Results 1 to 7 of 7
Thread: ASTRA 2 Connect - satellite internet
    01 Sep 2010
    Andromeda
    Default ASTRA 2 Connect - satellite internet
    In Polonia deja se poate asa ceva. Mai jos va prezint exact cum stau lucrurile. Eu consider ca in maxim 10 ani internetul ne va intra in case si prin satelit fara nicio problema. Stau si ma intreb daca in Romania se comercializeaza asa ceva, daca exista un magazin care sa vanda asa ceva.
    ASTRA2Connect satellite Internet service is high quality, guaranteeing a fixed broadband Internet access anywhere in Polish via two-way satellite link.
    If you live in a region where there is no access to broadband Internet, you can use it today with fast access technology via satellite ASTRA.
    ASTRA 2 Connect are :
    - Quick access to the Internet
    - VoIP phone
    - Satellite TV, IPTV
    A single antenna provides access to the internet, VOIP telephony and reception of digital television and radio programs. It's all in the subscription fee.
    Download 4Mbit / s
    ASTRA2Connect is a two-way satellite Internet access. Because the data is sent and received via satellite, you do not need any connection with terrestrial telecommunications networks. The service allows download speed up to 4 Mbit / s and send data up to 256 kbit / s.
    Ease of Installation
    Installation of equipment at home is so simple that you can do it yourself.
    See the video> Installation ASTRA2Connect
    Two-way Internet is our advantage
    • Two-way communication (downlink / uplink) ASTRA2Connect - the return channel via satellite
    • Collection of data to the terminal at a speed of between 256 kbit / s - 2048 kbit / s (downstream)
    • Sending data from the terminal between 64 kbit / s - 128 kbit / s (upstream)
    • Position satellites: 23.5 ° E
    • Independence from existing terrestrial telephone lines, GSM, etc.
    • Immediate availability in Europe
    Pret : 1 599,00 zł gross
    In euro : 362
    Sursa :
    Sprzet
    15 Feb 2007
    O sa fie si pe satelit asa cum zici tu, dar tot pe fibra o sa ne permitem, cred ca pe satelit este piperat, chiar iute...
    24 Sep 2008
    Suceava
    De ceva vreme, exista si la noi ceva de genul: http://www.toowaysat.ro/! Problema este ca nu merita din cauza preturilor si a traficului limitat!
    RSP - Team dan2000's Avatar
    28 Feb 2007
    roma
    daca mai pui si pingul de cca 2 secunde...
    31 Mar 2007
    Cu noua oferta, preturile si conditiile de abonare au devenit mai prietenoase.
    Detalii : http://toowaysat.ro/index.php?page=new_order_form
    PS Latenta ( ping-ul) este maxim 800 ms.
    06 Jul 2016
    de unde secumpara acest aparat,?vreau o adresa
    95 Post(s)
    Din link-ul de la postul precedent cumperi.
