Likes Likes:  2
Results 1 to 10 of 10
Thread: SifTeam 1.9.4 Ipbox 200
    O zi frumoasa! Snow's Avatar
    Default SifTeam 1.9.4 Ipbox 200
    Changes:
    1) CVS updated to 26.07.2009
    2) Now you are able to see info about packs,enable the function trought advanced panel
    3) Now you can see the latest packs and updates available on our panel
    4) Changed webif and boot images
    5) Some changes on code
    6) UPNP is available (SERVER/CLIENT)
    7) Moved vsftpd.conf in /var/etc/
    8) New flashes of qbox one are now ok
    9) Qbox manager updated(some fixes on dtt)
    10) Two new skins by nikolasi sifteam_red e sifteam_blu (thx)
    11) Added Black_Matrix gold by MX mod_RG (thanks matrix) modded by rroatan
    12) Added skin Army omega black (thanks army)
    13) Added all_languages for sifteam 1.9.4
    14) Added and fixed Multiview pack
    Note:
    For the version ipbox-200@64mb you must:
    1)install the normal img for ipbox200
    2)install "serial_uboot_64.img"
    both with flashtools or Flasher
    * About Programs:
    For all sifteam images, on /var/etc/rcS.d/S99user_start.sh you can choose a program to start(there are already some commented examples..remove "#" to active them)
    Tips
    To enter in Control Panel from Emu panel you can press the yellow button (added also on webif)
    The menu Script can be opened from Control panel pressing 0(zero)
    To change the positions of Channel name or Clock you can modified by telnet the values
    (Horizontal)(50 & 80 are the default values)
    echo 50 > /var/etc/SifTeam/conf/altOraOSD
    echo 80 > /var/etc/SifTeam/conf/altCanaleOSD
    (Vertical)(10 is the default value)
    echo 10 > /var/etc/SifTeam/conf/oriOraOSD
    echo 10 > /var/etc/SifTeam/conf/oriCanaleOSD
    Errors:
    If the following message appear "..curl_global_init.."...please restart enigma(Menu-5-restart enigma)
    * The option Move OSD is no longer available but you can install it as external plugin
    To use the old /Var you should edit the file /var/tuxbox/config/enigma/config
    and change the text "s:/ezap/ui/skin=/share/tuxbox/enigma/skins/golden.esml" in
    "s:/ezap/ui/skin=/share/tuxbox/enigma/skins/bluzzy3_adv.esml"
    ** The Q-box has not all the functions of the other boxes...for example to open the Control Panel you must press blue>yellow
    Enjoy Sif-team fans
    user root
    password sifteam
    DOWNLOAD
    95 Post(s)
    Cum fac sa imi apara emu la download pe imaginile Sif Team la Ipbox 200?
    Am vazut tarziu dar poate e util pentru altii:
    easysurf.ro_url2.zip - 1.3 Kb
    Copy this file (url2) into directory /var/etc/SifTeam/tmp
    delete url2_new
    Attached Files Attached Files
    20 Sep 2007
    Dupa aproape 4 ani de pauza pe acest topic, vin cu o problema.
    Am incarcat aceasta imagine apoi m-a pus naiba sa incarc si 'serial_uboot_64.img'. Acum imi apare mesajul 8888 pe display si nu se mai intampla nimic. Sa inteleg ca singura solutie ramane JTAG-ul ? Am gasit un material pe net pentru receptoare Relook, dar inteleg ca practic e tot ipbox. Oare merita sa ma chinui ?
    Multumesc pentru orice parere !
    08 Oct 2010
    Eu zic ca merita. Mai ales daca faci pentru tine! Prima data vezi daca o mai gasesti materialele necesare (de pe internet), deci: bootloader, jtag sw, .img, etc . Daca le ai ,sa faci rost de cablul respectiv si de calc. cu mufa respectiva. Dupa acea mai poti intreba aici sau in sectiunea de jtag (dac ai nelamuriri) Iar daca n-ai timp deloc, si ai bani sa iei un alt rec. nou, atunci donezal la careva, poate o sa-l foloseasca cu suckces (dupa ce le repara).
    20 Sep 2007
    Pentru mine vreau sa-l fac. Am gasit ca printr-o minune softurile si anume:
    1. jtag_ver1.3, care contine jtag. exe, WINIO.VXD, WinIo.dll si WinIo.sys
    2. porttalk22 care contine AllowIo.exe, porttalk.reg, porttalk.sys, PortTalk_IOCTL.h.
    Am dat cuiva schema sa-mi faca acel cablu si sa vedem daca reusesc operatiunea. Mersi de incurajare.
    08 Oct 2010
    Ai reusit sa faci ceva ? S-au mai dureaza? Suckcess!
    20 Sep 2007
    Astept cablul. O sa postez rezultatul, bun sau rau.
    20 Sep 2007
    Dupa lupte seculare am reusit. Atasez un printscreen. Am repetat operatiunea pe un calculator mai nou, pentru ca pe al meu dadea rateu.
