cum arata pentru dm800 pentru a citi cardul tvr ?
sa incepem cu newcs.xml. aici se afla toate setarile serverului cu newcs.pentru pc vom avea :
<readers name="Phoenix">
<device>
<name>Phoenix Interface</name>
<type>phoenix</type> /tipul interfetei de card in cazul de fata phoenix interface
<mhz>368</mhz> /frecventa la care lucreaza cardul in acest exemplu 3,68Mhz. aceasta linie poate lipsi caz in care cardul va luca la 3.57Mhz. se pot seta urmatoarele valori:
153(1.53Mhz), 358(3.58Mhz), 368(3,68Mhz), 450(4.5Mhz), 536(5.36Mhz), 600(6.00Mhz), 800(8.00Mhz), 715(7.15 Mhz)
1000(10.00Mhz), 1071(10.71Mhz), 1431(14.31 Mhz)
<node>COM1</node> /portul (serial aici)la care este conectat phoenix
<parity>odd</parity>
<reset>normal</reset> /normal ptr phoenix inverse pentru smartmouse
<export>Yes</export>
<enabled>Yes</enabled>
<blocksa>Yes</blocksa> /blocheaza share address
<blockua>Yes</blockua> /blocheaza unique address foarte util in cazul mosc-urilor
<blockga>no</blockga> /blocheaza ga
<!-- <boxkey>0000000000</boxkey> -->/box key in cazul nagra /boxid penru nds
<!-- <rsa>0000000000</rsa> -->
<irdeto-camkey>0000000000000000</irdeto-camkey>
<irdeto-camkey-data>00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 0000000000000000000000000000000000000000000000000000000000000</irdeto-camkey-data>
<crypto-special>No</crypto-special>
<ipk>00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 0000000000000000000000000000000000000000000000000000000000000</ipk>
<ucpk>0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000000000000000</ucpk>
<PTShandshake>No</PTShandshake>
<carddetect>yes</carddetect>
<newcamd_port>1001</newcamd_port>
<autosid>Yes</autosid>
<Seca-PPV>no</Seca-PPV>
<pincode>0000</pincode>
<priority>round</priority>
</device>
</readers>
<radegastserver>
<enabled>No</enabled>
<port>16000</port> / portul serverului
<allow>
<hostname>localhost</hostname>
</allow>
</radegastserver>
<cache>
<emm>20</emm>
<ecm>-1</ecm>
</cache>
<debug> /foarte util pentru "depanare" putem monitoriza ce se intampla cu serverul
<password>1234</password> /
<level>normal</level>
<type>init</type>
<output>console,tcp</output>
<console_options>normal,init</console_options>
<tcp_port>11022</tcp_port>
<tcp_options>normal,init</tcp_options>
</debug>
<newcamdserver>
<name>newcs</name>
<deskey>11 22 33 44 55 66 77 88 99 00 12 23 34 01 </deskey> /des key
<user>
<name>user1</name>
<password>pass1</password>
<au>on</au>
<sidoverride>off</sidoverride>
<spider>No</spider>
<rate>2</rate>
</user>
<user>
<name>user2</name>
<password>pass2</password>
<spider>No</spider>
<rate>2</rate>
</user>
<user>
<name>userx</name>
<password>passx</password>
</user>
</newcamdserver>
</newCSconfig>
in acest exemplu avem 3 useri
1)
user user1
pass pass1
port 16000
deskey 11 22 33 44 55 66 77 88 99 00 12 23 34 01
2)
user user2
pass pass2
port 16000
3)
user userx
pass passx
port 16000
in cazul uni dm 500 va arata asa:
<newCSconfig>
<readers name="SCI">
<device>
<name>Cardreader</name>
<type>sci</type>
<mhz>368</mhz>
<node>/dev/sci0</node>
<blocksa>No</blocksa>
<blockua>No</blockua>
<blockga>No</blockga>
<newcamd_port>16000</newcamd_port>
</device>
</readers>
<radegastserver>
<port>16000</port>
<allow>
</allow>
</radegastserver>
<cache>
<emm>20</emm>
<ecm>-1</ecm>
</cache>
<httpd> /webif, o alta chestie utila ptr adaugare /stergere/ban user cu ajutorul pc
<server>
<port>8080</port>
<enabled>yes</enabled>
</server>
<user>
<name>1234</name>
<accesslevel>admin</accesslevel>
</user>
</httpd>
<debug>
<mode>advanced</mode>
<level>spam</level>
<type>all</type>
<output>console,tcp,udp</output>
<console_options>spam,all</console_options>
<udp_host>192.168.0.11</udp_host>
<udp_port>1002</udp_port>
<udp_options>verbose,all</udp_options>
<tcp_port>1001</tcp_port>
</debug>
<newcamdserver>
<name>newcs</name>
<user>
<name>user1</name>
<au>on</au>
<spider>No</spider>
<rate>2</rate>
</user>
<user>
<name>user2</name>
<spider>No</spider>
<rate>2</rate>
</user>
<user>
<name>userx</name>
</user>
</newcamdserver>
</newCSconfig>
in cazul uni dm 7020 va arata asa:
<newCSconfig>
<device>
<name>Lower Cardreader</name>
<type>sci</type>
<mhz>368</mhz>
</device>
<device>
<name>Upper Cardreader</name>
<type>sci</type>
<mhz>368</mhz>
<node>/dev/sci1</node>
<newcamd_port>17000</newcamd_port>
</device>
</readers>
<radegastserver>
<port>16000</port>
<allow>
</allow>
</radegastserver>
<cache>
<emm>20</emm>
<ecm>-1</ecm>
</cache>
<httpd>
<server>
<port>8080</port>
</server>
<user>
<name>1234</name>
</user>
</httpd>
<debug>
<level>spam</level>
<type>all</type>
</debug>
<newcamdserver>
<name>newcs</name>
<user>
<name>user1</name>
<au>on</au>
<spider>No</spider>
<rate>2</rate>
</user>
<user>
<name>user2</name>
<spider>No</spider>
<rate>2</rate>
</user>
<user>
<name>userx</name>
</user>
</newcamdserver>
</newCSconfig>
acum cei 3 useri vor fi:
1)
user user1
pass pass1
port 16000 pentru cardul din cititorul de jos / 17000 pentru cel de sus
2)
user user2
pass pass2
3)
user userx
pass passx
deskey 11 22 33 44 55 66 77 88 99 00 12 23 34 01+
in cazul uni dm 7020 + phoenix interface va arata asa:
<newCSconfig>
<device>
<mhz>600</mhz>
<node>/dev/ttyS0</node>
<newcamd_port>15100</newcamd_port>
</device>
<device>
<type>sci</type>
<mhz>368</mhz>
</device>
<device>
<type>sci</type>
<mhz>368</mhz>
</device>
</readers>
<radegastserver>
<port>16000</port>
<allow>
</allow>
</radegastserver>
<cache>
<emm>20</emm>
<ecm>-1</ecm>
</cache>
<httpd>
<server>
<port>8080</port>
</server>
<user>
<name>1234</name>
</user>
</httpd>
<debug>
<level>spam</level>
<type>all</type>
</debug>
<newcamdserver>
<name>newcs</name>
<user>
<name>user1</name>
<au>on</au>
<spider>No</spider>
<rate>2</rate>
</user>
<user>
<name>user2</name>
<spider>No</spider>
<rate>2</rate>
</user>
<user>
<name>userx</name>
</user>
</newcamdserver>
</newCSconfig>
1)
user user1
pass pass1
port 16000 pentru cardul din cititorul de jos / 17000 pentru cel de sus /15100 pentru phoenix inerface
2)
user user2
pass pass2
3)
user userx
pass passx
v.1.66 RC1
ALL cdks are new, due to server crash.. many many changes to libs etc.
Support for TNTSAT.
Experimental support for NDS 0963. NB! Remeber to put the 4 byte hex boxkey in config!
Multi-realms added to chameleon.
Support for pin-code on specific channels specified by <protectedsid> in config.
Added the ability to disable/enable certain virtualcards on chameleon in config, or disable whole list.
NB! NewCS has gone green - removed all support for windows )
Time to grow up, get a powerfriendly little linux-device to run NewCS on!
de la aceasta varianta au renuntal la suportul ptr windows . se pare ca recunoaste cardul de dolce in phoenix dar nu am testat.
si inca ceva...Support for pin-code on specific channels specified by <protectedsid> in config
Testat! cu N2 merge bine pe linux, citeste cardu din prima, fata de varianta mai veche care mai dadea rateuri la recunoasterea cardului.
Multumuri
Toate-s vechi si noua toate!
Sal.Cu Dm800 iti citeste cartela N2?Si daca da cu ce imagine(drivere)?
Cartela N2 este citita cu orice imagine atata timp cat stii bk si rsa-ul respectivului card
cum in ultimul timp nu am mai deloc timp liber nu am testat inca daca trimite pin la cardul nds. a probat cineva?
si o varianta noua cu suport ptr inca cateva receptoare,newcs v.1.67 RC1
Added support for the Synology devices on the Marvell ARM platform.
Added support for the Coolstream STB. (PS! NO Sci support.. yet)
Added support for the Azbox STB and devices on the Sigma MIPS platform. (PS! NO Sci support.. yet)
ALOT of PC/SC fixes, prefer these devices with the ccid driver over phoenixes.
Misc. phoenix fixes.
HTB+ Viaccess fix.
Added support for the new viasat cards (we think, no feedback on tests).
PS!
You _HAVE_ to use boxkey manually on certain NDS cards now.
