Results 1 to 15 of 20
Thread: Smargo Smartreader Plus -> Oscam -> RSP
    12 Aug 2009
    Default Smargo Smartreader Plus -> Oscam -> RSP
    Could anyone confirm the settings for using a Smartgo Smartreader plus for use with Oscam on RSP image.
    95 Post(s)
    http://sateliti.info/showthread.php?t=15878
    FTDI driver is included in latest images.
    12 Aug 2009
    Thanks Zildan, i'm using RSP V3.128, Smartreader version 1.3
    Now getting the following
    >> OSCam <<  cardserver started at Mon Sep  6 11:46:02 2010
    2010/09/06 11:46:02    783 s   version=0.99.4svn, build #2974, system=sh4-amino-linux, nice=-10
    2010/09/06 11:46:02    783 s   max. clients=29, client max. idle=120 sec
    2010/09/06 11:46:02    783 s   max. logsize=500 Kb
    2010/09/06 11:46:02    783 s   client timeout=5000 ms, fallback timeout=2000 ms, cache delay=120 ms
    2010/09/06 11:46:02    783 s   shared memory initialized (size=497258, fd=3)
    2010/09/06 11:46:02    783 s   auth size=4772
    2010/09/06 11:46:02    783 s   services reloaded: 0 services freed, 1 services loaded
    2010/09/06 11:46:02    783 s   userdb reloaded: 0 accounts freed, 1 accounts loaded, 0 expired, 0 disabled
    2010/09/06 11:46:02    783 s   signal handling initialized (type=sysv)
    2010/09/06 11:46:02    783 s   can't open file "/var/keys/oscam.srvid" (err=2), no service-id's loaded
    2010/09/06 11:46:02    783 s   can't open file "/var/keys/oscam.tiers" (err=2), no tier-id's loaded
    2010/09/06 11:46:02    783 s   can't open file "/var/keys/oscam.provid" (err=2), no provids's loaded
    2010/09/06 11:46:02    783 s   monitor: disabled
    2010/09/06 11:46:02    783 s   camd 3.3x: disabled
    2010/09/06 11:46:02    783 s   camd 3.5x: disabled
    2010/09/06 11:46:02    783 s   cs378x: disabled
    2010/09/06 11:46:02    783 s   newcamd: disabled
    2010/09/06 11:46:02    783 s   cccam: disabled
    2010/09/06 11:46:02    783 s   radegast: disabled
    2010/09/06 11:46:02    783 s   logger started (pid=784)
    2010/09/06 11:46:02    783 s   Resolver thread started
    2010/09/06 11:46:02    783 s   http started (pid=786)
    2010/09/06 11:46:02    783 s   reader started (pid=787, device=001:005, detect=cd, mhz=357, cardmhz=357)
    2010/09/06 11:46:02    783 s   waiting for local card init
    2010/09/06 11:46:02    786 h   HTTP Server listening on port 84
    2010/09/06 11:46:02    787 r02 Found smartreader device 001:005
    2010/09/06 11:46:02    787 r02 card detected
    2010/09/06 11:46:06    787 r02 ATR: 3F FD 13 25 02 50 00 0F 33 B0 0F 69 FF 4A 50 D0 00 00 53 59 02
    2010/09/06 11:46:06    787 r02 Maximum frequency for this card is formally 5 Mhz, clocking it to 4.80 Mhz
    2010/09/06 11:46:07    787 r02 [videoguard2-reader] type: VideoGuard BSkyB (0963)
    2010/09/06 11:46:07    787 r02 card system not supported
    2010/09/06 11:46:07    787 r02 Normal mode failed, reverting to Deprecated Mode
    2010/09/06 11:46:10    787 r02 ATR: 3F FD 13 25 02 50 00 0F 33 B0 0F 69 FF 4A 50 D0 00 00 53 59 02
    2010/09/06 11:46:11    787 r02 Maximum frequency for this card is formally 5 Mhz, clocking it to 4.80 Mhz
    2010/09/06 11:46:12    787 r02 [videoguard2-reader] type: VideoGuard BSkyB (0963)
    2010/09/06 11:46:13    787 r02 card system not supported
    2010/09/06 11:46:13    787 r02 card initializing error
    2010/09/06 11:46:13    783 s   init for all local cards done
    2010/09/06 11:46:13    783 s   anti cascading disabled
    2010/09/06 11:46:13    783 s   dvbapi: initialized (pid=789)
    2010/09/06 11:46:13    789 c01 plain dvbapi-client 127.0.0.1 granted (kathy, au=0)
    2010/09/06 11:46:15    789 c01 dvbapi: [ADD PID 0] CAID: 0960 ECM_PID: 0508 PROVID: 000000
    2010/09/06 11:46:15    789 c01 dvbapi: [ADD PID 1] CAID: 0961 ECM_PID: 0508 PROVID: 000000
    2010/09/06 11:46:15    789 c01 dvbapi: [ADD PID 2] CAID: 0963 ECM_PID: 0508 PROVID: 000000
    2010/09/06 11:46:15    789 c01 dvbapi: new program number: C7A9 (0960:C7A9 unknown)
    2010/09/06 11:46:15    789 c01 kathy (0963&000000/C7A9/75:B631): rejected group (129 ms) ()
    2010/09/06 11:46:15    789 c01 kathy (0960&000000/C7A9/75:B631): rejected group (129 ms) ()
    2010/09/06 11:46:15    789 c01 kathy (0961&000000/C7A9/75:B631): rejected group (129 ms) ()
    2010/09/06 11:46:15    789 c01 dvbapi: try pids again #1
    2010/09/06 11:46:18    789 c01 kathy (0963&000000/C7A9/75:A1D0): rejected group (129 ms) ()
    2010/09/06 11:46:18    789 c01 kathy (0960&000000/C7A9/75:A1D0): rejected group (129 ms) ()
    My oscam.server is
    [reader]
    reconnecttimeout = 5
    label      = remote
    protocol   = cccam
    device     = 192.168.0.9,12000
    account    = kathy,password
    group      = 1
    caid       = 0963
    cccversion = 2.1.4
    enable = 0
    #cccbuild   = 3191
    [reader]
    label    = mysmartreader
    protocol = smartreader
    device   = 001:005
    aeskey   = 0102030405060708090a0b0c0d0e0f10
    group    = 1
    caid     = 0963
    boxid = ####### (my boxkey from cccam here)
    #mhz = 357
    #Cardmhz = 368
    EMMCache = 1,3,2
    blockemm-u = 0
    blockemm-s = 0
    blockemm-g = 1
    blockemm-unknown = 0
    #detect = CD
    enable = 1
    I already had it working connected to a cccam server on another local receiver, just want to get it working locally as well
    After restarting the log now has a lot of these entries:-
    r02 usb bulk write failed : ret = -1
    95 Post(s)
    Try tu use list_smargo-sh4-amino .
    Full oscam pack.
    12 Aug 2009
    Output from list_smargo
    ./list_smargo-sh4-amino
    bus 001, device 004 : 0403:6001 Smartreader (Device=001:004 Serial=?)
    In my oscam.server above it was 5, because i'd unplugged it and put it back, got device using :-
    cat /proc/bus/usb/devices
    Do i need insmod $MODDIR/ftdi.ko in start.sh, currently
    mknod /dev/ttyUSB0 c 188 0
    chmod 666 /dev/ttyUSB0
    insmod $MODDIR/usbserial.ko
    insmod $MODDIR/pl2303.ko
    12 Aug 2009
    For some reason my start.sh is not being processed, if i try
    . /var/config/start.sh
    i get the following error:-
    Kathy_RSP:/var/config# . /var/config/start.sh
    -sh: .: line 1: can't open /var/config/symlink
    The file is there it contains
    SYMLINK="/usr/lib/enigma2/python/Plugins/Extensions/Fantastic"
    Whilst looking at the file, i think it only loads usbserial if newcs is used, dont know enough about linux to tell properly.
    12 Aug 2009
    Zildan, will there be a new RSP Image released soon, as my start.sh is messed up so i will need to re-install
    01 Nov 2008
    Am Smargo setat pentru tvr conectat la un port usb in spatele receptorului cu RSP 3.128 cu oscam care functioneaza ca si client dar nu deschide tvr hd de pe card
    [reader]
    label = ReaderExtern
    #enable = 1
    protocol = mouse
    device = /dev/ttyUSB0
    #ecmcache = 1
    emmcache = 1,3,2
    detect = CD
    #showcls = 20
    #maxqlen = 128
    Group = 2
    services = tvrhd
    mhz = 357
    caid = 0500
    ident = 0500:025900,025910,00000,fff720
    #lb_weight = 200
    2010/09/12 11:56:08 489 r05 ERROR opening device /dev/ttyUSB0
    2010/09/12 11:56:08 489 r05 Cannot open device: /dev/ttyUSB0
    Default /dev
    vezi in /dev poate nu-l vede sau il vede altfel decit /dev/ttyUSB0
    Si de ce " #enable = 1" ?
    01 Nov 2008
    in /dev nu am ttyUSB0 doar ttyAS0..1,2,3,4
    Pai atunci daca nu-l vede....
    Nu am priceput ce receptor ai, poate iti trebuie drivere...
    01 Nov 2008
    Kathrein cu imagine RSP 3.128 care are drivere
    95 Post(s)
    @dorin55
    Panelul era "croit" sa puna driverele doar daca ai newcs instalat.
    Descarca din installer Newcs si da un restart.
    Lucrez la imagine si o sa refac si partea asta.
    01 Nov 2008
    multumesc,am acum in /dev , ttyUSB0 ,deci vede smargo dar oscam tot nu citeste cardul,
    Last edited by zmeura; 12-09-10 at 15:59. Reason: Quote inutil.Foloseste butonul New Post!
    27 Dec 2008
    Salutare,
    Mi-am luat un smargo plus dar nu reusesc sa-l configurez pe oscam pe rsp imagine in kathrein910 .Am card de tvr.
    Cineva care sa ma ajute?
