Editor channels for the built-in TV viewing application.
version 0.6.0.0 by _sm0ke_
Now, starting with this version, with our DiZil1 joint project.
As the saying goes, "one head is good ...";)[*] Changed almost all code[*] The application design with multi-window interface with a tabbed interface
[+] Following function template (template includes favorite channels, regardless of the version of the channel list;
those. imposing a pattern on the channel list, favorites are restored)
[+] For foreigners added 2 languages - English and German (toggle through the "Help" menu item)
[+] To choose the audio track by default.
[+] Filter to use to search for the channel (s) (for example, when searching for 3 satellites (astra, hotbird, sirius) finds more than 4000 channels; look for scrolling through the list would take a lot of time, but knowing that the desired channel has a specific signature ( name, frequency, etc.), it is possible to apply a filter)
[+] Column indicating the channel type (HD, encrypted)
