Thanks Thanks:  3
Likes Likes:  3
Results 1 to 13 of 13
Thread: Glamour Aura FHD skin - RC3 for new generation HDTV/4K STBs
    Thumbs up Glamour Aura FHD skin - RC3 for new generation HDTV/4K STBs
    With great pleasure, I finally present publicly my latest project, which is none other than my new skin called Glamour Aura FHD by MCelliotG. It's a labor of more than a year in the making and testing!
    Glamour Aura FHD (GAFHD) is a Full High Definition and High graphic resolution skin for receivers running Enigma2 and the recent OpenPLI/OpenPLI-based images.
    Due to it's high resolution graphical nature, GAFHD was designed and optimized to run on new generation receivers. The minimal requirement is an STB with a CPU of 750 Mhz (2000 DMIPS).
    GAFHD is also a skin you can contribute to. The ipk of the skin is distributed with closed converters/renderers, but all the python code along with the skin code is available on Github.
    You can find the source code here: https://github.com/MCelliotG/GlamourAuraFHD-skin
    You can pull your requestsand I will push contributions after testing.
    GAFHD on par with its graphical user interface is fortified with an extended python system that runs along with OpenPLI's enviroment, providing it with some exclusive new features.
    SCREENSHOTS and extended features presentation
    1. Main Infobar
    The main infobar is divided into two sections. The top section contains all frequency and signal info. GAFHD is the first skin that fully supports real-time info for Multistream services, showing MIS info when such a service is tuned. Up to 12 tuners can also be displayed. The left top part is a weather panel which shows today's weather. Weather info requires the MSN weather plugin to be installed and configured (instructions will follow).
    The top infobar will also display full stream URL and stream type when a service is stream.
    The lower section is the main infobar which contains along with the program info, an extended service info icons panel, including icons for audio/video codecs, a full exact framerate display, and a short weather panel which shows the current weather condition. GAFHD can also display a live bitrate if the bitrate plugin is installed and configured (this will be explained below as well).
    The lowest part of the main infobar is the extended encryption info. GAFHD uses a new detection feature which shows all available caids and encryption system names of a service.
    NOTE: The skin works best with 400X240 picon size.
    2. Second infobar
    The second infobar brings an amplitude of extra information for both the service and the system layout. The weather panel shows additional info on tomorrows weather.
    The left panel is the layout info showing real time CPU work, temperature, speed and load and internal HDD temperature. The upper layers show the pids of the service in decimal format and also real time info on connected storage devices, memory and swap.The middle part displays now and next program extended description.
    3. Channel selection screens
    Channel selection along with the service list on the right displays the extended program description on the left, the five following events and also a new transponder info panel which also shows the stream type and stream url on a stream service and transponder info for the rest.
    4. Media player infobar
    Media player will additionally show icons for resolution, audio/video codecs, subtitle availability and the exact framerate of a video or stream.
    5. Info screen
    Info screen along with the usual info also displays the HDD storage panel, which shows connected devices space both internal and network HDD and USB. The storage panel is also available on the HDD screens.
    6. Language selection
    GAFHD is a truly multilingual skin. It utilizes the new Aura new font I created based on Roboto and Noto fonts the skin is able to show Greek, Cyrillic, Arabic and Georgian among others. More alphabets can be added by request.
    INSTRUCTIONS:
    1) Download the ipk of the file. Send the file to /tmp your receiver using an FTP program. Then you can install it manually via telnet or via the software manager.
    Manually:
    opkg install /tmp/enigma2-plugin-skins-glamouraurafhd_RC.3_all.ipk 2) FOR BITRATE INFO
    The bitrate plugin is essential for bitrate to work. You can download it from the plugins menu. For correct display in the skin it needs to be configured as follows:
    mode: as infobar, style skin: compact, background window: transparent-black, X screen position: 1645, Y screen position: 0837, Z screen position: 14. The correct settings are also shown in the screencap below:
    3) FOR WEATHER INFO
    The weather info requires the msn weather plugin to be installed. I have included the ipk as well. After installation you can configure your location via its settings menu.
    Download MSN weather plugin from here:
    https://mega.nz/#!bNNVFSYB!9YW_42B6x...KOsUKNOg87-0sk
    NOTE: For IPTV streams serviceapp is highly recommended with this skin.
    IMPORTANT NOTE: As stated above, GAFHD is designed to work well ONLY for receivers with a CPU higher than 750Mhz. This is an obligatory limitation due to the high resolution graphical nature of the skin which also makes the package large in size. For receivers with slower CPUs use at your own risk! Also, GAFHD for the moment will not work on any other images (such as OE-A) than OpenPLI and OpenPLI-based images (like SatDreamGr, etc).
    DOWNLOAD THE GAFHD SKIN IPK HERE:
    https://mega.nz/#!KQ9VVAYQ!Cf7zvq9tY...Ve-4jfMzgDQ6mE
    I want to personally thank my beta testers for their feedback. I encourage developers to contribute to the skin's further development in github.
    I really hope you enjoy my work.
    thanks to : glamour_services
    Two videos showing the usage of the skin in real-time (SF4008 receiver with SDG5.0).
    1. ATSC and American C and Ku band satellite usage
    https://www.youtube.com/watch?v=jHLzbAslym0
    2. Multistream and 4K channels in Europe
    https://www.youtube.com/watch?v=Nt8eLGJBzj0
    GLAMOUR AURA FHD version RC.4
    - fixed crash and compatibility with older OpenPLI 4.0 images
    https://mega.nz/#!GdMmjIDR!5jGR0aiLh...bJzjUN1xqwTDOk
    multumim...@MCelliotG celui care a realizat skinu ptr pli6 nici nu cred ca e deja pe feeds in pli
    GLAMOUR AURA FHD v.RC5
    - minor cosmetic changes and better CAM name detection
    https://mega.nz/#!KR1FCaSL!PN1wUfvq8...Tv5eg1NK3eH1To
    GLAMOUR AURA FHD v.RC6
    - Added Flash Image screens for OpenPLI 6.1 (love the new icon)
    - Added Subtitle QuickMenu screen
    https://mega.nz/#!DJ8kGIIB!GXvYbY1sF...zfYTN5fMVMymRw
    IMPORTANT NOTE:
    The skin currently works only on OpenPLI and OpenPLI based images like SatDreamGr.
    All other images based on OE-A (OpenATV, Open8, OpenSPA etc) and Blackhole are not yet supported.
    GLAMOUR AURA FHD for OpenPLI update 10/6/2018
    - Major changes in coding, optimized for OpenPLI 6.2
    - New button and switch pixmaps added
    - New screens added
    - All develop changes updated
    GlamourAuraFHD now supports two versions
    The develop version for OpenPLI 6.2/develop and SatDreamGr images
    Version B.5
    https://mega.nz/#!HVM3kKIb!vELFUWZfH...4qnsx0buBhHTuU
    The older OpenPLI 6.1 version for older OpenPLI images with old button style
    Version A.9
    https://mega.nz/#!vFsQmDwL!n1Lx57FBe...kBDROe-QJs8dPI
    Make sure to choose the correct version for your image.
    GLAMOUR AURA FHD vB.8 for OpenPLI/SDG update 25/6/2018
    - Fixed infinite scrolling in several screens
    - Added dynamic auto scrolling
    - Several cosmetics and screen fixes
    Develop version vB.8 for OpenPLI 6.2
    https://mega.nz/#!fdM3DQAB!N30R2PP05...lB2tu7qidDqI7Q
    Stable version v.A.11 for OpenPLI 6.1 and older images
    https://mega.nz/#!LRMFiKzZ!-L5cUwnP8...cvF9zcoEQJkWjM
    Thumbs up GLAMOUR AURA FHD for OpenPLI/SDG version B.11 update 8/7/2018
    - Graphic rearrangements and cleanup
    - Added fan speed info on the second infobar, moved HDD temp to Info and HDD menu
    - Improved readability in main screens
    - Added Foreca plugin support
    - Several fixes and improvements
    Download here:
    OpenPLI 6.2 and SatDreamGr/develop images version B.11
    https://mega.nz/#!TZdnzI5I!WwW4VBpAv...QptWlkIIEElpfY
    OpenPLI 6.1 and older images version A.14
    https://mega.nz/#!zFVAVIQY!NB-EepCnv...jdf5enKEzoUFko
    Thumbs up GLAMOUR AURA FHD for OpenPLI images version B.16 update 25/7/2018
    - Added picon support for provider bouquets in ChannelSelection.
    The naming of the picon is the same as snr picons. For instance a bouquet named AFN (9.0E) should have a picon named afn90e etc.
    - Improved system speed and stability
    - Added new timer icons
    Download here:
    For OpenPLI 6.2, develop and SatDreamGr images
    https://mega.nz/#!3B9kHIzK!-I6anKoT8...9pPpOqZyLdvoi0
    For OpenPLI 6.1 and older images (version A.16)
    Thumbs up GLAMOUR AURA FHD for OpenPLI develop/SDG version B.24 update 25/9/201
    GLAMOUR AURA FHD skin v.B.24 for OpenPLI develop and SatDreamGr images (update 25/9/2018)
    - Added new converter GlamourTuners, only the available installed tuners will now show
    - Added support for displaying up to 24 tuners (if ever available)!!!
    - Graphic rearrangements in the infobar
    - Fixed not found error when hddtemp binary is missing
    - Several cosmetic fixes and improvements
    - Added new VirtualKeyboard layout support
    Download here (version B.24 for OpenPLI/SDG updated 25/9/2018):
    https://mega.nz/#!aMsyyQiJ!Ms0QwcG5l...7sc9-CHdXCDJDE
    It is recommended to uninstall previous version first.
    GLAMOUR AURA FHD version B.28 for OpenPLI/SDG images (update 27/11/2018)
    - Rearranged Channel Selection Radio screen and workaround to possible crashes after switching back to TV.
    - Various skin and python cosmetic fixes and optimizations
    Download here (v.B.28) for OpenPLI and SDG images
    https://mega.nz/#!KNEkGCCB!3FrGnxItJ..._C4TqFseE_HbOg
    or via online update from the SDG feeds
    Thumbs up GLAMOUR AURA FHD skin v.F.04 (Finalized) for OpenPLI/SDG images
    Glamour Aura FHD skin has entered its finalized stage, the new release is completely revamped with a multitude of changes.
    - Reworked NextEvents, now only title will scroll when does not fit
    - Added PrimeTime indication in channelselection
    - Added support for T2MI, PLP ID display
    - Reworked on infobar icons and rearrangements
    - Added support for Color Curve (HDR, SDR etc) with icons on the infobar and on the mediaplayer
    IMPORTANT NOTE: The icons will appear ONLY on receivers and images that support this feature
    - Added more CPUs display on Second Infobar (they will appear if available)
    - Added RusCrypt icon and more CA systems detection
    - Added AudioSync screen
    And countless small fixes and code optimizations
    Download IPK here version F.04 update 22/12/2018 for OpenPLI/SDG:
    https://mega.nz/#!rUlj0QoL!BqMwhWEbL...UrOs5N2bg7Kxq0
    or via SatDreamGr feeds
    Thumbs up Glamour Aura FHD skin for OpenPLI/SDG based images version F.14 (updat
    Glamour Aura FHD skin for OpenPLI/SDG based images version F.14 (update 21/2/2019)
    - Major recode for better stability and speed
    - New graphics lossless compression (smaller skin size)
    - Improved several icons visibility
    - Fixed several screens, including Blindscan
    - Fixed startwizards
    - Added more caids detection (i.e. 4B64-Samsung/TV Key)
    - Added support for more plugins (like Dreamexplorer etc).
    - New aura spinner
    REMINDER: MSN weather plugin and bitrate plugin should be installed for weather info and bitrate
    Install IPK from here (OpenPLI/SDG version F.14):
    https://mega.nz/#!LddEwQSR!aGbTVwDM6...QQJgXxjpez3Lr8
    or via the SatDreamGr feeds if the skin is installed from there, just run an image update.
