interesant, foarte...cu ce soft? ai testat, merge ceva?
Writing Data to Flash ... Please wait.
DIABLOCAM Flash written successfully
Waiting for Filesystem update ...
Making folder CAM:\CONFIG ...
Making folder CAM:\CONFIG\CAIDS ...
Making folder CAM:\MENU ...
Making folder CAM:\MENU\LANG ...
Making folder CAM:\PLUGIN ...
Making folder CAM:\PLUGIN\CAS ...
Making folder CAM:\EMU ...
Making folder CAM:\EMU\TABLES ...
Making folder CAM:\EMU\NAGRA3 ...
Making folder CAM:\EMU\NAGRA3\A ...
Making folder CAM:\EMU\NAGRA3\B ...
Making folder CAM:\EMU\NAGRA3\C ...
Making folder CAM:\EMU\NAGRA3\D ...
Making folder CAM:\EMU\NAGRA3\E ...
Making folder CAM:\EMU\NAGRA3\F ...
Deleting file CAM:\CONFIG\CAIDS.XML ...
Deleting file CAM:\CONFIG\CAIDS\CAIDS.XML ...
Deleting file CAM:\CONFIG\CAIDS\ASTRA_1.XML ...
Deleting file CAM:\CONFIG\CAIDS\EAST_EUR.XML ...
Deleting file CAM:\CONFIG\CAIDS\FRENCH.XML ...
Deleting file CAM:\CONFIG\CAIDS\GERMAN.XML ...
Deleting file CAM:\CONFIG\CAIDS\UK.XML ...
Deleting file CAM:\CONFIG\CAIDS\SPAN_ITA.XML ...
Deleting file CAM:\CONFIG\CAIDS\OTHER.XML ...
Deleting file CAM:\MENU\LANG\ENGLISH.XML ...
Deleting file CAM:\MENU\LANG\ITALIAN.XML ...
Deleting file CAM:\MENU\LANG\DEUTSCH.XML ...
Deleting file CAM:\MENU\LANG\DUTCH.XML ...
Deleting file CAM:\MENU\LANG\TURKISH.XML ...
Deleting file CAM:\PLUGIN\EXTENDED.BIN ...
Deleting file CAM:\KEYS.BIN ...
Deleting file CAM:\DATA.BIN ...
Deleting file CAM:\EMU\NAGRA3\EEPR_152.BIN ...
Deleting file CAM:\EMU\NAGRA3\FULLROM.BIN ...
Deleting file CAM:\EMU\NAGRA3\RAM_152.BIN ...
Deleting file CAM:\EMU\NAGRA3\ROM_181.BIN ...
Deleting file CAM:\PLUGIN\CAS\CAS_1.DPI ...
Deleting file CAM:\PLUGIN\CAS\CAS_2.DPI ...
Deleting file CAM:\PLUGIN\CAS\CAS_3.DPI ...
Deleting file CAM:\PLUGIN\CAS\CAS_4.DPI ...
Deleting file CAM:\PLUGIN\CAS\CAS_5.DPI ...
Deleting file CAM:\PLUGIN\CAS\CAS_6.DPI ...
Deleting file CAM:\PLUGIN\CAS\CAS_7.DPI ...
Deleting file CAM:\PLUGIN\CAS\OTHER.DPI ...
Deleting file CAM:\PLUGIN\CAS\OTHER2.DPI ...
Deleting file CAM:\EMU\TPS3\V_TPS.DB ...
Deleting file CAM:\EMU\TPS3\TPS_DECR.BIN ...
Deleting file CAM:\EMU\TABLES\S2_NL.BIN ...
Deleting file CAM:\EMU\TABLES\S2_PL.BIN ...
Copying CAIDS.XML to CAM:\CONFIG\CAIDS ...
Verify CAM:\CONFIG\CAIDS\CAIDS.XML...
Copying ASTRA_1.XML to CAM:\CONFIG\CAIDS ...
Verify CAM:\CONFIG\CAIDS\ASTRA_1.XML...
Copying EAST_EUR.XML to CAM:\CONFIG\CAIDS ...
Verify CAM:\CONFIG\CAIDS\EAST_EUR.XML...
Copying FRENCH.XML to CAM:\CONFIG\CAIDS ...
Verify CAM:\CONFIG\CAIDS\FRENCH.XML...
Copying GERMAN.XML to CAM:\CONFIG\CAIDS ...
Verify CAM:\CONFIG\CAIDS\GERMAN.XML...
Copying UK.XML to CAM:\CONFIG\CAIDS ...
Verify CAM:\CONFIG\CAIDS\UK.XML...
Copying SPAN_ITA.XML to CAM:\CONFIG\CAIDS ...
Verify CAM:\CONFIG\CAIDS\SPAN_ITA.XML...
Copying OTHER.XML to CAM:\CONFIG\CAIDS ...
Verify CAM:\CONFIG\CAIDS\OTHER.XML...
Copying CONFIG.XML to CAM:\CONFIG ...
Skip. CAM:\CONFIG\CONFIG.XML already exist
Copying ENGLISH.XML to CAM:\MENU\LANG ...
Copying ITALIAN.XML to CAM:\MENU\LANG ...
Copying DEUTSCH.XML to CAM:\MENU\LANG ...
Copying DUTCH.XML to CAM:\MENU\LANG ...
Copying TURKISH.XML to CAM:\MENU\LANG ...
Copying EXTENDED.BIN to CAM:\PLUGIN ...
Copying KEYS.BIN to CAM: ...
Copying DATA.BIN to CAM: ...
Copying S2_FR.BIN to CAM:\EMU\TABLES ...
Skip. CAM:\EMU\TABLES\S2_FR.BIN already exist
Copying A.BIN to CAM:\EMU\NAGRA3\A ...
Skip. CAM:\EMU\NAGRA2\A\A.BIN already exist
Copying A.BIN to CAM:\EMU\NAGRA3\B ...
Skip. CAM:\EMU\NAGRA2\B\A.BIN already exist
Copying A.BIN to CAM:\EMU\NAGRA3\C ...
Skip. CAM:\EMU\NAGRA2\C\A.BIN already exist
Copying A.BIN to CAM:\EMU\NAGRA3\D ...
Skip. CAM:\EMU\NAGRA2\D\A.BIN already exist
Copying A.BIN to CAM:\EMU\NAGRA3\E ...
Skip. CAM:\EMU\NAGRA2\E\A.BIN already exist
Copying A.BIN to CAM:\EMU\NAGRA3\F ...
Skip. CAM:\EMU\NAGRA2\F\A.BIN already exist
Copying B.BIN to CAM:\EMU\NAGRA3 ...
Skip. CAM:\EMU\NAGRA2\B.BIN already exist
Copying A.BIN to CAM:\EMU\NAGRA3 ...
Skip. CAM:\EMU\NAGRA2\A.BIN already exist
Copying C.BIN to CAM:\EMU\NAGRA3 ...
Skip. CAM:\EMU\NAGRA2\C.BIN already exist
Copying D.BIN to CAM:\EMU\NAGRA3 ...
Skip. CAM:\EMU\NAGRA2\D.BIN already exist
Copying OTHER.DPI to CAM:\PLUGIN\CAS ...
Copying OTHER2.DPI to CAM:\PLUGIN\CAS ...
Copying CAS_1.DPI to CAM:\PLUGIN\CAS ...
Copying CAS_2.DPI to CAM:\PLUGIN\CAS ...
Copying CAS_3.DPI to CAM:\PLUGIN\CAS ...
Copying CAS_4.DPI to CAM:\PLUGIN\CAS ...
Copying CAS_5.DPI to CAM:\PLUGIN\CAS ...
Copying CAS_6.DPI to CAM:\PLUGIN\CAS ...
Copying CAS_7.DPI to CAM:\PLUGIN\CAS ...
Filesystem updated successffully.
CAM programmed successffully
-So...?
.de
un nou underworld? 201?
Ce mai deschide constant in afara de gigi ? Mersi .Al jazeera se deschide doar cand apar chei ?
salut cam astea si 12111 sirius
20-11-09
-Update new key 01 for TV Globo (13°E)
-Update 00 key for digitv N2 AU [OFF]
-Uptade seca keys
-Uptade biss keys Nat Geo Wild HD freg:11004.00 H 14400 5/6
-Update biss keys Fox Portugal HD freg:11004.00 H 14400 5/6
-Fixed biss for TRT3 (42.0E) on freq:11918.00 V 24440 3/4
-Uptade biss key IRIB TV 3 freg:11555 V 27500 3/4
-Uptade biss key IRIB TV 3 freg:12352 V 30000 3/4
-Uptade biss key Imedi TV freg:12609 V 3700 5/6
-Uptade biss key Megasport freg:10889 V 27500 3/4
-Uptade biss key Inter freg:10889 V 27500 3/4
-Uptade biss key NTN freg:10889 V 27500 3/4
-Update biss key TRT 1 freq: 11919 V 24444 3/4
-Uptade biss key ictimai freg:11554.00 H 2916 2/3
-Update biss key Lider TV freq: 12521 H 4340 1/2
-Update biss key Mir Belogorya freq: 12546 V 1747 3/4
-Update biss key INTER freq: 11190 H 3333 3/4
-Update biss key Rustavi 2 freq:12593 V 2500-5/6
ASTEA
19/11/09 TV Globo Key01 13°E - thx Verdeoro
09/11/09 K75 (testcard-tests-key likely to change when channel starts) 4.8°E Biss Key - thx ramzen
04/11/09 RAI 13°E Key0C [Next, Dec09] (for Diablo use RAI card or Fausto Emulator) - thx ANTR@G
02/11/09 Telespazio Hungary 4°W Key0C [Next, Dec09] (for Diablo use Telespazio Hungary card or Fausto Emulator) - thx kiliantv
25/10/09 Canal Digital Nederlands 19.2°E (Down-Unknown Key03)
19/10/09 Megasport/NTN 4°W Biss New Freq 10890V - thx Nichipor
06/10/09 Telespazio Hungary 4°W Key0D [Active, Nov09] (for Diablo use Telespazio Hungary card or Fausto Emulator) - thx 5ocnarf2
30/09/09 RAI 13°E Key0D [Active, Nov09] (for Diablo use RAI card or Fausto Emulator) - thx 5ocnarf2
18/09/09 Inter+ 4.8°E Biss Key - thx taxi19
08/09/09 B92 12.5°W Biss Key - thx bokili84
07/09/09 RCS DigiTv 1°W Key00 [2nd Change] [N2 AU [ON] failed, turn N2 AU [OFF] - thx senadxxx
31/08/09 BeTVision 9°E Biss Key - thx BIS
29/08/09*LiderTV 36°E Biss Key - thx ig0r
02/04/09 MTV Unlimited/DaVinci Learning 19.2/4.8°E - thx Arkana Team [Back on Diablo Light with UW187 from 18/11/09]
28/03/09*TRT Events (TRT1/3 11919V) 42°E Biss Key - thx zimar
24/03/09 EURO1080 7°E [UW166 data.bin, Untested, HD Only] - thx Arkana Team
18/01/09*Fox News/Fox Sports/Discovery ME 8°W - thx k@lkov/humax54 (Now Active on 8W @ 11064H 12667)
20/03/08 Fox Life France 5°W Biss Key - thx sofien72tu
23/02/08*TV Canaria 30°W Biss Key - thx joseph_lowe
06/12/07 Al Riyadiah Earth 26°E Biss Key - thx baloota
04/12/07 ENTV-Prog Nat 5°W Biss Key - thx tasarim
04/11/07*GPB aka 1TV (Georgian Tv) 42°E Biss Key - thx empb
16/10/07*NBC feeds (DAD SATOPS) 15°W Biss Key - thx dionysos
14/10/07 Rustavi2 42°E Biss Key - thx Dr.dre
04/09/07 AL Jazzera feeds 10°E Biss Key - thx aitchala
29/04/07*MTV/Nickelodeon Belgique 33°E Biss Key - thx tomek.wysoka
28/04/07 MBC Int 26°E Biss Key - thx Rocknroll
14/03/07 Sat2000 9°E Biss Key - thx edit
24/10/06 TET 4.8°E Biss Key - thx Pattyren
10/10/06 Fox Srbija 12.5°W Biss Key - thx rpgp
*Biss Management in Diablo see this thread: Biss Management
[NB Next Keys Untested]
(West Europe key bundle similair to my Dragon/T-Rex updates [see keys below], Remember you can add/change keys with Fausto or Diablo Key edit tools)
Keys: (only those tested [Last Full Test 27/09/09 1.25pm] listed, except Seca/EURO1080, more included)
Nagravision2: 0.8W RCS DigiTV (2111), 13E TV Globo (C102), 23.5E Kabel Deutch (1101).
Cryptoworks: 4.8E/9E Kingston (TNT/Travel/Hustler/Zone Tv etc) (0D0020/30), 13E BT 'H'(Disney) (0D03A0).
Seca1&2: 4W Telespazio Hungary (002A, 11260H only Under fausto Emulator or Seca Card), 13E RAI (0030/02E2, only Under fausto Emulator or Seca Card).
Irdeto2: 19.2E Canal Digitaal Nederlands (0622), 9E EURO1080 (0624). (All Irdeto handled by UnderWorld EMU).
Viaccess: 16E SIC Inter-Now mostly FTA (CSatFrance)(7800), 5W MCM Europe (7400), 13E Mezzo (7400).
Conax: 19.2E MTV Unlimited, 4.8E DaVinci Learning. (All Conax handled by UnderWorld EMU & for Diablo2.3 only).
Biss: 30W TV Canaries* 11474H, 15W WNBC-4 feeds* 11519H, 12.5W Fox Serbia & B92 11177H, 8W Fox Sports ME, Discovery ME & Fox News* 11064H, 5W ENTV-ProgNat 11065H, Fox Life France 12543H, 4W NTN & Megasport 10890V, 4.8E TET 11766H, K75 (tests) 12380H & Inter+ 12073H, 9E Sat2000 11823H & BeTVision 11747H, 10E JSC feed 11156H, 26E MBC INT 11919V & Al Riyad Earth 12015V, 33E MTV Belgium* 11139V,36E LiderTV* 12521H, 42E TRT1* & TRT3 11918V, GPB 1TV* 12605V & Rustavi2 12593V.
Constant Control Words: Turn Fixed CW [ON] also in most cases turn Auto PMT [OFF] Unless Control Word CAID not in CAID file
Active at upload:
- None.
*Note only the first Biss SID:0001 in the file is active, if you need to change this from LiderTV @ 36E please read the Biss Management in Diablo thread (link above).
Not tested by myself (only have Diablo Light2.3 myself) Under Fausto/Season interface but now Cryptoworks Card Key06 added to Cryptoworks providers and all Betacrypt Tuneled Nagra2 idents now added (shamelessly taken from Saoud007's key.bin), advised to work ok with Fausto Emulator, please let me know if any problems (thx to Saoud007 for infos).
Latest UnderWorld 187 for Diablo Light/WiFi, latest key.bin, data.bin, CAIDs etc in post below....
And don't forget to check out the Satellite News section for details of current Free to Air (FTA) Channels, there are some great channels FTA/temp FTA at the moment! eg. 45E PrimaTV, VTK TV, Kiss TV, 42E TNT Turkiye, MTV Turkiye, FLY, NR1, 40E MTV Russia, 39E More Music, The Voice, MadTV, 36E RTNC, 28.2E BBC/ITV/CH4/ZONE services etc, 26E Dubai One, MBC2 Movies, MBC3 Action, MBC4 Series, MBC Max, MBC Persia, Bahrain55, MTV Arabic, 19.2E MTV Germany, MTV Austria, VIVA Germany, VIVA Austria, DELUXE MUSIC, DSF Sports, Eurosport Germany, CNBC, RTL, 16E Nat Geo Music, 13E VIVA Polska, BBC World News, 9E C-Music, 4W MTV Ukraine, 12.5W MTV Italia, 15W WNBC-4 NY feeds.[List last updated 09/11/09 - not exhaustive!]
am un diablo cam .un t-rex cam +o cartela deocamdata ......open platform...se pricepe careva so scriu si io
id meu .....mamutulparos..... sau la varul meu valistancu11 ramin dator am ceva cunostinta dar vreau un inpuls
Ai un diablo cam....
Esti....vag. La fel si cu celalalt cam.
Specifica ce ai exact!! Light,wifi,wireless. 2.2,2.3 la diablo sau poate diabloII?
Ai CAS 2..3...3+? Altfel....vorbim aiurea.
La TRex....nu stiu.
parpaneata uite am cas 3+........diablo cam light2.3 +++++ o cartela open platformcum procedez nu sint incepator am tot intra pe id meu valistancu11 restul discutam pe mes .. sind disperat si migreu ......ajutama prietenul meu mamutulparos i ocupat dar uite bem o bere cind ne intilnim promitsi am dreambox 7020 care i facut dar uite discutam pe mes
Verisorii, voi ce faceti, doi insi pe acelasi user?
@soarece am acelasi ID peste tot! Yahoo sau Skype. Scriu public asta pentru a demonstra cuiva,care vad ca e insistent si-mi trimite deja mesaje aiurea,ca eu....nu sunt tu si...invers!
Dupa cum ti-am scris si pe messenger DiabloCam varianta light va ajunge....piesa de muzeu sau...un foarte bun cititor de carduri dupa ce Digi va schimba cryptarea. Ultimile softuri Underworld sunt strict ptr Diablo wi-fi si Diablo 2. Diablo light si-a facut treaba pentru ani buni. Canalele nordice cu ale lor posturi HD,plus sexoasele plus...ce mai deschidea cu emulatorul. Si-a scos banii!
Wi-fi merge bine in CS cu cccam. Il recomand. Diablo 2 insa....face cam putine dar.... e timp. Warianta wi-fi,desigur atunci cand va iesi,va sti destul de multe. Si ma refer aici poate la scrierea mai multor linii C in configul cccamului,la imbunatatirea transmisiei cam-router,etc.
Cam atat.
Am o rugaminte la cei cunoscatori detin un diablocam wifi am setat totul cum trebuie merge 20 30 minute si dupa o ia pe aratura 3 secunde imagine 4 5 secunde intuneric ma chinui de o luna de cind lam luat si nu dau de capat
---------- Post added at 11:27 ---------- Previous post was at 11:22 ----------
mentionez ca am instalat pe el underworld 192
AZBOX PREMIUM HD+DIABLO CAM 2+Card it 093b
Care este probalitatea de a functiona in CCcam? diablo citeste cardul cu ultimul soft 4.3 in receptoarele cu CI dar ideea este daca acesta o face si in AXBOX sau nu
