<newCSconfig>
<readers name="SCI">
<device>
<name>Lower Cardreader</name>
<type>sci</type>
<mhz>357</mhz>
<node>/dev/sci0</node>
<parity>odd</parity>
<reset>normal</reset>
<export>Yes</export>
<enabled>Yes</enabled>
<blocksa>No</blocksa>
<blockua>No</blockua>
<blockga>No</blockga>
<!-- <boxkey>0000000000</boxkey> -->
<!-- <rsa>0000000000</rsa> -->
<irdeto-camkey>0000000000000000</irdeto-camkey>
<irdeto-camkey-data>00000000000000000000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000000000000000000000000000000000 0000000000000000000</irdeto-camkey-data>
<crypto-special>No</crypto-special>
<ipk>00000000000000000000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000000000000000000000000000000000 0000000000000000000</ipk>
<ucpk>00000000000000000000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000000000000000000000000000000000 0000000000000000000</ucpk>
<PTShandshake>No</PTShandshake>
<carddetect>yes</carddetect>
<newcamd_port>34000</newcamd_port>
<autosid>Yes</autosid>
<Seca-PPV>no</Seca-PPV>
<pincode>0000</pincode>
<priority>round</priority>
</device>
<device>
<name>Upper Cardreader</name>
<type>sci</type>
<mhz>357</mhz>
<node>/dev/sci1</node>
<newcamd_port>34001</newcamd_port>
</device>
</readers>
<radegastserver>
<enabled>No</enabled>
<port>16000</port>
<allow>
<hostname>localhost</hostname>
</allow>
</radegastserver>
<cache>
<emm>20</emm>
<ecm>-1</ecm>
</cache>
<debug>
<password>NewCSpwd</password>
<level>normal</level>
<type>init</type>
<output>console,tcp</output>
<console_options>normal,init</console_options>
<tcp_port>1001</tcp_port>
<tcp_options>normal,init</tcp_options>
</debug>
<newcamdserver>
<name>newcs</name>
<deskey>01 02 03 04 05 06 07 08 09 10 11 12 13 14</deskey>
<user>
<name>user1</name>
<password>user1</password>
<port>34000</port>
<au>on</au>
<sidoverride>off</sidoverride>
<spider>No</spider>
<allow>lower</allow>
<rate>2</rate>
</user>
<user>
<name>user2</name>
<password>user2</password>
<port>34001</port>
<au>on</au>
<spider>No</spider>
<allow>Upper</allow>
<rate>2</rate>
</user>
<user>
<name>peer1</name>
<password>peer1</password>
<port>34000</port>
<au>on</au>
<spider>No</spider>
<rate>2</rate>
</user>
<user>
<name>peer2</name>
<password>peer2</password>
<port>34001</port>
<au>on</au>
<spider>No</spider>
<rate>2</rate>
</user>
</newcamdserver>
</newCSconfig>
