Mdah, mi-am raspuns singur pe jumatate.
Problema sub AAF era de la versiunea de camd3.
Am facut update la 3.902 si totul merge brici, dar numai sub AAF, nu si sub Enigma.
Sub enigma cu aceleasi setari primesc asta:
09.02.2009 23:14:53 camd3: BOXTYPE: ufs910
09.02.2009 23:14:53 camd3: LOG: 3
09.02.2009 23:14:53 camd3: UDP_PORT: 20248
09.02.2009 23:14:53 camd3: HTTP_PORT: 9080
09.02.2009 23:14:53 camd3: LOG_FILE: /tmp/camd3.log
09.02.2009 23:14:53 camd3: DNS_CACHE: 60 sec
09.02.2009 23:14:53 camd3: DESCR_DELAY: 0 ms
09.02.2009 23:14:53 camd3: camd3.map not found
09.02.2009 23:14:53 camd3: camd3.ignore not found
09.02.2009 23:14:53 camd3: camd3.servers not found
09.02.2009 23:14:53 camd3: camd3.users not found
09.02.2009 23:14:53 camd3: camd3.keys not found
09.02.2009 23:14:53 camd3: KeyDB: started
09.02.2009 23:14:53 camd3: HTTP: started on port 9080
09.02.2009 23:14:53 camd3: rom120.bin -> No such file or directory
09.02.2009 23:14:55 camd3: slot my.server.ip:47112 -> init...
09.02.2009 23:14:55 camd3: slot my.server.ip:47112 monitor start...
09.02.2009 23:14:55 camd3: slot my.server.ip:47112 -> card in
09.02.2009 23:14:55 camd3: slot my.server.ip:47112 -> CAID 1702
09.02.2009 23:14:57 camd3: camd v3.902 - erfolgreich gestartet
09.02.2009 23:15:25 camd3: failed start ecm pid 1742 caid 1702 ident 000000
09.02.2009 23:15:25 camd3: failed start ecm pid 1c43 caid 1722 ident 000000
09.02.2009 23:15:25 camd3: failed start ecm pid 1a42 caid 1837 ident 000000
09.02.2009 23:15:25 camd3: failed start ecm pid 1842 caid 1833 ident 000000
09.02.2009 23:15:25 camd3: failed start ecm pid 1c42 caid 1834 ident 000000
09.02.2009 23:15:25 camd3: failed start ecm pid 1843 caid 1836 ident 000000
09.02.2009 23:15:25 camd3: failed start ecm pid 1b42 caid 09c4 ident 000000
samd.
