Thanks Thanks:  27
Likes Likes:  27
Page 4 of 6 FirstFirst 123456 LastLast
Results 46 to 60 of 83
Thread: Oscam - setari deosebite
  1. #46
    Aes-ul de tntsat nu e functional.
  2. #47
    07 Sep 2013
    https://t.me/blackhatshiller
    setarile respective(TNTsat) erau pe
    DOSCAM V0.17
  3. #48
    Mda, poate stie ala sa deschida. In oscam arata la fel, zice ca deschide, ecm ok dar ... ecran negru.
    O sa probez si eu un doscam, se pare ca ala deschide.
  4. #49
    07 Sep 2013
    Default diferite caid in oscam!
    [reader]
    label                         = hd01-weiss_oben
    enable                        = 0
    protocol                      = internal
    device                        = /dev/sci1
    key                           = 0102030405060708091011121314
    caid                          = 1830
    fix9993                       = 0
    rsakey              = BF358B5461863130686FC933FB541FFCED682F3680F09DBC1A23829FB3B2F766B9DD1BF3B3ECC9AD6661B753DCC3A9624156F9EB64E8168EF09E4D9C5CCA4DD5
    boxkey                        = A7642F57BC96D37C
    detect                        = cd
    mhz                           = 368
    cardmhz                       = 368
    group                         = 2
    emmcache                      = 1,3,2
    lb_weight                     = 100
    [reader]
    label = hdplus
    protocol = internal
    detect = CD
    device = /dev/sci1
    group = 2
    emmcache = 1,3,2
    caid = 1830
    n3_rsakey = BF358B5461863130686FC933FB541FFCED682F3680F09DBC1A23829FB3B2F766B9DD1BF3B3ECC9AD6661B753DCC3A9624156F9EB64E8168EF09E4D9C5CCA4DD5
    n3_boxkey = A7642F57BC96D37C
    poate e careva interesat si de 1830
    bulgari
    [reader]
    label                         = bulsat-bulcrypt
    protocol                      = internal
    device                        = /dev/sci0
    caid                          = 5581,4AEE
    force_irdeto                  = 1
    ecmwhitelist                  = 5581:4F;4AEE:4F
    detect                        = cd
    mhz                           = 500
    group                         = 1
    emmcache                      = 1,3,-1
    nc+
    [reader]
    label                         = p2c
    enable                        = 1
    protocol                      = internal
    device                        = /dev/sci0
    services                      =
    caid                          =
    rsakey                = 849D312EB63A0A68919EC75CFF6699180CB0B191B0CE4A6CE42BDD4E716432A0C2C76E08F3434D81F64410FABB8DD0D89276D0C74559B3E35591850D17494A55
    boxkey                    = 6C0670E7019573B5
    detect                        = cd
    mhz                           = 500
    cardmhz                       = 368
    ident                         =
    group                         = 1
    blockemm-unknown              = 1
    blockemm-u                    = 1
    blockemm-s                    = 1
    blockemm-g                    = 1
    lb_weight                     = 100
    polsat
    [reader]
    label                         = dream
    description                   = polsat,
    protocol                      = internal
    device                        = /dev/sci0
    caid                          = 1801,1803,1803:1801
    rsakey               = 840BE0747533632AE4CA2F24CE8126C5A21977A8897AE6A0DA4AF4A00621ECE98C699E659564FD4A893E8C8EEF11FDA62C2E0186517ECF0F5FF295400DC689E7
    boxkey                        = 2763A5A1E88DB31A
    detect                        = cd
    mhz                           = 368
    cardmhz                       = 368
    group                         = 1
    emmcache                      = 1,3,2
    lb_weight                     = 500
    dropbadcws                    = 1
    audisabled                    = 1
    auprovid                      = 001803
  5. #50
    07 Sep 2013
    Default 1860
    [reader]
    label                        = hdplus_schwarz_hd03_>Slot_oben<
    protocol                      = internal
    device                        = /dev/sci0
    caid                          = 1860
    rsakey                        = 901E595152E67DFD5B134E1D195C4141B3BB1394A8AF4D6BF1D1085DCC4D9CBA5C73A06ED21FC3556B685498030BB1185766117565E39995EFBF72135C2817B7
    detect                        = cd
    mhz                          = 368
    cardmhz                      = 368
    group                        = 1
    emmcache                      = 1,1,2
    [reader]
    label                        = hdplus_schwarz_hd03_>Slot_unten<
    protocol                      = internal
    device                        = /dev/sci1
    caid                          = 1860
    detect                        = cd
    mhz                          = 368
    cardmhz                      = 368
    group                        = 2
    emmcache                      = 1,1,2
  6. #51
    07 Sep 2013
    Default ...
    PHP Code:
    [reader]
    #Power = DTR
    #PTS = 1
    Label          Tauta
    Protocol
    internal
    Device
    = /dev/sci0
    boxid
    aaaaaa
    Fallback
    Group
    1
    CAID
    093e
    #IDENT          = 093e:000000
    EMMCache      1,1,2
    #CLASS         = 06 60 07 08 3C  ???
    [reader]
    label ZON
    Protocol
    internal
    detect
    CD
    device
    = /dev/sci0
    group
    1
    emmcache
    1,3,2
    rsakey
    aaa
    boxkey
    aaa
    mhz
    368
    cardmhz
    368
    [reader]
    label TVCABO
    Protocol
    internal
    detect
    CD
    device
    = /dev/sci0
    Group
    1
    EMMCache
    1,3,2
    CAID
    1802
    ident
    1802:004801,004901,000000
  7. #52
    95 Post(s)
    Cei care au locale de YT pot incerca asta:
    For who have 09CD cards.
    On oscam.server add this:
    caid = 093B:09CD
    or
    caid = 0919:09CD
    This remaps CAID 09cd to 093b or 0919 and should decrypt SD channels.
    Pare poveste !
  8. #53
    95 Post(s)
    Evident nu s-a confirmat !
  9. #54
    85 Post(s)
    Aici vad ca ticketul e inchis si problema rezolvata...se pare ca functioneaza.
    95 Post(s)
    Citeste mai atent !
  11. #56
    13 Feb 2008
    FAKE
    It is not possible to map Caid 09CD to 0919,093B becouse the Servid, PID are diffrent between this Caids
    So please dont kill your Cards whit Avviso 08
    Problem is that Sky has introduced some new INS for initialisation of the card and whitout this the Payload for SD Channels will be wrong or empty
    greetings
    Luca1234
  12. #57
    19 Apr 2014
    Cineva ma poate ajuta si pe mine cu setarile cele mai indicate pentru FREESAT ? Am incercat pana acum din 2 locuri niste teste si sincer se blocheaza foarte foarte des. As vrea sa fiu sigur ca nu e din cauza setarilor din decodorul meu . Momentan folosesc Oscam-9705/cccam213. Daca gresesc cu aceasta intrebare in acest topic imi cer scuze sunt incepator in domeniu si ...
  13. #58
    20 Mar 2009
    Iasi
    http://sateliti.info/showthread.php/...eesat-in-oscam
    Greu, nu? Sigur e din cauza setarilor tale. Apropo, ce card e? Si ar fi si mai simplu daca ai posta configul si logul, sa ne dam seama ce nu e bine. Unde conteaza si un spatiu vrei sa ghicim ce ai tu acolo?
    HH/1m
  14. #59
    15 Feb 2007
    O întrebare, unde trebuie setat in oscam pentru ignore card, per exemplu un card de SKY DE de la un user. Mulţumesc.
  15. #60
    Faci un service cu caid si ce siduri vrei, apoi ii pui bifa la ce reader sau user doresti la not services in webif
