le dau peste nas imediat!
    18 Nov 2008
    Nu, nu e facut de mine.
    Am scris in primul post ca am adaptat doar si testat plugin-ul pentru E2 Kathy.
    In arhiva e un fisier 'maintainer.info' in care scrie cine l-a facut.
    Adresa de e-mail se termina in '.de' dar s-ar putea sa fie si polonez baiatu' de l-a scris.
    M-am uitat pe AAF Board. L-au copiat de aici ca-mi recunosc modificarile
    Poate ar fi o chestie buna sa traduc si-n engleza ce-am scris in primul post.
    26 Jul 2007
    Era bine sa-ti lasi si tu "amprenta" acolo si sa specifici ca e adaptat de tine pt. Kathrein UFS 910 cu E2.
    Intra pe AAF si posteaza pe engleza.
    25 Oct 2007
    Chisinau
    L-am instalat, e prima mea instalare de plughinuri pe Kathrein 910 HD. Merge bine, multumesc.
    03 Jun 2008
    Trebuie mentionat faptul ca functia "deinterlacer mod" e activa numai la 50hz.La 60hz e inactiva.
