Results 1 to 12 of 12
Thread: IPBOX 91 **SIFTEAM firmware**
    02 Feb 2007
    Somewhere in Aegean Sea!!
    Default IPBOX 91 **SIFTEAM firmware**
    Aici o sa gasiti firmware pt ipbox 91HD.
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default Sifteam 0.1.9 r8873 91HD
    Version 0.2.0
    Added default password as "sifteam"
    Added script "advanced.command.sh" ..for:
    Add NFS disk
    Remove NFS disk
    Make USB for use as Disk (in congiuntion with NFS option is very good)
    Move /var in part1 of disk or USB (part1 = first partition)
    Removed any files (script)
    Added script for see proper card permission
    P.S.
    Added other file ..and other basic option ?
    http://dreambox.sifteam.eu/index.php...ate.img.tar.gz
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default SifTeam 0.2.0 r9047 91HD
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    Standard RSP member coburn's Avatar
    02 Apr 2007
    Exista doar un lucru bun, stiinta, si doar unul rau, nestiinta.
    27 Dec 2009
    Thumbs down ipbox 259 hd
    on this image sifteam how ccam possible work yhx
    27 Dec 2009
    Default ipbox 91 250 hd
    sorry is not 259 is 250 hd
    29 Nov 2008
    Cu capu' in nori
    IpBox 91 = CubeRevo 250 , not compatible with cccam, only incubuscam client for cccam.
