5
5
Dislikes:
- 127
Open Source Image 3.0 ----------------Update 13/12/2015
http://code.vuplus.com/download/boxi...181708_usb.zip
The new RUDREAM VU + SOLO 4K support- Live X (beta)
Saturday, December 12, 2015
❖Now ruDREAM Live X supports a new VU+ SOLO4K model, test firmware can be downloaded from the beta firmware section (firmware has not been tested yet, and offer as it is),
https://yadi.sk/d/OaAMikxGf6yhG
- 127
OpenViX 3.2 Release Image for Vu+Solo4K
- 127
VU+rudream-4-------Vu+Solo4K-----16.12.2015
- 127
OpenNFR 5.1 VU+ Solo 4K Image
- 127
Open Source Image 3.0 ----------------Update 23/12/2015
http://code.vuplus.com/download/boxi...=30&m=vusolo4k
- 127
A little Gift from the Black Hole Team this Christmas
We have a small Christmas present for our users. We have been working to get live tv working on XBMC, this isn't a release ready feature just yet, but it is ready as a preview.
If you would like to test this feature, you need to have the latest Black Hole 3.0.1 (and have done all the online updates) then in telnet enter the following commands:
opkg update
opkg install xbmc-pvr-vuplus
Then restart E2.
Next launch XBMC, go to settings, enable pvr, enable vuplus addon and then configure it by setting zap before tune.
If you have set a password in OpenWebif remember to set it in the addon as well.
Current Known issues:
- Livetv takes time to enable after XBMC is started due to downloading channels from the backend and sync with XBMC
- XBMC settings may be lost if your box crashes
- It is not yet possible to switch channels when watching livetv (you must exit the channel and go back to channel list).
It is not perfect, as we said it's just a preview for the moment, we hope to fix the bugs soon, but for now it is not a priority so please just be patient and when we have the bugs fixed it will be included in the release images.
Obviously this little Christmas present is only for the XBMC enabled boxes (SoloSE, Solo2, Duo2 and Solo4K).
http://speedy.sh/2M3RC/xbmc-pvr-addo...3-vusolo4k.ipk
Merry Christmas from the Black Hole Team.
- 127
OpenSPA 5.0.003 for VU+ Solo 4K NEW UPDATE 2015-12-30
- OpenEmbedded OE-A 3.2
- Enigma2 28-12-15
- GCC 4.9.2
- GStreamer 1.6.x (Except Wetek/GigaBlue/ZGemma/GI ET-7000 MINI GStreamer 0.10)
- WeTek Play : Kernel 3.10.93 and Drivers 07-12-15
- Vuplus: Updated HbbTV to 20151213
- Formuler F1: Added Kodi 15.2 ready to install
- New Confluence skin: based in xbmc/kodi confluence skin by Jezz_X, Team Kodi
- DeviceManager: Added SD cards support
- Fixes full HD skins support
- Info Panel : Fixed problem with SWAP (now it's shown)
- DeviceManager: Fix to create and format devices partitions
- Fixes MyTube : now you can play VEVO videos.
- Translate improvements.
- Other minor fixes
Confluence skin is only installed in receivers with more than one core because it is a bit heavy and can produce lag. In receivers with one core, Basic retro skin is being installed, but Confluence skin can be installed optionally.
Password FTP/Telnet : openspa
http://openspa.info/resources/opensp...d?version=1681
- 127
VU+rudream-5-------Vu+Solo4K-----31.12.2015
rudream-5
OE_5_Live_X_BETA
We present a new version of the Live X firmware! Now in Beta status!
This firmware build from scratch and based on the new OpenEmbedded version, which included the upgrade to newer versions of more than 300 packages and libraries. The main changes obtained in the firmware:
❖Upgrading more than 300 packages and libraries.
❖Updated DVBMediaSink library which docks enigma2 with GStreamer 1.6.2 multimedia framework (thanks christophecvr) and updated version of a media framework GStreamer to 1.6.2.
❖From firmware by default removed all SMB, ATF, and NFS protocols clients / servers. To use them, you need to install the appropriate packages using the "Packages and extensions manager".
❖Updated version of the Samba Server to 4.1. This is a new package that file is able to serve all supported by Microsoft Windows-version clients, including Windows 8. The new Samba Server 4.1 now supports protocols SMB3, SMB2, SMB2.1, SMB and CIFS. This package no longer includes a built-in utility mount.cifs to mount network drives, for this purpose, added a new separate package cifs-utilites, using bibiloteki package Samba Server, and firmware plugin Networkbrowser, but for user configuration and connection management of network resources It remained unchanged!
ATTENTION!
Unfortunately, these packages take up considerable disk space (~ 7 Mb), which requires careful consideration when installing them, especially in boxes with limited internal memory.
❖Removed packages CDFs, as it is no longer required (GStreamer), and adding native support in enigma2.
❖To avoid confusion, which option to use the user-agent header, and that would allow you to set different user agent header for each service, it is now permitted to install it only in reference to the way the line, details can be found on the forum OpenPLi ®.
❖Fixed ON/OFF bug of transmission service using the setup menu of the Transmission plugin.
❖Fixed bug leading to crashes during loading VU + SOLO4K .
❖Other changes and additions to enhance stability and performance.
ATTENTION!
To install the update, you must make a backup of the firmware and save the settings, and then install the firmware from scratch. After installing the firmware, restore settings without packages restore, that will have to be installed then using the "Packages and extensions manager " If after the recovery options you have crash of enigma2 GUI, do not use the restore settings option. All firmware for testing can be found here.
NOTICE!
ExtInfoBar plugin does not work on the current firmware, do not install or use this plugin, until it will be adapted!
release 31.12.2015
https://yadi.sk/d/I4i6yYG4mKfWF
- 127
VU+rudream-5-------Vu+Solo4K-----09.01.2016
- 127
- 127
- 127
VU+rudream-5-------Vu+Solo4K-----17.01.2016
- 127
Open Source Image 3.0 ----------------Update 20/01/2016
http://code.vuplus.com/download/boxi...165005_usb.zip
VTi "Vu+ Team Image Solo 4K" - V 9.0.2
19.01.2016 - Urgent Information
Please check tuner configuration when tuners are in loop through mode.
It is not allowed to loop through a tuner multiple times
19.01.2016 - Software Update VTi 9.0.2
- increase image version: VTi 9.0.2
- update drivers (2016-01-19) (solo4k)
support Chromium OS
fix DiSEqC problem
improve power consumption
fix misc.
- add Chromium OS to image (including YouTube TV) (solo4k)
- update dvbapp2 (2016-01-17)
keep compatibility for extra headers in stream urls
MovieList: improve handling when leaving movie
MovieList: add option to hide entries
when start dir is set to all or new movies
Timeshift: add separate menu: Menu>VTi>Setup - Timeshift
Timeshift: map button STOP to live TV (timeshift recording is still in progress)
Timeshift: map button STOP LONG to stop timeshift
Timeshift: add function to transform timeshift to regular recording (Please note: short outage in TS file at transforming timestamp)
Common: add global option for dvbapp2 debug output
Menu>VTi>Setup - System
Common: support EPG and picons for 4097 services (e.g IP>TV)
Common: support recording of 4097 services (e.g IP>TV) -> THX @betacentauri
Common: fix handling of http timeout at streams
Common: fix button EXIT when infobar animation is enabled
EPG: add option to blacklist services for DVB EPG (EIT) updates
EPG: support for adding extra data to EPG events
- add plugin epgshare THX @einfall (ver. 0.01 20160117)
- add plugin tinyfoscamviewer (ver. 1.0)
- readd plugin mediatombplugin (ver. 1.0-r5)
- update plugin autoframerate
fix switching to 24p mode
- update plugin camofs (ver. 10.01)
- update plugin devicemanager2 (ver. 1.7)
fix partitioning for some devices
- update plugin graphicalmultiepg
support button mappings
support custom picon folder
- update plugin infobartunerstate (ver. 3.0.1 20160108)
- update plugin lcd4linux (ver. 4.7.-r2)
- update plugin multiquickbutton (ver. 2.7.14-r6)
- update plugin openwebif
switch to standby when transcoding starts (solo4k)
- update plugin picturecenterfs (ver. 7.03)
- update plugin seriesplugin (ver. 4.5.0 20151221)
- update plugin webradiofs (ver. 13.57)
- update skin atile (ver. 4.2-r0)
- update skin mutespectator (ver. 2.8)
- update skin stylefhd (ver. 2016-01-11)
- update opera hbbtv (2015-12-22) (ultimo,uno,duo,solo,zero,duo2,solo2,solose)
- update transtreamproxy</itemtext>
support infobartunerstate plugin
- update vtipanel (ver. 3.36)</itemtext>
add favourites list loader (see forum for howto)
Menu>Setup>Service Searching
- add package jpegtran-cffi
- remove xbmc from image (solo4k,duo2,solo2,solose)
Quote:
http://www.megafileupload.com/ejeD/v..._9-0-2_usb.zip
- 127
20.01.2016 - Software Update
- update dvbapp2 (2016-01-20)
fix silly timer conflicts
add missing service info for 4097 streaming services
- update plugin devicemanager2 (ver. 1.8)
readd support for devices without single partitions
-update plugin hbbtv (YouTubeTV) (ultimo,uno,duo,solo,zero,duo2,solo2,solose)
keep compatibility for skins
- update plugin epgshare (ver. 0.1 20160120)
- update plugin infobartunerstate (ver. 3.0.3 20160120)
Replace VTi 9.0.2 (2016-01-19) --> VTi 9.0.2 (2016-01-21)
Quote:
http://www.megafileupload.com/ekcP/v..._9-0-2_usb.zip
21.01.2016 - Software Update
- update dvbapp2 (2016-01-21)
fix freezing mkv playback for some rare mkv types
fix black screen after framerate change
to activate plugin set:
Menu>Setup>System>A/V settings>Refresh rate: multi
https://mega.nz/#!Vslhyaga!zFoxdtDx8...o0spaG1WkDZbrA
- 127
24.01.2016 - Software Update
- update dvbapp2 (2016-01-24)
Timeshift: change default value for file remove intervall (default = 0)
fix dvbapp2 shutdown
